 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 206 2. Vites tekleme</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 206 : 206 2. Vites tekleme]]></description>
  <pubDate>Mon, 04 May 2026 16:24:13 +0000</pubDate>
  <lastBuildDate>Thu, 29 May 2014 13:40:09 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=35317</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[206 2. Vites tekleme : hadi hay&#305;rl&#305;s&#305; in&#351; bir daha denk...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508699&amp;title=206-2-vites-tekleme#508699</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13961">popeyes</a><br /><strong>Konu:</strong> 35317<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Mayıs&nbsp;2014 Saat 13:40<br /><br />hadi hayırlısı inş bir daha denk gelmez]]>
   </description>
   <pubDate>Thu, 29 May 2014 13:40:09 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508699&amp;title=206-2-vites-tekleme#508699</guid>
  </item>
  <item>
   <title><![CDATA[206 2. Vites tekleme : sorunu &#231;&#246;zd&#252;k bujilerdenmi&#351; ate&#351;leme...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508698&amp;title=206-2-vites-tekleme#508698</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=14034">Bysekowest</a><br /><strong>Konu:</strong> 35317<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Mayıs&nbsp;2014 Saat 13:37<br /><br />sorunu çözdük bujilerdenmiş ateşleme bobini yeni değişmişti zaten şimdide bujileri değiştirdim sıntısı yok şimdilirk.]]>
   </description>
   <pubDate>Thu, 29 May 2014 13:37:26 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508698&amp;title=206-2-vites-tekleme#508698</guid>
  </item>
  <item>
   <title><![CDATA[206 2. Vites tekleme : Ne zamand&#305;r sorunsuz peki? GM...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508657&amp;title=206-2-vites-tekleme#508657</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11281">ahmed206</a><br /><strong>Konu:</strong> 35317<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Mayıs&nbsp;2014 Saat 12:52<br /><br />Ne zamandır sorunsuz peki? GM logolu olan da arıza çıkarabilir mi acaba?]]>
   </description>
   <pubDate>Thu, 29 May 2014 12:52:46 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508657&amp;title=206-2-vites-tekleme#508657</guid>
  </item>
  <item>
   <title><![CDATA[206 2. Vites tekleme : sorunun %90 bobin.bende vectra...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508606&amp;title=206-2-vites-tekleme#508606</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13905">fætih</a><br /><strong>Konu:</strong> 35317<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Mayıs&nbsp;2014 Saat 09:30<br /><br />sorunun %90 bobin.&nbsp;<div>bende vectra c var. aynı sorun ondada var bobini değiştirdim düzeldi. orjinal takmadım ilkinde hatta gm logosu olmayan delphi marka bobini bile yedi. şimdi gm logolu delphi taktım sorunsuz devam.</div><div><br></div>]]>
   </description>
   <pubDate>Thu, 29 May 2014 09:30:43 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508606&amp;title=206-2-vites-tekleme#508606</guid>
  </item>
  <item>
   <title><![CDATA[206 2. Vites tekleme : 2. viteste ara&#231; m&#305; kald&#305;r&#305;l&#305;r....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508601&amp;title=206-2-vites-tekleme#508601</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13961">popeyes</a><br /><strong>Konu:</strong> 35317<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Mayıs&nbsp;2014 Saat 09:18<br /><br />2. viteste araç mı kaldırılır. zaten sebebi belli benzinin gücü fazla olduğu için o teklemeyi yaptırmıyor. LPG'nin gücü yetmediği için de tekletiyor. ayrıca lpg li araçlarda yokuş çıkarken benzin gibi düşünmeyin gazı biraz kökleyn araç biraz gaz yesin. &nbsp;ayrıca birde dediğim şekilde deneme yapın 2. viteste gazı kökleyince tekleme yapıyor mu bi bakın yapmıyorsa yola devam]]>
   </description>
   <pubDate>Thu, 29 May 2014 09:18:20 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508601&amp;title=206-2-vites-tekleme#508601</guid>
