 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Marş Basmama Sorunu ÇÖZÜLMEMİŞ</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 307 : Marş Basmama Sorunu ÇÖZÜLMEMİŞ]]></description>
  <pubDate>Mon, 04 May 2026 21:51:48 +0000</pubDate>
  <lastBuildDate>Tue, 07 Oct 2014 04:52:40 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=36039</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Marş Basmama Sorunu ÇÖZÜLMEMİŞ : Arkadaslar motor sicakken kapatip...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=36039&amp;PID=522823&amp;title=mars-basmama-sorunu-cozulmemis#522823</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13592">suppor</a><br /><strong>Konu:</strong> 36039<br /><strong>Gönderim Zamanı:</strong> 07&nbsp;Ekim&nbsp;2014 Saat 04:52<br /><br />Arkadaslar motor sicakken kapatip bida mars bastiginizda tik ditip kaliyosa mars otomatigidir ve komurleride degistirin acmisken iscilik dogru istiyolar bende 75 vermistim 100 mars otomatigi 20 de komurler aklinizda olsun]]>
   </description>
   <pubDate>Tue, 07 Oct 2014 04:52:40 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=36039&amp;PID=522823&amp;title=mars-basmama-sorunu-cozulmemis#522823</guid>
  </item>
  <item>
   <title><![CDATA[Marş Basmama Sorunu ÇÖZÜLMEMİŞ : Evet sorun bendix di&#351;lisinde imi&#351;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=36039&amp;PID=522805&amp;title=mars-basmama-sorunu-cozulmemis#522805</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11520">MertMurat</a><br /><strong>Konu:</strong> 36039<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Ekim&nbsp;2014 Saat 21:30<br /><br />Evet sorun bendix dişlisinde imiş oda elimde fazladan oldugundan masrafsiz hallettik.<br>Öte yandan köllektör de heran arıza cıkartacaktı o da arada değişmiş oldu.<br>Sorun çözüldü<br>]]>
   </description>
   <pubDate>Mon, 06 Oct 2014 21:30:48 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=36039&amp;PID=522805&amp;title=mars-basmama-sorunu-cozulmemis#522805</guid>
  </item>
  <item>
   <title><![CDATA[Marş Basmama Sorunu ÇÖZÜLMEMİŞ : &#350;u 1:http://forum.peugeotturke...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=36039&amp;PID=516128&amp;title=mars-basmama-sorunu-cozulmemis#516128</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11281">ahmed206</a><br /><strong>Konu:</strong> 36039<br /><strong>Gönderim Zamanı:</strong> 20&nbsp;Temmuz&nbsp;2014 Saat 16:09<br /><br />Şu 1:<div><a href="http://forum.peugeotturkey.com/forum_posts.asp?TID=15474" rel="nofollow">http://forum.peugeotturkey.com/forum_posts.asp?TID=15474</a></div><div><br></div><div>Şu 2:</div><div><a href="http://www.teamdoblo.com/forum/viewthread.php?thread_id=6537&amp;rowstart=20" target="_blank" rel="nofollow">tıkla</a></div><div><br></div><div>Şu da 3:</div><div><a href="http://forum.d&#111;nanimhaber.com/m_37760681/tm.htm" target="_blank" rel="nofollow">buna kesin bak</a></div><div><br></div><div>3. linkteki son mesajı buraya kopyalıyorum.</div><div><br></div><div>"<span style="font-size: 12.800000190734863px; line-height: normal; : rgb241, 241, 241;"><i>Uzun zaman geçmis ama simdileri basina gelen arkadaşlar içinrehber olsun ddiye yaziyorum. Araç lpglibise sorun LPG regülatörü. Regülatör gazibkesmiyor ve manifolu gazla dolduruyor ve calistirmada motoru boğuyor. LPG regülatör beyni değişimi sonuç veriyor.</i>"</span></div><div><span style="font-size: 12.800000190734863px; line-height: normal; : rgb241, 241, 241;"><br></span></div><div><span style="font-size: 12.800000190734863px; line-height: normal; : rgb241, 241, 241;">Herkes farklı çözümler sunmuş hangisi uyar bilmiyorum. Tekrar geçmiş olsun.</span></div>]]>
