 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Golf &#039; e Gelen Takas Teklifi</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Ara&#231; Al&#305;m &amp; Sat&#305;m&#305; : Golf &#039; e Gelen Takas Teklifi]]></description>
  <pubDate>Mon, 04 May 2026 23:24:11 +0000</pubDate>
  <lastBuildDate>Fri, 22 Nov 2013 00:13:20 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=32158</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Golf &#039; e Gelen Takas Teklifi : Konu kilit ilgilenen arkada&#351;lara...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=463057&amp;title=golf-e-gelen-takas-teklifi#463057</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10321">Burak</a><br /><strong>Konu:</strong> 32158<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Kasım&nbsp;2013 Saat 00:13<br /><br />Konu kilit ilgilenen arkadaşlara tekrar teşekkürler.<br>]]>
   </description>
   <pubDate>Fri, 22 Nov 2013 00:13:20 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=463057&amp;title=golf-e-gelen-takas-teklifi#463057</guid>
  </item>
  <item>
   <title><![CDATA[Golf &#039; e Gelen Takas Teklifi : zaten o kadar etmez o araba:) ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=463029&amp;title=golf-e-gelen-takas-teklifi#463029</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11281">ahmed206</a><br /><strong>Konu:</strong> 32158<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Kasım&nbsp;2013 Saat 22:02<br /><br />zaten o kadar etmez o araba:)]]>
   </description>
   <pubDate>Thu, 21 Nov 2013 22:02:53 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=463029&amp;title=golf-e-gelen-takas-teklifi#463029</guid>
  </item>
  <item>
   <title><![CDATA[Golf &#039; e Gelen Takas Teklifi :   Burak Yazd&#305;:vaz ge&#231;tik arkada&#351;lar...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=463009&amp;title=golf-e-gelen-takas-teklifi#463009</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 32158<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Kasım&nbsp;2013 Saat 20:18<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Burak" alt="Orjinalini yazan: Burak" style="vertical-align: text-bottom;" /> <strong>Burak Yazdı:</strong><br /><br />vaz geçtik arkadaşlar aracın sahibine olumsuz cevabı yolladım ilginiz için teşekkürler<br><br></td></tr></table><div><br></div><div>herzaman</div>]]>
   </description>
   <pubDate>Thu, 21 Nov 2013 20:18:15 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=463009&amp;title=golf-e-gelen-takas-teklifi#463009</guid>
  </item>
  <item>
   <title><![CDATA[Golf &#039; e Gelen Takas Teklifi : vaz ge&#231;tik arkada&#351;lar arac&#305;n sahibine...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=463004&amp;title=golf-e-gelen-takas-teklifi#463004</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10321">Burak</a><br /><strong>Konu:</strong> 32158<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Kasım&nbsp;2013 Saat 19:57<br /><br />vaz geçtik arkadaşlar aracın sahibine olumsuz cevabı yolladım ilginiz için teşekkürler<br><br>]]>
   </description>
   <pubDate>Thu, 21 Nov 2013 19:57:02 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=463004&amp;title=golf-e-gelen-takas-teklifi#463004</guid>
  </item>
  <item>
   <title><![CDATA[Golf &#039; e Gelen Takas Teklifi : &#304;lan buram buram &#252;&#231;ka&#287;&#305;t kokuyor....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=462999&amp;title=golf-e-gelen-takas-teklifi#462999</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=12189">Can Oksuz</a><br /><strong>Konu:</strong> 32158<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Kasım&nbsp;2013 Saat 19:36<br /><br />İlan buram buram üçkağıt kokuyor. 10 cm eğilen bir kaput değişir mi radyatör değişir mi sizce?<br><br>Tamam araba çok güzel lafımız yok ama ben olsam çok beğenmeme rağmen almazdım.<br><br>Esas sorun şu. BMW motoru 230binde bitiyorsa o araba hor kullanılmıştır. Muhtemelen yanlamalar vs ile oynamadık yeri de kalmamıştır. Aynı aracın cabrio olmayan 1.8is modelini bir arkadaşımın babası kullanıyordu. Arabayı tam 790bin kmde sattılar ve bildiğim kadarıyla motoru yenilenmemişti. Ama maalesef bu araçların kıymeti bilinmiyor. Hor kullanılıyor ve motorları haddinden çok erken bitiyor. İyi düşünün derim.<br>]]>
   </description>
