 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 206 kilit problemi</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 206 : 206 kilit problemi]]></description>
  <pubDate>Sat, 02 May 2026 08:14:20 +0000</pubDate>
  <lastBuildDate>Fri, 30 Sep 2016 17:00:23 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=42104</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[206 kilit problemi : arkada&#351;lar gidin &#351;ahin tesisat&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=572067&amp;title=206-kilit-problemi#572067</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=15153">mbsb44</a><br /><strong>Konu:</strong> 42104<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Eylül&nbsp;2016 Saat 17:00<br /><br />arkadaşlar gidin şahin tesisatı çektrin 100 lira verin kurtulun bu masraflara girmenin bi manası yok<span style="font-size:10px"><br /><br />Düzenleyen sonerkyl - 30&nbsp;Eylül&nbsp;2016 Saat 17:10</span>]]>
   </description>
   <pubDate>Fri, 30 Sep 2016 17:00:23 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=572067&amp;title=206-kilit-problemi#572067</guid>
  </item>
  <item>
   <title><![CDATA[206 kilit problemi : eline dilene sagl&#305;k g&#252;zelce anlatm&#305;ss&#305;n&#305;z...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=572066&amp;title=206-kilit-problemi#572066</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18612">dejawu1978</a><br /><strong>Konu:</strong> 42104<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Eylül&nbsp;2016 Saat 16:36<br /><br />eline dilene saglık güzelce anlatmıssınız ... benım oldugum şöför tarafı zaten sıkıntılı olan ben onu biliyorum sprey ve bant işini yapayım ilk olarak...]]>
   </description>
   <pubDate>Fri, 30 Sep 2016 16:36:54 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=572066&amp;title=206-kilit-problemi#572066</guid>
  </item>
  <item>
   <title><![CDATA[206 kilit problemi :   dejawu1978 Yazd&#305;:konuyu hortlatm&#305;s...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=572064&amp;title=206-kilit-problemi#572064</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=14237">Cyrus35</a><br /><strong>Konu:</strong> 42104<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Eylül&nbsp;2016 Saat 15:51<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: dejawu1978" alt="Orjinalini yazan: dejawu1978" style="vertical-align: text-bottom;" /> <strong>dejawu1978 Yazdı:</strong><br /><br />konuyu hortlatmıs gibi oldum ama kusura bakmayın ... buna benzer sorunda bende var... alarmdan acıyoruz ve araca biniyoruz &nbsp;4 kapıda kapalı oldugu halde tepe lambası yanıp yanıp sönüyor ve yol.bilgisayarında kapı acık uyarısı veriyor bir türlü anlamadım ancak larm ile kapatınca ses ve lamba sönüyor...sizce sorun nerde arkadaşlar...?</td></tr></table><div><br></div><div><br></div><div>Harici alarmda bu sorunları yaşamazsınız. Beyin olarak sonradan takılan alarmın beynine göre tüm kapılar kilitli görünür fakat orjinal kumandadan kilitlediginizde kapılar geri açılırsa yada durduk yere yolda giderken aniden tepe lambanız yanar sesli ve ışıklı uyarı alırsanız&nbsp;<br>PROBLEMİNİZ KAPI KİLİT SWİCHidir arkadaşlar.&nbsp;</div><div><br></div><div>Bunu çözmenin yollarıda balata spreyi ile kilit içine sıkın tozu pisligi aksın yine aynı sorunla karşılaşırsanız arızalı olan kapı kilidinin karşılıgına yani kasadaki ufak dile 2 tur bant sarın sorun çözülür yada kilit karşılıgını biraz geri yukarı arkaya konum değiştirerek tekrar deneyin çözebilirsiniz.<br><br><font color="#ff3300">Arızalı kapıyı ise şu şekilde bulabilirsiniz 3 yöntem var hangisi kolayınıza gelir ise..