 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Coilover</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Modifiye ve Tuning Bilgileri : Coilover]]></description>
  <pubDate>Fri, 01 May 2026 21:18:22 +0000</pubDate>
  <lastBuildDate>Thu, 27 Nov 2008 14:32:36 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=3501</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Coilover : Uzun laf&#305;n k&#305;sas&#305; yay kestirmeniz...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=3501&amp;PID=49548&amp;title=coilover#49548</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 3501<br /><strong>Gönderim Zamanı:</strong> 27&nbsp;Kasım&nbsp;2008 Saat 14:32<br /><br /><FONT face=Arial>Uzun lafın kısası yay kestirmeniz sakıncalıdır kesinlikle tavsiye etmiyorum<FONT color=#ffffff> </FONT></FONT><BR><BR>demek oyle sayın deran tavsıye etmıyorsunuz...]]>
   </description>
   <pubDate>Thu, 27 Nov 2008 14:32:36 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=3501&amp;PID=49548&amp;title=coilover#49548</guid>
  </item> 
  <item>
   <title><![CDATA[Coilover :    ya&#351;ar Yazd&#305;:  serhat tutar...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=3501&amp;PID=49543&amp;title=coilover#49543</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 3501<br /><strong>Gönderim Zamanı:</strong> 27&nbsp;Kasım&nbsp;2008 Saat 14:26<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: yaşar" alt="Orjinalini yazan: yaşar" style="vertical-align: text-bottom;" /> <strong>yaşar Yazdı:</strong><br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: serhat tutar" alt="Orjinalini yazan: serhat tutar" style="vertical-align: text-bottom;" /> <strong>serhat tutar Yazdı:</strong><br /><br />1- dezavantajı soyle olur ıyı bıyerde takılmamıssa on takımı etkıler... <div>2- kendımız ayarlıyoruz anahtarı sayesınde...</div><div>3- kullnım suresı tamamen kullnıcıyla alakalı sert ce spor kullnım ıcın olanı var bırde cadde tıpı olanı var sertlıgını kendın ayarlıyorsun ne tıpde kullnmak ıstersen...</div><div>4- torsıyonlu araclarda sadece onde oluyr arkaya sadace yardım amaclı spor amortusor konuyor möalıyet 1000 ytl ıle 3000 ytl arasında degısıyor markayla alakalı...</div></td></tr></table> <div><br><strong><font color="#cc6600">serhat ve deran&nbsp;sagolun bizim için yararlı bir bilgi oldu ;)</font></strong></div></td></tr></table><br><br><font color="#000000">Madem oyle yaşar baba hazır konu açılmışken birazda yaylardan bahsedelim çünkü coil harici başka bir yontemde kısa yay takmak yada yayları kestirmek ama burada dikkat edilmesi gereken hayati noktalar sözkonus<font size="2"><font face="Arial">u bunlardan biride spring rate yani yay oranıdır</font></font></font><br><font style="font-size: 9pt;" color="#ffffff" face="Arial"><font color="#000000">Bir yayın yumuşaklık veya sertlik karakteristiğini belirtmek                 için, üzerine uygulanan belli bir miktar (x gr.) ağırlık sonucu                 belli bir mesafe (y mm) kadar azalır şeklinde açıklanan orandır.                 Bu orana spring rate yani yay oranı denir ve g/mm veya lbs/inch                 olarak ifade edilir. <br><br>                Konunun daha iyi anlaşılmasını sağlamak açısından, eğer ölçü                 birimini g/mm kabul edersek x rakamı değişken, fakat yayın ne                 kadar düşeceğini belirten y rakamı sabittir ve 1mm. dir.                 İsterseniz hemen bir örnek verelim:<br><br>                Elimizde farklı yay oranlarına (spring rate&#8217;e) sahip 2 değişik                 yay olduğunu varsayalım. Bunlardan birinin yay oranı 345 g/mm,                 diğerininki de 480 g/mm olsun. Bu, şu demektir: Birinci yaya 345                 gram ağırlık uygularsan bu yay 1mm. kısalır, ikinci yaya ise                 ancak 480 gr. ağırlık uyguladığımızda bu yay 1mm. kısalır. Buna                 göre, ikinci yay birinciden daha sert bir yaydır.<br><br>                Buradan şu sonuca varabiliriz: spring rate&#8217;i düşük yaylar                 yumuşak, spring rate&#8217;i yüksek yaylar sert yaylardır...