 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Motor ariza lambasi</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Arac&#305;n&#305;z Hakk&#305;ndaki T&#252;m Sorular : Motor ariza lambasi]]></description>
  <pubDate>Mon, 04 May 2026 12:41:27 +0000</pubDate>
  <lastBuildDate>Sat, 10 Jan 2015 16:07:05 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=37943</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Motor ariza lambasi : Lpg li deyil aracim 206 HD&#304; 1.4...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=37943&amp;PID=530955&amp;title=motor-ariza-lambasi#530955</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=14865">Dewil1606</a><br /><strong>Konu:</strong> 37943<br /><strong>Gönderim Zamanı:</strong> 10&nbsp;Ocak&nbsp;2015 Saat 16:07<br /><br />Lpg li deyil aracim 206 HDİ 1.4 sanirim mazot gitmeyince yakiyor ariza lambasini surekli bununlami ugrascam cozemedim]]>
   </description>
   <pubDate>Sat, 10 Jan 2015 16:07:05 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=37943&amp;PID=530955&amp;title=motor-ariza-lambasi#530955</guid>
  </item>
  <item>
   <title><![CDATA[Motor ariza lambasi : Baglat bak ne arizasi var.yoksa...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=37943&amp;PID=530954&amp;title=motor-ariza-lambasi#530954</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=5538">sezar206</a><br /><strong>Konu:</strong> 37943<br /><strong>Gönderim Zamanı:</strong> 10&nbsp;Ocak&nbsp;2015 Saat 15:38<br /><br />Baglat bak ne arizasi var.yoksa sondur yine yanarsa ona gore bak. Lpg varsa arda yakar normal]]>
   </description>
   <pubDate>Sat, 10 Jan 2015 15:38:55 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=37943&amp;PID=530954&amp;title=motor-ariza-lambasi#530954</guid>
  </item>
  <item>
   <title><![CDATA[Motor ariza lambasi : Arkadaslar merhaba yaklasik 3...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=37943&amp;PID=530937&amp;title=motor-ariza-lambasi#530937</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=14865">Dewil1606</a><br /><strong>Konu:</strong> 37943<br /><strong>Gönderim Zamanı:</strong> 10&nbsp;Ocak&nbsp;2015 Saat 10:52<br /><br />Arkadaslar merhaba yaklasik 3 ay once yakit hortumunda delik vardi ve hava aliyordu sorunu giderdik fakat sabah aracimi calistirdim isinsin die beklerken stopetti tekrar calistirdigimda motor ariza lambasi yandi sorun ne olabilir? Bilgisayara baglatip sildirsem sorun cozulurmu???]]>
   </description>
   <pubDate>Sat, 10 Jan 2015 10:52:01 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=37943&amp;PID=530937&amp;title=motor-ariza-lambasi#530937</guid>
  </item>
 </channel>
</rss>
