 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Hararet</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Arac&#305;n&#305;z Hakk&#305;ndaki T&#252;m Sorular : Hararet]]></description>
  <pubDate>Mon, 04 May 2026 05:11:48 +0000</pubDate>
  <lastBuildDate>Thu, 27 Mar 2014 09:12:16 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=34298</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Hararet : BEN&#304;M 1998 306 1.6 GRILL&#304;FE HORTUM...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495804&amp;title=hararet#495804</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13693">mamaju</a><br /><strong>Konu:</strong> 34298<br /><strong>Gönderim Zamanı:</strong> 27&nbsp;Mart&nbsp;2014 Saat 09:12<br /><br />BENİM &nbsp;1998 306 1.6 GRILLİFE &nbsp;HORTUM ŞİŞİRİYO &nbsp;VE HARARET SÜREKLİ 90-100 ARASI :d NE YAPAYIM&nbsp;]]>
   </description>
   <pubDate>Thu, 27 Mar 2014 09:12:16 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495804&amp;title=hararet#495804</guid>
  </item>
  <item>
   <title><![CDATA[Hararet : Benim ara&#231; k&#305;&#351;&#305;n 90&amp;#039;&#305; &#231;ok...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495800&amp;title=hararet#495800</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10539">_ali_</a><br /><strong>Konu:</strong> 34298<br /><strong>Gönderim Zamanı:</strong> 27&nbsp;Mart&nbsp;2014 Saat 09:00<br /><br />Benim araç kışın 90'ı çok nadir geçiyor, yazın da sıkışık trafikte 90'a dayanıyor, yukarı pek çıkmıyor.<br>]]>
   </description>
   <pubDate>Thu, 27 Mar 2014 09:00:15 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495800&amp;title=hararet#495800</guid>
  </item>
  <item>
   <title><![CDATA[Hararet :   rahmi 206 Yazd&#305;:e&#287;er 100&amp;#039;&#252;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495769&amp;title=hararet#495769</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13440">zr'lmn</a><br /><strong>Konu:</strong> 34298<br /><strong>Gönderim Zamanı:</strong> 26&nbsp;Mart&nbsp;2014 Saat 22:45<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: rahmi 206" alt="Orjinalini yazan: rahmi 206" style="vertical-align: text-bottom;" /> <strong>rahmi 206 Yazdı:</strong><br /><br />eğer 100'ü geçmiyor ve fan açıyorsa araç,bence telaşlanacak,servise koşacak bir durum yok.şehir içi kısa mesafede ve özellikle dur-kalk'larda hararetin kısa sürede yükselmesi pugeot gibi bir araç için anormal bir durum değil bana göre.bahsettiğiniz aracı stop ettikten 15 dakika veya yarım saat sonra çalıştırdığınızda hararetin 90-100'lerde gezmesi &nbsp;(muhtemelen aracı çalıştırdığınızda direkt olarak fanı açıyordur)bende de zaman zaman oluşan bir durum.dikkatimi çeken şey;aracım fan açmak üzereyken ama henüz fan devreye girmeden aracımı stop edip 15 veya 30dk sonra çalıştırdığımda meydana gelmesi,bunun haricinde öyle bir durumla karşılaşmadım</td></tr></table>&nbsp;<div><br></div><div>teşekkürler peugeot u ilk defa kullandığım için telaşlanıyorum</div><div><br></div>]]>
   </description>
   <pubDate>Wed, 26 Mar 2014 22:45:35 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495769&amp;title=hararet#495769</guid>
  </item>
  <item>
   <title><![CDATA[Hararet : e&#287;er 100&amp;#039;&#252; ge&#231;miyor ve fan...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495768&amp;title=hararet#495768</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13689">rahmi 206</a><br /><strong>Konu:</strong> 34298<br /><strong>Gönderim Zamanı:</strong> 26&nbsp;Mart&nbsp;2014 Saat 22:40<br /><br />eğer 100'ü geçmiyor ve fan açıyorsa araç,bence telaşlanacak,servise koşacak bir durum yok.şehir içi kısa mesafede ve özellikle dur-kalk'larda hararetin kısa sürede yükselmesi pugeot gibi bir araç için anormal bir durum değil bana göre.bahsettiğiniz aracı stop ettikten 15 dakika veya yarım saat sonra çalıştırdığınızda hararetin 90-100'lerde gezmesi &nbsp;(muhtemelen aracı çalıştırdığınızda direkt olarak fanı açıyordur)bende de zaman zaman oluşan bir durum.dikkatimi çeken şey;aracım fan açmak üzereyken ama henüz fan devreye girmeden aracımı stop edip 15 veya 30dk sonra çalıştırdığımda meydana gelmesi,bunun haricinde öyle bir durumla karşılaşmadım]]>