</font><br><br>Her kapının içindeki soketi sökerek kilitleyip deneyin yani sırası ile kapı içindeki soketi sökün e kilitleyin ta ki kapılar normal bir şekilde kilitlenene kadar.<br><br><font color="#ff3300">Diğer bir yöntem...</font><br><br>kapıları tek tek deniycez yine ve bu sefer kapıyı açıcaz ve kilit dilini elimiz yada tornavida yardımı ile kilitleyip dilin üstüne baskı uyguluycaz ve aynı anda kumandadan kilitleme tuşuna vasıcaz kapılar normal kilitlenene kadar tüm kapıları deniyceaz.<br><br><font color="#ff3300">Bir önceki yöntemin kolaylaşmış halide bu şekilde...<br></font><br>Kapıları kapatıp her kilitleme düğmesine basmadan önce kapının kilit bölümünün oldugu yere baskı yapıcaz kalça kısmı ile birazcık agırlık vererek sensörün tam algılamasına yardımcı olucaz. bunun sebebide yukarıda belirttigim gibi kapı kilit karşılıgındaki plastik kırılmış olabilir yada yerinden oynamış olabilir. bir bant atarak yada kilit karşılıgını vidalarını gevşeterek biraz geri almamız bu durumu kalıcı olarak çözücektir.<br><br></div>]]>
   </description>
   <pubDate>Fri, 30 Sep 2016 15:51:19 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=572064&amp;title=206-kilit-problemi#572064</guid>
  </item>
  <item>
   <title><![CDATA[206 kilit problemi : Benim kap&#305;da a&#231;&#305;l&#305;yor kapanm&#305;yordu...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=572057&amp;title=206-kilit-problemi#572057</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18374">Onurzdn</a><br /><strong>Konu:</strong> 42104<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Eylül&nbsp;2016 Saat 11:06<br /><br />Benim kapıda açılıyor kapanmıyordu kapanır gibi oluyor ses çıkıyor kapanmıyordu kapı motoru bozulmuştu 70 tl ye yaptırdım]]>
   </description>
   <pubDate>Fri, 30 Sep 2016 11:06:46 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=572057&amp;title=206-kilit-problemi#572057</guid>
  </item>
  <item>
   <title><![CDATA[206 kilit problemi : konuyu hortlatm&#305;s gibi oldum ama...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=571691&amp;title=206-kilit-problemi#571691</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18612">dejawu1978</a><br /><strong>Konu:</strong> 42104<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Eylül&nbsp;2016 Saat 20:27<br /><br />konuyu hortlatmıs gibi oldum ama kusura bakmayın ... buna benzer sorunda bende var... alarmdan acıyoruz ve araca biniyoruz &nbsp;4 kapıda kapalı oldugu halde tepe lambası yanıp yanıp sönüyor ve yol.bilgisayarında kapı acık uyarısı veriyor bir türlü anlamadım ancak larm ile kapatınca ses ve lamba sönüyor...sizce sorun nerde arkadaşlar...?]]>
   </description>
   <pubDate>Thu, 22 Sep 2016 20:27:21 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=571691&amp;title=206-kilit-problemi#571691</guid>
  </item>
  <item>
   <title><![CDATA[206 kilit problemi : Anahtarla kapatinca kapan&#305;yor...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=564927&amp;title=206-kilit-problemi#564927</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18028">Furkan_58_</a><br /><strong>Konu:</strong> 42104<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Mayıs&nbsp;2016 Saat 16:27<br /><br />Anahtarla kapatinca kapanıyor kapılar tamamen ama kumanda ile kilitlenmiyor tamam abi akşam bakalim]]>
   </description>
   <pubDate>Fri, 06 May 2016 16:27:10 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=564927&amp;title=206-kilit-problemi#564927</guid>
  </item>
  <item>
