 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : boite de vit defaillant</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 307 : boite de vit defaillant]]></description>
  <pubDate>Sun, 03 May 2026 07:12:08 +0000</pubDate>
  <lastBuildDate>Fri, 01 Apr 2016 18:48:06 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=41773</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[boite de vit defaillant : Klasik otomatik &#351;anzuman ar&#305;zas&#305;....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=41773&amp;PID=562980&amp;title=boite-de-vit-defaillant#562980</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=15673">talip206</a><br /><strong>Konu:</strong> 41773<br /><strong>Gönderim Zamanı:</strong> 01&nbsp;Nisan&nbsp;2016 Saat 18:48<br /><br />Klasik otomatik şanzuman arızası. Yüzde 80 selenoid değişimi ile çözülür. Yüzde 20 ise değişik problemler çıkabilir. Şanzumanciya gidip cihaza bağlanması gerekmektedir. Kesin çözüm o zaman belli olur.]]>
   </description>
   <pubDate>Fri, 01 Apr 2016 18:48:06 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=41773&amp;PID=562980&amp;title=boite-de-vit-defaillant#562980</guid>
  </item>
  <item>
   <title><![CDATA[boite de vit defaillant : Yok mu bu hata ile karsilasan...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=41773&amp;PID=562918&amp;title=boite-de-vit-defaillant#562918</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=15873">ramazaneminaksu</a><br /><strong>Konu:</strong> 41773<br /><strong>Gönderim Zamanı:</strong> 31&nbsp;Mart&nbsp;2016 Saat 19:08<br /><br />Yok mu bu hata ile karsilasan :( gearbox faulty]]>
   </description>
   <pubDate>Thu, 31 Mar 2016 19:08:54 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=41773&amp;PID=562918&amp;title=boite-de-vit-defaillant#562918</guid>
  </item>
  <item>
   <title><![CDATA[boite de vit defaillant : Gearbox faulty ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=41773&amp;PID=562697&amp;title=boite-de-vit-defaillant#562697</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=15873">ramazaneminaksu</a><br /><strong>Konu:</strong> 41773<br /><strong>Gönderim Zamanı:</strong> 26&nbsp;Mart&nbsp;2016 Saat 11:44<br /><br />Gearbox faulty]]>
   </description>
   <pubDate>Sat, 26 Mar 2016 11:44:55 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=41773&amp;PID=562697&amp;title=boite-de-vit-defaillant#562697</guid>
  </item>
  <item>
   <title><![CDATA[boite de vit defaillant : Dili &#304;ngilizceye &#231;evirdim gelen...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=41773&amp;PID=562696&amp;title=boite-de-vit-defaillant#562696</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=15873">ramazaneminaksu</a><br /><strong>Konu:</strong> 41773<br /><strong>Gönderim Zamanı:</strong> 26&nbsp;Mart&nbsp;2016 Saat 11:42<br /><br />Dili İngilizceye çevirdim gelen hata gearnox faulty.kesin selonoid değişimi uyarısı mi bu]]>
   </description>
   <pubDate>Sat, 26 Mar 2016 11:42:31 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=41773&amp;PID=562696&amp;title=boite-de-vit-defaillant#562696</guid>
  </item>
  <item>
   <title><![CDATA[boite de vit defaillant : Dili &#304;ngilizceye &#231;evirdim bir...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=41773&amp;PID=562533&amp;title=boite-de-vit-defaillant#562533</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=15873">ramazaneminaksu</a><br /><strong>Konu:</strong> 41773<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Mart&nbsp;2016 Saat 00:26<br /><br />Dili İngilizceye çevirdim bir daha hatayı verirse buraya yazarım.]]>
   </description>
   <pubDate>Thu, 24 Mar 2016 00:26:28 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=41773&amp;PID=562533&amp;title=boite-de-vit-defaillant#562533</guid>
  </item>
  <item>
   <title><![CDATA[boite de vit defaillant : Bahsetti&#287;iniz tipik otomatik gear...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=41773&amp;PID=562521&amp;title=boite-de-vit-defaillant#562521</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=15673">talip206</a><br /><strong>Konu:</strong> 41773<br /><strong>Gönderim Zamanı:</strong> 23&nbsp;Mart&nbsp;2016 Saat 19:30<br /><br />Bahsettiğiniz tipik otomatik gear fault arızası. Vites kendini korumaya alıyor kontağı kapatıp açınca düzeliyor. ingilizce dil seçeneği vardır ordan ingilizce yaparsanız daha sağlıklı bilgi verebiliriz. Ama büyük bir ihtimal şanzuman uyarısı. ]]>
