 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Yağ basıncı hk,</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Arac&#305;n&#305;z Hakk&#305;ndaki T&#252;m Sorular : Yağ basıncı hk,]]></description>
  <pubDate>Sat, 02 May 2026 14:27:48 +0000</pubDate>
  <lastBuildDate>Tue, 08 Apr 2014 17:38:33 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=34400</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Yağ basıncı hk, :  ge&#231;mi&#351; olsun dostumsevindim...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=498513&amp;title=yag-basinci-hk#498513</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13570">mehmethannn</a><br /><strong>Konu:</strong> 34400<br /><strong>Gönderim Zamanı:</strong> 08&nbsp;Nisan&nbsp;2014 Saat 17:38<br /><br />geçmiş olsun dostum<div>sevindim valla. </div><div>bu işte en önemli şey usta. bir kez daha öğrenmiş olduk.</div><div>&nbsp;</div><div>&nbsp;</div>]]>
   </description>
   <pubDate>Tue, 08 Apr 2014 17:38:33 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=498513&amp;title=yag-basinci-hk#498513</guid>
  </item>
  <item>
   <title><![CDATA[Yağ basıncı hk, :   hamzaoglu Yazd&#305;:Merhaba arkada&#351;&#305;m....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=498511&amp;title=yag-basinci-hk#498511</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13663">serkomser</a><br /><strong>Konu:</strong> 34400<br /><strong>Gönderim Zamanı:</strong> 08&nbsp;Nisan&nbsp;2014 Saat 17:33<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: hamzaoglu" alt="Orjinalini yazan: hamzaoglu" style="vertical-align: text-bottom;" /> <strong>hamzaoglu Yazdı:</strong><br /><br />Merhaba arkadaşım. Geçende araba d de firene basılı iken sarsıntı ve bazen vites geçişlerinde sorun vardı. Önce Boğaz kelebeğini temizlettim azalma var şimdide ustam bi kulakta sorun var onuda değişelim sarsıntı tamamen keser dedi onuda bu hafta içi değiştireceğim. Sonrasında sonucu paylaşırım. Araçta p de takılı kalma d modunda P S ışığı yakma sönme gibi durumlar olursa selenoid değiştirirsin dedi bana. Bakalım kulakla işi çözebilecekmiyim.</td></tr></table><div>&nbsp;</div><div>Aynen dediğin gibi sanki frene basınca sarsını daha çok yapıyor gibi ama emin değilim, birde ben birşeye dikkat ettim araba sıcakken şanzıman aşure gibi karkarışık hareketler yapıyo. Soğukken tık yok. </div><div>&nbsp;</div><div>Aklıma acaba yağ değişimi yaptırdığım usta farklı yağ mı koydu veya hiç değiştirmedi mi diye düşünüyrm.</div><div>Merakla bekliyorum cevabını.. Bu arada henüz vakit bulamadım kulaklara baktırmaya..</div><span style="font-size:10px"><br /><br />Düzenleyen serkomser - 26&nbsp;Haziran&nbsp;2014 Saat 15:48</span>]]>
   </description>
   <pubDate>Tue, 08 Apr 2014 17:33:42 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=498511&amp;title=yag-basinci-hk#498511</guid>
  </item>
  <item>
   <title><![CDATA[Yağ basıncı hk, : Merhaba arkada&#351;&#305;m. Ge&#231;ende araba...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=498415&amp;title=yag-basinci-hk#498415</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13647">hamzaoglu</a><br /><strong>Konu:</strong> 34400<br /><strong>Gönderim Zamanı:</strong> 08&nbsp;Nisan&nbsp;2014 Saat 00:04<br /><br />Merhaba arkadaşım. Geçende araba d de firene basılı iken sarsıntı ve bazen vites geçişlerinde sorun vardı. Önce Boğaz kelebeğini temizlettim azalma var şimdide ustam bi kulakta sorun var onuda değişelim sarsıntı tamamen keser dedi onuda bu hafta içi değiştireceğim. Sonrasında sonucu paylaşırım. Araçta p de takılı kalma d modunda P S ışığı yakma sönme gibi durumlar olursa selenoid değiştirirsin dedi bana. Bakalım kulakla işi çözebilecekmiyim.]]>
   </description>
   <pubDate>Tue, 08 Apr 2014 00:04:24 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=498415&amp;title=yag-basinci-hk#498415</guid>
  </item>
  <item>
