 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Geri viteste vurma sesi</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Arac&#305;n&#305;z Hakk&#305;ndaki T&#252;m Sorular : Geri viteste vurma sesi]]></description>
  <pubDate>Sun, 03 May 2026 09:18:47 +0000</pubDate>
  <lastBuildDate>Sat, 30 Oct 2010 20:49:41 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=3174</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Geri viteste vurma sesi : ama yinede bi g&#246;stermesinde fayda...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=157338&amp;title=geri-viteste-vurma-sesi#157338</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3191">oguzhan29</a><br /><strong>Konu:</strong> 3174<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Ekim&nbsp;2010 Saat 20:49<br /><br /><P><FONT style=": #9cb9e1">ama yinede bi göstermesinde fayda var küçük sorun olur sonra büyük sorun olmasın</FONT></P>]]>
   </description>
   <pubDate>Sat, 30 Oct 2010 20:49:41 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=157338&amp;title=geri-viteste-vurma-sesi#157338</guid>
  </item>
  <item>
   <title><![CDATA[Geri viteste vurma sesi : her ara&#231;ta olur geri vites klitli...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=157321&amp;title=geri-viteste-vurma-sesi#157321</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=4371">furkan</a><br /><strong>Konu:</strong> 3174<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Ekim&nbsp;2010 Saat 19:50<br /><br />her araçta olur geri vites klitli sistemdir giderken geriye takılmasın diye sen tam dişliye oturtamamışsın dır ozaman şanzıman atar vitesi geri]]>
   </description>
   <pubDate>Sat, 30 Oct 2010 19:50:23 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=157321&amp;title=geri-viteste-vurma-sesi#157321</guid>
  </item>
  <item>
   <title><![CDATA[Geri viteste vurma sesi : sans&#305;mandan olabilir arkada&#351;&#305;m&#305;n...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=157311&amp;title=geri-viteste-vurma-sesi#157311</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3191">oguzhan29</a><br /><strong>Konu:</strong> 3174<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Ekim&nbsp;2010 Saat 18:27<br /><br />sansımandan olabilir arkadaşımın kartalında oldu geri geri giderken sanki bir yere çarpma sesi o 210 tl ye yaptırdı kartalını ama sadec onu değil bir kaç masrafını daha]]>
   </description>
   <pubDate>Sat, 30 Oct 2010 18:27:21 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=157311&amp;title=geri-viteste-vurma-sesi#157311</guid>
  </item>
  <item>
   <title><![CDATA[Geri viteste vurma sesi :   sinan-s Yazd&#305;:O bazen bendede...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=45843&amp;title=geri-viteste-vurma-sesi#45843</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=311">sedat23</a><br /><strong>Konu:</strong> 3174<br /><strong>Gönderim Zamanı:</strong> 15&nbsp;Kasım&nbsp;2008 Saat 11:33<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: sinan-s" alt="Orjinalini yazan: sinan-s" style="vertical-align: text-bottom;" /> <strong>sinan-s Yazdı:</strong><br /><br />O bazen bendede oluyor sedat.Korkulacak bişi yok..</td></tr></table> <DIV>&nbsp;</DIV><DIV>Abi sanki bir yere vurmuş ögibi ses çıkıyo</DIV>]]>
   </description>
   <pubDate>Sat, 15 Nov 2008 11:33:06 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=45843&amp;title=geri-viteste-vurma-sesi#45843</guid>
  </item>
  <item>
   <title><![CDATA[Geri viteste vurma sesi : O bazen bendede oluyor sedat.Korkulacak...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=45840&amp;title=geri-viteste-vurma-sesi#45840</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8">sinan-s</a><br /><strong>Konu:</strong> 3174<br /><strong>Gönderim Zamanı:</strong> 15&nbsp;Kasım&nbsp;2008 Saat 11:30<br /><br />O bazen bendede oluyor sedat.Korkulacak bişi yok..]]>
