 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 307 ses sistemi</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Peugeot Ses Sistemleri : 307 ses sistemi]]></description>
  <pubDate>Sat, 02 May 2026 09:39:38 +0000</pubDate>
  <lastBuildDate>Tue, 13 Jan 2015 17:34:37 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=38000</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[307 ses sistemi : eyvallah karde&#351;im goldmaster buldum...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=38000&amp;PID=531330&amp;title=307-ses-sistemi#531330</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13197">hakan574</a><br /><strong>Konu:</strong> 38000<br /><strong>Gönderim Zamanı:</strong> 13&nbsp;Ocak&nbsp;2015 Saat 17:34<br /><br />eyvallah kardeşim goldmaster buldum 500 watt lık birde 2000 watt anfi var onları alacam 125 tl ye bitirdik. tabiki ikinci el ama tertemiz tanıdıktan alıyorum. hoparlörler sıfır alacam.]]>
   </description>
   <pubDate>Tue, 13 Jan 2015 17:34:37 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=38000&amp;PID=531330&amp;title=307-ses-sistemi#531330</guid>
  </item>
  <item>
   <title><![CDATA[307 ses sistemi :   hakan574 Yazd&#305;:verdi&#287;in bilgi...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=38000&amp;PID=531328&amp;title=307-ses-sistemi#531328</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10471">korkusuz202</a><br /><strong>Konu:</strong> 38000<br /><strong>Gönderim Zamanı:</strong> 13&nbsp;Ocak&nbsp;2015 Saat 17:12<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: hakan574" alt="Orjinalini yazan: hakan574" style="vertical-align: text-bottom;" /> <strong>hakan574 Yazdı:</strong><br /><br />verdiğin bilgi için çok teşekkür ederim kardeşim ama sanırım arkalar 70 watt oluyor. 300 watlık taksak sorun olurmu asıl düşüncem bu.<div><br></div></td></tr></table><br><br>amfin varsa tak..Sadece teyp var ise 1000 lik te taksan bişey değişmez<br>birde 30 tl ye bulduğun markalar kalitesizdir.(navtech,piranha vb)Bir kaç ay sonra elinde kalır.jbl,pionner,sony,kenwood bu markalar seni üzmez.Her hoparlörde 300 watt yazanada inanma..<br>]]>
   </description>
   <pubDate>Tue, 13 Jan 2015 17:12:59 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=38000&amp;PID=531328&amp;title=307-ses-sistemi#531328</guid>
  </item>
  <item>
   <title><![CDATA[307 ses sistemi : verdi&#287;in bilgi i&#231;in &#231;ok te&#351;ekk&#252;r...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=38000&amp;PID=531323&amp;title=307-ses-sistemi#531323</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13197">hakan574</a><br /><strong>Konu:</strong> 38000<br /><strong>Gönderim Zamanı:</strong> 13&nbsp;Ocak&nbsp;2015 Saat 16:39<br /><br />verdiğin bilgi için çok teşekkür ederim kardeşim ama sanırım arkalar 70 watt oluyor. 300 watlık taksak sorun olurmu asıl düşüncem bu.<div><br></div>]]>
   </description>
   <pubDate>Tue, 13 Jan 2015 16:39:21 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=38000&amp;PID=531323&amp;title=307-ses-sistemi#531323</guid>
  </item>
  <item>
   <title><![CDATA[307 ses sistemi : Merhabalar bizim ara&#231;larda &#246;nler...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=38000&amp;PID=531322&amp;title=307-ses-sistemi#531322</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=15083">Özel6521</a><br /><strong>Konu:</strong> 38000<br /><strong>Gönderim Zamanı:</strong> 13&nbsp;Ocak&nbsp;2015 Saat 16:35<br /><br />Merhabalar bizim araçlarda önler 16 cm arkalar 13 cm olarak biliyorum. ben yaptırırken arkalarada 16 lık aldım kesmeden biçmeden taktık onları şuan için bi sıkıntı yok.&nbsp;<h1 style="margin-right: 0px; margin-left: 0px; padding: 15px 0px 12px; height: 18px; max-width: 710px; white-space: nowrap; text-overflow: ellipsis; line-height: normal;"><font face="Arial, Helvetica, sans-serif" size="2">JBL GTO 6508C 16CM COMPENANT</font></h1><div><str&#111;ng style="color: rgb24, 24, 37; line-height: normal; text-align: center;"><font face="Arial, Helvetica, sans-serif" size="2">Power Handling, RMS 70 Watts<br>Power Handling, Peak 210 Watts<br>Frequency Response (±3dB) 50Hz – 21kHz<br>Sensitivity 92dB<br>Mounting Depth 59mm Midwoofer, 19mm tweeter&nbsp;<br>Cutout Diameter 145mm Midwoofer, 48mm tweeter&nbsp;<br>Impedance 2 Ohms&nbsp;</font></strong></div><div><str&#111;ng style="color: rgb24, 24, 37; line-height: normal; text-align: center;"><font face="Arial, Helvetica, sans-serif" size="2"><br></font></strong></div><div><str&#111;ng style="color: rgb24, 24, 37; line-height: normal; text-align: center;"><font face="Arial, Helvetica, sans-serif" size="2">Özellikleri böyleymiş</font></strong></div><div><str&#111;ng style="color: rgb24, 24, 37; line-height: normal; text-align: center;"><font face="Arial, Helvetica, sans-serif" size="2">Orjinal çıkışını falan bilmiyorum ama</font></strong></div>]]>
   </description>
   <pubDate>Tue, 13 Jan 2015 16:35:00 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=38000&amp;PID=531322&amp;title=307-ses-sistemi#531322</guid>
  </item>
  <item>
   <title><![CDATA[307 ses sistemi : merhaba arkada&#351;lar arka kap&#305; hoparl&#246;r&#252;m...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=38000&amp;PID=531317&amp;title=307-ses-sistemi#531317</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13197">hakan574</a><br /><strong>Konu:</strong> 38000<br /><strong>Gönderim Zamanı:</strong> 13&nbsp;Ocak&nbsp;2015 Saat 16:18<br /><br />merhaba arkadaşlar arka kapı hoparlörüm patlak ve dğiştirecem ama 2 tane hoparlöre 100-150 lira fiyat istiyorlar. ben internetten 30 tl ye buldum ve 300 watlık. orjinali kaç wat, ölçüsü nedir ve 300 watlık takarsam olurmu bilgisi olan yardımcı olursa sevinirim. bu arada double teyp var kaç watlık çıkışı var bilmiyorum]]>
   </description>
   <pubDate>Tue, 13 Jan 2015 16:18:07 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=38000&amp;PID=531317&amp;title=307-ses-sistemi#531317</guid>
  </item>
 </channel>
</rss>