  </item>
  <item>
   <title><![CDATA[206 2. Vites tekleme : Rampa a&#351;a&#287;&#305; demedi&#287;iniz i&#231;in &#246;yle...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508514&amp;title=206-2-vites-tekleme#508514</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9585">Serkan</a><br /><strong>Konu:</strong> 35317<br /><strong>Gönderim Zamanı:</strong> 28&nbsp;Mayıs&nbsp;2014 Saat 19:36<br /><br />Rampa aşağı demediğiniz için öyle anlamışım, dediğim gibi benzinde yapmıyorsa sorunu lpg'de armak lazım, önce benzinde yapmadığına emin ol benzinde yapmıyorsa, iyi bir kalibrasyon yapmak gerekir, birde benzinli araçlar düşük devirleri pek sevmezler biraz daha devirli kullanmayı deneyin, birde lp'li olunca düşük devirde zor toparlar kendini]]>
   </description>
   <pubDate>Wed, 28 May 2014 19:36:11 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508514&amp;title=206-2-vites-tekleme#508514</guid>
  </item>
  <item>
   <title><![CDATA[206 2. Vites tekleme :   Serkan Yazd&#305;:Benzinde olmuyorsa...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508512&amp;title=206-2-vites-tekleme#508512</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=14034">Bysekowest</a><br /><strong>Konu:</strong> 35317<br /><strong>Gönderim Zamanı:</strong> 28&nbsp;Mayıs&nbsp;2014 Saat 19:08<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Serkan" alt="Orjinalini yazan: Serkan" style="vertical-align: text-bottom;" /> <strong>Serkan Yazdı:</strong><br /><br />Benzinde olmuyorsa sorunu lpg'de aramak lazım, önce ayarları kontrol etmeli, iyi bir kalibrasyon yaptırmalı, eğer sorun devam ederse bujiler kontrol edilmeli, bujiler orjinal değilse bujilerden de yapabilir, lpg ateşleme sistemine karşı hassastır. Diğer bir konu kalkış vitesi birinci vitestir neden aracı 2. viteste kaldırıyorsunuz özellikle yokuşta?<div><br></div></td></tr></table><div><br></div><div>yokuş aşağı 2. viteste kaldırıyorum yokuş yukarı kalmazki zaten</div>]]>
   </description>
   <pubDate>Wed, 28 May 2014 19:08:05 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508512&amp;title=206-2-vites-tekleme#508512</guid>
  </item>
  <item>
   <title><![CDATA[206 2. Vites tekleme :  Kimisi beyin der kimi &#351;anz&#305;man...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508495&amp;title=206-2-vites-tekleme#508495</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13663">serkomser</a><br /><strong>Konu:</strong> 35317<br /><strong>Gönderim Zamanı:</strong> 28&nbsp;Mayıs&nbsp;2014 Saat 15:34<br /><br /><div>Kimisi beyin der kimi şanzıman der kimi blok der hepte pahalı parçaları söylerler. </div><span style="font-size:10px"><br /><br />Düzenleyen eurest - 23&nbsp;Haziran&nbsp;2014 Saat 13:51</span>]]>
   </description>
   <pubDate>Wed, 28 May 2014 15:34:09 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508495&amp;title=206-2-vites-tekleme#508495</guid>
  </item>
  <item>
   <title><![CDATA[206 2. Vites tekleme : Aynen ya gaz ayar&#305; ile ilgilidir...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508477&amp;title=206-2-vites-tekleme#508477</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11281">ahmed206</a><br /><strong>Konu:</strong> 35317<br /><strong>Gönderim Zamanı:</strong> 28&nbsp;Mayıs&nbsp;2014 Saat 12:59<br /><br />Aynen ya gaz ayarı ile ilgilidir herhalde. Bu tip sorunlar başlar başlamaz çözmeye bakın sonra daha büyük şeylere sebep oluyor.]]>
   </description>
   <pubDate>Wed, 28 May 2014 12:59:00 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508477&amp;title=206-2-vites-tekleme#508477</guid>
  </item>
  <item>
   <title><![CDATA[206 2. Vites tekleme : Benzinde olmuyorsa sorunu lpg&amp;#039;de...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508468&amp;title=206-2-vites-tekleme#508468</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9585">Serkan</a><br /><strong>Konu:</strong> 35317<br /><strong>Gönderim Zamanı:</strong> 28&nbsp;Mayıs&nbsp;2014 Saat 12:41<br /><br />Benzinde olmuyorsa sorunu lpg'de aramak lazım, önce ayarları kontrol etmeli, iyi bir kalibrasyon yaptırmalı, eğer sorun devam ederse bujiler kontrol edilmeli, bujiler orjinal değilse bujilerden de yapabilir, lpg ateşleme sistemine karşı hassastır. Diğer bir konu kalkış vitesi birinci vitestir neden aracı 2. viteste kaldırıyorsunuz özellikle yokuşta?<div><br></div>]]>
