 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Hararet</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 206 : Hararet]]></description>
  <pubDate>Sat, 02 May 2026 11:19:48 +0000</pubDate>
  <lastBuildDate>Thu, 24 Apr 2014 10:21:40 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=34795</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Hararet : te&#351;ekk&#252;r ederim erdi. ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34795&amp;PID=501899&amp;title=hararet#501899</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=12364">mdursunn</a><br /><strong>Konu:</strong> 34795<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Nisan&nbsp;2014 Saat 10:21<br /><br />teşekkür ederim erdi.]]>
   </description>
   <pubDate>Thu, 24 Apr 2014 10:21:40 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34795&amp;PID=501899&amp;title=hararet#501899</guid>
  </item>
  <item>
   <title><![CDATA[Hararet : 95 olmasi sikinti degil ama kirmiziya...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34795&amp;PID=501896&amp;title=hararet#501896</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13242">ErdiCoskun</a><br /><strong>Konu:</strong> 34795<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Nisan&nbsp;2014 Saat 10:16<br /><br />95 olmasi sikinti degil ama kirmiziya dayandiysa derhal bir ustaya gotur, sıkışık trafikte biraz yukselebilir, ama senin hararet musurunde sorun olabilir, sogutma suyun eksiliyor olabilir, termostatina devir daiminde falan sorun olabilir, cok masrafli seyler degil ama ihmal edersen baya masrafli olur ]]>
   </description>
   <pubDate>Thu, 24 Apr 2014 10:16:26 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34795&amp;PID=501896&amp;title=hararet#501896</guid>
  </item>
  <item>
   <title><![CDATA[Hararet : merhaba arkada&#351;lar ilk defa peugeot...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34795&amp;PID=501894&amp;title=hararet#501894</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=12364">mdursunn</a><br /><strong>Konu:</strong> 34795<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Nisan&nbsp;2014 Saat 10:11<br /><br />merhaba arkadaşlar ilk defa peugeot 206 ım hararet göstergesi yoldayken 95 i geçti. fan çalışmasına rağmen seviye düşmedi. biraz bekledikten sonra devam ettim yola yine aynı şekilde kırmızıya kadar dayandı gösterge yine rölantide bırakıp soğumasını bekledim sorun ne olabilir.suyuna, yağına baktım yeterince vardı.]]>
   </description>
   <pubDate>Thu, 24 Apr 2014 10:11:31 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34795&amp;PID=501894&amp;title=hararet#501894</guid>
  </item>
 </channel>
</rss>
