 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : PROBLEMİ ANLAYAMADIM :/</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Arac&#305;n&#305;z Hakk&#305;ndaki T&#252;m Sorular : PROBLEMİ ANLAYAMADIM :/]]></description>
  <pubDate>Sat, 02 May 2026 10:03:58 +0000</pubDate>
  <lastBuildDate>Sun, 02 Mar 2014 13:44:46 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=33115</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[PROBLEMİ ANLAYAMADIM :/ : iyi &#231;&#246;z&#252;lmesine sevindim. ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33115&amp;PID=487130&amp;title=problemi-anlayamadim#487130</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3191">oguzhan29</a><br /><strong>Konu:</strong> 33115<br /><strong>Gönderim Zamanı:</strong> 02&nbsp;Mart&nbsp;2014 Saat 13:44<br /><br />iyi çözülmesine sevindim.<br>]]>
   </description>
   <pubDate>Sun, 02 Mar 2014 13:44:46 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33115&amp;PID=487130&amp;title=problemi-anlayamadim#487130</guid>
  </item>
  <item>
   <title><![CDATA[PROBLEMİ ANLAYAMADIM :/ : Bobin ve lpg enjekt&#246;r&#252; de&#287;i&#351;ti...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33115&amp;PID=487127&amp;title=problemi-anlayamadim#487127</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13283">bluemoon</a><br /><strong>Konu:</strong> 33115<br /><strong>Gönderim Zamanı:</strong> 02&nbsp;Mart&nbsp;2014 Saat 12:55<br /><br />Bobin ve lpg enjektörü değişti araba zıpkın gibi oldu yağlar ve tüm filtreler geğisti bakımlarıda yapıldı hiçbir sorun sıkıntı yok herkeze teşekkürler ..]]>
   </description>
   <pubDate>Sun, 02 Mar 2014 12:55:30 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33115&amp;PID=487127&amp;title=problemi-anlayamadim#487127</guid>
  </item>
  <item>
   <title><![CDATA[PROBLEMİ ANLAYAMADIM :/ : 200-300 aras&#305; diye tahmin ediyorum...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33115&amp;PID=475618&amp;title=problemi-anlayamadim#475618</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7819">Sertan</a><br /><strong>Konu:</strong> 33115<br /><strong>Gönderim Zamanı:</strong> 20&nbsp;Ocak&nbsp;2014 Saat 01:07<br /><br />200-300 arası diye tahmin ediyorum fiyatları hocam ama araştırmak en iyisi&nbsp;]]>
   </description>
   <pubDate>Mon, 20 Jan 2014 01:07:38 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33115&amp;PID=475618&amp;title=problemi-anlayamadim#475618</guid>
  </item>
  <item>
   <title><![CDATA[PROBLEMİ ANLAYAMADIM :/ : usta LPG beyni pahal&#305; bi&#351;ey mibanada...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33115&amp;PID=475612&amp;title=problemi-anlayamadim#475612</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13283">bluemoon</a><br /><strong>Konu:</strong> 33115<br /><strong>Gönderim Zamanı:</strong> 20&nbsp;Ocak&nbsp;2014 Saat 00:43<br /><br />usta LPG beyni pahalı bişey mi<br><br>banada Bobini ve buji leri değiştirelim dedi usta anlamadım vallaha ne yapacagımı]]>
   </description>
   <pubDate>Mon, 20 Jan 2014 00:43:22 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33115&amp;PID=475612&amp;title=problemi-anlayamadim#475612</guid>
  </item>
  <item>
   <title><![CDATA[PROBLEMİ ANLAYAMADIM :/ : usta ayn&#305; sorunu ben yasad&#305;m t&#305;pat&#305;p...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33115&amp;PID=475204&amp;title=problemi-anlayamadim#475204</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7819">Sertan</a><br /><strong>Konu:</strong> 33115<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Ocak&nbsp;2014 Saat 02:20<br /><br />usta aynı sorunu ben yasadım tıpatıp aynı benzinde problem yok lpg de titremeler gaz yememe gibi sorunlar vardı. Önce bobinler değişti arıza devam etti. lpg havası alındı kablolar değişti sorun devam etti. En son olarak lpg beyni değiştirildi ve suan sorunsuz kullanıyorum. Hemde garantisi vardı 5 kurus parada ödemedim. Sana tavsiyem lpg beyni ile ilgilen.<div><br></div>]]>
