 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : hareret durumu</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 206 : hareret durumu]]></description>
  <pubDate>Sun, 03 May 2026 09:00:55 +0000</pubDate>
  <lastBuildDate>Wed, 09 Oct 2013 23:06:12 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=31381</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[hareret durumu : verilen ilgiye tsk ederim saolun...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=31381&amp;PID=454472&amp;title=hareret-durumu#454472</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9308">206x-line</a><br /><strong>Konu:</strong> 31381<br /><strong>Gönderim Zamanı:</strong> 09&nbsp;Ekim&nbsp;2013 Saat 23:06<br /><br />verilen ilgiye tsk ederim saolun ]]>
   </description>
   <pubDate>Wed, 09 Oct 2013 23:06:12 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=31381&amp;PID=454472&amp;title=hareret-durumu#454472</guid>
  </item>
  <item>
   <title><![CDATA[hareret durumu : bu durumda ne yapt&#305;rmam gerekir...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=31381&amp;PID=454471&amp;title=hareret-durumu#454471</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9308">206x-line</a><br /><strong>Konu:</strong> 31381<br /><strong>Gönderim Zamanı:</strong> 09&nbsp;Ekim&nbsp;2013 Saat 23:04<br /><br />bu durumda ne yaptırmam gerekir araca en iyisi iyi  bir ustaya danismak kaliyor galiba  yârin bi göstereyim bakalım ne diyecekler umarim kotu durum arz edecek birsey degildir]]>
   </description>
   <pubDate>Wed, 09 Oct 2013 23:04:47 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=31381&amp;PID=454471&amp;title=hareret-durumu#454471</guid>
  </item>
  <item>
   <title><![CDATA[hareret durumu : &#214;ylesine gezinirken bir sitede...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=31381&amp;PID=454469&amp;title=hareret-durumu#454469</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11466">Bünyamin.Kar</a><br /><strong>Konu:</strong> 31381<br /><strong>Gönderim Zamanı:</strong> 09&nbsp;Ekim&nbsp;2013 Saat 22:37<br /><br />Öylesine gezinirken bir sitede buldum yardımcı olur inşallah&nbsp;<div><br></div><div><p ="ikiyana" style="text-align: justify; font-size: 17px; font-family: 'Times New Roman'; line-height: normal;"><span ="ikiyana">&nbsp; Radyatör hava yapmıştır. Yakın zamanda antifiriz değişimi ,su değişimi yada devirdaim değişimi gibi motor suyunu değiştirmek gerektiren herhangi bir işlem yaptıysanız radyatörünüz hava yapmış olabilir. Bir başka hava yapma nedenide su tesisatındaki kaçaklar ve silindir kapak contasının yanması yada silindir kapağının çatlamasıdır. Bu konular ayrı bir konu başlığında ele alınacaktır. Radyatör havasını almak için ;pekçok model araçta hava almak için su borularında yada radyatör üst kısımlarında hava alma vanaları vardır. Keza yeni model araçların tamamına yakını radyatör havasını kendisi atmaktadır (motor çalıştıkça) .Eğer yoksa motorun en üst -yüksek noktalarına bakın. İçerisinde su olduğu kesin bilinen -özellikle hararet müşürü- bir parça yada hortum bulun ve gevşetin. Motor havası buradan çıkacaktır. Radyatör hortumunu sıkıp gevşeterek pompa yapabilir ve havanın atılmasını kolaylaştırabilirsiniz. Kabarçıklar geliyorsa bu hava yaptığı manasına gelirki kesintisiz su gelene kadar bekleyin ve sonra parçayı sıkın- kapatın. Radyatörünüzde kılcal kaçaklar varsa ve bu su eksiltme hararete neden oluyorsa tamirciye gidene kadar sıcak motor suyuna su haznesine karabiber atarak hafifletebilir hatta kesebilirsiniz. Bu şekilde aracınızı servise kadar idare edebilirsiniz.