 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Tesisat Yardım</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Peugeot Ses Sistemleri : Tesisat Yardım]]></description>
  <pubDate>Sat, 02 May 2026 13:24:08 +0000</pubDate>
  <lastBuildDate>Tue, 28 Jan 2014 17:30:06 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=33296</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Tesisat Yardım : tamam abim tekrar te&#351;ekk&#252;rlerr...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33296&amp;PID=478176&amp;title=tesisat-yardim#478176</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3191">oguzhan29</a><br /><strong>Konu:</strong> 33296<br /><strong>Gönderim Zamanı:</strong> 28&nbsp;Ocak&nbsp;2014 Saat 17:30<br /><br />tamam abim tekrar teşekkürlerr&nbsp;]]>
   </description>
   <pubDate>Tue, 28 Jan 2014 17:30:06 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33296&amp;PID=478176&amp;title=tesisat-yardim#478176</guid>
  </item>
  <item>
   <title><![CDATA[Tesisat Yardım : Rica ederim.. Kabin yapamam ama...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33296&amp;PID=478170&amp;title=tesisat-yardim#478170</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13076">barishrocker</a><br /><strong>Konu:</strong> 33296<br /><strong>Gönderim Zamanı:</strong> 28&nbsp;Ocak&nbsp;2014 Saat 16:52<br /><br />Rica ederim.. Kabin yapamam ama biraz bilgim var. ürünün sitesinde önerilen kabinlere bakarak kendin yaptırabilirsin. ]]>
   </description>
   <pubDate>Tue, 28 Jan 2014 16:52:56 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33296&amp;PID=478170&amp;title=tesisat-yardim#478170</guid>
  </item>
  <item>
   <title><![CDATA[Tesisat Yardım : anlad&#305;m abim bilgilendirme i&#231;in...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33296&amp;PID=478166&amp;title=tesisat-yardim#478166</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3191">oguzhan29</a><br /><strong>Konu:</strong> 33296<br /><strong>Gönderim Zamanı:</strong> 28&nbsp;Ocak&nbsp;2014 Saat 16:15<br /><br />anladım abim bilgilendirme için teşekkürler&nbsp;]]>
   </description>
   <pubDate>Tue, 28 Jan 2014 16:15:12 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33296&amp;PID=478166&amp;title=tesisat-yardim#478166</guid>
  </item>
  <item>
   <title><![CDATA[Tesisat Yardım : Kabin &#246;l&#231;&#252;leri ezbere yap&#305;lmaz....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33296&amp;PID=478145&amp;title=tesisat-yardim#478145</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13076">barishrocker</a><br /><strong>Konu:</strong> 33296<br /><strong>Gönderim Zamanı:</strong> 28&nbsp;Ocak&nbsp;2014 Saat 12:49<br /><br />Kabin ölçüleri ezbere yapılmaz. Uzun bass yerine kısa ama sertolsun diyorsan kapalı kutu yaoabilirsin. Portu iptal et yani.]]>
   </description>
   <pubDate>Tue, 28 Jan 2014 12:49:51 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33296&amp;PID=478145&amp;title=tesisat-yardim#478145</guid>
  </item>
  <item>
   <title><![CDATA[Tesisat Yardım : arkada&#351;lar zaten &#231;ok deli vuruyor...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33296&amp;PID=478122&amp;title=tesisat-yardim#478122</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3191">oguzhan29</a><br /><strong>Konu:</strong> 33296<br /><strong>Gönderim Zamanı:</strong> 28&nbsp;Ocak&nbsp;2014 Saat 10:26<br /><br />arkadaşlar zaten çok deli vuruyor inletiyorda ben ne yappsam daha da vurur diyorum zaten kabini büyütsem mi mesela]]>
   </description>
   <pubDate>Tue, 28 Jan 2014 10:26:40 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33296&amp;PID=478122&amp;title=tesisat-yardim#478122</guid>
  </item>
  <item>