   <title><![CDATA[Yağ basıncı hk, : merhaba ,Verdi&#287;iniz bilgi ve payla&#351;&#305;m...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=498389&amp;title=yag-basinci-hk#498389</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6538">206cc57</a><br /><strong>Konu:</strong> 34400<br /><strong>Gönderim Zamanı:</strong> 07&nbsp;Nisan&nbsp;2014 Saat 21:52<br /><br />merhaba ,&nbsp;<div><br></div><div>Verdiğiniz bilgi ve paylaşım için teşekkürler , geçmiş olsun , bir şey dikkatimi çekti,<span style="line-height: 1.4;">şanzıman yağ değişimi ve selonoid değişimi yapılma gereksinimi varsa bu forumdaki çok kişi sanayiyi tavsiye ediyor ,uzun bir süre araştırdım ,tavsiye üzerine gidincede bir başkasının aldığı başarılı hizmet bir başkası için aynısı olmuyor gibi gözüküyor okuduklarımdan arızalar birbirinden farklı olsada olmasada .. &nbsp;.. Söylemek istediğim, ödenen ücretler, şanzıman yağ değişimi ve selonoid için çok farklı değil yetkili serviste ,üstelik yetkili serviste kredi kartına taksit yaptırabiliyorsunuz .. ayrıca yazılım atıp atılmadığı konusunda içiniz rahat oluyor ,kesinlikle eminim ki sanayidede bu işi çok iyi yapan yazılımıda başarılı şekilde yükleyen yerler var fakat ben ön aks keçe değişimi için gittiğim otomatik şanzımancıdan 2 kere kazık yedim işini bilmediği için daha çok şanzıman yağı kaybettim ...Lakin benimde şanzımanımla ilgili sorunlarım vardı son aylarda,çok uzuan zamandır gittiğim yetkili servise gittim ,selonoidlerim yetkili serviste sorunsuz gözüktü , sadece yağ değişimi yapıldı şanzıman için, teslim eden usta arıza tekrarlarsa bilki tek çare revizyon dedi .. İlk hafta çok güzeldi fakat malasef son 15 günde 2 kez arıza verdi ...Ama şu an biliyorumki beni ilerleyen aylarda şanzıman &nbsp;revizyonu bekliyor .. &nbsp;</span></div>]]>
   </description>
   <pubDate>Mon, 07 Apr 2014 21:52:20 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=498389&amp;title=yag-basinci-hk#498389</guid>
  </item>
  <item>
   <title><![CDATA[Yağ basıncı hk, : ben &#351;unu anlad&#305;m herkez sanzuman...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=498277&amp;title=yag-basinci-hk#498277</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13726">emrepunar</a><br /><strong>Konu:</strong> 34400<br /><strong>Gönderim Zamanı:</strong> 07&nbsp;Nisan&nbsp;2014 Saat 10:47<br /><br />ben şunu anladım herkez sanzuman diyor ama ufak sorunlardan kaynaklanıyor. Benim aracımdada bir sıkıntı vardı ama gaz pedel sensörü bozulmuş ondan yapıyormuş sonra bir sıkıntı kalmadı allah herkezi işin evli ustaların eline düşürsün.&nbsp;<div><br></div><div>tekrar geçmiş olsun</div><span style="font-size:10px"><br /><br />Düzenleyen emrepunar - 07&nbsp;Nisan&nbsp;2014 Saat 10:48</span>]]>
   </description>
   <pubDate>Mon, 07 Apr 2014 10:47:23 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=498277&amp;title=yag-basinci-hk#498277</guid>
  </item>
  <item>
   <title><![CDATA[Yağ basıncı hk, :  Hepinize te&#351;ekk&#252;r ediyorum,...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=498266&amp;title=yag-basinci-hk#498266</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13663">serkomser</a><br /><strong>Konu:</strong> 34400<br /><strong>Gönderim Zamanı:</strong> 07&nbsp;Nisan&nbsp;2014 Saat 09:33<br /><br />Hepinize teşekkür ediyorum, birşeye dikkat ettim motor harareti 100 dereceye geldiği zaman <strong>(Araba sıcakken markete gittiğimde motoru istop ediyorum alışveriş dönüşü araca tekrar bindiğimde 110 olduğunu görüyorum)</strong>&nbsp;şanzıman yavşıyo, yani nasıl diyeyim vuruntu ve kerkinme her zaman olmuyor. <div></div><div>Sağ üst motor kulağı aracı aldığımda kopuk olduğunu farkettik ve değiştirdim aracımda herhangi bir vibrasyon yok, bekleme modunda vites N de olsun olmasın&nbsp;az biraz çok az 3-4 kere hoplama gibi birşey oluyor. </div><div>Alt takozlara baktırdım sağlam dendi. Şanzıman kulaklarına ve motorun diğer kulağına baktırmadım. Aklımda ama bugün öğlen arası baktırmaya gidicem yazarım sizlere durumu.. </div>]]>
   </description>
