 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 206 lpg sorunu ?</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 206 : 206 lpg sorunu ?]]></description>
  <pubDate>Sun, 03 May 2026 06:07:31 +0000</pubDate>
  <lastBuildDate>Tue, 25 Aug 2015 09:07:05 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=40191</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[206 lpg sorunu ? : program laz&#305;m hocam hayr&#305;na biri...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40191&amp;PID=550363&amp;title=206-lpg-sorunu#550363</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 40191<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Ağustos&nbsp;2015 Saat 09:07<br /><br />program lazım hocam hayrına biri verirse neden olmasın internettende ayarları bulursun zaten nasıl yapıldıgını]]>
   </description>
   <pubDate>Tue, 25 Aug 2015 09:07:05 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40191&amp;PID=550363&amp;title=206-lpg-sorunu#550363</guid>
  </item>
  <item>
   <title><![CDATA[206 lpg sorunu ? : netde gormustum bi ara lpg ayar...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40191&amp;PID=550342&amp;title=206-lpg-sorunu#550342</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11867">Turgay_66</a><br /><strong>Konu:</strong> 40191<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Ağustos&nbsp;2015 Saat 18:08<br /><br />netde gormustum bi ara lpg ayar kablosu diye alsak kendimiz yapabilirmiyiz acaba ?]]>
   </description>
   <pubDate>Mon, 24 Aug 2015 18:08:44 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40191&amp;PID=550342&amp;title=206-lpg-sorunu#550342</guid>
  </item>
  <item>
   <title><![CDATA[206 lpg sorunu ? : tesekkur ederim hocam aydinlattiginiz...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40191&amp;PID=550340&amp;title=206-lpg-sorunu#550340</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11867">Turgay_66</a><br /><strong>Konu:</strong> 40191<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Ağustos&nbsp;2015 Saat 18:06<br /><br />tesekkur ederim hocam aydinlattiginiz icin,en kisa surede filtre degisimi ve gaz ayari yaptirmam lazim :)]]>
   </description>
   <pubDate>Mon, 24 Aug 2015 18:06:32 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40191&amp;PID=550340&amp;title=206-lpg-sorunu#550340</guid>
  </item>
  <item>
   <title><![CDATA[206 lpg sorunu ? : evet hocam aynen bendede ara ara...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40191&amp;PID=550337&amp;title=206-lpg-sorunu#550337</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 40191<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Ağustos&nbsp;2015 Saat 16:58<br /><br />evet hocam aynen bendede ara ara benzine geçince gaz aldım internetten filtresini alıp kendim değiştirdim lpg nin daha ucuza geldi iki filtre 25 tl aldim kargo dahil.]]>
   </description>
   <pubDate>Mon, 24 Aug 2015 16:58:48 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40191&amp;PID=550337&amp;title=206-lpg-sorunu#550337</guid>
  </item>
  <item>
   <title><![CDATA[206 lpg sorunu ? : bende sizin gibi yaptim benzinde...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40191&amp;PID=550336&amp;title=206-lpg-sorunu#550336</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11867">Turgay_66</a><br /><strong>Konu:</strong> 40191<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Ağustos&nbsp;2015 Saat 16:34<br /><br />bende sizin gibi yaptim benzinde gittim biraz sonra gaza aldim 100 km sonra anca duzeldi. ama bu 100 km icinde yine ikaz vererek gazdan benzine en az 3-4 defa gecti,elimle gaza aldim bende tekrar]]>
   </description>
   <pubDate>Mon, 24 Aug 2015 16:34:21 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40191&amp;PID=550336&amp;title=206-lpg-sorunu#550336</guid>
  </item>
  <item>
   <title><![CDATA[206 lpg sorunu ? : hocam ayn&#305;s&#305; benim ba&#351;&#305;ma geldi...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40191&amp;PID=550332&amp;title=206-lpg-sorunu#550332</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 40191<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Ağustos&nbsp;2015 Saat 14:12<br /><br />hocam aynısı benim başıma geldi tatilden dönüşte afyondan shellden aldım gazı araç gaz yememeye başladı hatta hızlanmıyordu sizin gibi sinyal sesi verdi bir müddet benzinde gittim bir sıkıntı yok tekrar gaza geçtim 150 km sonra ancak düzeldi. büyük ihtimal yakıtla alakalı filtreleriniz tekrardan değiştiriniz.&nbsp;]]>
   </description>
   <pubDate>Mon, 24 Aug 2015 14:12:57 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40191&amp;PID=550332&amp;title=206-lpg-sorunu#550332</guid>
  </item>
  <item>
   <title><![CDATA[206 lpg sorunu ? : gazi shellden almistim hocam ama...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40191&amp;PID=550331&amp;title=206-lpg-sorunu#550331</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11867">Turgay_66</a><br /><strong>Konu:</strong> 40191<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Ağustos&nbsp;2015 Saat 13:57<br /><br />gazi shellden almistim hocam ama baska bi ilden ,filtre degiseli 5bin km felan oldu,peki ariza lambasi ve lpg dugmesinden gelen sesin anlami ne hocam uc kere hizli hizli ikaz verdi ?]]>
   </description>
   <pubDate>Mon, 24 Aug 2015 13:57:13 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40191&amp;PID=550331&amp;title=206-lpg-sorunu#550331</guid>
  </item>
  <item>
   <title><![CDATA[206 lpg sorunu ? : Ald&#305;&#287;&#305;n&#305;z gaz&#305;n kalitesinden dolay&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40191&amp;PID=550304&amp;title=206-lpg-sorunu#550304</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=15673">talip206</a><br /><strong>Konu:</strong> 40191<br /><strong>Gönderim Zamanı:</strong> 23&nbsp;Ağustos&nbsp;2015 Saat 22:21<br /><br />Aldığınız gazın kalitesinden dolayı yapıyordur. Her 15 binde lpg filtrenizi değiştirmeniz gerekiyor. eğer o kirlendi ise ondan dolayı yapar. ]]>
   </description>
   <pubDate>Sun, 23 Aug 2015 22:21:48 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40191&amp;PID=550304&amp;title=206-lpg-sorunu#550304</guid>
  </item>
  <item>
   <title><![CDATA[206 lpg sorunu ? : meraba arkadaslar dun 400 kmlik...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40191&amp;PID=550292&amp;title=206-lpg-sorunu#550292</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11867">Turgay_66</a><br /><strong>Konu:</strong> 40191<br /><strong>Gönderim Zamanı:</strong> 23&nbsp;Ağustos&nbsp;2015 Saat 13:08<br /><br />meraba arkadaslar dun 400 kmlik bi uzun yola ciktim farkli bi yerden gaz alinca arabaya biseyler oluyor. once araba teklemeye basladi sonra aracin ariza lambasi yandi ,sonrada lpg dugmesinden degisik bi ikaz sesi geldi benzine gecti,stop ettim tekrar calistirdim ariza lambasi yanip sonuyordu ama gidiste sorun yoktu.bunu neden yapar pislikmi gelmistir yada gaz ayariyla alakasi varmidir ?]]>
   </description>
   <pubDate>Sun, 23 Aug 2015 13:08:21 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40191&amp;PID=550292&amp;title=206-lpg-sorunu#550292</guid>
  </item>
 </channel>
</rss>