   <pubDate>Thu, 21 Nov 2013 19:36:01 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=462999&amp;title=golf-e-gelen-takas-teklifi#462999</guid>
  </item>
  <item>
   <title><![CDATA[Golf &#039; e Gelen Takas Teklifi : 230000 de 0 motor yap&#305;lm&#305;&#351; &#351;uan...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=462988&amp;title=golf-e-gelen-takas-teklifi#462988</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7880">tongucuk</a><br /><strong>Konu:</strong> 32158<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Kasım&nbsp;2013 Saat 18:16<br /><br />230000 de 0 motor yapılmış şuan 260000 de yani heran yenibi motormu yapma gerekebilir anlamadım hem burak sen golften memnun değilmisin neden bence adam teklif ediyorsa üzerine sen para iste bu araba için <br>]]>
   </description>
   <pubDate>Thu, 21 Nov 2013 18:16:22 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=462988&amp;title=golf-e-gelen-takas-teklifi#462988</guid>
  </item>
  <item>
   <title><![CDATA[Golf &#039; e Gelen Takas Teklifi : Kime denk getirirsem &#231;ak&#305;y&#305;m gitsin...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=462980&amp;title=golf-e-gelen-takas-teklifi#462980</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11130">volkanC2</a><br /><strong>Konu:</strong> 32158<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Kasım&nbsp;2013 Saat 17:49<br /><br /><b>Kime denk getirirsem çakıyım gitsin gibi bi ilan bence uzak dur kardeşim.</b>]]>
   </description>
   <pubDate>Thu, 21 Nov 2013 17:49:45 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=462980&amp;title=golf-e-gelen-takas-teklifi#462980</guid>
  </item>
  <item>
   <title><![CDATA[Golf &#039; e Gelen Takas Teklifi : eee do&#287;ru demi&#351; abi adam :D ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=462955&amp;title=golf-e-gelen-takas-teklifi#462955</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=12580">ozncnercn</a><br /><strong>Konu:</strong> 32158<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Kasım&nbsp;2013 Saat 17:15<br /><br />eee doğru demiş abi adam :D]]>
   </description>
   <pubDate>Thu, 21 Nov 2013 17:15:49 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=462955&amp;title=golf-e-gelen-takas-teklifi#462955</guid>
  </item>
  <item>
   <title><![CDATA[Golf &#039; e Gelen Takas Teklifi : babama s&#246;yledigimde bmw cabriodan...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=462953&amp;title=golf-e-gelen-takas-teklifi#462953</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10321">Burak</a><br /><strong>Konu:</strong> 32158<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Kasım&nbsp;2013 Saat 17:10<br /><br />babama söyledigimde bmw cabriodan inip golfemi binecekmiş kafasımı iyi dedi :D]]>
   </description>
   <pubDate>Thu, 21 Nov 2013 17:10:44 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=462953&amp;title=golf-e-gelen-takas-teklifi#462953</guid>
  </item>
  <item>
   <title><![CDATA[Golf &#039; e Gelen Takas Teklifi : Alt k&#305;s&#305;mdaki ac&#305;klamalarda de&#287;i&#351;ensiz...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=462945&amp;title=golf-e-gelen-takas-teklifi#462945</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11725">KILIÇ</a><br /><strong>Konu:</strong> 32158<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Kasım&nbsp;2013 Saat 16:49<br /><br />Alt kısımdaki acıklamalarda değişensiz yazıyor ama yukarda da kaput ve radyatör değişdi bir ay önce diyor :))]]>
   </description>
   <pubDate>Thu, 21 Nov 2013 16:49:35 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=462945&amp;title=golf-e-gelen-takas-teklifi#462945</guid>
  </item>
  <item>
   <title><![CDATA[Golf &#039; e Gelen Takas Teklifi : Ara&#231; fena Burak. Tam benim istedi&#287;im...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=462944&amp;title=golf-e-gelen-takas-teklifi#462944</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7967">Alicilik</a><br /><strong>Konu:</strong> 32158<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Kasım&nbsp;2013 Saat 16:47<br /><br />Araç fena Burak. Tam benim istediğim modelden ama rengini sevmeidm ben. <br><br>Garaj arabası demiş. Aylık ortalama 1444km yapan bir araba ne ara garajda durmuş merak ettim. HArdtop da yok sıkıntı bence<br>]]>
   </description>
   <pubDate>Thu, 21 Nov 2013 16:47:19 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=462944&amp;title=golf-e-gelen-takas-teklifi#462944</guid>