   <pubDate>Mon, 07 Apr 2014 09:33:37 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=498266&amp;title=yag-basinci-hk#498266</guid>
  </item>
  <item>
   <title><![CDATA[Yağ basıncı hk, : bence sorun motor kulaklar&#305;nda.benimde...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=497942&amp;title=yag-basinci-hk#497942</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3423">ramtas</a><br /><strong>Konu:</strong> 34400<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Nisan&nbsp;2014 Saat 12:03<br /><br />bence sorun motor kulaklarında.benimde alt motor kulağı dağılmış servis 200-300 tl arası dedi masrafına.usta vites geçişlerinde vurma yapar dedi başka bi sıkıntı olmaz&nbsp; yavas git dedi .malum benzin pompası&nbsp; sensör vs 1000 tl harcayınca ona sıra gelmedi . <br>]]>
   </description>
   <pubDate>Sat, 05 Apr 2014 12:03:55 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=497942&amp;title=yag-basinci-hk#497942</guid>
  </item>
  <item>
   <title><![CDATA[Yağ basıncı hk, : Ge&#231;mi&#351; olsun. Bence son ustaya...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=497930&amp;title=yag-basinci-hk#497930</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11113">pusutr</a><br /><strong>Konu:</strong> 34400<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Nisan&nbsp;2014 Saat 10:51<br /><br />Geçmiş olsun. Bence son ustaya tekrar gidip durumu paylaşmalısınız. <br><span style="font-size:10px"><br /><br />Düzenleyen pusutr - 05&nbsp;Nisan&nbsp;2014 Saat 10:55</span>]]>
   </description>
   <pubDate>Sat, 05 Apr 2014 10:51:51 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=497930&amp;title=yag-basinci-hk#497930</guid>
  </item>
  <item>
   <title><![CDATA[Yağ basıncı hk, : Hep&#305;m&#305;z&#305;n ortak s&#305;k&#305;nt&#305;s&#305; usta...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=497817&amp;title=yag-basinci-hk#497817</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11357">samet206</a><br /><strong>Konu:</strong> 34400<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Nisan&nbsp;2014 Saat 20:24<br /><br />Hepımızın ortak sıkıntısı usta işte adamlar beceremıyor ki becerebılse ışını guzel yapsa sıkıntı kalmıcakta markayla modelle alakası yok bu durumların bu durumlar ıkı parça değişimi yapıp ustayım dıye dukkan açanlar yuzunden veya patron oldum deyıp elını yağa pıse surmeden 15 yaşındakı çıraklara ış yaptıranlar yuzunden.geçmış olsun sızede dıcek bısey bulamadım orjınal dıye baskı balata değiştirdim 134 bınde araç 138 bınde baskı balata çekmıyor 2012&nbsp; kasımda fren balatalarını değiştirdim el frenı kaçırıyor en tepede zor tutuyor&nbsp; bı pasta cıla yaptırdım her tarafı sumuklu böcek yurumuş gıbı oldu mılletle bu yuzden tartışmaktan gıtcek yerde kalmadı ne yapıcam bılmıyorum Allah herkesın yardımcısı olsun :) vuruntu olayı akstanda yapabılır benım başımda o dertte var 2.vıteste vuruyor dığer vıteslerde sorun yok manuel araç aksa baktırdım bıseyler değişti biraz para ödedım yıne aynısı oldu vıtes topuzu sallanıyor falan daha öncelerı aksla ılgılı sorunlar yaşadıysanız buda aklınızda bulunsun.<br>]]>
   </description>
   <pubDate>Fri, 04 Apr 2014 20:24:12 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=497817&amp;title=yag-basinci-hk#497817</guid>
  </item>
  <item>
   <title><![CDATA[Yağ basıncı hk, : &#231;ok &#252;z&#252;ld&#252;m hocam ya. ama araba...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=497815&amp;title=yag-basinci-hk#497815</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11281">ahmed206</a><br /><strong>Konu:</strong> 34400<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Nisan&nbsp;2014 Saat 20:18<br /><br />çok üzüldüm hocam ya. ama araba yağ gibi olmuştu, o kablolar yine yanmış olmasın?<div>bence son ustaya gidip başına ekşiyin</div>]]>
   </description>
   <pubDate>Fri, 04 Apr 2014 20:18:32 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=497815&amp;title=yag-basinci-hk#497815</guid>
  </item>
