 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : mutlu olan varta !</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Sohbet \ Muhabbet : mutlu olan varta !]]></description>
  <pubDate>Sat, 02 May 2026 20:58:23 +0000</pubDate>
  <lastBuildDate>Mon, 19 Aug 2013 20:12:48 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=30620</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[mutlu olan varta ! : ge&#231;mi&#351;olsun ama arac&#305;n&#305; &amp;#034;peugeotu&amp;#034;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446572&amp;title=mutlu-olan-varta#446572</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11908">errör</a><br /><strong>Konu:</strong> 30620<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Ağustos&nbsp;2013 Saat 20:12<br /><br />geçmişolsun ama aracını "peugeotu" "citroeni" tanıyan bir yere götür bence, her markayı yaparım abi diyenler genelde biryeri yapıp başka yeri bozuyorlar..]]>
   </description>
   <pubDate>Mon, 19 Aug 2013 20:12:48 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446572&amp;title=mutlu-olan-varta#446572</guid>
  </item>
  <item>
   <title><![CDATA[mutlu olan varta ! :   err&#246;r Yazd&#305;:  fatihpekgoz...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446568&amp;title=mutlu-olan-varta#446568</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=5538">sezar206</a><br /><strong>Konu:</strong> 30620<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Ağustos&nbsp;2013 Saat 19:55<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: errör" alt="Orjinalini yazan: errör" style="vertical-align: text-bottom;" /> <strong>errör Yazdı:</strong><br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: fatihpekgoz" alt="Orjinalini yazan: fatihpekgoz" style="vertical-align: text-bottom;" /> <strong>fatihpekgoz Yazdı:</strong><br /><br /><br><div>Hocam geçmiş olsun&nbsp; öncelikle bilye sesii nasıl bir şeydi? Şu anda bende de var önceleri yoktu, debriyaj halatını değiştirdim ve bir süre sonra bu sesi yapmaya başladı. Şimdi gösteriyorum aynen dediğiniz gibi şanzımandan geliyor diyorlar. Araç boşta çalışırken ses geliyor debriyaja basınca kesiyor bendeki. Sizdeki nasıldı acaba? Boşa şanzımanı açtırmak da istemiyorum aslında.&nbsp;</div></td></tr></table><div><br></div><div>teşekkürler fatih bendeki ses şöyleydi; araç boşta, çalıştırdık ön taraftan başlıyor şıkşıkşık sübap sesine benzer ses çıkartmaya debriyaja bastğım anrda kesiyor eğer ayağımı debriyajdan çok yavaş çekersem ses az geliyor ama&nbsp;<span style="line-height: 1.4;">ayağımı</span><span style="line-height: 1.4;">&nbsp;</span><span style="line-height: 1.4;">debriyajdan&nbsp;</span><span style="line-height: 1.4;">birden çekince&nbsp;</span><span style="line-height: 1.4;">ses daha yüksek çıkıyor bunları sende bir dene .</span></div><div><span style="line-height: 1.4;"><br></span></div><div>işin aslı kimse "bilmiyorum abi açıp bakmak lazım" demiyor hemen şanzıman deyip çıkıveriyor işin içinden.</div><div><br>&nbsp;</div><div>ses öyle çok yüksek değilse sistemin çalışmasına büyük bir zarar vermiyor ama yüksek devirdede o bozuk bilya illaki mile ve yuvasına zarar falan veriyordur.</div><div><br></div><div>debriyaj set olarak değişince ses kesildi bende ama halatıda bir tekrar kontrol etmek lazım gerginliğinde falan sorun olabilir.</div></td></tr></table><div>&nbsp;</div><div>Teşekkür ederim. Bendeki sorun ise motor soğukken ses yok denecek kadar az hatta yok. Ama biraz kullanıp motor ısındığında özellikle uzun yolda ses yapmaya başlıyor.