 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 206 CC TAVAN SORUNU</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 206 : 206 CC TAVAN SORUNU]]></description>
  <pubDate>Mon, 04 May 2026 18:07:32 +0000</pubDate>
  <lastBuildDate>Sat, 14 Nov 2015 11:04:08 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=36602</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[206 CC TAVAN SORUNU : &#304;yi g&#252;nler ayn&#305; sorun benim arac&#305;mda...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=36602&amp;PID=553609&amp;title=206-cc-tavan-sorunu#553609</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16933">alperen1414</a><br /><strong>Konu:</strong> 36602<br /><strong>Gönderim Zamanı:</strong> 14&nbsp;Kasım&nbsp;2015 Saat 11:04<br /><br />İyi günler aynı sorun benim aracımda da var. Sorunu çözdünüz mü acaba?]]>
   </description>
   <pubDate>Sat, 14 Nov 2015 11:04:08 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=36602&amp;PID=553609&amp;title=206-cc-tavan-sorunu#553609</guid>
  </item>
  <item>
   <title><![CDATA[206 CC TAVAN SORUNU : &#304;yi g&#252;nler benim arac&#305;mda da ayn&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=36602&amp;PID=553608&amp;title=206-cc-tavan-sorunu#553608</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16933">alperen1414</a><br /><strong>Konu:</strong> 36602<br /><strong>Gönderim Zamanı:</strong> 14&nbsp;Kasım&nbsp;2015 Saat 11:03<br /><br />İyi günler benim aracımda da aynı sorun var. Sorunu çözdünüz mü?]]>
   </description>
   <pubDate>Sat, 14 Nov 2015 11:03:29 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=36602&amp;PID=553608&amp;title=206-cc-tavan-sorunu#553608</guid>
  </item>
  <item>
   <title><![CDATA[206 CC TAVAN SORUNU :   herry Yazd&#305;:&#246;ncelikle aram&#305;za...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=36602&amp;PID=520851&amp;title=206-cc-tavan-sorunu#520851</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=14679">Ceasmert</a><br /><strong>Konu:</strong> 36602<br /><strong>Gönderim Zamanı:</strong> 12&nbsp;Eylül&nbsp;2014 Saat 20:50<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: herry" alt="Orjinalini yazan: herry" style="vertical-align: text-bottom;" /> <strong>herry Yazdı:</strong><br /><br />öncelikle aramıza hosgeldin ve gecmis olsun.<br><br>sorununu anladım, sistemin nasıl isledigini iyi bilirim. eksik bir islem var, o yuzden cam kapatma acma moduna gecemiyorsun. bip sesi de eksik islem oldugundan, hareket etme henuz ust açma islemi sona ermemisti diyor sana. camlari zorlama sakın. özellikle arka kelebeklerin motorunu kırdın mı bittin demektir. yok cunku oyle bir parca bizim ülkede. sorun tamamen bagaj sistemi ile alakalı. ilk planda kapalı bir garaja park etmeni tavsiye ederim. <br>&nbsp;<br>hangi sehirdesin?<br></td></tr></table><br><br><span style="line-height: 16.7999992370605px;">İstanbulda oturuyorum araçı o şekilde kullandım bir kaç gün. Şuan sitenin garajında duruyor. Ve hala o bip bip sesi geliyor. Ustaya götürmüştük üstü acılığ kapanmıyordu güçü yarıda kesiyordu. yağsı bitmiş dediler yağ doldurdular. Aynı sorun tekrar olursa koltuklara kadar söküp bakıcaz demişlerdi bende korkuyorum büyük masraf çıkartırlar diye. Benim tek sorunum üstü acmak istediğimde camların acılmaması ve o bip sesinin gelmemesi. Onun haricinde tavan sorunsuz bir şekilde acılıyor.</span>]]>
   </description>
   <pubDate>Fri, 12 Sep 2014 20:50:05 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=36602&amp;PID=520851&amp;title=206-cc-tavan-sorunu#520851</guid>
  </item>
  <item>