</span></p><p ="ikiyana" style="text-align: justify; font-size: 17px; font-family: 'Times New Roman'; line-height: normal;"><span ="ikiyana"><br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Devirdaim pompası kaçak yapıyordur. Motor devri arttınca hararet iniyor ,devir düştükçe hararet artıyorsa kaçaktan şüphelenebilirsiniz. Pompa dağıldıysa devir yüksekliği pekte etki etmeyecektir.ınıza fazla zengin yakıt geliyordur. Aracınız enjektörlü ise enjektörlerde işeme -ayarsızlık olabilir. Motorun titreşiminden ,sesinden ,yakıt yüksekliğinden ve egzoszt dumanından anlayabilirsiniz bu durumu.</span></p></div>]]>
   </description>
   <pubDate>Wed, 09 Oct 2013 22:37:12 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=31381&amp;PID=454469&amp;title=hareret-durumu#454469</guid>
  </item>
  <item>
   <title><![CDATA[hareret durumu :   dogan106 Yazd&#305;:  206x-line...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=31381&amp;PID=454464&amp;title=hareret-durumu#454464</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 31381<br /><strong>Gönderim Zamanı:</strong> 09&nbsp;Ekim&nbsp;2013 Saat 21:55<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: dogan106" alt="Orjinalini yazan: dogan106" style="vertical-align: text-bottom;" /> <strong>dogan106 Yazdı:</strong><br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: 206x-line" alt="Orjinalini yazan: 206x-line" style="vertical-align: text-bottom;" /> <strong>206x-line Yazdı:</strong><br /><br />arkadaşlar 2 yıldır araç bende böyle birsey olmamisti sorunu nedir yardimci olursaniz sevinirim  2004 1.4 benzinli 206x araç var termostat olduğu için hareret cabuk 90'a ulaşıyor bunu sordum benzinli araçlarda normal dediler istersen termostati kapatır yavaş yavaş çıkmasını sağlarız ama kısın calistirmada zorluk cekecegimi söylemişlerdi bende normalse  birsey yapilmamasini istedim ama bu aralar 90 a ulaşıyor trafikte 2 dakka 1. vites 2. vites derken hemen 98-100 ulaşıp fan acıyor daha once böyle değildi sürekli trafikte oluyordum ama 90'nı cok az geçerdi dusuk viteste  simdi neden böyle oluyor onu anlamadım sebebi nedir sizce<br><br><br>bu durumu halledecek yenibosna civarinda usta varmi</td></tr></table><div><br></div><div>&nbsp;100de sabit kalıp 95-100 arası gidip gelmesi motor bloğunda çatlak var demektir. Çok uzak bi ihtimal ama bi baktır 7000 kadranlı araçlarınızda 4000 ' i geçmeyiniz</div></td></tr></table>]]>
   </description>
   <pubDate>Wed, 09 Oct 2013 21:55:51 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=31381&amp;PID=454464&amp;title=hareret-durumu#454464</guid>
  </item>
  <item>
   <title><![CDATA[hareret durumu : sabit kalm&#305;yor fan calisip hemen...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=31381&amp;PID=454463&amp;title=hareret-durumu#454463</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9308">206x-line</a><br /><strong>Konu:</strong> 31381<br /><strong>Gönderim Zamanı:</strong> 09&nbsp;Ekim&nbsp;2013 Saat 21:55<br /><br />sabit kalmıyor fan calisip hemen 90'a iniyor ama dusuk viteste devam edersen  geri yükselmeye basliyor normal uzun yol surusunde hersey normal]]>
   </description>
   <pubDate>Wed, 09 Oct 2013 21:55:00 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=31381&amp;PID=454463&amp;title=hareret-durumu#454463</guid>
  </item>
  <item>