   </description>
   <pubDate>Wed, 26 Mar 2014 22:40:18 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495768&amp;title=hararet#495768</guid>
  </item>
  <item>
   <title><![CDATA[Hararet :   murat222 Yazd&#305;:  zr&amp;#039;lmn...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495767&amp;title=hararet#495767</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13440">zr'lmn</a><br /><strong>Konu:</strong> 34298<br /><strong>Gönderim Zamanı:</strong> 26&nbsp;Mart&nbsp;2014 Saat 22:29<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: murat222" alt="Orjinalini yazan: murat222" style="vertical-align: text-bottom;" /> <strong>murat222 Yazdı:</strong><br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: zr'lmn" alt="Orjinalini yazan: zr'lmn" style="vertical-align: text-bottom;" /> <strong>zr'lmn Yazdı:</strong><br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: murat222" alt="Orjinalini yazan: murat222" style="vertical-align: text-bottom;" /> <strong>murat222 Yazdı:</strong><br /><br />bunlar hararetli arabalar hemen hemen her Peugeot sahibi bundan şikayetçi bende merak ediyorum yazın ne olacak diye :D</td></tr></table><div><br></div><div>daha önce focus 1 vardı hayatta 90 ı geçmezdi ilk görünce şeytan çarpmışa döndüm :) tırstım baya bir ama normal diyorlar bakalım yazın ne olacak arabanın arkasında 5 lt li su bidonu taşıyorum :))&nbsp;</div><p></td></tr></table></p><p>bende yaşadım aynı olayı<img src="https://forum.peugeotturkey.com/smileys/smiley4.gif" border="0" alt="Big smile" title="Big smile" /></p></td></tr></table><div><br></div><div><br></div><div><br></div><div>ne yaptın pekı :)) çözüm yolu nedir ?&nbsp;</div>]]>
   </description>
   <pubDate>Wed, 26 Mar 2014 22:29:36 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495767&amp;title=hararet#495767</guid>
  </item>
  <item>
   <title><![CDATA[Hararet :   rahmi 206 Yazd&#305;:ben bu hararet...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495766&amp;title=hararet#495766</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13440">zr'lmn</a><br /><strong>Konu:</strong> 34298<br /><strong>Gönderim Zamanı:</strong> 26&nbsp;Mart&nbsp;2014 Saat 22:28<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: rahmi 206" alt="Orjinalini yazan: rahmi 206" style="vertical-align: text-bottom;" /> <strong>rahmi 206 Yazdı:</strong><br /><br />ben bu hararet sorununu 2 yıl yaşadım,diyebilirim ki hararet 100'ün altına hiç inmedi(tabi motor ısındıktan sonra :) ) bu durum uzun yol'da da değişmedi,gaza bastıkça 100-115 lere kadar çıktığına defalarca şahit oldum.5-6 kez'de hararet 120 yi bulup stop ikaz lambasını yaktı.aracımda termostat'tan tutun da müşüre ve hatta radyatör değişimine kadar herşeyi denedik olmadı taa ki devirdaim pompasını değiştirene kadar.ilk bakılması gereken yere en son baktığımız için bir sürü masraf ettim ama çok şükür halloldu,şimdi 100'ü hiç geçmiyor.şunuda sizlerle paylaşmak istiyorum;aracım bir kaç kez hararette tavan yaptığı için usta conta yakmış ve suya hava veriyor olabilir,contayı değişelim demişti bende kabul etmiştim.işin ilginç yanı;2 sene boyunca sürekli hararet yapan ve bir kaç kez tavan yapmasına rağmen reglefeye götürdüğümde kapakta hiç bir bozulma veya yamulma yoktu :)</td></tr></table><div><br></div><div>arabanın 10 bin km önce bütün ağır bakımları yapılmış faturaları mevcut. devirdaim değişmiş. hani normal bir durum mu yoksa servise koşmam gereken bir durum mu ?</div>]]>
   </description>
   <pubDate>Wed, 26 Mar 2014 22:28:38 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495766&amp;title=hararet#495766</guid>
  </item>
  <item>