   </description>
   <pubDate>Sun, 20 Jul 2014 16:09:31 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=36039&amp;PID=516128&amp;title=mars-basmama-sorunu-cozulmemis#516128</guid>
  </item>
  <item>
   <title><![CDATA[Marş Basmama Sorunu ÇÖZÜLMEMİŞ : Arkadaslar motor &#305;s&#305;n&#305;nca mar&#351;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=36039&amp;PID=516124&amp;title=mars-basmama-sorunu-cozulmemis#516124</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11520">MertMurat</a><br /><strong>Konu:</strong> 36039<br /><strong>Gönderim Zamanı:</strong> 20&nbsp;Temmuz&nbsp;2014 Saat 15:08<br /><br />Arkadaslar motor ısınınca marş artık basmıyor tık edip kalıyor&nbsp;<div>en kısa zamanda tamirciye götürüp baktırcam sonucu paylaşırım ancak önerisi olan arkadaslar varmı&nbsp;</div><div>röleden olabilir diye düşünüyorum</div>]]>
   </description>
   <pubDate>Sun, 20 Jul 2014 15:08:13 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=36039&amp;PID=516124&amp;title=mars-basmama-sorunu-cozulmemis#516124</guid>
  </item>
  <item>
   <title><![CDATA[Marş Basmama Sorunu ÇÖZÜLMEMİŞ : gecmi&#351; olsun dostum. bazen durduk...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=36039&amp;PID=515603&amp;title=mars-basmama-sorunu-cozulmemis#515603</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13995">okaNStarss</a><br /><strong>Konu:</strong> 36039<br /><strong>Gönderim Zamanı:</strong> 16&nbsp;Temmuz&nbsp;2014 Saat 09:47<br /><br />gecmiş olsun dostum. bazen durduk yere şemsiye oluyor işte :)<span style="font-size:10px"><br /><br />Düzenleyen okaNStarss - 16&nbsp;Temmuz&nbsp;2014 Saat 09:47</span>]]>
   </description>
   <pubDate>Wed, 16 Jul 2014 09:47:14 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=36039&amp;PID=515603&amp;title=mars-basmama-sorunu-cozulmemis#515603</guid>
  </item>
  <item>
   <title><![CDATA[Marş Basmama Sorunu ÇÖZÜLMEMİŞ : ayn&#305;s&#305; benimde ba&#351;&#305;ma gelmi&#351;ti...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=36039&amp;PID=515581&amp;title=mars-basmama-sorunu-cozulmemis#515581</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=12865">emrah_388</a><br /><strong>Konu:</strong> 36039<br /><strong>Gönderim Zamanı:</strong> 16&nbsp;Temmuz&nbsp;2014 Saat 02:00<br /><br />aynısı benimde başıma gelmişti hem 206 da hem 307 de kafasına esince marş basıyordu tesadüfe bakarsak iki aracımda bakımdan çıktıktan sonra bu sorun olmuştu 206 da para vermemiştim serviste sorun başladı diye ama 307 de yemedi 120 tl vermiştim demekki sorun seninki ile aynıymış]]>
   </description>
   <pubDate>Wed, 16 Jul 2014 02:00:28 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=36039&amp;PID=515581&amp;title=mars-basmama-sorunu-cozulmemis#515581</guid>
  </item>
  <item>
   <title><![CDATA[Marş Basmama Sorunu ÇÖZÜLMEMİŞ : 50 liraya g&#252;zel bir lokma tak&#305;m&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=36039&amp;PID=515579&amp;title=mars-basmama-sorunu-cozulmemis#515579</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11281">ahmed206</a><br /><strong>Konu:</strong> 36039<br /><strong>Gönderim Zamanı:</strong> 16&nbsp;Temmuz&nbsp;2014 Saat 01:54<br /><br />50 liraya güzel bir lokma takımı alınır haa :)]]>