   </description>
   <pubDate>Sat, 15 Nov 2008 11:30:40 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=45840&amp;title=geri-viteste-vurma-sesi#45840</guid>
  </item>
  <item>
   <title><![CDATA[Geri viteste vurma sesi : bunu son 1 senede 3. kez yapt&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=45819&amp;title=geri-viteste-vurma-sesi#45819</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=311">sedat23</a><br /><strong>Konu:</strong> 3174<br /><strong>Gönderim Zamanı:</strong> 15&nbsp;Kasım&nbsp;2008 Saat 10:41<br /><br />bunu son 1 senede 3. kez yaptı ama debriyaja basılı şekilde yanaşırsan yapmıyo geri nasıl araba sto ederken vurur ya bir ses gelir onun gibi]]>
   </description>
   <pubDate>Sat, 15 Nov 2008 10:41:26 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=45819&amp;title=geri-viteste-vurma-sesi#45819</guid>
  </item>
  <item>
   <title><![CDATA[Geri viteste vurma sesi : v&#305;tes ger&#305; tepm&#305;&#351; sen&#305;n t&#305;tret&#305;nce...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=45815&amp;title=geri-viteste-vurma-sesi#45815</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=271">gökan</a><br /><strong>Konu:</strong> 3174<br /><strong>Gönderim Zamanı:</strong> 15&nbsp;Kasım&nbsp;2008 Saat 10:29<br /><br />vıtes gerı tepmış senın tıtretınce]]>
   </description>
   <pubDate>Sat, 15 Nov 2008 10:29:27 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=45815&amp;title=geri-viteste-vurma-sesi#45815</guid>
  </item>
  <item>
   <title><![CDATA[Geri viteste vurma sesi : &#246;nce 4 sonra geri yapt&#305;&#287;&#305;nda ayn&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=45801&amp;title=geri-viteste-vurma-sesi#45801</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=81">hasimayaz</a><br /><strong>Konu:</strong> 3174<br /><strong>Gönderim Zamanı:</strong> 15&nbsp;Kasım&nbsp;2008 Saat 09:17<br /><br />önce 4 sonra geri yaptığında aynı sıkıntıyı yapıyormu?? <DIV></DIV><DIV></DIV><DIV></DIV><DIV></DIV>&nbsp; <DIV>Tekrar ederse vites kolu kablolarına bir bakmak gerekebilir.. Birde tutma agrafı sorun çıkarıyor olabilir.</DIV><span style="font-size:10px"><br /><br />Düzenleyen hasimayaz - 15&nbsp;Kasım&nbsp;2008 Saat 10:04</span>]]>
   </description>
   <pubDate>Sat, 15 Nov 2008 09:17:53 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=45801&amp;title=geri-viteste-vurma-sesi#45801</guid>
  </item>
  <item>
   <title><![CDATA[Geri viteste vurma sesi : bence b&#305;rsey&#305; yok y&#305;nede bakt&#305;rmak...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=45799&amp;title=geri-viteste-vurma-sesi#45799</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 3174<br /><strong>Gönderim Zamanı:</strong> 15&nbsp;Kasım&nbsp;2008 Saat 09:13<br /><br />bence bırseyı yok yınede baktırmak lazım her arac gerı vıtesde bazen oyle tak dıye ses cıkartır korkulucak bırsey yok...]]>
   </description>
   <pubDate>Sat, 15 Nov 2008 09:13:00 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=45799&amp;title=geri-viteste-vurma-sesi#45799</guid>
  </item>
  <item>
   <title><![CDATA[Geri viteste vurma sesi : &#246;n taraftan geliyor dimi ses?...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=45794&amp;title=geri-viteste-vurma-sesi#45794</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=385">gokhanozmen</a><br /><strong>Konu:</strong> 3174<br /><strong>Gönderim Zamanı:</strong> 15&nbsp;Kasım&nbsp;2008 Saat 08:58<br /><br />ön taraftan geliyor dimi ses? <br>peki akıncı nası giderririz bu sorunu? bendede yapio arada bir.<br>]]>
   </description>
   <pubDate>Sat, 15 Nov 2008 08:58:31 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=45794&amp;title=geri-viteste-vurma-sesi#45794</guid>
  </item>
  <item>
