 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 307 XT BVA 1.6 ÇEKİŞ PROBLEMİ</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 307 : 307 XT BVA 1.6 ÇEKİŞ PROBLEMİ]]></description>
  <pubDate>Sat, 02 May 2026 04:23:26 +0000</pubDate>
  <lastBuildDate>Thu, 15 Oct 2015 21:02:17 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=40451</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[307 XT BVA 1.6 ÇEKİŞ PROBLEMİ : Ankarada tavsiye edebilece&#287;iniz...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40451&amp;PID=552315&amp;title=307-xt-bva-1-6-cekis-problemi#552315</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16880">üçyüzyedi</a><br /><strong>Konu:</strong> 40451<br /><strong>Gönderim Zamanı:</strong> 15&nbsp;Ekim&nbsp;2015 Saat 21:02<br /><br />Ankarada tavsiye edebileceğiniz bir usta var mı?<br>]]>
   </description>
   <pubDate>Thu, 15 Oct 2015 21:02:17 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40451&amp;PID=552315&amp;title=307-xt-bva-1-6-cekis-problemi#552315</guid>
  </item>
  <item>
   <title><![CDATA[307 XT BVA 1.6 ÇEKİŞ PROBLEMİ : &#246;yle d&#252;zg&#252;n usta bulmakta zor...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40451&amp;PID=552214&amp;title=307-xt-bva-1-6-cekis-problemi#552214</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 40451<br /><strong>Gönderim Zamanı:</strong> 13&nbsp;Ekim&nbsp;2015 Saat 11:42<br /><br />öyle düzgün usta bulmakta zor işallah iyi bir ustaya denk gelirsiniz. problemlerinize çözüm bulur.]]>
   </description>
   <pubDate>Tue, 13 Oct 2015 11:42:42 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40451&amp;PID=552214&amp;title=307-xt-bva-1-6-cekis-problemi#552214</guid>
  </item>
  <item>
   <title><![CDATA[307 XT BVA 1.6 ÇEKİŞ PROBLEMİ : Daha do&#287;rusu sanayide d&#252;zg&#252;n,...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40451&amp;PID=552210&amp;title=307-xt-bva-1-6-cekis-problemi#552210</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16880">üçyüzyedi</a><br /><strong>Konu:</strong> 40451<br /><strong>Gönderim Zamanı:</strong> 13&nbsp;Ekim&nbsp;2015 Saat 10:33<br /><br />Daha doğrusu sanayide düzgün, içime sisnen bir usta olmadığı için artık aracın heryerini kontrol ettirmek istemiyorum. her kontrolde araçta bir arıza meydana geliyor.<br>]]>
   </description>
   <pubDate>Tue, 13 Oct 2015 10:33:33 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40451&amp;PID=552210&amp;title=307-xt-bva-1-6-cekis-problemi#552210</guid>
  </item>
  <item>
   <title><![CDATA[307 XT BVA 1.6 ÇEKİŞ PROBLEMİ : ilginiz i&#231;in te&#351;ekk&#252;r ederim....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40451&amp;PID=552209&amp;title=307-xt-bva-1-6-cekis-problemi#552209</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16880">üçyüzyedi</a><br /><strong>Konu:</strong> 40451<br /><strong>Gönderim Zamanı:</strong> 13&nbsp;Ekim&nbsp;2015 Saat 10:31<br /><br />ilginiz için teşekkür ederim. <br><br>araç 5 yılı aşkın süredir bende ve 5 yıldırda bakım harici sanayi yüzü görmeyen araç sanayiden çıkamaz oldu.Yaptırdığım yere tekrar gittim kontrol etmek için motoru askıya almdıklarında&nbsp; motor kulaklarını da zarar vermişler. Bu seferde ç D konumda bekleme esnasında aracın içinde aşırı bir titreme oldu.Daha sonra da oraya gitmemeye karar verdim.<br><br><br>]]>
   </description>
   <pubDate>Tue, 13 Oct 2015 10:31:37 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40451&amp;PID=552209&amp;title=307-xt-bva-1-6-cekis-problemi#552209</guid>
  </item>
  <item>
   <title><![CDATA[307 XT BVA 1.6 ÇEKİŞ PROBLEMİ : subap iticileri ve soketlerin...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40451&amp;PID=552208&amp;title=307-xt-bva-1-6-cekis-problemi#552208</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 40451<br /><strong>Gönderim Zamanı:</strong> 13&nbsp;Ekim&nbsp;2015 Saat 10:20<br /><br />subap iticileri ve soketlerin kontrolü yapıldımı aracı toplarken çırak bir soketi tam yerine oturtmamış yada takmamış olabilir. manifolt kontrolü yapıldımı belkide değişen parçalarda problem olabilir. gerekir yaptırdıgın yer tekrar söküp kontrol etmez zorunda sonuçta para verdiniz.&nbsp;]]>
   </description>
   <pubDate>Tue, 13 Oct 2015 10:20:45 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40451&amp;PID=552208&amp;title=307-xt-bva-1-6-cekis-problemi#552208</guid>
  </item>
  <item>
   <title><![CDATA[307 XT BVA 1.6 ÇEKİŞ PROBLEMİ :  Arkada&#351;lar, bu problem hakk&#305;nda...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40451&amp;PID=552186&amp;title=307-xt-bva-1-6-cekis-problemi#552186</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16880">üçyüzyedi</a><br /><strong>Konu:</strong> 40451<br /><strong>Gönderim Zamanı:</strong> 12&nbsp;Ekim&nbsp;2015 Saat 17:54<br /><br /><p>Arkadaşlar, bu problem hakkında daha önce de yazdım ama problem hala devam ediyor.Bir kaç benzer konu yakaladım ancak o kişilerle de hala görüşemedim.</p><p>Vites farketmeksizin&nbsp; gaza bastığımda devir 2700 -3000a yaklaştığında ve geçtiğinde motordan boğultulu bir ses gelmektedir.bunu hem bezinde hem de lpg de yapıyor.gaza yüklenme esnasında bu ses bariz bir şekilde duyuluyor. Sanki hava filitresini takmamış yada yerine otrutmamış gibi.yada araçta kaen fitre var gibi.önceden gaz pedalına dokunur dokunmaz araba fırlıyordu.şimdi gaz pedalına basıyorum, bir kaç saniye sonra gaz yiyor ve araba önce ki gibi seri bir şekilde fırlamıyor. Araç sanki kendini kasıyor. 3. ve 4. viteslere geçişte aracı sanki arkadan çekiyorlarmış gibi oluyor.</p><p>Bütün bu şikayetlerim aracın triger kayışını kopartıp sübapları eğdikten sonra oluştu.</p><p>Aşağıda belrttiğim noktaları kontrol eettirdim.</p><p>_Sente ayarı tekrar kontrol.<br>_Aracın komple hava fitresi yolları kontrol.<br>_Orta ve arka eksoz değişti.<br>_PC bağlantısında arıza vermiyor.</p><p>Yardımlarınızı rica ediyorum.</p>]]>
   </description>
   <pubDate>Mon, 12 Oct 2015 17:54:47 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40451&amp;PID=552186&amp;title=307-xt-bva-1-6-cekis-problemi#552186</guid>
  </item>
 </channel>
</rss>
