 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : acil yardım!!</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Arac&#305;n&#305;z Hakk&#305;ndaki T&#252;m Sorular : acil yardım!!]]></description>
  <pubDate>Sun, 03 May 2026 19:26:36 +0000</pubDate>
  <lastBuildDate>Mon, 30 Sep 2013 18:15:53 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=31240</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[acil yardım!! : kelebek temizli&#287;i ve kalibrasyon...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=31240&amp;PID=452881&amp;title=acil-yardim#452881</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=12631">serkans</a><br /><strong>Konu:</strong> 31240<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Eylül&nbsp;2013 Saat 18:15<br /><br />kelebek temizliği ve kalibrasyon ile]]>
   </description>
   <pubDate>Mon, 30 Sep 2013 18:15:53 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=31240&amp;PID=452881&amp;title=acil-yardim#452881</guid>
  </item>
  <item>
   <title><![CDATA[acil yardım!! : ayn&#305; problemi buji de&#287;i&#351;imi kelea&#351;t&#305;m...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=31240&amp;PID=452880&amp;title=acil-yardim#452880</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=12631">serkans</a><br /><strong>Konu:</strong> 31240<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Eylül&nbsp;2013 Saat 18:15<br /><br />aynı problemi buji değişimi keleaştım hepsi 100 liraya&nbsp;haloldu]]>
   </description>
   <pubDate>Mon, 30 Sep 2013 18:15:35 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=31240&amp;PID=452880&amp;title=acil-yardim#452880</guid>
  </item>
  <item>
   <title><![CDATA[acil yardım!! : karda&#351;im ayn&#305; sorun benim arac&#305;mdada...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=31240&amp;PID=452807&amp;title=acil-yardim#452807</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=12163">engin6162</a><br /><strong>Konu:</strong> 31240<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Eylül&nbsp;2013 Saat 12:36<br /><br />kardaşim aynı sorun benim aracımdada vardı gaz kelebek boğazı dolduğu için istop ediyordu yolda giderken temizlettim şimdi canavar gibi.genelde ondan yapar]]>
   </description>
   <pubDate>Mon, 30 Sep 2013 12:36:29 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=31240&amp;PID=452807&amp;title=acil-yardim#452807</guid>
  </item>
  <item>
   <title><![CDATA[acil yardım!! : Durumu birde benzindeyken gozlemleyin....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=31240&amp;PID=452771&amp;title=acil-yardim#452771</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2147">koliva</a><br /><strong>Konu:</strong> 31240<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Eylül&nbsp;2013 Saat 08:15<br /><br />Durumu birde benzindeyken gozlemleyin. Sayet orada da ayni durum var ise bogaz kelebegi ilk baktiracaginiz yer olacaktir.<br>]]>
   </description>
   <pubDate>Mon, 30 Sep 2013 08:15:13 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=31240&amp;PID=452771&amp;title=acil-yardim#452771</guid>
  </item>
  <item>
   <title><![CDATA[acil yardım!! : arkada&#351;lar merabalar;sorun d&#252;n...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=31240&amp;PID=452725&amp;title=acil-yardim#452725</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11393">mrtoknctn</a><br /><strong>Konu:</strong> 31240<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Eylül&nbsp;2013 Saat 22:44<br /><br />arkadaşlar merabalar;<br><br>sorun dün başıma geldi ankara karabük arası yola çıktım vardığımda araba düşük devirde sanki gazı kesiyordu biraz zaman geçtikten sonra daha da kötü oldu ancak gaza bastığım zaman araba kendini toparlıyordu rolantide çalışırken araç istop ediyor ama direksiyon hala yumuşak rolanti okuyucusundan şüpeleniyorum .. aracım lovato marka sıralı sistem lpg li ve düz vites yardımcı olabilirseniz sevinirim <br>]]>
   </description>
   <pubDate>Sun, 29 Sep 2013 22:44:35 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=31240&amp;PID=452725&amp;title=acil-yardim#452725</guid>
  </item>
 </channel>
</rss>