   </description>
   <pubDate>Wed, 28 May 2014 12:41:26 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508468&amp;title=206-2-vites-tekleme#508468</guid>
  </item>
  <item>
   <title><![CDATA[206 2. Vites tekleme :   newlook45 Yazd&#305;:tekleme derken?...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508456&amp;title=206-2-vites-tekleme#508456</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13223">Mbiwa</a><br /><strong>Konu:</strong> 35317<br /><strong>Gönderim Zamanı:</strong> 28&nbsp;Mayıs&nbsp;2014 Saat 11:36<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: newlook45" alt="Orjinalini yazan: newlook45" style="vertical-align: text-bottom;" /> <strong>newlook45 Yazdı:</strong><br /><br />tekleme derken? 2.vitesde giderken bi anlık bile olsa araba gazmı kesiyor ?</td></tr></table><div><br></div><div>Aynı sorun bende var çözümü nedir yokuş veya düz yol farketmiyor lpg li aracım bakımdan sonra oldu böyle</div>]]>
   </description>
   <pubDate>Wed, 28 May 2014 11:36:22 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508456&amp;title=206-2-vites-tekleme#508456</guid>
  </item>
  <item>
   <title><![CDATA[206 2. Vites tekleme : Ama 1. Viteste s&#305;k&#305;nt&#305;s&#305; yok diyer...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508455&amp;title=206-2-vites-tekleme#508455</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=14034">Bysekowest</a><br /><strong>Konu:</strong> 35317<br /><strong>Gönderim Zamanı:</strong> 28&nbsp;Mayıs&nbsp;2014 Saat 11:33<br /><br />Ama 1. Viteste sıkıntısı yok diyer viteslerdede]]>
   </description>
   <pubDate>Wed, 28 May 2014 11:33:56 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508455&amp;title=206-2-vites-tekleme#508455</guid>
  </item>
  <item>
   <title><![CDATA[206 2. Vites tekleme : D&#252;z vites yoku&#351;tada oluyor d&#252;z...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508454&amp;title=206-2-vites-tekleme#508454</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=14034">Bysekowest</a><br /><strong>Konu:</strong> 35317<br /><strong>Gönderim Zamanı:</strong> 28&nbsp;Mayıs&nbsp;2014 Saat 11:33<br /><br />Düz vites yokuştada oluyor düz yoldada atıyorum  rampada 2.. Vitesle kalkınca 2000 devire kada tekliyor 2000 devirden sonra sıkıntısı kalmıyo]]>
   </description>
   <pubDate>Wed, 28 May 2014 11:33:26 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508454&amp;title=206-2-vites-tekleme#508454</guid>
  </item>
  <item>
   <title><![CDATA[206 2. Vites tekleme :  Ara&#231; otomatik mi ve d&#252;z yolda...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508451&amp;title=206-2-vites-tekleme#508451</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13663">serkomser</a><br /><strong>Konu:</strong> 35317<br /><strong>Gönderim Zamanı:</strong> 28&nbsp;Mayıs&nbsp;2014 Saat 11:22<br /><br />Araç otomatik mi ve düz yolda oluyor mu yoksa yokuşta mı oluyor?]]>
   </description>
   <pubDate>Wed, 28 May 2014 11:22:38 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508451&amp;title=206-2-vites-tekleme#508451</guid>
  </item>
  <item>
   <title><![CDATA[206 2. Vites tekleme : Sadece 2.viteste hay&#305;r fark etmiyor...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508449&amp;title=206-2-vites-tekleme#508449</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=14034">Bysekowest</a><br /><strong>Konu:</strong> 35317<br /><strong>Gönderim Zamanı:</strong> 28&nbsp;Mayıs&nbsp;2014 Saat 11:17<br /><br />Sadece 2.viteste hayır fark etmiyor eskiden arada yapardı şimdi sıklaştı]]>
   </description>
   <pubDate>Wed, 28 May 2014 11:17:28 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=35317&amp;PID=508449&amp;title=206-2-vites-tekleme#508449</guid>
  </item>
 </channel>
</rss>
