 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : klima gazı bitmiş?</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Sohbet \ Muhabbet : klima gazı bitmiş?]]></description>
  <pubDate>Fri, 01 May 2026 19:28:03 +0000</pubDate>
  <lastBuildDate>Mon, 31 Mar 2014 11:46:26 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=34388</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[klima gazı bitmiş? :   206x-line Yazd&#305;:Bu gaz dolum...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34388&amp;PID=496760&amp;title=klima-gazi-bitmis#496760</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7593">tlp</a><br /><strong>Konu:</strong> 34388<br /><strong>Gönderim Zamanı:</strong> 31&nbsp;Mart&nbsp;2014 Saat 11:46<br /><br /> <table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: 206x-line" alt="Orjinalini yazan: 206x-line" style="vertical-align: text-bottom;" /> <strong>206x-line Yazdı:</strong><br /><br />Bu gaz dolum işlemi uzun sürermi</td></tr></table> <br /><br />5-10 dk]]>
   </description>
   <pubDate>Mon, 31 Mar 2014 11:46:26 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34388&amp;PID=496760&amp;title=klima-gazi-bitmis#496760</guid>
  </item> 
  <item>
   <title><![CDATA[klima gazı bitmiş? : Bu gaz dolum i&#351;lemi uzun s&#252;rermi...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34388&amp;PID=496753&amp;title=klima-gazi-bitmis#496753</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9308">206x-line</a><br /><strong>Konu:</strong> 34388<br /><strong>Gönderim Zamanı:</strong> 31&nbsp;Mart&nbsp;2014 Saat 11:05<br /><br />Bu gaz dolum işlemi uzun sürermi ]]>
   </description>
   <pubDate>Mon, 31 Mar 2014 11:05:56 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34388&amp;PID=496753&amp;title=klima-gazi-bitmis#496753</guid>
  </item> 
  <item>
   <title><![CDATA[klima gazı bitmiş? : borularda ka&#231;ak varsa maliyetli...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34388&amp;PID=496745&amp;title=klima-gazi-bitmis#496745</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2369">yawruaslan</a><br /><strong>Konu:</strong> 34388<br /><strong>Gönderim Zamanı:</strong> 31&nbsp;Mart&nbsp;2014 Saat 10:12<br /><br />borularda kaçak varsa maliyetli olur benden soylemesi umarım oyle bişey yoktur :(]]>
   </description>
   <pubDate>Mon, 31 Mar 2014 10:12:13 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34388&amp;PID=496745&amp;title=klima-gazi-bitmis#496745</guid>
  </item> 
  <item>
   <title><![CDATA[klima gazı bitmiş? : &#199;ok k&#252;&#231;&#252;k k&#305;lcal &#231;atlaklar veya...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34388&amp;PID=496743&amp;title=klima-gazi-bitmis#496743</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10539">_ali_</a><br /><strong>Konu:</strong> 34388<br /><strong>Gönderim Zamanı:</strong> 31&nbsp;Mart&nbsp;2014 Saat 10:08<br /><br />Çok küçük kılcal çatlaklar veya kaçaklar olabiliyor, bunu tespit için renkli bir gaz basılıyor, 1-2 hafta sonra bir ışık ve gözlükle borular falan muayene ediliyor, kılcal çatlakların olduğu yerlerde renkli kaçaklar görülebiliyor. <br><br>Geçen yıl bir esnaf beni resmen kazıkladı, gaz basıp 80-TL aldı, 1-2 hafta sonra soğutma bitince tekrar gittim, kaçak var radyatör falan sökülecek 1000-TL masraf olabilir dedi. Elletmedim ve başka bir yere gittim, vanayı açınca basınçlı hava çıktı borudan, teknisyen klima gazı değil bu çoğunu normal hava basmış dedi :D sonra yukarıda bahsettiğim işlemi yaptı,&nbsp; muayenesi bakımı vs. yine 80-TL verdim. <br><br>1 Yıl olacak gücü biraz azalmış ama hala soğutuyor, idare eder ama bakıma gideceğim yine de, iyi esnaf böyle kazanıyor işte.<br>]]>
   </description>
   <pubDate>Mon, 31 Mar 2014 10:08:51 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34388&amp;PID=496743&amp;title=klima-gazi-bitmis#496743</guid>
  </item> 
  <item>
   <title><![CDATA[klima gazı bitmiş? : te&#351;ekk&#252;rler cevaplar i&#231;in pazartesi...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34388&amp;PID=496402&amp;title=klima-gazi-bitmis#496402</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8493">C@GL@R</a><br /><strong>Konu:</strong> 34388<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Mart&nbsp;2014 Saat 13:55<br /><br />teşekkürler cevaplar için pazartesi kontrol ettireyim kaçak yoksa basalım sıcaklar bastırdı kliması olmuyor artık :D<br>]]>
   </description>
   <pubDate>Sat, 29 Mar 2014 13:55:07 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34388&amp;PID=496402&amp;title=klima-gazi-bitmis#496402</guid>
  </item> 
  <item>