   <title><![CDATA[206 kilit problemi : ben &#351;imdi hi&#231; bi&#351;i anlamad&#305;mm...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=564913&amp;title=206-kilit-problemi#564913</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=14237">Cyrus35</a><br /><strong>Konu:</strong> 42104<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Mayıs&nbsp;2016 Saat 15:15<br /><br />ben şimdi hiç bişi anlamadımm sensörler kapılardan birisini açık görüyorsa eğerrr kumandadan kilitledigin anda geri açar kardeşim. akşama bi konu açıyım forum için linkide buraya atıyım o şekilde kontrol et bakk nasip olursa&nbsp;]]>
   </description>
   <pubDate>Fri, 06 May 2016 15:15:41 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=564913&amp;title=206-kilit-problemi#564913</guid>
  </item>
  <item>
   <title><![CDATA[206 kilit problemi : Abi o dedi&#287;inizi denedim ama on...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=564904&amp;title=206-kilit-problemi#564904</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18028">Furkan_58_</a><br /><strong>Konu:</strong> 42104<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Mayıs&nbsp;2016 Saat 14:26<br /><br />Abi o dediğinizi denedim ama on iki kapı düğmesine basınca hepsi kapanıyor kapıların ama anahtarla kapanınca kilitleniyor hepsi anlamadım bide araç hareket edince biraz dit dit diye uyarı veriyor ]]>
   </description>
   <pubDate>Fri, 06 May 2016 14:26:29 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=564904&amp;title=206-kilit-problemi#564904</guid>
  </item>
  <item>
   <title><![CDATA[206 kilit problemi :   Cyrus35 Yazd&#305;:Direk motoru...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=564902&amp;title=206-kilit-problemi#564902</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=17876">x571</a><br /><strong>Konu:</strong> 42104<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Mayıs&nbsp;2016 Saat 14:05<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Cyrus35" alt="Orjinalini yazan: Cyrus35" style="vertical-align: text-bottom;" /> <strong>Cyrus35 Yazdı:</strong><br /><br />Direk motoru bozuk demmişsin çözüm yanlış. &nbsp; Belki seninki bile bozuk değildi soketlerinde korozyon vardı yağlanma vardı tetikleme yapmıyordu. ? 4 kilitleme düğmeside orjinal kumandaya basıldığında inip kalkıyorsa motor sağlam swich kapıyı tam kapalı görmüyor demektir bununda çözüm yollarını size söyle sıralıyım..<br><br><div>*Kapı kilit karşılığı ( araç şasesindeki ufak karşılık kapıdaki değil.) tors alyan ile açıp biraz geri ve yukarı kaydırarak tekrar sıkılamak.<br>*Kapı kilit dilinin içine wd-40 sıkıp temizlenmesini sağlamak.<br>*kapı kilit karşılığının plastiği kırılmıştır kapı dilini tam ittirmiyordur kapı açık görünüyordur üzerine flaster yada bant sarmak..<br>*Kapı arasındaki soketi söküp içini temizlemek..</div><div><br></div><div>Bozuk kelimesini kesinlikle kabul etmiyorum :) akşama size video hazırlar buraya yüklerim hatta birde konu açar başka arkadaşlarada yardım amaçlı olur..<br><br>Ben size bu akşam bi video çekip yüklüyüm buraya nasıl kontrol ediceğinizi ve tamirini yapıcağınıza dair.</div></td></tr></table><br><br>ben önce bir elektirikçiye gittim. anlattığı şekilde mazota yatırdı,kapının ana gövdeye bağlanan yerlerini kontrol etti,sildi taktı bilmem ne yaptı, bu bozuk dedi.burada parçasını bulamazsın servise git dedi. servide gittik ,bozuk dedi 380 lirayı bayıldık şimdi kapı normal <img src="https://forum.peugeotturkey.com/smileys/smiley4.gif" border="0" alt="Big smile" title="Big smile" /><br>benim sorunum; ne anahtarla ne kumandayla kapı kapanmıyordu (bazen tek seferde kapanıyor bazen 5 dakika kapanmıyor uğraştırıyordu).&nbsp; sağ kapı kilidi el ile basınca merkezi kilit hiç tepki vermiyordu,kumanda ile kapatmaya çalışınca kilitler inip kalkıyordu.<br>belki de sizin dediğiniz gibidir,arkadaş denesin .biz öyle bir çarpıldık işte.görünce yardım edeyim dedim.çünkü bazı çakallar(servisteki eleman) bana anahtarda komple bozuk o takılı kalmış sürekli sinyal gönderiyor falan dedi.yav he he dedim.<br>video yollarsanız süper olur bende öğrenirim. kapı için 2 gün serviste uğraştım ilçeden ile gittim geldim.hayatımdan bezdim .<br><span style="font-size:10px"><br /><br />Düzenleyen x571 - 06&nbsp;Mayıs&nbsp;2016 Saat 14:06</span>]]>