&nbsp; Debriyaja basınca ses kesiliyor, debriyajı bırakınca ötmeye başlıyor. Yarım basma işini hiç denemedim ama basıp bıraktıkça mutlaka&nbsp;düzenli olarak aynı sesi yapıyor. Olmazsa biraz daha binip sonrasında da baskı balatayı set olarak değiştirip bende bir denerim sizin gibi. Çünkü kimse dediğiniz gibi emin konuşmuyor. Şanzımandandır ya o gibi cevaplar alıyorum.&nbsp; Halat değiştiğinde bir iki hafta sonra sanayiye gidip kontrol ettirdim ve hlatı yanlış takmıştı kalfa usta da bana aracı sürerken debriyaja basılı tutarak sürdüğünü düşün o şekilde kullanmışsın demişti. Baskı balatanın anasını ağlattık yani :) Napcan ya vurmayla bitmez bu tip adamlar salla gitsin diyoruz artık bu kaç oldu sanayi işi :))</div>]]>
   </description>
   <pubDate>Mon, 19 Aug 2013 19:55:12 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446568&amp;title=mutlu-olan-varta#446568</guid>
  </item>
  <item>
   <title><![CDATA[mutlu olan varta ! :   fatihpekgoz Yazd&#305;:Hocam ge&#231;mi&#351;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446559&amp;title=mutlu-olan-varta#446559</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11908">errör</a><br /><strong>Konu:</strong> 30620<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Ağustos&nbsp;2013 Saat 19:25<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: fatihpekgoz" alt="Orjinalini yazan: fatihpekgoz" style="vertical-align: text-bottom;" /> <strong>fatihpekgoz Yazdı:</strong><br /><br /><br><div>Hocam geçmiş olsun&nbsp; öncelikle bilye sesii nasıl bir şeydi? Şu anda bende de var önceleri yoktu, debriyaj halatını değiştirdim ve bir süre sonra bu sesi yapmaya başladı. Şimdi gösteriyorum aynen dediğiniz gibi şanzımandan geliyor diyorlar. Araç boşta çalışırken ses geliyor debriyaja basınca kesiyor bendeki. Sizdeki nasıldı acaba? Boşa şanzımanı açtırmak da istemiyorum aslında.&nbsp;</div></td></tr></table><div><br></div><div>teşekkürler fatih bendeki ses şöyleydi; araç boşta, çalıştırdık ön taraftan başlıyor şıkşıkşık sübap sesine benzer ses çıkartmaya debriyaja bastğım anrda kesiyor eğer ayağımı debriyajdan çok yavaş çekersem ses az geliyor ama&nbsp;<span style="line-height: 1.4;">ayağımı</span><span style="line-height: 1.4;">&nbsp;</span><span style="line-height: 1.4;">debriyajdan&nbsp;</span><span style="line-height: 1.4;">birden çekince&nbsp;</span><span style="line-height: 1.4;">ses daha yüksek çıkıyor bunları sende bir dene .</span></div><div><span style="line-height: 1.4;"><br></span></div><div>işin aslı kimse "bilmiyorum abi açıp bakmak lazım" demiyor hemen şanzıman deyip çıkıveriyor işin içinden.</div><div><br></div><div>ses öyle çok yüksek değilse sistemin çalışmasına büyük bir zarar vermiyor ama yüksek devirdede o bozuk bilya illaki mile ve yuvasına zarar falan veriyordur.</div><div><br></div><div>debriyaj set olarak değişince ses kesildi bende ama halatıda bir tekrar kontrol etmek lazım gerginliğinde falan sorun olabilir.</div>]]>
   </description>
   <pubDate>Mon, 19 Aug 2013 19:25:32 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446559&amp;title=mutlu-olan-varta#446559</guid>
  </item>
  <item>
   <title><![CDATA[mutlu olan varta ! :   err&#246;r Yazd&#305;:yetkili servis...