   <title><![CDATA[Hararet :   zr&amp;#039;lmn Yazd&#305;:  murat222...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495765&amp;title=hararet#495765</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13140">murat222</a><br /><strong>Konu:</strong> 34298<br /><strong>Gönderim Zamanı:</strong> 26&nbsp;Mart&nbsp;2014 Saat 22:24<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: zr'lmn" alt="Orjinalini yazan: zr'lmn" style="vertical-align: text-bottom;" /> <strong>zr'lmn Yazdı:</strong><br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: murat222" alt="Orjinalini yazan: murat222" style="vertical-align: text-bottom;" /> <strong>murat222 Yazdı:</strong><br /><br />bunlar hararetli arabalar hemen hemen her Peugeot sahibi bundan şikayetçi bende merak ediyorum yazın ne olacak diye :D</td></tr></table><div><br></div><div>daha önce focus 1 vardı hayatta 90 ı geçmezdi ilk görünce şeytan çarpmışa döndüm :) tırstım baya bir ama normal diyorlar bakalım yazın ne olacak arabanın arkasında 5 lt li su bidonu taşıyorum :))&nbsp;</div><p></td></tr></table></p><p>bende yaşadım aynı olayı<img src="https://forum.peugeotturkey.com/smileys/smiley4.gif" border="0" alt="Big smile" title="Big smile" /></p>]]>
   </description>
   <pubDate>Wed, 26 Mar 2014 22:24:51 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495765&amp;title=hararet#495765</guid>
  </item>
  <item>
   <title><![CDATA[Hararet : ben bu hararet sorununu 2 y&#305;l...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495735&amp;title=hararet#495735</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13689">rahmi 206</a><br /><strong>Konu:</strong> 34298<br /><strong>Gönderim Zamanı:</strong> 26&nbsp;Mart&nbsp;2014 Saat 18:40<br /><br />ben bu hararet sorununu 2 yıl yaşadım,diyebilirim ki hararet 100'ün altına hiç inmedi(tabi motor ısındıktan sonra :) ) bu durum uzun yol'da da değişmedi,gaza bastıkça 100-115 lere kadar çıktığına defalarca şahit oldum.5-6 kez'de hararet 120 yi bulup stop ikaz lambasını yaktı.aracımda termostat'tan tutun da müşüre ve hatta radyatör değişimine kadar herşeyi denedik olmadı taa ki devirdaim pompasını değiştirene kadar.ilk bakılması gereken yere en son baktığımız için bir sürü masraf ettim ama çok şükür halloldu,şimdi 100'ü hiç geçmiyor.şunuda sizlerle paylaşmak istiyorum;aracım bir kaç kez hararette tavan yaptığı için usta conta yakmış ve suya hava veriyor olabilir,contayı değişelim demişti bende kabul etmiştim.işin ilginç yanı;2 sene boyunca sürekli hararet yapan ve bir kaç kez tavan yapmasına rağmen reglefeye götürdüğümde kapakta hiç bir bozulma veya yamulma yoktu :)]]>
   </description>
   <pubDate>Wed, 26 Mar 2014 18:40:41 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495735&amp;title=hararet#495735</guid>
  </item>
  <item>
   <title><![CDATA[Hararet :   fatihpekgoz Yazd&#305;:Termostat...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495232&amp;title=hararet#495232</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13627">erdem-120</a><br /><strong>Konu:</strong> 34298<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Mart&nbsp;2014 Saat 23:25<br /><br /> <table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: fatihpekgoz" alt="Orjinalini yazan: fatihpekgoz" style="vertical-align: text-bottom;" /> <strong>fatihpekgoz Yazdı:</strong><br /><br />Termostat acmasa uzun yol sehir ici ayirmaz.</td></tr></table> <br />Uzun yolda motora çarpan hava zaten belirli bir yerde tutmazmı ısıyı ? Yanlış anlaşılmasın yanlışım varsa düzelteyim :)]]>
   </description>
   <pubDate>Mon, 24 Mar 2014 23:25:10 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495232&amp;title=hararet#495232</guid>
  </item>
  <item>
   <title><![CDATA[Hararet : Termostat acmasa uzun yol sehir...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495229&amp;title=hararet#495229</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=5538">sezar206</a><br /><strong>Konu:</strong> 34298<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Mart&nbsp;2014 Saat 23:09<br /><br />Termostat acmasa uzun yol sehir ici ayirmaz.]]>
   </description>
