 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : no sorun</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Arac&#305;n&#305;z Hakk&#305;ndaki T&#252;m Sorular : no sorun]]></description>
  <pubDate>Mon, 04 May 2026 09:46:11 +0000</pubDate>
  <lastBuildDate>Fri, 31 Oct 2014 10:26:31 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=37160</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[no sorun : Hepsi yeni 10 bin oldu ve ge&#231;en...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=37160&amp;PID=524595&amp;title=no-sorun#524595</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=12875">pekmez006</a><br /><strong>Konu:</strong> 37160<br /><strong>Gönderim Zamanı:</strong> 31&nbsp;Ekim&nbsp;2014 Saat 10:26<br /><br />Hepsi yeni 10 bin oldu ve geçen hafta baktırsım iyi rölanti valfine bakılmadı]]>
   </description>
   <pubDate>Fri, 31 Oct 2014 10:26:31 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=37160&amp;PID=524595&amp;title=no-sorun#524595</guid>
  </item>
  <item>
   <title><![CDATA[no sorun : Bujiler ne durumda? ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=37160&amp;PID=524590&amp;title=no-sorun#524590</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11113">pusutr</a><br /><strong>Konu:</strong> 37160<br /><strong>Gönderim Zamanı:</strong> 31&nbsp;Ekim&nbsp;2014 Saat 09:22<br /><br />Bujiler ne durumda?<br>]]>
   </description>
   <pubDate>Fri, 31 Oct 2014 09:22:26 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=37160&amp;PID=524590&amp;title=no-sorun#524590</guid>
  </item>
  <item>
   <title><![CDATA[no sorun : oksijen sens&#246;r&#252;nden yap&#305;yo , bence...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=37160&amp;PID=524573&amp;title=no-sorun#524573</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9850">Ahmet_ach</a><br /><strong>Konu:</strong> 37160<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Ekim&nbsp;2014 Saat 20:06<br /><br />oksijen sensöründen yapıyo , bence beyni sıfırla tekrar dene akü kutup basını sök araçtaki tüm elektriği cıkarmak için frene birkaç defa bas 5 dak sonra kutup basını önce eksi sonra artı olarak tak belki düzelir<br>]]>
   </description>
   <pubDate>Thu, 30 Oct 2014 20:06:25 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=37160&amp;PID=524573&amp;title=no-sorun#524573</guid>
  </item>
  <item>
   <title><![CDATA[no sorun : Kalibrasyon da yap&#305;ld&#305; ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=37160&amp;PID=524563&amp;title=no-sorun#524563</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=12875">pekmez006</a><br /><strong>Konu:</strong> 37160<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Ekim&nbsp;2014 Saat 17:52<br /><br />Kalibrasyon da yapıldı ]]>
   </description>
   <pubDate>Thu, 30 Oct 2014 17:52:50 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=37160&amp;PID=524563&amp;title=no-sorun#524563</guid>
  </item>
  <item>
   <title><![CDATA[no sorun :  subap ayarlar&#305;na bi bakt&#305;r,...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=37160&amp;PID=524558&amp;title=no-sorun#524558</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13505">CrimsonChild</a><br /><strong>Konu:</strong> 37160<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Ekim&nbsp;2014 Saat 15:56<br /><br />subap ayarlarına bi baktır, Lpg de düzenin çok hassas olması lazım bobin uçlarının birinde bile çatlak ya da bi hasar varsa o da sorun yaratır bilgin olsun, başıma gelmiş bişey :)]]>
   </description>
   <pubDate>Thu, 30 Oct 2014 15:56:06 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=37160&amp;PID=524558&amp;title=no-sorun#524558</guid>
  </item>
  <item>
   <title><![CDATA[no sorun : bo&#287;az kelebe&#287;i temizlendikten...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=37160&amp;PID=524552&amp;title=no-sorun#524552</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3690">berk2309</a><br /><strong>Konu:</strong> 37160<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Ekim&nbsp;2014 Saat 15:25<br /><br />boğaz kelebeği temizlendikten sonra kalibrasyonu yapıldımı temizlendikten sonra]]>
   </description>
   <pubDate>Thu, 30 Oct 2014 15:25:57 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=37160&amp;PID=524552&amp;title=no-sorun#524552</guid>
  </item>
  <item>
   <title><![CDATA[no sorun : 2003 model 1.6 benzinli araca...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=37160&amp;PID=524550&amp;title=no-sorun#524550</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=12875">pekmez006</a><br /><strong>Konu:</strong> 37160<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Ekim&nbsp;2014 Saat 15:20<br /><br />2003 model 1.6 benzinli araca lpg yi ben takdırtım lovato ve obd kiti taktırdım lpg den arıza lamba yakması % 0 dan biraz fazla. lpg ayarı yapıldı boğaz kelebeği temizlendi ilk çalıştırmadada yapıyor trafiktede yapıyor.]]>
   </description>
   <pubDate>Thu, 30 Oct 2014 15:20:45 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=37160&amp;PID=524550&amp;title=no-sorun#524550</guid>
  </item>
  <item>
   <title><![CDATA[no sorun :  Ara&#231; marka modelini, arac&#305;n...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=37160&amp;PID=524539&amp;title=no-sorun#524539</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13505">CrimsonChild</a><br /><strong>Konu:</strong> 37160<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Ekim&nbsp;2014 Saat 13:57<br /><br />Araç marka modelini, aracın LPGli mi benzinli mi dizel&nbsp;mi olduğunu, lpg ise gaz ayarının en son ne zaman yapıldığını, araç ilk çalıştığında mı yoksa&nbsp;trafikte beklemede mi bu sorunu yapıyor ? &nbsp;Bunları cevaplayabilirsen yardım acısından daha net cevaplar alırsınız.]]>
   </description>
   <pubDate>Thu, 30 Oct 2014 13:57:05 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=37160&amp;PID=524539&amp;title=no-sorun#524539</guid>
  </item>
  <item>
   <title><![CDATA[no sorun : halloldu D&#252;zenleyen pekmez006...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=37160&amp;PID=524527&amp;title=no-sorun#524527</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=12875">pekmez006</a><br /><strong>Konu:</strong> 37160<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Ekim&nbsp;2014 Saat 12:07<br /><br />halloldu<span style="font-size:10px"><br /><br />Düzenleyen pekmez006 - 28&nbsp;Temmuz&nbsp;2015 Saat 18:05</span>]]>
   </description>
   <pubDate>Thu, 30 Oct 2014 12:07:12 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=37160&amp;PID=524527&amp;title=no-sorun#524527</guid>
  </item>
 </channel>
</rss>
