 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : acil yardım.</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Arac&#305;n&#305;z Hakk&#305;ndaki T&#252;m Sorular : acil yardım.]]></description>
  <pubDate>Sat, 02 May 2026 07:13:42 +0000</pubDate>
  <lastBuildDate>Fri, 04 Apr 2014 00:25:25 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=34447</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[acil yardım. : arkada&#351;lar sorun gaz ve fren sens&#246;r&#252;ndenmi&#351;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34447&amp;PID=497666&amp;title=acil-yardim#497666</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13726">emrepunar</a><br /><strong>Konu:</strong> 34447<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Nisan&nbsp;2014 Saat 00:25<br /><br />arkadaşlar sorun gaz ve fren sensöründenmiş değiştik şu anlık sorun yok.]]>
   </description>
   <pubDate>Fri, 04 Apr 2014 00:25:25 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34447&amp;PID=497666&amp;title=acil-yardim#497666</guid>
  </item>
  <item>
   <title><![CDATA[acil yardım. : aynen &#351;anz&#305;manc&#305;ya bi u&#287;ra ya&#287;&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34447&amp;PID=497488&amp;title=acil-yardim#497488</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=12209">tetik-soner</a><br /><strong>Konu:</strong> 34447<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Nisan&nbsp;2014 Saat 15:29<br /><br />aynen&nbsp; şanzımancıya bi uğra yağı falan bi değişsin]]>
   </description>
   <pubDate>Thu, 03 Apr 2014 15:29:04 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34447&amp;PID=497488&amp;title=acil-yardim#497488</guid>
  </item>
  <item>
   <title><![CDATA[acil yardım. : &#351;an&#305;zman bozulmu&#351; ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34447&amp;PID=497410&amp;title=acil-yardim#497410</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8959">arachnid</a><br /><strong>Konu:</strong> 34447<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Nisan&nbsp;2014 Saat 11:44<br /><br />şanızman bozulmuş]]>
   </description>
   <pubDate>Thu, 03 Apr 2014 11:44:07 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34447&amp;PID=497410&amp;title=acil-yardim#497410</guid>
  </item>
  <item>
   <title><![CDATA[acil yardım. : iyi geceler arkada&#351;lar ben 2 gun...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34447&amp;PID=497335&amp;title=acil-yardim#497335</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13726">emrepunar</a><br /><strong>Konu:</strong> 34447<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Nisan&nbsp;2014 Saat 00:38<br /><br />iyi geceler arkadaşlar ben 2 gun önce 2006 model 1,6 sw comport pejo aldım bugun bir sorun ile karşılaştım aracı ilk hareket ettirirken otomatik vitesde 1 den 2 ye rahat sonra 3 gecer ken arac gaz yemiyor ne yaparsan yap deviri sabip kalıyor sonra stop edip manuel alıyorum 1 2 3 4 yapıyorum seri şekilde sonra otomatige alıyorum sorun gidiyor ama ozmanda arac istedigim gibi rahat gitmiyor sanki 4 ncü vitese geçmiyor gibi sizce neden olabilir bir yard. olsanız.]]>
   </description>
   <pubDate>Thu, 03 Apr 2014 00:38:58 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34447&amp;PID=497335&amp;title=acil-yardim#497335</guid>
  </item>
 </channel>
</rss>
