 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : CC devreye girmiyor</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Arac&#305;n&#305;z Hakk&#305;ndaki T&#252;m Sorular : CC devreye girmiyor]]></description>
  <pubDate>Mon, 04 May 2026 06:04:38 +0000</pubDate>
  <lastBuildDate>Thu, 08 May 2014 17:53:15 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=34654</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[CC devreye girmiyor :   ByHack Yazd&#305;:ben dediydim eyvallah...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34654&amp;PID=504795&amp;title=cc-devreye-girmiyor#504795</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11165">SDYMZ</a><br /><strong>Konu:</strong> 34654<br /><strong>Gönderim Zamanı:</strong> 08&nbsp;Mayıs&nbsp;2014 Saat 17:53<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: ByHack" alt="Orjinalini yazan: ByHack" style="vertical-align: text-bottom;" /> <strong>ByHack Yazdı:</strong><br /><br />ben dediydim<img src="https://forum.peugeotturkey.com/smileys/smiley4.gif" border="0" alt="Big smile" title="Big smile" /></td></tr></table><div>eyvallah sağ ol sen dedikten sonra zaten baktım fren müşürüne</div>]]>
   </description>
   <pubDate>Thu, 08 May 2014 17:53:15 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34654&amp;PID=504795&amp;title=cc-devreye-girmiyor#504795</guid>
  </item>
  <item>
   <title><![CDATA[CC devreye girmiyor : ben dediydim ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34654&amp;PID=501851&amp;title=cc-devreye-girmiyor#501851</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6495">ByHack</a><br /><strong>Konu:</strong> 34654<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Nisan&nbsp;2014 Saat 00:47<br /><br />ben dediydim<img src="https://forum.peugeotturkey.com/smileys/smiley4.gif" border="0" alt="Big smile" title="Big smile" />]]>
   </description>
   <pubDate>Thu, 24 Apr 2014 00:47:32 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34654&amp;PID=501851&amp;title=cc-devreye-girmiyor#501851</guid>
  </item>
  <item>
   <title><![CDATA[CC devreye girmiyor :  fren m&#252;&#351;&#252;r&#252;nden kaynaklan&#305;yormu&#351;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34654&amp;PID=501468&amp;title=cc-devreye-girmiyor#501468</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11165">SDYMZ</a><br /><strong>Konu:</strong> 34654<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Nisan&nbsp;2014 Saat 09:06<br /><br />fren müşüründen kaynaklanıyormuş değiştirdim sorun çözüldü. debraj müşürünü kontrol ettim ölçü aleti ile onda sorun yok]]>
   </description>
   <pubDate>Tue, 22 Apr 2014 09:06:54 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34654&amp;PID=501468&amp;title=cc-devreye-girmiyor#501468</guid>
  </item>
  <item>
   <title><![CDATA[CC devreye girmiyor : Fren musuru bozulsa fren lambasida...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34654&amp;PID=500303&amp;title=cc-devreye-girmiyor#500303</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7967">Alicilik</a><br /><strong>Konu:</strong> 34654<br /><strong>Gönderim Zamanı:</strong> 16&nbsp;Nisan&nbsp;2014 Saat 16:38<br /><br />Fren musuru bozulsa fren lambasida yanmaz galiba ama cift tarafi olunca kesin de bisi diyemiyorum debriyajda olabilir frende olabilir. Hatta beyindeki baska bir hata da sebep olabilir. Servis bir 207de espyi acmis yanlislikla o da acmiyordu kapatinca duzeldi]]>
   </description>
   <pubDate>Wed, 16 Apr 2014 16:38:16 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34654&amp;PID=500303&amp;title=cc-devreye-girmiyor#500303</guid>
  </item>
  <item>
   <title><![CDATA[CC devreye girmiyor : Fren m&#252;&#351;&#252;r&#252; sorununu hem 206&amp;#039;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34654&amp;PID=500288&amp;title=cc-devreye-girmiyor#500288</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9585">Serkan</a><br /><strong>Konu:</strong> 34654<br /><strong>Gönderim Zamanı:</strong> 16&nbsp;Nisan&nbsp;2014 Saat 15:14<br /><br />Fren müşürü sorununu hem 206' da hem C3'de yaşadım, müşürü kontrol et ucu geri kaçmış olabilir, bozulmuşta olabilir]]>
   </description>