   </description>
   <pubDate>Fri, 06 May 2016 14:05:55 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=564902&amp;title=206-kilit-problemi#564902</guid>
  </item>
  <item>
   <title><![CDATA[206 kilit problemi : Direk motoru bozuk demmi&#351;sin &#231;&#246;z&#252;m...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=564835&amp;title=206-kilit-problemi#564835</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=14237">Cyrus35</a><br /><strong>Konu:</strong> 42104<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Mayıs&nbsp;2016 Saat 10:40<br /><br />Direk motoru bozuk demmişsin çözüm yanlış. &nbsp; Belki seninki bile bozuk değildi soketlerinde korozyon vardı yağlanma vardı tetikleme yapmıyordu. ? 4 kilitleme düğmeside orjinal kumandaya basıldığında inip kalkıyorsa motor sağlam swich kapıyı tam kapalı görmüyor demektir bununda çözüm yollarını size söyle sıralıyım..<br><br><div>*Kapı kilit karşılığı ( araç şasesindeki ufak karşılık kapıdaki değil.) tors alyan ile açıp biraz geri ve yukarı kaydırarak tekrar sıkılamak.<br>*Kapı kilit dilinin içine wd-40 sıkıp temizlenmesini sağlamak.<br>*kapı kilit karşılığının plastiği kırılmıştır kapı dilini tam ittirmiyordur kapı açık görünüyordur üzerine flaster yada bant sarmak..<br>*Kapı arasındaki soketi söküp içini temizlemek..</div><div><br></div><div>Bozuk kelimesini kesinlikle kabul etmiyorum :) akşama size video hazırlar buraya yüklerim hatta birde konu açar başka arkadaşlarada yardım amaçlı olur..<br><br>Ben size bu akşam bi video çekip yüklüyüm buraya nasıl kontrol ediceğinizi ve tamirini yapıcağınıza dair.</div>]]>
   </description>
   <pubDate>Fri, 06 May 2016 10:40:41 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=564835&amp;title=206-kilit-problemi#564835</guid>
  </item>
  <item>
   <title><![CDATA[206 kilit problemi :   Furkan_58_ Yazd&#305;:Oncelikle...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=564831&amp;title=206-kilit-problemi#564831</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=17876">x571</a><br /><strong>Konu:</strong> 42104<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Mayıs&nbsp;2016 Saat 10:19<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Furkan_58_" alt="Orjinalini yazan: Furkan_58_" style="vertical-align: text-bottom;" /> <strong>Furkan_58_ Yazdı:</strong><br /><br />Oncelikle herkese selamlar aranıza yeni katıldım ismim furkan 206 colorline m var 2001 model yalnız aracında bi sorunum var aracın orjinal anahtari aracı kilitlemiyor fakat acıyor kilit tuşuna basınca kilit yapıp geri acıyor iç lamba da kapıya getirince sürekli açık kalıyor ben kapıların biri kapanmıyor diye düşünüyorum ama sizin fikriniz nedir ustalarimizin özellikle</td></tr></table><br><br>merhaba<br><br>aynı sorunu ben iki hafta önce yaşadım. önce hangi kapı hasarlı onu tespit edeceğiz. <br>onu da şu şekilde yapıyoruz;<br><br>camları açın,kapıları kapatın.şoför kapısından başlayarak,kapılardaki el ile kilitleme düğmelerine basın.bozuk kapıya gelince siz o düğmeye bassanızda merkezi kilit çalışmıyor. o kapının kilitleme motoru bozuk. komple değişecek. serviste yenisi 180 tl, arızayı siz söylerseniz 100 tl arıza tespit parasından kurtulursunuz. ben bilmediğim için 380 tl çarpıldım.yada orjinal parçayı alıp sanayide siz taktırın. daha uygun olur.<br>]]>