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446558&amp;title=mutlu-olan-varta#446558</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=5538">sezar206</a><br /><strong>Konu:</strong> 30620<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Ağustos&nbsp;2013 Saat 19:12<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: errör" alt="Orjinalini yazan: errör" style="vertical-align: text-bottom;" /> <strong>errör Yazdı:</strong><br /><br />yetkili servis "altunizade açı" baskı balata seti değişiminde bir bilyayı değiştirmiyor\unutuyor\umursamıyor bilemem adamlara tekrar gidiyorum abi o bilyadan değil şanzımandan olur böle şeyler deyip gönderiyor, 5 sene bilya sesiyle gezdim sonra baskı balatayı maslak bosch gökçeklere değiştirttim abi bu bilya en az 10 senedir burdaymış dedi ve zaten debriyaj setinde çıkan bilyayı takyığında ne ses kaldı ne bişey,<div><br></div><div>şimdi kapandı okmeydanı yetkili servisiydi parlar peugeot önden kasiste iki parça birbirine vuruyor dedim aracı üç gün adamlara bıraktım abi bir şey yok biz gereken herşeyi yaptık al bin git dediler aracın sağ ön jantına asıldım bir iki salladım ses aynen devam ediyor bu ne dedim... yahu liftin var ustan var malzemen var bu hataları nasıl yapıyorsun birde üstüne bir şahin parası alıyorsun bu durumda bu millet kime neye nereye gitsin " nereye gidecekler ! "&nbsp;<img src="https://forum.peugeotturkey.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" /></div></td></tr></table><div>&nbsp;</div><div>Hocam geçmiş olsun&nbsp; öncelikle bilye sesii nasıl bir şeydi? Şu anda bende de var önceleri yoktu, debriyaj halatını değiştirdim ve bir süre sonra bu sesi yapmaya başladı. Şimdi gösteriyorum aynen dediğiniz gibi şanzımandan geliyor diyorlar. Araç boşta çalışırken ses geliyor debriyaja basınca kesiyor bendeki. Sizdeki nasıldı acaba? Boşa şanzımanı açtırmak da istemiyorum aslında.&nbsp;</div>]]>
   </description>
   <pubDate>Mon, 19 Aug 2013 19:12:42 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446558&amp;title=mutlu-olan-varta#446558</guid>
  </item>
  <item>
   <title><![CDATA[mutlu olan varta ! : er&#246;r ge&#231;mi&#351; olsun .be iyi ki sadece...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446482&amp;title=mutlu-olan-varta#446482</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8556">elsoberano</a><br /><strong>Konu:</strong> 30620<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Ağustos&nbsp;2013 Saat 10:09<br /><br />erör &nbsp;geçmiş olsun .&nbsp;be &nbsp;iyi ki &nbsp;sadece aküyle &nbsp;bırakmış utanmaz adam başka bişeyler daha çalmamış . bunlarda esnaf olacak.&nbsp;]]>
   </description>
   <pubDate>Mon, 19 Aug 2013 10:09:01 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446482&amp;title=mutlu-olan-varta#446482</guid>
  </item>
  <item>
   <title><![CDATA[mutlu olan varta ! : Abi ben olsam d&#246;nerdim yaw &#246;yle...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446470&amp;title=mutlu-olan-varta#446470</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7967">Alicilik</a><br /><strong>Konu:</strong> 30620<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Ağustos&nbsp;2013 Saat 08:58<br /><br />Abi ben olsam dönerdim yaw öyle iş mi olur. Bir de yolda bırakmış seni. Geçmiş olsun]]>
   </description>
   <pubDate>Mon, 19 Aug 2013 08:58:42 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446470&amp;title=mutlu-olan-varta#446470</guid>
  </item>
  <item>
   <title><![CDATA[mutlu olan varta ! : Bu adamlar&#305;n numaras&#305; filan yok...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446468&amp;title=mutlu-olan-varta#446468</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11186">yusufcaglarakarsu</a><br /><strong>Konu:</strong> 30620<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Ağustos&nbsp;2013 Saat 08:49<br /><br />Bu adamların numarası filan yok mu ? Bi ayıplayalım dürzüleri]]>
   </description>
   <pubDate>Mon, 19 Aug 2013 08:49:30 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446468&amp;title=mutlu-olan-varta#446468</guid>
  </item>
