 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : fan motoru</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 206 : fan motoru]]></description>
  <pubDate>Sun, 03 May 2026 03:51:09 +0000</pubDate>
  <lastBuildDate>Mon, 09 May 2016 14:20:18 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=42098</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[fan motoru : hararet m&#252;&#351;&#252;r&#252;fan rezistans&#305;de&#287;i&#351;tir...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42098&amp;PID=565161&amp;title=fan-motoru#565161</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16868">Selox</a><br /><strong>Konu:</strong> 42098<br /><strong>Gönderim Zamanı:</strong> 09&nbsp;Mayıs&nbsp;2016 Saat 14:20<br /><br /><div>hararet müşürü</div><div><font style=": rgb255, 255, 255;">fan rezistansı</font></div><div><font style=": rgb255, 255, 255;"><br></font></div><div><font style=": rgb255, 255, 255;">değiştir düzelecektir bence de. Bir arkadaş bu şekilde çözmüş. Bende de aynı sorun var bende değiştireceğim. </font></div>]]>
   </description>
   <pubDate>Mon, 09 May 2016 14:20:18 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42098&amp;PID=565161&amp;title=fan-motoru#565161</guid>
  </item>
  <item>
   <title><![CDATA[fan motoru :   Ali tugrul Yazd&#305;:Selam arkadaslar...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42098&amp;PID=564651&amp;title=fan-motoru#564651</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 42098<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Mayıs&nbsp;2016 Saat 08:39<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Ali tugrul" alt="Orjinalini yazan: Ali tugrul" style="vertical-align: text-bottom;" /> <strong>Ali tugrul Yazdı:</strong><br /><br />Selam arkadaslar peugeot 206 1.6 hdi  arabamin Fan motoru calismiyor sigortalari kontrol ettim devreye girmiyor araba stop sinyali veriyor bilgisi olan cevap verebilirmi</td></tr></table><div><br></div><div>a.s ali hoşgeldin öncelikle fan açmamasının sebebi hararet müşürü - fan rölesi ve fan rezistansı ile ilgili olabilir. bu üçünü kontrol ettir.</div>]]>
   </description>
   <pubDate>Wed, 04 May 2016 08:39:24 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42098&amp;PID=564651&amp;title=fan-motoru#564651</guid>
  </item>
  <item>
   <title><![CDATA[fan motoru : Selam arkadaslar peugeot 206 1.6...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42098&amp;PID=564649&amp;title=fan-motoru#564649</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18019">Ali tugrul</a><br /><strong>Konu:</strong> 42098<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Mayıs&nbsp;2016 Saat 05:53<br /><br />Selam arkadaslar peugeot 206 1.6 hdi  arabamin Fan motoru calismiyor sigortalari kontrol ettim devreye girmiyor araba stop sinyali veriyor bilgisi olan cevap verebilirmi ]]>
   </description>
   <pubDate>Wed, 04 May 2016 05:53:33 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42098&amp;PID=564649&amp;title=fan-motoru#564649</guid>
  </item>
 </channel>
</rss>