   <title><![CDATA[hareret durumu :   206x-line Yazd&#305;:arkada&#351;lar...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=31381&amp;PID=454460&amp;title=hareret-durumu#454460</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 31381<br /><strong>Gönderim Zamanı:</strong> 09&nbsp;Ekim&nbsp;2013 Saat 21:52<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: 206x-line" alt="Orjinalini yazan: 206x-line" style="vertical-align: text-bottom;" /> <strong>206x-line Yazdı:</strong><br /><br />arkadaşlar 2 yıldır araç bende böyle birsey olmamisti sorunu nedir yardimci olursaniz sevinirim  2004 1.4 benzinli 206x araç var termostat olduğu için hareret cabuk 90'a ulaşıyor bunu sordum benzinli araçlarda normal dediler istersen termostati kapatır yavaş yavaş çıkmasını sağlarız ama kısın calistirmada zorluk cekecegimi söylemişlerdi bende normalse  birsey yapilmamasini istedim ama bu aralar 90 a ulaşıyor trafikte 2 dakka 1. vites 2. vites derken hemen 98-100 ulaşıp fan acıyor daha once böyle değildi sürekli trafikte oluyordum ama 90'nı cok az geçerdi dusuk viteste  simdi neden böyle oluyor onu anlamadım sebebi nedir sizce<br><br><br>bu durumu halledecek yenibosna civarinda usta varmi</td></tr></table><div><br></div><div>&nbsp;100de sabit kalıp 95-100 arası gidip gelmesi motor bloğunda çatlak var demektir. Çok uzak bi ihtimal ama bi baktır</div>]]>
   </description>
   <pubDate>Wed, 09 Oct 2013 21:52:16 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=31381&amp;PID=454460&amp;title=hareret-durumu#454460</guid>
  </item>
  <item>
   <title><![CDATA[hareret durumu :  normal hocam hararetin o aralarda...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=31381&amp;PID=454459&amp;title=hareret-durumu#454459</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8322">hsnsnl</a><br /><strong>Konu:</strong> 31381<br /><strong>Gönderim Zamanı:</strong> 09&nbsp;Ekim&nbsp;2013 Saat 21:43<br /><br />normal hocam hararetin o aralarda oynaması, yeter ki kırmızı bölgeye gelmesın pejo sıcağı sever..&nbsp;boşu boşuna oynatma aracını, boşuna masraf etme bence..]]>
   </description>
   <pubDate>Wed, 09 Oct 2013 21:43:03 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=31381&amp;PID=454459&amp;title=hareret-durumu#454459</guid>
  </item>
  <item>
   <title><![CDATA[hareret durumu : arkada&#351;lar 2 y&#305;ld&#305;r ara&#231; bende...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=31381&amp;PID=454453&amp;title=hareret-durumu#454453</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9308">206x-line</a><br /><strong>Konu:</strong> 31381<br /><strong>Gönderim Zamanı:</strong> 09&nbsp;Ekim&nbsp;2013 Saat 21:26<br /><br />arkadaşlar 2 yıldır araç bende böyle birsey olmamisti sorunu nedir yardimci olursaniz sevinirim  2004 1.4 benzinli 206x araç var termostat olduğu için hareret cabuk 90'a ulaşıyor bunu sordum benzinli araçlarda normal dediler istersen termostati kapatır yavaş yavaş çıkmasını sağlarız ama kısın calistirmada zorluk cekecegimi söylemişlerdi bende normalse  birsey yapilmamasini istedim ama bu aralar 90 a ulaşıyor trafikte 2 dakka 1. vites 2. vites derken hemen 98-100 ulaşıp fan acıyor daha once böyle değildi sürekli trafikte oluyordum ama 90'nı cok az geçerdi dusuk viteste  simdi neden böyle oluyor onu anlamadım sebebi nedir sizce<br /><br /><br />bu durumu halledecek yenibosna civarinda usta varmi<span style="font-size:10px"><br /><br />Düzenleyen 206x-line - 09&nbsp;Ekim&nbsp;2013 Saat 21:28</span>]]>
   </description>
   <pubDate>Wed, 09 Oct 2013 21:26:38 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=31381&amp;PID=454453&amp;title=hareret-durumu#454453</guid>
  </item>
 </channel>
</rss>