   <title><![CDATA[Tesisat Yardım :   barishrocker Yazd&#305;:Sm dk600...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33296&amp;PID=477811&amp;title=tesisat-yardim#477811</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7967">Alicilik</a><br /><strong>Konu:</strong> 33296<br /><strong>Gönderim Zamanı:</strong> 26&nbsp;Ocak&nbsp;2014 Saat 21:39<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: barishrocker" alt="Orjinalini yazan: barishrocker" style="vertical-align: text-bottom;" /> <strong>barishrocker Yazdı:</strong><br /><br />Sm dk600 2ohm 600rms..eğer sub 4ohm 600rms ise alinin dediği doğru olabilir. Ayrıca teypte tek rca varsa voltaj bölündüğü için de güç azalacaktır. Tam modelleri ve özellikleri yazarsanız daha sağlıklı olur;)</td></tr></table><div><br></div><div>+1,</div>]]>
   </description>
   <pubDate>Sun, 26 Jan 2014 21:39:29 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33296&amp;PID=477811&amp;title=tesisat-yardim#477811</guid>
  </item>
  <item>
   <title><![CDATA[Tesisat Yardım : Sm dk600 2ohm 600rms..e&#287;er sub...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33296&amp;PID=477810&amp;title=tesisat-yardim#477810</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13076">barishrocker</a><br /><strong>Konu:</strong> 33296<br /><strong>Gönderim Zamanı:</strong> 26&nbsp;Ocak&nbsp;2014 Saat 21:38<br /><br />Sm dk600 2ohm 600rms..eğer sub 4ohm 600rms ise alinin dediği doğru olabilir. Ayrıca teypte tek rca varsa voltaj bölündüğü için de güç azalacaktır. Tam modelleri ve özellikleri yazarsanız daha sağlıklı olur;)]]>
   </description>
   <pubDate>Sun, 26 Jan 2014 21:38:14 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33296&amp;PID=477810&amp;title=tesisat-yardim#477810</guid>
  </item>
  <item>
   <title><![CDATA[Tesisat Yardım : Gain ayarlar&#305;nda br s&#305;k&#305;nt&#305; vard&#305;r....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33296&amp;PID=477805&amp;title=tesisat-yardim#477805</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7967">Alicilik</a><br /><strong>Konu:</strong> 33296<br /><strong>Gönderim Zamanı:</strong> 26&nbsp;Ocak&nbsp;2014 Saat 21:31<br /><br />Gain ayarlarında br sıkıntı vardır. Bir de amfi kaç ohm da 600w rms veriyor ? 4ohm da 600w rms vermek ciddi bir iş çünkü. 5000wlık peak güce sahip olması lazım.&nbsp;]]>
   </description>
   <pubDate>Sun, 26 Jan 2014 21:31:18 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33296&amp;PID=477805&amp;title=tesisat-yardim#477805</guid>
  </item>
  <item>
   <title><![CDATA[Tesisat Yardım : Sert bass verenlerden akl&#305;ma kicker...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33296&amp;PID=477773&amp;title=tesisat-yardim#477773</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13076">barishrocker</a><br /><strong>Konu:</strong> 33296<br /><strong>Gönderim Zamanı:</strong> 26&nbsp;Ocak&nbsp;2014 Saat 20:01<br /><br />Sert bass verenlerden aklıma kicker geliyor.. Cadence dinlemedim ama normalde 600rms sub iyi çalması lazım..kutuda da sorun olabilir..]]>
   </description>
   <pubDate>Sun, 26 Jan 2014 20:01:19 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33296&amp;PID=477773&amp;title=tesisat-yardim#477773</guid>
  </item>
  <item>
   <title><![CDATA[Tesisat Yardım : Bug&#252;n arac&#305;ma tesisat ba&#287;latt&#305;m...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33296&amp;PID=477763&amp;title=tesisat-yardim#477763</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3191">oguzhan29</a><br /><strong>Konu:</strong> 33296<br /><strong>Gönderim Zamanı:</strong> 26&nbsp;Ocak&nbsp;2014 Saat 18:58<br /><br />Bugün aracıma tesisat bağlattım tesisatım şöyle<div><br></div><div>Teyp:Pioneer mixtrax son seri modelini hatırlamıyorum</div><div>Amfi: Jameson usa-505 2500 watt 4 kanal</div><div>Amfi: Sound magus 600 rms bas anfisi</div><div>Hoparlör :Pioneer 600 watt 100 rms 3 tkm</div><div>Bass: Cadence S1 1200 watt 600 rms</div><div>Tiz : Pioneer Tss 20</div><div>Kapasitör : Cadence 2,5 farad</div><div><br></div><div>Aracımı tesisatı herşeyi mükemmel oldu fakat bas da iyi ama böyle sanki tam inletmiyorr bu böylemi yoksa ayardan mıdır yardımlarınızı bekliyorum</div>]]>
   </description>
   <pubDate>Sun, 26 Jan 2014 18:58:27 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33296&amp;PID=477763&amp;title=tesisat-yardim#477763</guid>
  </item>
 </channel>
</rss>
