 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Amfi güç kablosu yardım</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Peugeot Ses Sistemleri : Amfi güç kablosu yardım]]></description>
  <pubDate>Sun, 03 May 2026 22:23:51 +0000</pubDate>
  <lastBuildDate>Tue, 11 Aug 2015 09:40:26 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=40117</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Amfi güç kablosu yardım : Sase kablosunu taktim geri tabi...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40117&amp;PID=549814&amp;title=amfi-guc-kablosu-yardim#549814</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=15178">Samet Çetin</a><br /><strong>Konu:</strong> 40117<br /><strong>Gönderim Zamanı:</strong> 11&nbsp;Ağustos&nbsp;2015 Saat 09:40<br /><br />Sase kablosunu taktim geri tabi oyle birakmadim. Sesi nasil kesecegim acaba bir fikri olan yok sanirim.<br />]]>
   </description>
   <pubDate>Tue, 11 Aug 2015 09:40:26 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40117&amp;PID=549814&amp;title=amfi-guc-kablosu-yardim#549814</guid>
  </item>
  <item>
   <title><![CDATA[Amfi güç kablosu yardım :   Samet &#199;etin Yazd&#305;:Yok mu yard&#305;m&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40117&amp;PID=549812&amp;title=amfi-guc-kablosu-yardim#549812</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13804">madblueblacksea</a><br /><strong>Konu:</strong> 40117<br /><strong>Gönderim Zamanı:</strong> 11&nbsp;Ağustos&nbsp;2015 Saat 09:16<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Samet Çetin" alt="Orjinalini yazan: Samet Çetin" style="vertical-align: text-bottom;" /> <strong>Samet Çetin Yazdı:</strong><br /><br />Yok mu yardımı dokunacak birisi? Araştırmalarımdan şase kablosunu boyasız kısımdan alınması gerektiğini gördüm fakat ben şase kablosunu iptal ediyorum amfi hala çalışıyor ve motor sesi kesilmiyor.</td></tr></table><div><br></div><div>Şase kablosunu çıkartınca amfinin çalışması normal teypten gelen line kabloları şaseyi tamamlıyor ama bu şekilde kullanmaman gerekir teyp kablo ve amfi risk altında. Kablo bağlantılarını çok iyi yapman gerekir. Şase kablosu deyip hafife alma (+) kadar önemli. Döngünün tamamlanması gerek. Akülerde elektrik akımı normalin aksine (-) kutuptan (+) kutupa gider.&nbsp;</div>]]>
   </description>
   <pubDate>Tue, 11 Aug 2015 09:16:12 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40117&amp;PID=549812&amp;title=amfi-guc-kablosu-yardim#549812</guid>
  </item>
  <item>
   <title><![CDATA[Amfi güç kablosu yardım : Yok mu yard&#305;m&#305; dokunacak birisi?...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40117&amp;PID=549794&amp;title=amfi-guc-kablosu-yardim#549794</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=15178">Samet Çetin</a><br /><strong>Konu:</strong> 40117<br /><strong>Gönderim Zamanı:</strong> 10&nbsp;Ağustos&nbsp;2015 Saat 22:43<br /><br />Yok mu yardımı dokunacak birisi? Araştırmalarımdan şase kablosunu boyasız kısımdan alınması gerektiğini gördüm fakat ben şase kablosunu iptal ediyorum amfi hala çalışıyor ve motor sesi kesilmiyor.]]>
   </description>
   <pubDate>Mon, 10 Aug 2015 22:43:49 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40117&amp;PID=549794&amp;title=amfi-guc-kablosu-yardim#549794</guid>
  </item>
  <item>
   <title><![CDATA[Amfi güç kablosu yardım : &#199;amurluk sinyalinin oralardan...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40117&amp;PID=549739&amp;title=amfi-guc-kablosu-yardim#549739</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=15178">Samet Çetin</a><br /><strong>Konu:</strong> 40117<br /><strong>Gönderim Zamanı:</strong> 09&nbsp;Ağustos&nbsp;2015 Saat 21:23<br /><br />Çamurluk sinyalinin oralardan filan geçirdim kabloyu fakat bu sefer motor sesini hoparlörlere veriyor bunu nasıl çözebilirim?]]>
   </description>
   <pubDate>Sun, 09 Aug 2015 21:23:02 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40117&amp;PID=549739&amp;title=amfi-guc-kablosu-yardim#549739</guid>
  </item>
  <item>
   <title><![CDATA[Amfi güç kablosu yardım : Merhaba herkese iyi forumlar,...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=40117&amp;PID=549736&amp;title=amfi-guc-kablosu-yardim#549736</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=15178">Samet Çetin</a><br /><strong>Konu:</strong> 40117<br /><strong>Gönderim Zamanı:</strong> 09&nbsp;Ağustos&nbsp;2015 Saat 16:40<br /><br />Merhaba herkese iyi forumlar, aracım 206 GTİ arkadaşlar yeni aldım biraz eksikleri var tamamladıktan sonra fotoğraflarını da ekleyeceğim. Şimdi aracıma bir amfi bağlayacağım ama aküden çekeceğim güç kablosunun yerini bulamadım diğer 206 aracımda çok kolay çekmiştim ama bunda bir sıkıntı var fotoğrafları ekleyeceğim nereden geçeceğine dair bir fikri olan varsa yardımcı olabilir mi? Normalde hemen amortsörün arkasından sokmuştum kabloyu şimdi benim orada delik yok.]]>
   </description>
   <pubDate>Sun, 09 Aug 2015 16:40:58 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=40117&amp;PID=549736&amp;title=amfi-guc-kablosu-yardim#549736</guid>
  </item>
 </channel>
</rss>
