 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Gaz yemiyo</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 206 : Gaz yemiyo]]></description>
  <pubDate>Sun, 03 May 2026 06:45:00 +0000</pubDate>
  <lastBuildDate>Tue, 19 Jan 2016 15:40:55 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=41191</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Gaz yemiyo : 10 / 40 motul var &#252;zerinde . Ya&#287;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=41191&amp;PID=558104&amp;title=gaz-yemiyo#558104</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=17415">Dzking</a><br /><strong>Konu:</strong> 41191<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Ocak&nbsp;2016 Saat 15:40<br /><br />10 / 40 motul var üzerinde . Yağ ile tam alakası nedir . Bilgi verirseniz sevinirim.iyi formlar ]]>
   </description>
   <pubDate>Tue, 19 Jan 2016 15:40:55 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=41191&amp;PID=558104&amp;title=gaz-yemiyo#558104</guid>
  </item>
  <item>
   <title><![CDATA[Gaz yemiyo : Motor ya&#287;&#305;n&#305;z&#305; yenileyin. SHELL...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=41191&amp;PID=558065&amp;title=gaz-yemiyo#558065</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=17075">dsinan26</a><br /><strong>Konu:</strong> 41191<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Ocak&nbsp;2016 Saat 02:11<br /><br /><b>Motor yağınızı yenileyin. SHELL HELIX tavsiye ederim. Sorun düzelecektir.<br></b>]]>
   </description>
   <pubDate>Tue, 19 Jan 2016 02:11:24 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=41191&amp;PID=558065&amp;title=gaz-yemiyo#558065</guid>
  </item>
  <item>
   <title><![CDATA[Gaz yemiyo : Sanki benzin pompas&#305; yada benzinle...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=41191&amp;PID=558056&amp;title=gaz-yemiyo#558056</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=17415">Dzking</a><br /><strong>Konu:</strong> 41191<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Ocak&nbsp;2016 Saat 23:10<br /><br />Sanki benzin pompası yada benzinle alakalı birşey gibi geliyor bana baskı balata kavramamda sıkıntı yok . Yani sanki ilk karştan ilk hareketten sonra benzinde bi boşluk oluyor gibi . Çok yorumlar duydum ecu diyen lambda sensör diyen bobin diyen bi cıkamadık işin içinden .]]>
   </description>
   <pubDate>Mon, 18 Jan 2016 23:10:01 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=41191&amp;PID=558056&amp;title=gaz-yemiyo#558056</guid>
  </item>
  <item>
   <title><![CDATA[Gaz yemiyo : Merhaba,Dostum bask&#305; balata olabilir...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=41191&amp;PID=558007&amp;title=gaz-yemiyo#558007</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=17173">ssakyel</a><br /><strong>Konu:</strong> 41191<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Ocak&nbsp;2016 Saat 11:37<br /><br />Merhaba,<br><br>Dostum baskı balata olabilir yine senin ki de.Bir kontrol et istersen.<br>]]>
   </description>
   <pubDate>Mon, 18 Jan 2016 11:37:17 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=41191&amp;PID=558007&amp;title=gaz-yemiyo#558007</guid>
  </item>
  <item>
   <title><![CDATA[Gaz yemiyo : Merhaba,&#246;ncelikle ge&#231;mi&#351; olsun,Bask&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=41191&amp;PID=557946&amp;title=gaz-yemiyo#557946</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=17173">ssakyel</a><br /><strong>Konu:</strong> 41191<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Ocak&nbsp;2016 Saat 20:22<br /><br />Merhaba,öncelikle geçmiş olsun,<br><br>Baskı balatanın durumunu kontrol edebilrsin,eğer bitmeye yaklaşmış ise bu sorunu verebilir.Bir de yeterli devire ulaşınca vites değiştiriyor musun?Bu devir olayı mesela üçten dörde geçerken çok farkedilmese de bir ile ikinci vites değişikliklerinde çok farkediyor.<br>]]>
   </description>
   <pubDate>Sun, 17 Jan 2016 20:22:30 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=41191&amp;PID=557946&amp;title=gaz-yemiyo#557946</guid>
  </item>
  <item>
   <title><![CDATA[Gaz yemiyo : Bi deneyimi veya fikri olan yokmu...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=41191&amp;PID=557918&amp;title=gaz-yemiyo#557918</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=17048">ozgorh</a><br /><strong>Konu:</strong> 41191<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Ocak&nbsp;2016 Saat 02:31<br /><br />Bi deneyimi veya fikri olan yokmu]]>
   </description>
   <pubDate>Sun, 17 Jan 2016 02:31:54 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=41191&amp;PID=557918&amp;title=gaz-yemiyo#557918</guid>
  </item>
  <item>
   <title><![CDATA[Gaz yemiyo : Merhaba arkadaslar lpg de giderken...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=41191&amp;PID=557805&amp;title=gaz-yemiyo#557805</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=17048">ozgorh</a><br /><strong>Konu:</strong> 41191<br /><strong>Gönderim Zamanı:</strong> 15&nbsp;Ocak&nbsp;2016 Saat 07:20<br /><br />Merhaba arkadaslar lpg de giderken hicbir sıkıntı yok benzinde giderken arada 2. Vitese alınca gaz yemiyo ozaman gaza fazla basıyorum düzeliyo neden olabilir]]>
   </description>
   <pubDate>Fri, 15 Jan 2016 07:20:37 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=41191&amp;PID=557805&amp;title=gaz-yemiyo#557805</guid>
  </item>
 </channel>
</rss>
