 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 307 DEBRİYAJ SORUNU</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 307 : 307 DEBRİYAJ SORUNU]]></description>
  <pubDate>Sun, 03 May 2026 18:15:08 +0000</pubDate>
  <lastBuildDate>Tue, 19 Nov 2013 10:09:25 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=31159</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[307 DEBRİYAJ SORUNU : bilgiler i&#231;in te&#351;ekk&#252;r ederim,...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=31159&amp;PID=462401&amp;title=307-debriyaj-sorunu#462401</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11643">service22</a><br /><strong>Konu:</strong> 31159<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Kasım&nbsp;2013 Saat 10:09<br /><br />bilgiler için teşekkür ederim, daha iyi bir ustaya gitmem gerek sanırım.]]>
   </description>
   <pubDate>Tue, 19 Nov 2013 10:09:25 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=31159&amp;PID=462401&amp;title=307-debriyaj-sorunu#462401</guid>
  </item>
  <item>
   <title><![CDATA[307 DEBRİYAJ SORUNU : kalki&#351;ta titreme &#252;stten kavrama...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=31159&amp;PID=462272&amp;title=307-debriyaj-sorunu#462272</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11945">E.B</a><br /><strong>Konu:</strong> 31159<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Kasım&nbsp;2013 Saat 18:17<br /><br />kalkişta titreme üstten kavrama bunlar baski balata ömrünün bitmeye yakin oldugunu gösteriyor]]>
   </description>
   <pubDate>Mon, 18 Nov 2013 18:17:06 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=31159&amp;PID=462272&amp;title=307-debriyaj-sorunu#462272</guid>
  </item>
  <item>
   <title><![CDATA[307 DEBRİYAJ SORUNU : Merhaba, Edirne merkezden &#214;mer...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=31159&amp;PID=462230&amp;title=307-debriyaj-sorunu#462230</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11643">service22</a><br /><strong>Konu:</strong> 31159<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Kasım&nbsp;2013 Saat 16:33<br /><br />Merhaba, Edirne merkezden Ömer ben. benim&nbsp;<span style=": rgb251, 251, 253; ">&nbsp;2003 model 155binde&nbsp;307 1.4 hdi arabamda da debriyaj kavraması çok yukarıda oduğunu düşünüyorum. birde geri vitese çoğu zaman zor geçiyor, önce 1 e takıyorum sonra geriye... &nbsp;ustaya sordum vites yukarıda kavrıyor diye, sorun yok abi gayet güzel dedi. bir de ilk kalkışta titreme yapıyor. ön balata ve diskleri iyi, sadece arka balatalar bitmiş durumda, onları bu hafta değiştirecem kısmetse.&nbsp;</span><div>debriyak üstte kavraması ve ilk kalkışta ki titremenin sebebi ne olabilir acaba, ilk önce neleri değerlendirmeli?&nbsp;<br><div><span style=": rgb251, 251, 253; "><br></span></div></div>]]>
   </description>
   <pubDate>Mon, 18 Nov 2013 16:33:26 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=31159&amp;PID=462230&amp;title=307-debriyaj-sorunu#462230</guid>
  </item>
  <item>
   <title><![CDATA[307 DEBRİYAJ SORUNU : Tabii kullan&#305;ma da bagl&#305; fakat...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=31159&amp;PID=461827&amp;title=307-debriyaj-sorunu#461827</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 31159<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Kasım&nbsp;2013 Saat 15:15<br /><br />Tabii kullanıma da baglı fakat aracınız kac km'de?]]>
   </description>
   <pubDate>Sun, 17 Nov 2013 15:15:59 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=31159&amp;PID=461827&amp;title=307-debriyaj-sorunu#461827</guid>
  </item>
  <item>
   <title><![CDATA[307 DEBRİYAJ SORUNU : tak&#305;lma hissi halatla alakal&#305;d&#305;r...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=31159&amp;PID=461817&amp;title=307-debriyaj-sorunu#461817</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=5538">sezar206</a><br /><strong>Konu:</strong> 31159<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Kasım&nbsp;2013 Saat 14:46<br /><br />takılma hissi halatla alakalıdır buyuk ihtimal tabi 307 de halat varsa]]>
   </description>
   <pubDate>Sun, 17 Nov 2013 14:46:40 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=31159&amp;PID=461817&amp;title=307-debriyaj-sorunu#461817</guid>
  </item>
  <item>