   </description>
   <pubDate>Wed, 16 Jul 2014 01:54:50 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=36039&amp;PID=515579&amp;title=mars-basmama-sorunu-cozulmemis#515579</guid>
  </item>
  <item>
   <title><![CDATA[Marş Basmama Sorunu ÇÖZÜLMEMİŞ : Ge&#231;mi&#351; olsun, otomatik arabada...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=36039&amp;PID=515558&amp;title=mars-basmama-sorunu-cozulmemis#515558</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9585">Serkan</a><br /><strong>Konu:</strong> 36039<br /><strong>Gönderim Zamanı:</strong> 16&nbsp;Temmuz&nbsp;2014 Saat 00:52<br /><br />Geçmiş olsun, otomatik arabada marş ve akü çok önemli malûm vurdurma şansı yok, araçta mutaka akü takviye kablosu da bulundurmak lazım.]]>
   </description>
   <pubDate>Wed, 16 Jul 2014 00:52:58 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=36039&amp;PID=515558&amp;title=mars-basmama-sorunu-cozulmemis#515558</guid>
  </item>
  <item>
   <title><![CDATA[Marş Basmama Sorunu ÇÖZÜLMEMİŞ : Merhaba arkadaslar Muayene yapt&#305;r&#305;rken...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=36039&amp;PID=515551&amp;title=mars-basmama-sorunu-cozulmemis#515551</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11520">MertMurat</a><br /><strong>Konu:</strong> 36039<br /><strong>Gönderim Zamanı:</strong> 16&nbsp;Temmuz&nbsp;2014 Saat 00:41<br /><br />Merhaba arkadaslar <br>Muayene yaptırırken tesaduf ilgilenen arkadas da forumdan cıktı ve otomatik 307 si varmış yani benimkinin aynısı<br>Bir sürü tavsiyelerde bulundu ve bak bu cok önemli hemen yaptır olmadık yerde kalırsın dedi veeee<br>harbiden olmadık yerde kaldım. Sultanahmette park yeri ararken ara sokakların birinde&nbsp; yer buldum park ettim sonra fark ettim ki dar sokak ve az daha kaldırma cıkmam gerek marşa bi bastım ki o da ne tık ses geliyor marş basmıyor aku sağlam ahaaa dedim gitti marş otomatiği neyse dedim iftarı açayım ilgilenirim.<br>1 saat sonra geri geldim tek marşta arbaa çalıştı ertesi gunde sorun yok sonraki de sorun yok ama ben gittim bi elektrikçiye durumu anlattım adam sökelim bakalım ya kömürdür ya baska şey dedi<br>Söktü marş motorunu kömürler sağlam<br>köllektörü cıkarttı ki 2 tel kopuk işte bu dedi kömürler buraya denk geldiginde çalışmaz dedi nasıl yani dedim usta geri topladı akuye taktı kopuk yeri kömüre denk getirdi motor dönmüyor az cevirdi ve motor çalıştı.<br>Bunu değişmemiz lazım dedi nerden buluruz şurdan önce netten fiyatına baktım 40 tl yazıyor parçacıya gittim 50 tl dedi mecbur aldım<br>usta takıtı topladı kaç para işcilik vercez dedim 70 tl demesinmi <br>neyse zor bela 50 ye anlaştık <br>uzun lafın kısası durduk yere 100 tl girdi <br>bu olmasada kömürden olsada&nbsp; yine bu kadar işcilik alırdım dedi <br>sökmesi baya sıkıntılı bir parça falan dedi hee hee dedim gectim.<br><span style="font-size:10px"><br /><br />Düzenleyen MertMurat - 20&nbsp;Temmuz&nbsp;2014 Saat 15:05</span>]]>
   </description>
   <pubDate>Wed, 16 Jul 2014 00:41:14 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=36039&amp;PID=515551&amp;title=mars-basmama-sorunu-cozulmemis#515551</guid>
  </item>
 </channel>
</rss>
