 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Devir saati sabit durmuyor</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Arac&#305;n&#305;z Hakk&#305;ndaki T&#252;m Sorular : Devir saati sabit durmuyor]]></description>
  <pubDate>Sat, 02 May 2026 04:23:18 +0000</pubDate>
  <lastBuildDate>Wed, 22 Jan 2014 15:49:11 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=33201</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Devir saati sabit durmuyor : te&#351;ekk&#252;rler arkada&#351;lar sanayiye...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33201&amp;PID=476576&amp;title=devir-saati-sabit-durmuyor#476576</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6920">Bavik</a><br /><strong>Konu:</strong> 33201<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Ocak&nbsp;2014 Saat 15:49<br /><br />teşekkürler arkadaşlar sanayiye gidince o zaman ilk iş rolanti valfi rolanti motorunu vb şeyleri kontrol ettirmek olacak<div><br></div>]]>
   </description>
   <pubDate>Wed, 22 Jan 2014 15:49:11 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33201&amp;PID=476576&amp;title=devir-saati-sabit-durmuyor#476576</guid>
  </item>
  <item>
   <title><![CDATA[Devir saati sabit durmuyor :   Bavik Yazd&#305;:Merhaba arkada&#351;lar...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33201&amp;PID=476432&amp;title=devir-saati-sabit-durmuyor#476432</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 33201<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Ocak&nbsp;2014 Saat 09:57<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Bavik" alt="Orjinalini yazan: Bavik" style="vertical-align: text-bottom;" /> <strong>Bavik Yazdı:</strong><br /><br />Merhaba arkadaşlar yaşayan vardır diye düşünüyorum aracımda yolda giderken yavaşladığım zaman devir saati çok düşük devirlere iniyor stoplayacak gibi veya stopluyor bugun bu durumla çok karşılaştım ve stopladı benzinde ve lpg de aynı şeyi yaptı biraz durduktan sonra kapalı olarak tekrar çalıştıgında benzeri bir durum olmadı yanlız motor sıcakken fan açtıgı sıralarda rolatiyi çok sallıyor nelerden kaynaklı olabilir teşekkürler</td></tr></table><div><br></div><div>%90 Rolanti motorundan kaynaklanıyor, içi temizlenip birde içinde bulunan conta tarzı ekipmanı değişince geçiyor. Bendede aynı problem vardı ustam halletti. (Sportif hava fitresi kullanılan araçlarda olur bu)</div>]]>
   </description>
   <pubDate>Wed, 22 Jan 2014 09:57:12 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33201&amp;PID=476432&amp;title=devir-saati-sabit-durmuyor#476432</guid>
  </item>
  <item>
   <title><![CDATA[Devir saati sabit durmuyor : kuscunun ded&#305;g&#305; g&#305;b&#305; rolant&#305; valf&#305;nden...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33201&amp;PID=476430&amp;title=devir-saati-sabit-durmuyor#476430</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9571">muro_60</a><br /><strong>Konu:</strong> 33201<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Ocak&nbsp;2014 Saat 09:47<br /><br />kuscunun dedıgı &nbsp;gıbı rolantı valfınden yapar benzın lpg farketmez ikisındede yapar fan calıştıgında otomatık olarak motor devrını yuksetmesı lazım klıma varsa rolantıde acın yıne düşme yapacaktır valfe baktırın]]>
   </description>
   <pubDate>Wed, 22 Jan 2014 09:47:31 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33201&amp;PID=476430&amp;title=devir-saati-sabit-durmuyor#476430</guid>
  </item>
  <item>
   <title><![CDATA[Devir saati sabit durmuyor :   Bavik Yazd&#305;:2 ay &#246;ncesinde...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33201&amp;PID=476401&amp;title=devir-saati-sabit-durmuyor#476401</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11593">kuscu38</a><br /><strong>Konu:</strong> 33201<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Ocak&nbsp;2014 Saat 02:58<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Bavik" alt="Orjinalini yazan: Bavik" style="vertical-align: text-bottom;" /> <strong>Bavik Yazdı:</strong><br /><br />2 ay öncesinde bi gaz ayarı yaptırdım ama bi daha ustaya görünmek gerekicek sanırım benzin map ı dediğimz şey ney <br></td></tr></table><div><br></div><div>Rolanti ayar valfi! aracın rolantisinin dengede olmasını az yakmasını devirli çalışmasını sağlar!</div>]]>
