 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Yokohama Lastik</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 206 : Yokohama Lastik]]></description>
  <pubDate>Sat, 02 May 2026 21:20:55 +0000</pubDate>
  <lastBuildDate>Sat, 28 Nov 2015 21:01:21 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=40724</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Yokohama Lastik :   pusutr Yazd&#305;:bence lassa :) Lassa...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40724&amp;PID=554617&amp;title=yokohama-lastik#554617</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13804">madblueblacksea</a><br /><strong>Konu:</strong> 40724<br /><strong>Gönderim Zamanı:</strong> 28&nbsp;Kasım&nbsp;2015 Saat 21:01<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: pusutr" alt="Orjinalini yazan: pusutr" style="vertical-align: text-bottom;" /> <strong>pusutr Yazdı:</strong><br /><br />bence lassa :)<br></td></tr></table><div><br></div><div>Lassa güzel lastik ama sertliği dışında :)</div>]]>
   </description>
   <pubDate>Sat, 28 Nov 2015 21:01:21 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40724&amp;PID=554617&amp;title=yokohama-lastik#554617</guid>
  </item>
  <item>
   <title><![CDATA[Yokohama Lastik :   G&#246;khaN Yazd&#305;:ben &#351;ahsen tevsiye...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40724&amp;PID=554616&amp;title=yokohama-lastik#554616</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13804">madblueblacksea</a><br /><strong>Konu:</strong> 40724<br /><strong>Gönderim Zamanı:</strong> 28&nbsp;Kasım&nbsp;2015 Saat 21:00<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: GökhaN" alt="Orjinalini yazan: GökhaN" style="vertical-align: text-bottom;" /> <strong>GökhaN Yazdı:</strong><br /><br />ben şahsen tevsiye etmem bosuna para verme tutunamadı ülkemizde yokohoma bence michelin den şaşma. uzak doğu üretimleri hep bir süre sonra sertleşiyor&nbsp;</td></tr></table><div><br></div><div>Evet michelin yapmış gerçekten ama fiyatlarda bişey yapmıyor :)</div>]]>
   </description>
   <pubDate>Sat, 28 Nov 2015 21:00:30 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40724&amp;PID=554616&amp;title=yokohama-lastik#554616</guid>
  </item>
  <item>
   <title><![CDATA[Yokohama Lastik : bence lassa :) ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40724&amp;PID=554517&amp;title=yokohama-lastik#554517</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11113">pusutr</a><br /><strong>Konu:</strong> 40724<br /><strong>Gönderim Zamanı:</strong> 27&nbsp;Kasım&nbsp;2015 Saat 13:29<br /><br />bence lassa :)<br>]]>
   </description>
   <pubDate>Fri, 27 Nov 2015 13:29:17 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40724&amp;PID=554517&amp;title=yokohama-lastik#554517</guid>
  </item>
  <item>
   <title><![CDATA[Yokohama Lastik : ben &#351;ahsen tevsiye etmem bosuna...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40724&amp;PID=554502&amp;title=yokohama-lastik#554502</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=1">GökhaN</a><br /><strong>Konu:</strong> 40724<br /><strong>Gönderim Zamanı:</strong> 27&nbsp;Kasım&nbsp;2015 Saat 09:56<br /><br />ben şahsen tevsiye etmem bosuna para verme tutunamadı ülkemizde yokohoma bence michelin den şaşma. uzak doğu üretimleri hep bir süre sonra sertleşiyor&nbsp;]]>
   </description>
   <pubDate>Fri, 27 Nov 2015 09:56:13 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40724&amp;PID=554502&amp;title=yokohama-lastik#554502</guid>
  </item>
  <item>
   <title><![CDATA[Yokohama Lastik : Test sonu&#231;lar&#305; anl&#305;k faydal&#305; olabiliyor...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40724&amp;PID=554486&amp;title=yokohama-lastik#554486</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13804">madblueblacksea</a><br /><strong>Konu:</strong> 40724<br /><strong>Gönderim Zamanı:</strong> 27&nbsp;Kasım&nbsp;2015 Saat 00:01<br /><br />Test sonuçları anlık faydalı olabiliyor ama uzun vadede yaşanacaklar için yol gösterici değil. Aldığımda yumuşak olup bir yıl sonra kütük gibi sertleşme ihtimali düşündürüyor beni]]>
   </description>
   <pubDate>Fri, 27 Nov 2015 00:01:41 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40724&amp;PID=554486&amp;title=yokohama-lastik#554486</guid>
  </item>
  <item>
   <title><![CDATA[Yokohama Lastik : http://www.rezulteo-lastik.com...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40724&amp;PID=554167&amp;title=yokohama-lastik#554167</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 40724<br /><strong>Gönderim Zamanı:</strong> 23&nbsp;Kasım&nbsp;2015 Saat 11:26<br /><br />http://www.rezulteo-lastik.com.tr/yokohama-lastikler/bluearth-ae-01-lastik/deneme-test-5738931<div><br></div><div>test sonuçlarınıda karşılaştırmanızı öneririm yokohamanın bildiğim kadarıyla bir kaç modelinin daha iyi sonuçlar verdiğini biliyorum. sert ve agresif bir lastik oldugunu yazanlar var ama genel olarak fiyat ve performans konusunda memnun olanlar orta seviyede. &nbsp; hatta geçen yıl bu seri lastiklerinde üretim problemi oldugunda firma geri çagrıda bulunmuştu müşterilerine. Yorumlar konusunda 2 inci &nbsp;yazında sertleş oldugu ve konforunun ve fren mesafesini arttıgını söyleyenler çogunlukta iyi forumlar.&nbsp;</div>]]>
   </description>
   <pubDate>Mon, 23 Nov 2015 11:26:25 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40724&amp;PID=554167&amp;title=yokohama-lastik#554167</guid>
  </item>
  <item>
   <title><![CDATA[Yokohama Lastik : Yokohama lastikleri tecr&#252;be eden...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40724&amp;PID=554097&amp;title=yokohama-lastik#554097</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13804">madblueblacksea</a><br /><strong>Konu:</strong> 40724<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Kasım&nbsp;2015 Saat 01:38<br /><br />Yokohama lastikleri tecrübe eden arkadaşların görüşlerine ihtiyacım var. Özellikle 185/65R14 86T AE01 modelini tecrübe eden varsa çok iyi olur. Teknik olarak aradığım lastik ancak son kullanıcıda durum değşebildiği içi emin olmak istiyorum. Lastik önerilerinize saygım var ama öncelikle bu lastiğin kullanıcılarının cevapları faydalı olacak. Hele bide 206 1.4 hdi kullanıcı varsa tadından yenmez :)]]>
   </description>
   <pubDate>Sun, 22 Nov 2015 01:38:21 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40724&amp;PID=554097&amp;title=yokohama-lastik#554097</guid>
  </item>
 </channel>
</rss>