   </description>
   <pubDate>Sat, 18 Jan 2014 02:20:57 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33115&amp;PID=475204&amp;title=problemi-anlayamadim#475204</guid>
  </item>
  <item>
   <title><![CDATA[PROBLEMİ ANLAYAMADIM :/ : Abi devaml&#305; aygazdan al&#305;yorum,...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33115&amp;PID=475193&amp;title=problemi-anlayamadim#475193</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13283">bluemoon</a><br /><strong>Konu:</strong> 33115<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Ocak&nbsp;2014 Saat 01:53<br /><br /><div>Abi devamlı aygazdan alıyorum, hep öneriliyor ondan olmaz diye düşünüyorum</div>]]>
   </description>
   <pubDate>Sat, 18 Jan 2014 01:53:00 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33115&amp;PID=475193&amp;title=problemi-anlayamadim#475193</guid>
  </item>
  <item>
   <title><![CDATA[PROBLEMİ ANLAYAMADIM :/ : Gaz ayar&#305; yapt&#305;r&#305;n ordaki usta...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33115&amp;PID=475164&amp;title=problemi-anlayamadim#475164</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=12515">kursat3006</a><br /><strong>Konu:</strong> 33115<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Ocak&nbsp;2014 Saat 23:55<br /><br />Gaz ayarı yaptırın ordaki usta tesisatı kontrol edip daha net bilgi verecektir. Bir de 1.6 xr 206 olmaz tek kapiysa xs olması lazım :)]]>
   </description>
   <pubDate>Fri, 17 Jan 2014 23:55:13 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33115&amp;PID=475164&amp;title=problemi-anlayamadim#475164</guid>
  </item>
  <item>
   <title><![CDATA[PROBLEMİ ANLAYAMADIM :/ : Hava yapma durumlar&#305; var m&#305; bunlar&#305;n?...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33115&amp;PID=475102&amp;title=problemi-anlayamadim#475102</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 33115<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Ocak&nbsp;2014 Saat 21:03<br /><br />Hava yapma durumları var mı bunların? Ondan da olabilir. Aynı zamanda Salih abinin dedigi gibi yakıtı aynı yerden almaya özen gösterin ve kaliteli olsun ve bir sey daha, lpg beyninde de bir sıkıntı olabilir. Benim diger aracımda oldu fakat o bu araclardan cok baska kıyaslamıyorum ama beyini degistirince düzeldi. :)]]>
   </description>
   <pubDate>Fri, 17 Jan 2014 21:03:12 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33115&amp;PID=475102&amp;title=problemi-anlayamadim#475102</guid>
  </item>
  <item>
   <title><![CDATA[PROBLEMİ ANLAYAMADIM :/ :  Selam&#305;n aleyk&#252;m abiler ve karde&#351;lerarac&#305;m...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=33115&amp;PID=475080&amp;title=problemi-anlayamadim#475080</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13283">bluemoon</a><br /><strong>Konu:</strong> 33115<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Ocak&nbsp;2014 Saat 19:25<br /><br /><br>Selamın aleyküm abiler ve kardeşler<br><br>aracım 1999 model 1.6 XR tek kapı<br><br>araba bazen kendi kendine titreme yapıyor , pat pat pat diye sanki gaz yemiyor..<br>Ama benzinde tam canavar gibi fırlıyor minicoper gelemiyor peşine&nbsp;<br>lpg ye aldıgımda gaza biraz fazla basınca yemiyor titretmeye baslıyor pat pat pat diye.<br>ustaya gösterdim bujilerden dedi , ama bujileri değişeli 10 gün oldu<br>Bobinden dediler tamam değişeyim dedim ama bu sefer bir yapıp bir yapmamaya başladı acaba sorun başkabir yerdemi gerçekten Bobindemi .<br><br>Bu sorunu yaşayan varmı , yardımcı olursanım memnun olurum , şimdiden teşekkür ederim ...]]>
   </description>
   <pubDate>Fri, 17 Jan 2014 19:25:10 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=33115&amp;PID=475080&amp;title=problemi-anlayamadim#475080</guid>
  </item>
 </channel>
</rss>