   <title><![CDATA[Geri viteste vurma sesi : Ya Meyve Suyu Kutusunun &#220;zerinden...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=45788&amp;title=geri-viteste-vurma-sesi#45788</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 3174<br /><strong>Gönderim Zamanı:</strong> 15&nbsp;Kasım&nbsp;2008 Saat 04:22<br /><br /><P>Ya Meyve Suyu Kutusunun Üzerinden Geçtin Ki Öle Durumda Çoçuklar Muhtemelen Uzaktan Gülmeye Başlamışlardır</P><DIV>Yada Daha Realist</DIV><DIV>&nbsp;</DIV><DIV>Sen Şanzımandan Geliyor.Kara Şanzımanlardaki Gibi Debriyajı Birkaç Kez Pompalayıp Geri Vitese Yavaşça ve sağlam bir şekilde takmayı dene..</DIV><DIV>&nbsp;</DIV><DIV>Titreşim Normal.</DIV><DIV>&nbsp;</DIV><DIV>Geri Vites İçin Şanzımanda Düz Dişli Kullanılır Helis Dişlisi Kullanılmaz.Her Araç Geri Giderken Ses Çıkartır ve&nbsp;Titrer.</DIV><DIV>&nbsp;</DIV><DIV>Geçmiş Olsun.&nbsp;</DIV>]]>
   </description>
   <pubDate>Sat, 15 Nov 2008 04:22:24 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=45788&amp;title=geri-viteste-vurma-sesi#45788</guid>
  </item>
  <item>
   <title><![CDATA[Geri viteste vurma sesi : enteresan ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=45784&amp;title=geri-viteste-vurma-sesi#45784</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=388">TOLGA</a><br /><strong>Konu:</strong> 3174<br /><strong>Gönderim Zamanı:</strong> 15&nbsp;Kasım&nbsp;2008 Saat 00:28<br /><br /><P>enteresan<img src="http://forum.peugeotturkey.com/smileys/smiley5.gif" height="17" width="17" border="0" alt="C&#111;nfused" /></P>]]>
   </description>
   <pubDate>Sat, 15 Nov 2008 00:28:14 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=45784&amp;title=geri-viteste-vurma-sesi#45784</guid>
  </item>
  <item>
   <title><![CDATA[Geri viteste vurma sesi : geri vitese takt&#305;m yana&#351;&#305;yodum...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=45782&amp;title=geri-viteste-vurma-sesi#45782</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=311">sedat23</a><br /><strong>Konu:</strong> 3174<br /><strong>Gönderim Zamanı:</strong> 15&nbsp;Kasım&nbsp;2008 Saat 00:16<br /><br />geri vitese taktım yanaşıyodum yavaş yavaş hafif titremeyle sanki duvara çarpmış gibi ses geldi gümm diye ]]>
   </description>
   <pubDate>Sat, 15 Nov 2008 00:16:58 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=45782&amp;title=geri-viteste-vurma-sesi#45782</guid>
  </item>
  <item>
   <title><![CDATA[Geri viteste vurma sesi : nas&#305;l vurma arkda&#351;&#305;m???? ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=45781&amp;title=geri-viteste-vurma-sesi#45781</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=271">gökan</a><br /><strong>Konu:</strong> 3174<br /><strong>Gönderim Zamanı:</strong> 15&nbsp;Kasım&nbsp;2008 Saat 00:12<br /><br />nasıl vurma arkdaşım????]]>
   </description>
   <pubDate>Sat, 15 Nov 2008 00:12:21 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=45781&amp;title=geri-viteste-vurma-sesi#45781</guid>
  </item>
  <item>
   <title><![CDATA[Geri viteste vurma sesi : Bug&#252;n 2 kere arabay&#305; park ederken...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=45780&amp;title=geri-viteste-vurma-sesi#45780</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=311">sedat23</a><br /><strong>Konu:</strong> 3174<br /><strong>Gönderim Zamanı:</strong> 15&nbsp;Kasım&nbsp;2008 Saat 00:11<br /><br /><P><FONT style=": #efefef">Bugün 2 kere arabayı park ederken geri viteste güm diye vurma sesi geldi arkadan neden olabilir acaba vuracak birşeyde yok arabanın altında gördüğüm kadarıyla neden olabilir?</FONT></P>]]>
   </description>
   <pubDate>Sat, 15 Nov 2008 00:11:21 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=3174&amp;PID=45780&amp;title=geri-viteste-vurma-sesi#45780</guid>
  </item>
 </channel>
</rss>
