 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 4.viteste ugultu</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Arac&#305;n&#305;z Hakk&#305;ndaki T&#252;m Sorular : 4.viteste ugultu]]></description>
  <pubDate>Sat, 02 May 2026 23:47:22 +0000</pubDate>
  <lastBuildDate>Sun, 09 Mar 2014 17:43:13 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=34030</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[4.viteste ugultu : moralim alt &#252;st olmus durumda...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34030&amp;PID=490218&amp;title=4-viteste-ugultu#490218</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11945">E.B</a><br /><strong>Konu:</strong> 34030<br /><strong>Gönderim Zamanı:</strong> 09&nbsp;Mart&nbsp;2014 Saat 17:43<br /><br />moralim alt üst olmus durumda siz böyle yazinca birazda olsa kafam rahatliyor yarin sabah 8 de gidicem direk fakat eger yag eksikse hangi derece yag koydurucam bir bilgisi olan varmi? hangi marka ?]]>
   </description>
   <pubDate>Sun, 09 Mar 2014 17:43:13 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34030&amp;PID=490218&amp;title=4-viteste-ugultu#490218</guid>
  </item>
  <item>
   <title><![CDATA[4.viteste ugultu :   E.B Yazd&#305;:arkadaslar arabami...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34030&amp;PID=490148&amp;title=4-viteste-ugultu#490148</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11165">SDYMZ</a><br /><strong>Konu:</strong> 34030<br /><strong>Gönderim Zamanı:</strong> 09&nbsp;Mart&nbsp;2014 Saat 14:26<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: E.B" alt="Orjinalini yazan: E.B" style="vertical-align: text-bottom;" /> <strong>E.B Yazdı:</strong><br /><br />arkadaslar arabami full bakima soktum sözde full mus bunu anladim özel serviste yaptirdim 1500 tl masraf döktüm arabayi ilk aldigimda araba rölantideyken fır fır bir ses vardi sanki fan sesi gibi debriyaja bastigimda gidiyordu ustaya sordugumda debriyaj bilyasindan dedi 3-4 gün kullan gecmezse bakariz dedi sanzimana hic ellemedik biz dedi <br><br>neyse bu 3-4 gün lük kullanimin son günü dün eve dönerken 4. viteste gaza basmamla birlikte bir islik sesi ve ugultu geliyor gaza basmamla  artiyor diger viteslerde yapmiyor<br><br>hakikaten ne yapicagimi sasirdim arabami hic ama hic satmak istemiyorum ama sürekli birşey cikiyor buda beni mutsuz ediyor <br><br>sizce ne yapmaliyim bu vitesteki ugultu konusunda ? sanziman yagi eksikligi olabilirmi veya tecrübesi olan varmi bilgisi olan bana yardimci olabilicek biri :(<br><br>Herkese tek tek teşekkür ederim..</td></tr></table> hocam şanzıman yağı eksik olabilir keçelerden kaçırmıştır. veya şanzımanın içinde 4 adet rulman var onların ömrü dolmuş olabilir bu durum benim başıma gelmişti araç ısındıkça ses artıyor. ama ilk şanzıman yağını baktır derim<br>]]>
   </description>
   <pubDate>Sun, 09 Mar 2014 14:26:45 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34030&amp;PID=490148&amp;title=4-viteste-ugultu#490148</guid>
  </item>
  <item>
   <title><![CDATA[4.viteste ugultu : yani aslinda full bakim derken...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34030&amp;PID=490114&amp;title=4-viteste-ugultu#490114</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11945">E.B</a><br /><strong>Konu:</strong> 34030<br /><strong>Gönderim Zamanı:</strong> 09&nbsp;Mart&nbsp;2014 Saat 12:49<br /><br />yani aslinda full bakim derken subap fincanlari degişti piston segmani ve full takim conta yeniledik neden degişti diye sorarsaniz araçta sadece hirilti sesi aliyordum acmisken degiştirelim dediler 5w50 mobil 1 yag koydular hava filtresi yag filtresi bujiler degişti ]]>
   </description>
   <pubDate>Sun, 09 Mar 2014 12:49:10 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34030&amp;PID=490114&amp;title=4-viteste-ugultu#490114</guid>
  </item>
  <item>
   <title><![CDATA[4.viteste ugultu : Full bak&#305;m&#305;n i&#231;inde neler yap&#305;ld&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34030&amp;PID=490113&amp;title=4-viteste-ugultu#490113</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9585">Serkan</a><br /><strong>Konu:</strong> 34030<br /><strong>Gönderim Zamanı:</strong> 09&nbsp;Mart&nbsp;2014 Saat 12:43<br /><br />Full bakımın içinde neler yapıldı hocam?]]>
   </description>
   <pubDate>Sun, 09 Mar 2014 12:43:56 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34030&amp;PID=490113&amp;title=4-viteste-ugultu#490113</guid>
  </item>
  <item>
   <title><![CDATA[4.viteste ugultu : Arkada&#351;lar eger sanziman yagi...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34030&amp;PID=490112&amp;title=4-viteste-ugultu#490112</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11945">E.B</a><br /><strong>Konu:</strong> 34030<br /><strong>Gönderim Zamanı:</strong> 09&nbsp;Mart&nbsp;2014 Saat 12:40<br /><br />Arkadaşlar eger sanziman yagi eksikse hangi marka hangi derece yag koydurmam gerekiyor biliyormusunuz <br /><br />aracim 307 xsi 2.0 136 hp benzinli]]>
   </description>
   <pubDate>Sun, 09 Mar 2014 12:40:53 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34030&amp;PID=490112&amp;title=4-viteste-ugultu#490112</guid>
  </item>
  <item>
   <title><![CDATA[4.viteste ugultu : arkadaslar arabami full bakima...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=34030&amp;PID=490108&amp;title=4-viteste-ugultu#490108</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11945">E.B</a><br /><strong>Konu:</strong> 34030<br /><strong>Gönderim Zamanı:</strong> 09&nbsp;Mart&nbsp;2014 Saat 11:56<br /><br />arkadaslar arabami full bakima soktum sözde full mus bunu anladim özel serviste yaptirdim 1500 tl masraf döktüm arabayi ilk aldigimda araba rölantideyken fır fır bir ses vardi sanki fan sesi gibi debriyaja bastigimda gidiyordu ustaya sordugumda debriyaj bilyasindan dedi 3-4 gün kullan gecmezse bakariz dedi sanzimana hic ellemedik biz dedi <br /><br />neyse bu 3-4 gün lük kullanimin son günü dün eve dönerken 4. viteste gaza basmamla birlikte bir islik sesi ve ugultu geliyor gaza basmamla  artiyor diger viteslerde yapmiyor<br /><br />hakikaten ne yapicagimi sasirdim arabami hic ama hic satmak istemiyorum ama sürekli birşey cikiyor buda beni mutsuz ediyor <br /><br />sizce ne yapmaliyim bu vitesteki ugultu konusunda ? sanziman yagi eksikligi olabilirmi veya tecrübesi olan varmi bilgisi olan bana yardimci olabilicek biri :(<br /><br />Herkese tek tek teşekkür ederim.. ]]>
   </description>
   <pubDate>Sun, 09 Mar 2014 11:56:47 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=34030&amp;PID=490108&amp;title=4-viteste-ugultu#490108</guid>
  </item>
 </channel>
</rss>