   <pubDate>Mon, 24 Mar 2014 23:09:59 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495229&amp;title=hararet#495229</guid>
  </item>
  <item>
   <title><![CDATA[Hararet :   cavit cevo Yazd&#305;:pejo larda...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495223&amp;title=hararet#495223</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13440">zr'lmn</a><br /><strong>Konu:</strong> 34298<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Mart&nbsp;2014 Saat 22:15<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: cavit cevo" alt="Orjinalini yazan: cavit cevo" style="vertical-align: text-bottom;" /> <strong>cavit cevo Yazdı:</strong><br /><br />pejo larda hararret hep yüksekte sanırım iki arabamdada aynı <br></td></tr></table><div><br></div><div>sıkıntı olmasın da isterse 200 de dursun :)</div>]]>
   </description>
   <pubDate>Mon, 24 Mar 2014 22:15:29 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495223&amp;title=hararet#495223</guid>
  </item>
  <item>
   <title><![CDATA[Hararet : pejo larda hararret hep y&#252;ksekte...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495220&amp;title=hararet#495220</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13437">cavit cevo</a><br /><strong>Konu:</strong> 34298<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Mart&nbsp;2014 Saat 22:07<br /><br />pejo larda hararret hep yüksekte sanırım iki arabamdada aynı <br>]]>
   </description>
   <pubDate>Mon, 24 Mar 2014 22:07:19 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495220&amp;title=hararet#495220</guid>
  </item>
  <item>
   <title><![CDATA[Hararet :   erdem-120 Yazd&#305;:Hocam termostat...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495219&amp;title=hararet#495219</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13440">zr'lmn</a><br /><strong>Konu:</strong> 34298<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Mart&nbsp;2014 Saat 22:06<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: erdem-120" alt="Orjinalini yazan: erdem-120" style="vertical-align: text-bottom;" /> <strong>erdem-120 Yazdı:</strong><br /><br />Hocam termostat açmıyor 90 lık termostat al en fazla 15 liralık bişeydir riske atma aracını 110 derece de zaten aracın zarar görmeye başlar . Bu sorunun çözümü budur ve eminim dene :)</td></tr></table><div><br></div><div>dırek 90 a dayanmıyor 90 da termostat acıyor hararet 80 lere fılan dusuyor ama sehır ıcıne gırınce orada yukselıyor hararet</div>]]>
   </description>
   <pubDate>Mon, 24 Mar 2014 22:06:12 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495219&amp;title=hararet#495219</guid>
  </item>
  <item>
   <title><![CDATA[Hararet : Hocam termostat a&#231;m&#305;yor 90 l&#305;k...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495217&amp;title=hararet#495217</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13627">erdem-120</a><br /><strong>Konu:</strong> 34298<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Mart&nbsp;2014 Saat 22:03<br /><br />Hocam termostat açmıyor 90 lık termostat al en fazla 15 liralık bişeydir riske atma aracını 110 derece de zaten aracın zarar görmeye başlar . Bu sorunun çözümü budur ve eminim dene :)]]>
   </description>
   <pubDate>Mon, 24 Mar 2014 22:03:32 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495217&amp;title=hararet#495217</guid>
  </item>
  <item>
   <title><![CDATA[Hararet : cok tesekkurler b&#305;lg&#305;ler &#305;c&#305;n...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495200&amp;title=hararet#495200</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13440">zr'lmn</a><br /><strong>Konu:</strong> 34298<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Mart&nbsp;2014 Saat 20:25<br /><br />cok tesekkurler bılgıler ıcın :)&nbsp;<div><br></div>]]>
   </description>
   <pubDate>Mon, 24 Mar 2014 20:25:27 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34298&amp;PID=495200&amp;title=hararet#495200</guid>
  </item>
 </channel>
</rss>