  <item>
   <title><![CDATA[Yağ basıncı hk, :   eurest Yazd&#305;: Sa&#287;ol dostum...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=497801&amp;title=yag-basinci-hk#497801</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11599">kaf kef</a><br /><strong>Konu:</strong> 34400<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Nisan&nbsp;2014 Saat 18:46<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: eurest" alt="Orjinalini yazan: eurest" style="vertical-align: text-bottom;" /> <strong>eurest Yazdı:</strong><br /><br />Sağol dostum ama sorunum hala devam ediyor ve ben eski orijinal parçayı çöpe attım meğer sağlammış al bide buradan yak.</td></tr></table><div>kardeşim gecmiş olsun ne bahtsızmıssın be bende sanayiye gıtmeye korkuyorum :( var benımde aracımın sorunu kafam rahat değil ustamla goruştum gıdecem benımde şimdi baya bı sıkıntı cıkacak dıye ınan korkuyorum ya kardesım peugeot askı varda boyle olunca aşkda kalmıyor....</div>]]>
   </description>
   <pubDate>Fri, 04 Apr 2014 18:46:23 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=497801&amp;title=yag-basinci-hk#497801</guid>
  </item>
  <item>
   <title><![CDATA[Yağ basıncı hk, :  Ben eski orijinal par&#231;ay&#305; &#231;&#246;pe...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=497761&amp;title=yag-basinci-hk#497761</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13663">serkomser</a><br /><strong>Konu:</strong> 34400<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Nisan&nbsp;2014 Saat 15:54<br /><br />Ben eski orijinal parçayı çöpe attım.<span style="font-size:10px"><br /><br />Düzenleyen eurest - 23&nbsp;Haziran&nbsp;2014 Saat 09:16</span>]]>
   </description>
   <pubDate>Fri, 04 Apr 2014 15:54:16 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=497761&amp;title=yag-basinci-hk#497761</guid>
  </item>
  <item>
   <title><![CDATA[Yağ basıncı hk, : &#246;ncelikle ge&#231;mi&#351; olsun ve bu payla&#351;&#305;m&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=497757&amp;title=yag-basinci-hk#497757</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3191">oguzhan29</a><br /><strong>Konu:</strong> 34400<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Nisan&nbsp;2014 Saat 15:51<br /><br />öncelikle geçmiş olsun ve bu paylaşımı yapıp bilgilendirdiğin içinde teşekkürler.<br>]]>
   </description>
   <pubDate>Fri, 04 Apr 2014 15:51:43 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=497757&amp;title=yag-basinci-hk#497757</guid>
  </item>
  <item>
   <title><![CDATA[Yağ basıncı hk, :  Selam, ara&#231;ta sesler devam ediyor.D&#252;zenleyen...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=497755&amp;title=yag-basinci-hk#497755</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13663">serkomser</a><br /><strong>Konu:</strong> 34400<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Nisan&nbsp;2014 Saat 15:43<br /><br />Selam, araçta sesler <span style="line-height: 1.4;">devam ediyor.</span><span style="font-size:10px"><br /><br />Düzenleyen serkomser - 26&nbsp;Haziran&nbsp;2014 Saat 15:47</span>]]>
   </description>
   <pubDate>Fri, 04 Apr 2014 15:43:21 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=497755&amp;title=yag-basinci-hk#497755</guid>
  </item>
  <item>
   <title><![CDATA[Yağ basıncı hk, :  4 g&#252;nl&#252;k sanayi maceram ve harcad&#305;&#287;&#305;m...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=496770&amp;title=yag-basinci-hk#496770</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13663">serkomser</a><br /><strong>Konu:</strong> 34400<br /><strong>Gönderim Zamanı:</strong> 31&nbsp;Mart&nbsp;2014 Saat 12:26<br /><br />4 günlük sanayi maceram ve harcadığım paranın haddi&nbsp;nihayet son buldu. Paylaşmak istedim sizlerle...]]>
   </description>
   <pubDate>Mon, 31 Mar 2014 12:26:52 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34400&amp;PID=496770&amp;title=yag-basinci-hk#496770</guid>
  </item>
 </channel>
</rss>