   <title><![CDATA[307 DEBRİYAJ SORUNU : slm.1. bug&#252;n 307 hdi 2005 arac&#305;m&#305;n...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=31159&amp;PID=461808&amp;title=307-debriyaj-sorunu#461808</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2827">heffera</a><br /><strong>Konu:</strong> 31159<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Kasım&nbsp;2013 Saat 14:16<br /><br />slm.&nbsp;<div>1. bugün 307 hdi 2005 aracımın debriyajı ayağımı kaldırırken aniden debriyaj kalkıyormuş gb bişey hissettiriyor.debriyaj aynı tonda değilde 3 cm kaldırınca takıldığı yerden çıkmış gb bir his uyandıran bir kalkış yapıyor pedal. sebebi nedir.&nbsp;</div><div>2. Geri vites sigortası nın yeri ve hangisi olduğu lazım.</div><div><br></div>]]>
   </description>
   <pubDate>Sun, 17 Nov 2013 14:16:04 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=31159&amp;PID=461808&amp;title=307-debriyaj-sorunu#461808</guid>
  </item>
  <item>
   <title><![CDATA[307 DEBRİYAJ SORUNU : vitesin h&#231;ok zor ge&#231;mesi yada...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=31159&amp;PID=451817&amp;title=307-debriyaj-sorunu#451817</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=5483">qqyyxx</a><br /><strong>Konu:</strong> 31159<br /><strong>Gönderim Zamanı:</strong> 23&nbsp;Eylül&nbsp;2013 Saat 18:37<br /><br />vitesin hçok zor geçmesi yada vitesten atması başka bir sorun. baskıyla alakalı bir durum olduğunu sanmıyorum baskı balata yeterince zayıfladığında vites geçişleri sürtünme hissi vererek tamalanır ama sizin sorun farklı, yağla alakalıda olduğunu düşünmüyorum. iyi bir ustaya baktırmanızda fayda var.&nbsp;]]>
   </description>
   <pubDate>Mon, 23 Sep 2013 18:37:57 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=31159&amp;PID=451817&amp;title=307-debriyaj-sorunu#451817</guid>
  </item>
  <item>
   <title><![CDATA[307 DEBRİYAJ SORUNU : Yoku&#351; kalk&#305;&#351;lar&#305;nda biraz zorlanma...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=31159&amp;PID=451812&amp;title=307-debriyaj-sorunu#451812</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=12633">achmild</a><br /><strong>Konu:</strong> 31159<br /><strong>Gönderim Zamanı:</strong> 23&nbsp;Eylül&nbsp;2013 Saat 17:16<br /><br />Yokuş kalkışlarında biraz zorlanma oluyor. 1 ay kadar önce istanbul-kastamonu dönüş yolunda 3.vitese hiç geçmiyordu 2 den 4 e atarak geldim.3. vitese attığımda kendi kendine boşa atıyordu.ama istanbula geldikten sonra o olay düzeldi. fakat bu kadar yukarıda kavraması beni şüpheye düşürdü.]]>
   </description>
   <pubDate>Mon, 23 Sep 2013 17:16:44 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=31159&amp;PID=451812&amp;title=307-debriyaj-sorunu#451812</guid>
  </item>
  <item>
   <title><![CDATA[307 DEBRİYAJ SORUNU : ayn&#305; ara&#231;tan kullan&#305;yorum vites...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=31159&amp;PID=451773&amp;title=307-debriyaj-sorunu#451773</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=5483">qqyyxx</a><br /><strong>Konu:</strong> 31159<br /><strong>Gönderim Zamanı:</strong> 23&nbsp;Eylül&nbsp;2013 Saat 14:04<br /><br />aynı araçtan kullanıyorum vites geçişlerinde sorunum yok ancak bende de biraz yukarıda kavrama yapıyor. arcın baskı balata bitmeye yakın daha belirgin sorunlar ortaya koyar sadece vites geçişlerini yağ değişimiylede çözebilirsin onun için balata değişimine gerek yok derim ben. &nbsp;aracın özellikle yokuştaki kalkışlrda zorlanıyormu, anormal sesler filan geliyormu bunları değerlendirmeye alarak kontrol ettirmende fayda var.]]>
   </description>
   <pubDate>Mon, 23 Sep 2013 14:04:15 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=31159&amp;PID=451773&amp;title=307-debriyaj-sorunu#451773</guid>
  </item>
  <item>
   <title><![CDATA[307 DEBRİYAJ SORUNU : Arkada&#351;lar 307 1.6 hdi 90 hp arabamda...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=31159&amp;PID=451765&amp;title=307-debriyaj-sorunu#451765</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=12633">achmild</a><br /><strong>Konu:</strong> 31159<br /><strong>Gönderim Zamanı:</strong> 23&nbsp;Eylül&nbsp;2013 Saat 13:29<br /><br />Arkadaşlar 307 1.6 hdi 90 hp arabamda debriyaj kavraması çok yukarıda birde vites geçişlerinde çok zor geçiş oluyor bildiğim debriyaj seti ve volanı mı değiştirmem gerekiyor bana ne kadar patlar yardımcı olursanız sevinirim..]]>
   </description>
   <pubDate>Mon, 23 Sep 2013 13:29:06 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=31159&amp;PID=451765&amp;title=307-debriyaj-sorunu#451765</guid>
  </item>
 </channel>
</rss>