   <title><![CDATA[klima gazı bitmiş? : Klima gaz&#305; da u&#231;ar gider kullanmasan...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34388&amp;PID=496399&amp;title=klima-gazi-bitmis#496399</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13674">ercn86</a><br /><strong>Konu:</strong> 34388<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Mart&nbsp;2014 Saat 13:45<br /><br />Klima gazı da uçar gider kullanmasan bile kimbilir eski sahibi klimayı ne kadar kullandı gazın olup olmaması sadece kaçakla alakalı değil gideceksin klimacıya bağlayacak makinayı kaçak olup olmadığını görecek ki yoksa basar gazı alır 70 80 lira ( sanayi ) bu kadar :)]]>
   </description>
   <pubDate>Sat, 29 Mar 2014 13:45:45 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34388&amp;PID=496399&amp;title=klima-gazi-bitmis#496399</guid>
  </item> 
  <item>
   <title><![CDATA[klima gazı bitmiş? : &#199;evrende herhangi bir klimac&#305;ya...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34388&amp;PID=496398&amp;title=klima-gazi-bitmis#496398</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7593">tlp</a><br /><strong>Konu:</strong> 34388<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Mart&nbsp;2014 Saat 13:40<br /><br />Çevrende herhangi bir klimacıya git onlarda vardır<br />Ben bizim mağazaya bakıma gelen abilere yaptırmıştım :)]]>
   </description>
   <pubDate>Sat, 29 Mar 2014 13:40:34 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34388&amp;PID=496398&amp;title=klima-gazi-bitmis#496398</guid>
  </item> 
  <item>
   <title><![CDATA[klima gazı bitmiş? :   bitter Yazd&#305;:gaz ka&#231;aktan u&#231;ar...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34388&amp;PID=496397&amp;title=klima-gazi-bitmis#496397</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8493">C@GL@R</a><br /><strong>Konu:</strong> 34388<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Mart&nbsp;2014 Saat 13:38<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: bitter" alt="Orjinalini yazan: bitter" style="vertical-align: text-bottom;" /> <strong>bitter Yazdı:</strong><br /><br />gaz kaçaktan uçar gider. yada klima kış içinde bi kaç kez çalışmamışsa borularda sorun olmamasına ragmen sızar.</td></tr></table><br><br>borularda sorun yoksa nerden sızıyorki acaba? demekki gazın kalmaması illa kaçağa işaret değil sanırım tşkler cvp için pazartesi bi bakıtayım<br>]]>
   </description>
   <pubDate>Sat, 29 Mar 2014 13:38:25 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34388&amp;PID=496397&amp;title=klima-gazi-bitmis#496397</guid>
  </item> 
  <item>
   <title><![CDATA[klima gazı bitmiş? : ka&#231;ak oldu&#287;unu nas&#305;l anlar&#305;z &#351;uan...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34388&amp;PID=496393&amp;title=klima-gazi-bitmis#496393</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8493">C@GL@R</a><br /><strong>Konu:</strong> 34388<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Mart&nbsp;2014 Saat 13:32<br /><br />kaçak olduğunu nasıl anlarız şuan için normalde hava basıp test ediyorlarmış ama anlamadığım klima gazı biten araçta hiç gaz kalmazmı tornavida ile dolum kısmına bastırdım sıfır gaz var..klima gazı bitmesinin anlamı nedir içinde gaz olur görevinimi yapamaz yoksa gaz kaybolurmu?<br>]]>
   </description>
   <pubDate>Sat, 29 Mar 2014 13:32:12 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34388&amp;PID=496393&amp;title=klima-gazi-bitmis#496393</guid>
  </item> 
  <item>
   <title><![CDATA[klima gazı bitmiş? : ge&#231;en yaz cliom i&#231;in gaz bast&#305;racakt&#305;m....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34388&amp;PID=496391&amp;title=klima-gazi-bitmis#496391</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=12847">Raskaa</a><br /><strong>Konu:</strong> 34388<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Mart&nbsp;2014 Saat 13:30<br /><br />geçen yaz cliom için gaz bastıracaktım. yanlış hatırlamıyorsam&nbsp;renault servisinde 120tl civarında fiyat vermişlerdi. sanayide ise&nbsp;50tl-70tl civarındaydı. sisteminizde kaçak yoksa maliyet sadece bu olur yani.]]>
   </description>
   <pubDate>Sat, 29 Mar 2014 13:30:18 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34388&amp;PID=496391&amp;title=klima-gazi-bitmis#496391</guid>
  </item> 
  <item>
   <title><![CDATA[klima gazı bitmiş? : arkada&#351;lar k&#305;&#351;&#305;n ald&#305;&#287;&#305;m&#305;z i&#231;in...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34388&amp;PID=496387&amp;title=klima-gazi-bitmis#496387</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8493">C@GL@R</a><br /><strong>Konu:</strong> 34388<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Mart&nbsp;2014 Saat 13:26<br /><br />arkadaşlar kışın aldığımız için aracı dikkat etmedim klima soğuk üflemiyor komprosör devreye giriyor gazı varmı diye baktım sıfır hava bile kalmamış bu klima sisteminde kaçakmı olduğunu gösteriyor? klima gazı maliyeti nedir kaçak yoksa?<br>]]>
   </description>
   <pubDate>Sat, 29 Mar 2014 13:26:59 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34388&amp;PID=496387&amp;title=klima-gazi-bitmis#496387</guid>
  </item> 
 </channel>
</rss>