   </description>
   <pubDate>Wed, 23 Mar 2016 19:30:59 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=41773&amp;PID=562521&amp;title=boite-de-vit-defaillant#562521</guid>
  </item>
  <item>
   <title><![CDATA[boite de vit defaillant :  frans&#305;zca ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=41773&amp;PID=562489&amp;title=boite-de-vit-defaillant#562489</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=15873">ramazaneminaksu</a><br /><strong>Konu:</strong> 41773<br /><strong>Gönderim Zamanı:</strong> 23&nbsp;Mart&nbsp;2016 Saat 08:05<br /><br />fransızca]]>
   </description>
   <pubDate>Wed, 23 Mar 2016 08:05:11 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=41773&amp;PID=562489&amp;title=boite-de-vit-defaillant#562489</guid>
  </item>
  <item>
   <title><![CDATA[boite de vit defaillant : Onu tam bilmiyorum ama ariza &#305;&#351;&#305;&#287;&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=41773&amp;PID=562481&amp;title=boite-de-vit-defaillant#562481</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=15323">crazysado</a><br /><strong>Konu:</strong> 41773<br /><strong>Gönderim Zamanı:</strong> 23&nbsp;Mart&nbsp;2016 Saat 00:28<br /><br />Onu tam bilmiyorum ama ariza ışığı yanikken baglatirsaniz<br />Daha net olur diye düşünüyorum<br />Birde konu basligindaki uyari yazisi dili hangi ülkeye ait ?????]]>
   </description>
   <pubDate>Wed, 23 Mar 2016 00:28:19 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=41773&amp;PID=562481&amp;title=boite-de-vit-defaillant#562481</guid>
  </item>
  <item>
   <title><![CDATA[boite de vit defaillant : Maalesef &#304;ngilizce dil se&#231;ene&#287;i...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=41773&amp;PID=562475&amp;title=boite-de-vit-defaillant#562475</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=15873">ramazaneminaksu</a><br /><strong>Konu:</strong> 41773<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Mart&nbsp;2016 Saat 23:13<br /><br />Maalesef İngilizce dil seçeneği yok arabada ya da ben goremedim. Hata kaybolduktan sonra gene de PC ye baglatsam belli olur mu hata.]]>
   </description>
   <pubDate>Tue, 22 Mar 2016 23:13:49 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=41773&amp;PID=562475&amp;title=boite-de-vit-defaillant#562475</guid>
  </item>
  <item>
   <title><![CDATA[boite de vit defaillant : Siz oncelikle yol bilgisayar&#305;n&#305;z&#305;n...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=41773&amp;PID=562400&amp;title=boite-de-vit-defaillant#562400</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=15323">crazysado</a><br /><strong>Konu:</strong> 41773<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Mart&nbsp;2016 Saat 11:00<br /><br />Siz oncelikle yol bilgisayarınızın ayarlarından dil seçeneğini ingilizce yapın yazmis olduğunuz hata yazısının dili farkli gibi geldi bana yada araci pc ye baglatip hata kodu aldirin]]>
   </description>
   <pubDate>Tue, 22 Mar 2016 11:00:45 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=41773&amp;PID=562400&amp;title=boite-de-vit-defaillant#562400</guid>
  </item>
  <item>
   <title><![CDATA[boite de vit defaillant :  arkada&#351;lar merhaba.Peugeot 307...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=41773&amp;PID=562360&amp;title=boite-de-vit-defaillant#562360</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=15873">ramazaneminaksu</a><br /><strong>Konu:</strong> 41773<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Mart&nbsp;2016 Saat 16:34<br /><br />arkadaşlar merhaba.<div>Peugeot 307 1.6 benzinli/lipg li aracımda arasıra boite de vit defaillant hatası alıyorum. Bu hata geldiği anda aracında vites geçişleri değişiyor, gaz yemesi gecikiyor ve triptronik kullanma özelliği ortadan kalkıyor. aracı istop edip biraz bekledikten sonra tekrar çalıştırdığımda uyarı ortadan kalkıyor. Bunun nedeni selenoid midir? daha önce böyle bir hata ile karşılasan varsa tecrübelerini paylaşırsa sevinirim.</div>]]>
   </description>
   <pubDate>Mon, 21 Mar 2016 16:34:48 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=41773&amp;PID=562360&amp;title=boite-de-vit-defaillant#562360</guid>
  </item>
 </channel>
</rss>
