 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Mazot gostergesi</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Arac&#305;n&#305;z Hakk&#305;ndaki T&#252;m Sorular : Mazot gostergesi]]></description>
  <pubDate>Sun, 03 May 2026 09:06:54 +0000</pubDate>
  <lastBuildDate>Fri, 06 Dec 2013 08:03:32 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=32359</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Mazot gostergesi : Arkdaslar yardimci cevalariniz...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=32359&amp;PID=465830&amp;title=mazot-gostergesi#465830</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11607">efesbright</a><br /><strong>Konu:</strong> 32359<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Aralık&nbsp;2013 Saat 08:03<br /><br />Arkdaslar yardimci cevalariniz icin tesekkur ederim o gun cok ugras verdim ama 100tl daha yakit ekleyince duzeldi. Fakat smdide on fiskiyeler su vermiyor. Surekli bir ariza durumumu var bu araclarda anlamiyorum sorunsuz olarak kullanamadim 1.5 yildir. Defalarca farlar patliyor park,fren ve sinyal ozellikle. Yine park lambasi patlamis durduk yere anlamsiz anlam veremiyorum artik :)]]>
   </description>
   <pubDate>Fri, 06 Dec 2013 08:03:32 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=32359&amp;PID=465830&amp;title=mazot-gostergesi#465830</guid>
  </item>
  <item>
   <title><![CDATA[Mazot gostergesi : &#350;amand&#305;ra tak&#305;l&#305; kalm&#305;&#351;t&#305;r arac&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=32359&amp;PID=465499&amp;title=mazot-gostergesi#465499</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11001">xdesign_206</a><br /><strong>Konu:</strong> 32359<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Aralık&nbsp;2013 Saat 11:20<br /><br />Şamandıra takılı kalmıştır aracı biraz sallayın şamandıra kendine gelir eğer gelmezse servise gidip şamandıra kalibre ayarı yaptırmanız lazım.]]>
   </description>
   <pubDate>Wed, 04 Dec 2013 11:20:54 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=32359&amp;PID=465499&amp;title=mazot-gostergesi#465499</guid>
  </item>
  <item>
   <title><![CDATA[Mazot gostergesi : EVET DOSTUM BEN BU Y&#220;ZDEN FULL...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=32359&amp;PID=465493&amp;title=mazot-gostergesi#465493</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=12966">206+bülent</a><br /><strong>Konu:</strong> 32359<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Aralık&nbsp;2013 Saat 10:59<br /><br />EVET DOSTUM BEN BU YÜZDEN FULL DEPO TESLİM ETTİM ARACI aracı parkedince kapıyı aç biraz salla çalıştırdığında düzeldiğini göreceksin]]>
   </description>
   <pubDate>Wed, 04 Dec 2013 10:59:08 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=32359&amp;PID=465493&amp;title=mazot-gostergesi#465493</guid>
  </item>
  <item>
   <title><![CDATA[Mazot gostergesi : bazen oluyor normal bir&#351;ey. ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=32359&amp;PID=465398&amp;title=mazot-gostergesi#465398</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11113">pusutr</a><br /><strong>Konu:</strong> 32359<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Aralık&nbsp;2013 Saat 18:40<br /><br />bazen oluyor normal birşey.<br>]]>
   </description>
   <pubDate>Tue, 03 Dec 2013 18:40:48 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=32359&amp;PID=465398&amp;title=mazot-gostergesi#465398</guid>
  </item>
  <item>
   <title><![CDATA[Mazot gostergesi : Arkdaslar dun aracima yakit aldim...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=32359&amp;PID=465385&amp;title=mazot-gostergesi#465385</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11607">efesbright</a><br /><strong>Konu:</strong> 32359<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Aralık&nbsp;2013 Saat 17:00<br /><br />Arkdaslar dun aracima yakit aldim 50tl civari. Yakit seviyesini gostermiyor. Surekli isik yaniyor ve yakit minimum seviyede gozukuyor. Neden olabilir bu durum? Pompaci samandira takilmistr ani fren vs yap duzelir dedide o sekilde duzelmedi. 100km yakin yol yaptim yani yakit koydu araca sizce neden kaynaklanir bu durum elektronik birsey olabilirmi?]]>
   </description>
   <pubDate>Tue, 03 Dec 2013 17:00:19 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=32359&amp;PID=465385&amp;title=mazot-gostergesi#465385</guid>
  </item>
 </channel>
</rss>