   <pubDate>Wed, 16 Apr 2014 15:14:55 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34654&amp;PID=500288&amp;title=cc-devreye-girmiyor#500288</guid>
  </item>
  <item>
   <title><![CDATA[CC devreye girmiyor : Bsi ve ecu da hata var mi bakmak...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34654&amp;PID=500250&amp;title=cc-devreye-girmiyor#500250</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7967">Alicilik</a><br /><strong>Konu:</strong> 34654<br /><strong>Gönderim Zamanı:</strong> 16&nbsp;Nisan&nbsp;2014 Saat 12:12<br /><br />Bsi ve ecu da hata var mi bakmak lazim onlara mutevellit bir sorun olablir]]>
   </description>
   <pubDate>Wed, 16 Apr 2014 12:12:41 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34654&amp;PID=500250&amp;title=cc-devreye-girmiyor#500250</guid>
  </item>
  <item>
   <title><![CDATA[CC devreye girmiyor :   Alicilik Yazd&#305;:Herhangi bir...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34654&amp;PID=500199&amp;title=cc-devreye-girmiyor#500199</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11165">SDYMZ</a><br /><strong>Konu:</strong> 34654<br /><strong>Gönderim Zamanı:</strong> 16&nbsp;Nisan&nbsp;2014 Saat 06:12<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Alicilik" alt="Orjinalini yazan: Alicilik" style="vertical-align: text-bottom;" /> <strong>Alicilik Yazdı:</strong><br /><br />Herhangi bir hata alma veya beyin konfigurasyonlarında değişme oldu mu ?<br></td></tr></table>bi keresinde mazot hortumu delinmişti bunla alakalı motor arıza lambası yakmıştı hortumu değiştirdim lamba söndü. bu olaydan epey&nbsp;CC çalışıyordu ]]>
   </description>
   <pubDate>Wed, 16 Apr 2014 06:12:46 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34654&amp;PID=500199&amp;title=cc-devreye-girmiyor#500199</guid>
  </item>
  <item>
   <title><![CDATA[CC devreye girmiyor : Hocam bende de ayn&#305; sorun vard&#305;,...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34654&amp;PID=500175&amp;title=cc-devreye-girmiyor#500175</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6495">ByHack</a><br /><strong>Konu:</strong> 34654<br /><strong>Gönderim Zamanı:</strong> 16&nbsp;Nisan&nbsp;2014 Saat 01:19<br /><br />Hocam bende de aynı sorun vardı, hatta biraz önce açtığım konuda değinmiştim. Fren müşüründen kaynaklı olma ihtimalini değerlendirmeni öneririm. Fren müşürünün tırnaklı ucu geriye kaydığında tam olarak işlevini yerine getiremeyip bu hataya sebep olabiliyor. bilginize...<div><br></div><div><img src="http://i.hizliresim.com/ZNWbQG.jpg" height="480" width="640" border="0" /><br></div>]]>
   </description>
   <pubDate>Wed, 16 Apr 2014 01:19:48 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34654&amp;PID=500175&amp;title=cc-devreye-girmiyor#500175</guid>
  </item>
  <item>
   <title><![CDATA[CC devreye girmiyor : Herhangi bir hata alma veya beyin...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34654&amp;PID=500171&amp;title=cc-devreye-girmiyor#500171</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7967">Alicilik</a><br /><strong>Konu:</strong> 34654<br /><strong>Gönderim Zamanı:</strong> 16&nbsp;Nisan&nbsp;2014 Saat 00:57<br /><br />Herhangi bir hata alma veya beyin konfigurasyonlarında değişme oldu mu ?<br>]]>
   </description>
   <pubDate>Wed, 16 Apr 2014 00:57:12 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34654&amp;PID=500171&amp;title=cc-devreye-girmiyor#500171</guid>
  </item>
  <item>
   <title><![CDATA[CC devreye girmiyor :  yakla&#351;&#305;k bir seneden beri sorunsuz...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34654&amp;PID=500165&amp;title=cc-devreye-girmiyor#500165</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11165">SDYMZ</a><br /><strong>Konu:</strong> 34654<br /><strong>Gönderim Zamanı:</strong> 16&nbsp;Nisan&nbsp;2014 Saat 00:14<br /><br />yaklaşık bir seneden beri sorunsuz kullandığım hız sabitleyicisi son 2-3 kullanışımda devreye girmedi neden olabilir acaba]]>
   </description>
   <pubDate>Wed, 16 Apr 2014 00:14:20 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34654&amp;PID=500165&amp;title=cc-devreye-girmiyor#500165</guid>
  </item>
 </channel>
</rss>