   <title><![CDATA[206 CC TAVAN SORUNU : &#304;stanbulda oturuyorum ara&#231;&#305; o...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=36602&amp;PID=520831&amp;title=206-cc-tavan-sorunu#520831</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=14679">Ceasmert</a><br /><strong>Konu:</strong> 36602<br /><strong>Gönderim Zamanı:</strong> 12&nbsp;Eylül&nbsp;2014 Saat 16:44<br /><br />İstanbulda oturuyorum araçı o şekilde kullandım bir kaç gün. Şuan sitenin garajında duruyor. Ve hala o bip bip sesi geliyor. Ustaya götürmüştük üstü acılığ kapanmıyordu güçü yarıda kesiyordu. yağsı bitmiş dediler yağ doldurdular. Aynı sorun tekrar olursa koltuklara kadar söküp bakıcaz demişlerdi bende korkuyorum büyük masraf çıkartırlar diye. Benim tek sorunum üstü acmak istediğimde camların acılmaması ve o bip sesinin gelmemesi. Onun haricinde tavan sorunsuz bir şekilde acılıyor.]]>
   </description>
   <pubDate>Fri, 12 Sep 2014 16:44:59 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=36602&amp;PID=520831&amp;title=206-cc-tavan-sorunu#520831</guid>
  </item>
  <item>
   <title><![CDATA[206 CC TAVAN SORUNU : &#246;ncelikle aram&#305;za hosgeldin ve...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=36602&amp;PID=520175&amp;title=206-cc-tavan-sorunu#520175</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=4635">herry</a><br /><strong>Konu:</strong> 36602<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Eylül&nbsp;2014 Saat 21:48<br /><br />öncelikle aramıza hosgeldin ve gecmis olsun.<br><br>sorununu anladım, sistemin nasıl isledigini iyi bilirim. eksik bir islem var, o yuzden cam kapatma acma moduna gecemiyorsun. bip sesi de eksik islem oldugundan, hareket etme henuz ust açma islemi sona ermemisti diyor sana. camlari zorlama sakın. özellikle arka kelebeklerin motorunu kırdın mı bittin demektir. yok cunku oyle bir parca bizim ülkede. sorun tamamen bagaj sistemi ile alakalı. ilk planda kapalı bir garaja park etmeni tavsiye ederim. <br>&nbsp;<br>hangi sehirdesin?<br><span style="font-size:10px"><br /><br />Düzenleyen herry - 06&nbsp;Eylül&nbsp;2014 Saat 22:12</span>]]>
   </description>
   <pubDate>Sat, 06 Sep 2014 21:48:41 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=36602&amp;PID=520175&amp;title=206-cc-tavan-sorunu#520175</guid>
  </item>
  <item>
   <title><![CDATA[206 CC TAVAN SORUNU : &#214;ncelikle herkese merhaba ben...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=36602&amp;PID=520171&amp;title=206-cc-tavan-sorunu#520171</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=14679">Ceasmert</a><br /><strong>Konu:</strong> 36602<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Eylül&nbsp;2014 Saat 19:10<br /><br />Öncelikle herkese merhaba ben aranıza yeni katıldım 21 yaşındayım üniversite öğrenciyim. Arabam 206 cc Roland Garros modeli. 2005 model Otomatik vites.<br><br>Sorunum şu daha dün üstü açık geziyordum hiç bir sıkıntım yoktu uyarı sesi yada herhangi bir uyarı sesi yoktu. Fakat bugün arabayı garajdan aldım susmak bilmeyen bi uyarı sesi. Sonra üstünü açmayı denedim mandalları indirdim üstü açıldı fakat camları açmadan üstü açtı. Normalde mandalı açınca tuşa bastığımda ilk camları acıyordu sonra üstü acıyordu. Üstü açıldığı zaman camları ne kapatabiliyorum nede açabiliyorum uyarı sesi sürekli devam ediyo. Ve cam yüzünden arabanın üstü kapanmıyo açık kalıyor. Bunun sebebi nedir bilen abilerim var mı acaba yardımcı olursanız çok sevinirim. Daha arabayı alalı 2 ay olmadı ..&nbsp;<img src="https://forum.peugeotturkey.com/smileys/smiley19.gif" border="0" alt="Cry" title="Cry" /><img src="https://forum.peugeotturkey.com/smileys/smiley19.gif" border="0" alt="Cry" title="Cry" /><img src="https://forum.peugeotturkey.com/smileys/smiley19.gif" border="0" alt="Cry" title="Cry" />]]>
   </description>
   <pubDate>Sat, 06 Sep 2014 19:10:35 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=36602&amp;PID=520171&amp;title=206-cc-tavan-sorunu#520171</guid>
  </item>
 </channel>
</rss>