   </description>
   <pubDate>Fri, 06 May 2016 10:19:51 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=564831&amp;title=206-kilit-problemi#564831</guid>
  </item>
  <item>
   <title><![CDATA[206 kilit problemi : Abi switch neresinde tam olarak...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=564748&amp;title=206-kilit-problemi#564748</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18028">Furkan_58_</a><br /><strong>Konu:</strong> 42104<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Mayıs&nbsp;2016 Saat 14:48<br /><br />Abi switch neresinde tam olarak bulamiyorum da <span style="font-size:10px"><br /><br />Düzenleyen Furkan_58_ - 05&nbsp;Mayıs&nbsp;2016 Saat 14:49</span>]]>
   </description>
   <pubDate>Thu, 05 May 2016 14:48:43 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=564748&amp;title=206-kilit-problemi#564748</guid>
  </item>
  <item>
   <title><![CDATA[206 kilit problemi : &#214;ncelikle swichi bozuk yada temasszl&#305;k...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=564735&amp;title=206-kilit-problemi#564735</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=14237">Cyrus35</a><br /><strong>Konu:</strong> 42104<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Mayıs&nbsp;2016 Saat 10:19<br /><br /><br>Öncelikle swichi bozuk yada temasszlık yapan kapıyı bulmalısınız. bunun içinde tek tek bi kapı açık diğer 3 kapı kapalı şekilde kilitleri elinizle kapı içindeki dile bastırarak kumandadan kilitleyiniz taki kilitlenene kadar tüm kapılarda aynı işlemi uygulayınız. Eğerki sorunu çözemezseniz bu akşam size aracımdada olan bu hatayla ilgili örnek bi video çeker gönderirim 2 gün önce aynı sorun vardı bendede kapı karşılığındaki plastik kırıldığı için bant sardım ve düzeldi..<br><br><br>]]>
   </description>
   <pubDate>Thu, 05 May 2016 10:19:51 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=564735&amp;title=206-kilit-problemi#564735</guid>
  </item>
  <item>
   <title><![CDATA[206 kilit problemi : ho&#351;geldin furkan sorun kap&#305; i&#231;lerindeki...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=564732&amp;title=206-kilit-problemi#564732</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 42104<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Mayıs&nbsp;2016 Saat 09:14<br /><br />hoşgeldin furkan sorun kapı içlerindeki swichlerden birinde sorun var kapıyı açık gösterdiği için kumanda kapıları kitlemeş iç lamba kapı konumunda ikin sönmez ve dediğin gibi sürekli yanar.&nbsp;]]>
   </description>
   <pubDate>Thu, 05 May 2016 09:14:28 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=564732&amp;title=206-kilit-problemi#564732</guid>
  </item>
  <item>
   <title><![CDATA[206 kilit problemi : Oncelikle herkese selamlar aran&#305;za...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=564731&amp;title=206-kilit-problemi#564731</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18028">Furkan_58_</a><br /><strong>Konu:</strong> 42104<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Mayıs&nbsp;2016 Saat 09:10<br /><br />Oncelikle herkese selamlar aranıza yeni katıldım ismim furkan 206 colorline m var 2001 model yalnız aracında bi sorunum var aracın orjinal anahtari aracı kilitlemiyor fakat acıyor kilit tuşuna basınca kilit yapıp geri acıyor iç lamba da kapıya getirince sürekli açık kalıyor ben kapıların biri kapanmıyor diye düşünüyorum ama sizin fikriniz nedir ustalarimizin özellikle ]]>
   </description>
   <pubDate>Thu, 05 May 2016 09:10:09 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42104&amp;PID=564731&amp;title=206-kilit-problemi#564731</guid>
  </item>
 </channel>
</rss>