<br><br>                Eşit bakla aralıkları a,a,a,a,a,.. <br><br><br><b>NORMAL (LINEAR) YAYLAR</b><br><br>                Üzerine uygulanan ağırlıkta hep aynı miktar kısalan yaylara                 normal (linear) yaylar denir.<br><br>                Normal bir yayda her bir bakla arasındaki mesafe birbirine                 eşittir. Bunun doğal sonucu olarak da yay üzerine yük                 bindiğinde, baklalar birbirlerine eşit oranda yaklaşırlar.<br><br>                Örneğin 10 bakladan oluşan ve her bir bakla aralığı 2 cm. olan                 bir yayımız olduğunu varsayalım. Yayın üzerine, yayı 2 cm                 kısaltacak bir ağırlık uygularsanız spring rate sabit olduğundan                 her bir yayın arası 2cm/10=2mm azalacak, yani bakla aralıkları                 her birinde eşit olmak üzere 1,8 cm&#8217;ye düşecektir. <br>                Yani, NORMAL YAYLARIN SPRİNG RATE&#8217;İ SABİTTİR, üzerlerine                 uygulanan herhangi bir ağırlıkta bakla aralıkları eşit olarak                 azalır.<br><br>                2 farklı bakla aralığı <br>                a,a,a,a,a,..,b,b,b,b,b <br><br><br><b>STEP LINEAR YAYLAR </b><br><br>                Step Linear yayları çift sertlikli yaylar olarak düşünebiliriz.                 Bu tip yaylar normal yay ile progressive yay arasıdır. Step                 Linear yaylarda baklaların yarısının arası birbirine daha                 yakınken diğer yarısının aralıkları farklıdır. Yani, step linear                 yaylar çift spring rate&#8217;e sahip yaylardır.<br><br>                Step Linear yaylar şu şekilde çalışır: <br><br>                Yay sıkıştığı zaman baklalar birbirine yaklaşmaya başlar. Belli                 bir noktadan sonra arası yakın olan yaylar birbirine değer ve bu                 kısım yaylanma işini sonlandırır. Geriye kalan, arası daha açık                 baklalar yayın daha sert olması sonucunu doğurur çünkü bir yayın                 uzunluğu kısaldıkça sertleşir. Bu yayları, yukarıda bahsetmiş                 olduğumuz gibi çift sertlikli veya çift spring rate&#8217;e sahip                 (1.bölüm için ayrı, 2. bölüm için ayrı) yaylar olarak                 düşünebiliriz.<br><br>                Değişken bakla aralığı <br>                a,b,c,d,e,f,g,h,i <br><br><br><b>PROGRESSİVE YAYLAR (Progressive spring / Progressive feder /                 Ressort progressif) </b><br><br>                Değişken spring rate&#8217;e sahip yaylardır (Örn Eibach). Progressive                 yaylarda HER BİR BAKLANIN ARALIĞI BİRBİRİNDEN FARKLIDIR. Bunun                 sonucu olarak yol tutuşta, zıplamalarda, frenlemede en iyi                 performansı gösteren yaylardır.<br><br>                Progressive yaylarda, yaya uygulanan her fazla baskıda                 (ağırlıkta) yay bu baskıya daha fazla sertleşerek karşılık                 verir.<br><br>                Günlük hayattaki gerçek sürüş koşullarında yayın maruz kaldığı                 baskılar son derece değişken olacağı, yani step linear                 yaylardaki gibi sadece 2 ayrı yük seviyesi olmayacağı için,                 PROGRESSIVE YAYLAR değişken spring rate&#8217;leriyle her koşula en                 iyi şekilde ayak uyduran yaylardır...<br><br>Uzun lafın kısası yay kestirmeniz sakıncalıdır kesinlikle tavsiye etmiyorum</font> <br>                </font><br>]]>
   </description>
   <pubDate>Thu, 27 Nov 2008 14:26:05 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=3501&amp;PID=49543&amp;title=coilover#49543</guid>
  </item> 
  <item>
   <title><![CDATA[Coilover : &#304;stanbulda setsiz yolmu var be...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=3501&amp;PID=49532&amp;title=coilover#49532</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 3501<br /><strong>Gönderim Zamanı:</strong> 27&nbsp;Kasım&nbsp;2008 Saat 13:33<br /><br />İstanbulda setsiz yolmu var be abi tek çare nizam ustayı bekleyeceğiz ]]>
   </description>