  </item>
  <item>
   <title><![CDATA[Golf &#039; e Gelen Takas Teklifi :   Burak Yazd&#305;:benimde kafama...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=462941&amp;title=golf-e-gelen-takas-teklifi#462941</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 32158<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Kasım&nbsp;2013 Saat 16:38<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Burak" alt="Orjinalini yazan: Burak" style="vertical-align: text-bottom;" /> <strong>Burak Yazdı:</strong><br /><br />benimde kafama takılan adam açıklamaya ihtiyacımdan satıyorum yazmış bana kafa kafaya takas diyo&nbsp;</td></tr></table><div><br></div><div>dümen işte anla, kazadan sonra bi sıkıntısı var demek arabanın çözemedi çok gördük böylelerini. 10 cm' lik kaza , radyator delindi diyo, ya radyatörün yanındaki ekipmanlar? (radyatöründelinmesi için nasıl bi şiddet gerekiyo sen hesap et)</div><span style="font-size:10px"><br /><br />Düzenleyen dogan106 - 21&nbsp;Kasım&nbsp;2013 Saat 16:42</span>]]>
   </description>
   <pubDate>Thu, 21 Nov 2013 16:38:04 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=462941&amp;title=golf-e-gelen-takas-teklifi#462941</guid>
  </item>
  <item>
   <title><![CDATA[Golf &#039; e Gelen Takas Teklifi : benimde kafama tak&#305;lan adam a&#231;&#305;klamaya...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=462935&amp;title=golf-e-gelen-takas-teklifi#462935</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10321">Burak</a><br /><strong>Konu:</strong> 32158<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Kasım&nbsp;2013 Saat 16:31<br /><br />benimde kafama takılan adam açıklamaya ihtiyacımdan satıyorum yazmış bana kafa kafaya takas diyo&nbsp;]]>
   </description>
   <pubDate>Thu, 21 Nov 2013 16:31:14 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=462935&amp;title=golf-e-gelen-takas-teklifi#462935</guid>
  </item>
  <item>
   <title><![CDATA[Golf &#039; e Gelen Takas Teklifi :   Burak Yazd&#305;:Arabama gelen takas...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=462929&amp;title=golf-e-gelen-takas-teklifi#462929</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 32158<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Kasım&nbsp;2013 Saat 16:24<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Burak" alt="Orjinalini yazan: Burak" style="vertical-align: text-bottom;" /> <strong>Burak Yazdı:</strong><br /><br />Arabama gelen takas teklifi arkadaşlar ne dersiniz :))<div><br></div><div><a href="http://www.sahibinden.com/ilan/vasita-otomobil-bmw-keyfe-keder,boylesini-zor-bulursunuz-103174663/detay/" target="_blank" rel="nofollow">http://www.sahibinden.com/ilan/vasita-otomobil-bmw-keyfe-keder,boylesini-zor-bulursunuz-103174663/detay/</a></div></td></tr></table><div><br></div><div>şaka yapıyosun<img src="https://forum.peugeotturkey.com/smileys/smiley4.gif" border="0" alt="Big smile" title="Big smile" />&nbsp;1 ay önce kaza yapmış araçla kesin bişey çıktı arabada kazadan sonra ondan satıyor</div><span style="font-size:10px"><br /><br />Düzenleyen dogan106 - 21&nbsp;Kasım&nbsp;2013 Saat 16:26</span>]]>
   </description>
   <pubDate>Thu, 21 Nov 2013 16:24:44 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=462929&amp;title=golf-e-gelen-takas-teklifi#462929</guid>
  </item>
  <item>
   <title><![CDATA[Golf &#039; e Gelen Takas Teklifi : Arabama gelen takas teklifi arkada&#351;lar...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=462927&amp;title=golf-e-gelen-takas-teklifi#462927</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10321">Burak</a><br /><strong>Konu:</strong> 32158<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Kasım&nbsp;2013 Saat 16:22<br /><br />Arabama gelen takas teklifi arkadaşlar ne dersiniz :))<div><br></div><div><a href="http://www.sahibinden.com/ilan/vasita-otomobil-bmw-keyfe-keder,boylesini-zor-bulursunuz-103174663/detay/" target="_blank" rel="nofollow">http://www.sahibinden.com/ilan/vasita-otomobil-bmw-keyfe-keder,boylesini-zor-bulursunuz-103174663/detay/</a></div>]]>
   </description>
   <pubDate>Thu, 21 Nov 2013 16:22:13 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=32158&amp;PID=462927&amp;title=golf-e-gelen-takas-teklifi#462927</guid>
  </item>
 </channel>
</rss>
