 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Debriyajta sorun</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 106 : Debriyajta sorun]]></description>
  <pubDate>Sat, 02 May 2026 20:50:20 +0000</pubDate>
  <lastBuildDate>Fri, 15 Apr 2016 19:50:53 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=41951</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Debriyajta sorun : Neyse beterin beteri vard&#305;r. Ge&#231;mi&#351;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=41951&amp;PID=563635&amp;title=debriyajta-sorun#563635</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=15954">silverlion</a><br /><strong>Konu:</strong> 41951<br /><strong>Gönderim Zamanı:</strong> 15&nbsp;Nisan&nbsp;2016 Saat 19:50<br /><br />Neyse beterin beteri vardır. Geçmiş olsun tekrar. büyük bir sorun olmadığına sevindim.<br><br>]]>
   </description>
   <pubDate>Fri, 15 Apr 2016 19:50:53 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=41951&amp;PID=563635&amp;title=debriyajta-sorun#563635</guid>
  </item>
  <item>
   <title><![CDATA[Debriyajta sorun : Sorun Debriyaj setinin bacagi...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=41951&amp;PID=563628&amp;title=debriyajta-sorun#563628</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=17906">Ronin271</a><br /><strong>Konu:</strong> 41951<br /><strong>Gönderim Zamanı:</strong> 15&nbsp;Nisan&nbsp;2016 Saat 15:29<br /><br />Sorun Debriyaj setinin bacagi kirilmis mecbur debriyaj seti değistirecez]]>
   </description>
   <pubDate>Fri, 15 Apr 2016 15:29:50 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=41951&amp;PID=563628&amp;title=debriyajta-sorun#563628</guid>
  </item>
  <item>
   <title><![CDATA[Debriyajta sorun : Baski balatasi ve ya&#287;i yeni degistirildi...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=41951&amp;PID=563613&amp;title=debriyajta-sorun#563613</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=17906">Ronin271</a><br /><strong>Konu:</strong> 41951<br /><strong>Gönderim Zamanı:</strong> 15&nbsp;Nisan&nbsp;2016 Saat 00:16<br /><br />Baski balatasi ve yaği yeni degistirildi tamirci bi arkadasi kontrolu icin test etti debriyaj telinden dedi bbende arkadasa araci verdim yarin belli olacak neyi var ne yok insallah sadece teldendir ]]>
   </description>
   <pubDate>Fri, 15 Apr 2016 00:16:12 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=41951&amp;PID=563613&amp;title=debriyajta-sorun#563613</guid>
  </item>
  <item>
   <title><![CDATA[Debriyajta sorun : Arkada&#351;&#305;m ge&#231;mi&#351; olsun.Ayn&#305; sorunu...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=41951&amp;PID=563604&amp;title=debriyajta-sorun#563604</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=15954">silverlion</a><br /><strong>Konu:</strong> 41951<br /><strong>Gönderim Zamanı:</strong> 14&nbsp;Nisan&nbsp;2016 Saat 21:12<br /><br />Arkadaşım geçmiş olsun.<br>Aynı sorunu bende yaşadım. Debriyaj telini değiştirerek sorunu giderdim. Motor şase numarası ile yedek parçacıdan temin edip kendim değişimini yaptım ve sorunsuz kullanıyorum. Umarım sorununu halledersin.&nbsp;]]>
   </description>
   <pubDate>Thu, 14 Apr 2016 21:12:35 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=41951&amp;PID=563604&amp;title=debriyajta-sorun#563604</guid>
  </item>
  <item>
   <title><![CDATA[Debriyajta sorun : &#214;ncelikle bask&#305; balata ve &#351;anzuman...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=41951&amp;PID=563558&amp;title=debriyajta-sorun#563558</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=17173">ssakyel</a><br /><strong>Konu:</strong> 41951<br /><strong>Gönderim Zamanı:</strong> 14&nbsp;Nisan&nbsp;2016 Saat 11:57<br /><br />Öncelikle baskı balata ve şanzuman yağı kontrol edilmeli,Baskı balata en son ne zaman değişmiş?<br>]]>
   </description>
   <pubDate>Thu, 14 Apr 2016 11:57:40 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=41951&amp;PID=563558&amp;title=debriyajta-sorun#563558</guid>
  </item>
  <item>
   <title><![CDATA[Debriyajta sorun : Merhaba arkadaslar98 model xr...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=41951&amp;PID=563539&amp;title=debriyajta-sorun#563539</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=17906">Ronin271</a><br /><strong>Konu:</strong> 41951<br /><strong>Gönderim Zamanı:</strong> 14&nbsp;Nisan&nbsp;2016 Saat 01:29<br /><br />Merhaba arkadaslar<br />98 model xr araci yeni aldim ilk gun bindigimde sorun yoktu ama suan 1 2 3 vitesi atip gidiyordum sonra 4 cu vitese atmak istedigimde debriyajin yumusadigini fark ettim ve 4cu vitese gecmedi geri 3atmaya denedim yine olmadi sonra musait yere cekip 1 2 3 4 5 geri vitesleri denedim olmadi debriyaj islem gormedi debriyaji pompalamis gibi yaparak sertligini aldi vitesi atabildim yoluma devam ettim bu sorun devamli olmuyor bazen isiklarda beklerkende ayni sorunu yasiyorum pompalmis gibi yaparak sorun gidiyor acaba aracimin ne gibi bi sorunu vardir<span style="font-size:10px"><br /><br />Düzenleyen Ronin271 - 14&nbsp;Nisan&nbsp;2016 Saat 01:30</span>]]>
   </description>
   <pubDate>Thu, 14 Apr 2016 01:29:36 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=41951&amp;PID=563539&amp;title=debriyajta-sorun#563539</guid>
  </item>
 </channel>
</rss>