   <pubDate>Thu, 27 Nov 2008 13:33:25 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=3501&amp;PID=49532&amp;title=coilover#49532</guid>
  </item> 
  <item>
   <title><![CDATA[Coilover :   DERAN_TUYNER Yazd&#305;:  gs5165...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=3501&amp;PID=49518&amp;title=coilover#49518</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 3501<br /><strong>Gönderim Zamanı:</strong> 27&nbsp;Kasım&nbsp;2008 Saat 13:16<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: DERAN_TUYNER" alt="Orjinalini yazan: DERAN_TUYNER" style="vertical-align: text-bottom;" /> <strong>DERAN_TUYNER Yazdı:</strong><br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: gs5165" alt="Orjinalini yazan: gs5165" style="vertical-align: text-bottom;" /> <strong>gs5165 Yazdı:</strong><br /><br />yani diyelim yolda seyir halindeyken önümde set var aracı yükseltebiliyormuyum lowrider gibi yani :))</td></tr></table><BR><BR>Nizam usta yakında yapacak onuda tasarım bitti sayılır ama daha piyasaya sürmedi<BR></td></tr></table> <DIV>&nbsp;</DIV><DIV>ya basıcan tum rısklerı goz onune alıp (su bırıkıntılerı kazılmıs yollar barıketler) buralardab gecmıycen yada stock bınıcen secım senın...</DIV>]]>
   </description>
   <pubDate>Thu, 27 Nov 2008 13:16:42 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=3501&amp;PID=49518&amp;title=coilover#49518</guid>
  </item> 
  <item>
   <title><![CDATA[Coilover :    gs5165 Yazd&#305;:yani diyelim...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=3501&amp;PID=49513&amp;title=coilover#49513</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 3501<br /><strong>Gönderim Zamanı:</strong> 27&nbsp;Kasım&nbsp;2008 Saat 13:02<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: gs5165" alt="Orjinalini yazan: gs5165" style="vertical-align: text-bottom;" /> <strong>gs5165 Yazdı:</strong><br /><br />yani diyelim yolda seyir halindeyken önümde set var aracı yükseltebiliyormuyum lowrider gibi yani :))</td></tr></table><br><br>Nizam usta yakında yapacak onuda tasarım bitti sayılır ama daha piyasaya sürmedi<br>]]>
   </description>
   <pubDate>Thu, 27 Nov 2008 13:02:20 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=3501&amp;PID=49513&amp;title=coilover#49513</guid>
  </item> 
  <item>
   <title><![CDATA[Coilover : yani diyelim yolda seyir halindeyken...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=3501&amp;PID=49502&amp;title=coilover#49502</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 3501<br /><strong>Gönderim Zamanı:</strong> 27&nbsp;Kasım&nbsp;2008 Saat 12:52<br /><br />yani diyelim yolda seyir halindeyken önümde set var aracı yükseltebiliyormuyum lowrider gibi yani :))]]>
   </description>
   <pubDate>Thu, 27 Nov 2008 12:52:13 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=3501&amp;PID=49502&amp;title=coilover#49502</guid>
  </item> 
  <item>
   <title><![CDATA[Coilover : ucuz yollu hand made . made &#305;n...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=3501&amp;PID=49496&amp;title=coilover#49496</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10">MirakGTI</a><br /><strong>Konu:</strong> 3501<br /><strong>Gönderim Zamanı:</strong> 27&nbsp;Kasım&nbsp;2008 Saat 12:43<br /><br />ucuz yollu hand made . made ın Turkey istersen Maslak sanayide NAMISTAIN<DIV>yok ben kalite arıyorum dersen KW öneririm</DIV>]]>
   </description>
   <pubDate>Thu, 27 Nov 2008 12:43:56 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=3501&amp;PID=49496&amp;title=coilover#49496</guid>
  </item> 
  <item>