   </description>
   <pubDate>Wed, 22 Jan 2014 02:58:13 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33201&amp;PID=476401&amp;title=devir-saati-sabit-durmuyor#476401</guid>
  </item>
  <item>
   <title><![CDATA[Devir saati sabit durmuyor : &#304;lk olarak gaz kelebe&#287;ini temizleyin....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33201&amp;PID=476316&amp;title=devir-saati-sabit-durmuyor#476316</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7922">KenBlockJR</a><br /><strong>Konu:</strong> 33201<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Ocak&nbsp;2014 Saat 21:59<br /><br />İlk olarak gaz kelebeğini temizleyin.]]>
   </description>
   <pubDate>Tue, 21 Jan 2014 21:59:08 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33201&amp;PID=476316&amp;title=devir-saati-sabit-durmuyor#476316</guid>
  </item>
  <item>
   <title><![CDATA[Devir saati sabit durmuyor : 2 ay &#246;ncesinde bi gaz ayar&#305; yapt&#305;rd&#305;m...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33201&amp;PID=476310&amp;title=devir-saati-sabit-durmuyor#476310</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6920">Bavik</a><br /><strong>Konu:</strong> 33201<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Ocak&nbsp;2014 Saat 21:47<br /><br />2 ay öncesinde bi gaz ayarı yaptırdım ama bi daha ustaya görünmek gerekicek sanırım benzin map ı dediğimz şey ney <br>]]>
   </description>
   <pubDate>Tue, 21 Jan 2014 21:47:48 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33201&amp;PID=476310&amp;title=devir-saati-sabit-durmuyor#476310</guid>
  </item>
  <item>
   <title><![CDATA[Devir saati sabit durmuyor : lpg ayar&#305;na bi bakt&#305;r s&#305;k&#305;nt&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33201&amp;PID=476301&amp;title=devir-saati-sabit-durmuyor#476301</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11593">kuscu38</a><br /><strong>Konu:</strong> 33201<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Ocak&nbsp;2014 Saat 21:20<br /><br />lpg ayarına bi baktır sıkıntı yoksa benzim map'ında sıkıntı olma ihtimali yüksek araç fan açtığında yapıyorsa eğer akü zayıf kalıyor demektir şarj dinamosunu tam vazife görmüyor olabilir!!!&nbsp;]]>
   </description>
   <pubDate>Tue, 21 Jan 2014 21:20:45 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33201&amp;PID=476301&amp;title=devir-saati-sabit-durmuyor#476301</guid>
  </item>
  <item>
   <title><![CDATA[Devir saati sabit durmuyor : Merhaba arkada&#351;lar ya&#351;ayan vard&#305;r...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33201&amp;PID=476299&amp;title=devir-saati-sabit-durmuyor#476299</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6920">Bavik</a><br /><strong>Konu:</strong> 33201<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Ocak&nbsp;2014 Saat 21:14<br /><br />Merhaba arkadaşlar yaşayan vardır diye düşünüyorum aracımda yolda giderken yavaşladığım zaman devir saati çok düşük devirlere iniyor stoplayacak gibi veya stopluyor bugun bu durumla çok karşılaştım ve stopladı benzinde ve lpg de aynı şeyi yaptı biraz durduktan sonra kapalı olarak tekrar çalıştıgında benzeri bir durum olmadı yanlız motor sıcakken fan açtıgı sıralarda rolatiyi çok sallıyor nelerden kaynaklı olabilir teşekkürler]]>
   </description>
   <pubDate>Tue, 21 Jan 2014 21:14:46 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33201&amp;PID=476299&amp;title=devir-saati-sabit-durmuyor#476299</guid>
  </item>
 </channel>
</rss>