   <title><![CDATA[Coilover :   serhat tutar Yazd&#305;:1- dezavantaj&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=3501&amp;PID=49491&amp;title=coilover#49491</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 3501<br /><strong>Gönderim Zamanı:</strong> 27&nbsp;Kasım&nbsp;2008 Saat 12:38<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: serhat tutar" alt="Orjinalini yazan: serhat tutar" style="vertical-align: text-bottom;" /> <strong>serhat tutar Yazdı:</strong><br /><br />1- dezavantajı soyle olur ıyı bıyerde takılmamıssa on takımı etkıler... <DIV>2- kendımız ayarlıyoruz anahtarı sayesınde...</DIV><DIV>3- kullnım suresı tamamen kullnıcıyla alakalı sert ce spor kullnım ıcın olanı var bırde cadde tıpı olanı var sertlıgını kendın ayarlıyorsun ne tıpde kullnmak ıstersen...</DIV><DIV>4- torsıyonlu araclarda sadece onde oluyr arkaya sadace yardım amaclı spor amortusor konuyor möalıyet 1000 ytl ıle 3000 ytl arasında degısıyor markayla alakalı...</DIV></td></tr></table> <DIV><BR><strong><FONT color=#cc6600>serhat ve deran&nbsp;sagolun bizim için yararlı bir bilgi oldu ;)</FONT></strong></DIV><span style="font-size:10px"><br /><br />Düzenleyen yaşar - 27&nbsp;Kasım&nbsp;2008 Saat 12:47</span>]]>
   </description>
   <pubDate>Thu, 27 Nov 2008 12:38:59 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=3501&amp;PID=49491&amp;title=coilover#49491</guid>
  </item> 
  <item>
   <title><![CDATA[Coilover :  1) Avantajlar&#305;n&#305; k&#305;smen biliyorum...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=3501&amp;PID=49490&amp;title=coilover#49490</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 3501<br /><strong>Gönderim Zamanı:</strong> 27&nbsp;Kasım&nbsp;2008 Saat 12:38<br /><br /><div>1) Avantajlarını kısmen biliyorum dezavantajları nelerdir?<font color="#ff0000"> Fiyatı + Arac sertleşir kule gergisi şarttır </font><br></div><div>2) Araç Yüksekliğini manuel kendimiz ayarlayabiliyormuyuz , evetse nasıl ? <font color="#ff0000">Yanında verilen anahtarla çok yakında araç içinden elektronik olarak</font><br></div><div>3) Kullanım süresi ne kadardır? Masraf nedir ?<font color="#ff0000"> Kullanım tarzına bağlı</font><br></div><div>4) Torsiyonlu araçlarda uygulama nasıl yapılıyor? sadece önleremi takılıyor? <font color="#ff0000">Hayır arkalarada taktırabilirsiniz (tavsiye edilir tarafımca :) )</font><br></div>]]>
   </description>
   <pubDate>Thu, 27 Nov 2008 12:38:19 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=3501&amp;PID=49490&amp;title=coilover#49490</guid>
  </item> 
  <item>
   <title><![CDATA[Coilover : 1- dezavantaj&#305; soyle olur &#305;y&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=3501&amp;PID=49489&amp;title=coilover#49489</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 3501<br /><strong>Gönderim Zamanı:</strong> 27&nbsp;Kasım&nbsp;2008 Saat 12:34<br /><br />1- dezavantajı soyle olur ıyı bıyerde takılmamıssa on takımı etkıler...<DIV>2- kendımız ayarlıyoruz anahtarı sayesınde...</DIV><DIV>3- kullnım suresı tamamen kullnıcıyla alakalı sert ce spor kullnım ıcın olanı var bırde cadde tıpı olanı var sertlıgını kendın ayarlıyorsun ne tıpde kullnmak ıstersen...</DIV><DIV>4- torsıyonlu araclarda sadece onde oluyr arkaya sadace yardım amaclı spor amortusor konuyor möalıyet 1000 ytl ıle 3000 ytl arasında degısıyor markayla alakalı...</DIV>]]>
   </description>
   <pubDate>Thu, 27 Nov 2008 12:34:52 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=3501&amp;PID=49489&amp;title=coilover#49489</guid>
  </item> 
  <item>
   <title><![CDATA[Coilover : Arkada&#351;lar bu coil hakk&#305;nda bir...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=3501&amp;PID=49488&amp;title=coilover#49488</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 3501<br /><strong>Gönderim Zamanı:</strong> 27&nbsp;Kasım&nbsp;2008 Saat 12:32<br /><br />Arkadaşlar bu coil hakkında bir kaç sorum olacak.<DIV>&nbsp;</DIV><DIV>1) Avantajlarını kısmen biliyorum dezavantajları nelerdir?</DIV><DIV>2) Araç Yüksekliğini manuel kendimiz ayarlayabiliyormuyuz , evetse nasıl ?</DIV><DIV>3) Kullanım süresi ne kadardır? Masraf nedir ?</DIV><DIV>4) Torsiyonlu araçlarda uygulama nasıl yapılıyor? sadece önleremi takılıyor?</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV>]]>
   </description>
   <pubDate>Thu, 27 Nov 2008 12:32:02 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=3501&amp;PID=49488&amp;title=coilover#49488</guid>
  </item> 
 </channel>
</rss>