  <item>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446387&amp;title=mutlu-olan-varta#446387</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11867">Turgay_66</a><br /><strong>Konu:</strong> 30620<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Ağustos&nbsp;2013 Saat 17:41<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: errör" alt="Orjinalini yazan: errör" style="vertical-align: text-bottom;" /> <strong>errör Yazdı:</strong><br /><br />yetkili servis "altunizade açı" baskı balata seti değişiminde bir bilyayı değiştirmiyor\unutuyor\umursamıyor bilemem adamlara tekrar gidiyorum abi o bilyadan değil şanzımandan olur böle şeyler deyip gönderiyor, 5 sene bilya sesiyle gezdim sonra baskı balatayı maslak bosch gökçeklere değiştirttim abi bu bilya en az 10 senedir burdaymış dedi ve zaten debriyaj setinde çıkan bilyayı takyığında ne ses kaldı ne bişey,<div><br></div><div>şimdi kapandı okmeydanı yetkili servisiydi parlar peugeot önden kasiste iki parça birbirine vuruyor dedim aracı üç gün adamlara bıraktım abi bir şey yok biz gereken herşeyi yaptık al bin git dediler aracın sağ ön jantına asıldım bir iki salladım ses aynen devam ediyor bu ne dedim... yahu liftin var ustan var malzemen var bu hataları nasıl yapıyorsun birde üstüne bir şahin parası alıyorsun bu durumda bu millet kime neye nereye gitsin " nereye gidecekler ! "&nbsp;<img src="https://forum.peugeotturkey.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" /></div></td></tr></table>sonuna kadar haklısınız valla :)]]>
   </description>
   <pubDate>Sun, 18 Aug 2013 17:41:14 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446387&amp;title=mutlu-olan-varta#446387</guid>
  </item>
  <item>
   <title><![CDATA[mutlu olan varta ! : yetkili servis &amp;#034;altunizade...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446377&amp;title=mutlu-olan-varta#446377</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11908">errör</a><br /><strong>Konu:</strong> 30620<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Ağustos&nbsp;2013 Saat 13:46<br /><br />yetkili servis "altunizade açı" baskı balata seti değişiminde bir bilyayı değiştirmiyor\unutuyor\umursamıyor bilemem adamlara tekrar gidiyorum abi o bilyadan değil şanzımandan olur böle şeyler deyip gönderiyor, 5 sene bilya sesiyle gezdim sonra baskı balatayı maslak bosch gökçeklere değiştirttim abi bu bilya en az 10 senedir burdaymış dedi ve zaten debriyaj setinde çıkan bilyayı takyığında ne ses kaldı ne bişey,<div><br></div><div>şimdi kapandı okmeydanı yetkili servisiydi parlar peugeot önden kasiste iki parça birbirine vuruyor dedim aracı üç gün adamlara bıraktım abi bir şey yok biz gereken herşeyi yaptık al bin git dediler aracın sağ ön jantına asıldım bir iki salladım ses aynen devam ediyor bu ne dedim... yahu liftin var ustan var malzemen var bu hataları nasıl yapıyorsun birde üstüne bir şahin parası alıyorsun bu durumda bu millet kime neye nereye gitsin " nereye gidecekler ! "&nbsp;<img src="https://forum.peugeotturkey.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" /></div>]]>
   </description>
   <pubDate>Sun, 18 Aug 2013 13:46:46 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446377&amp;title=mutlu-olan-varta#446377</guid>
  </item>
  <item>
   <title><![CDATA[mutlu olan varta ! :   pt206 Yazd&#305;:  Turgay_66 Yazd&#305;:s&#305;rf...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446374&amp;title=mutlu-olan-varta#446374</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11867">Turgay_66</a><br /><strong>Konu:</strong> 30620<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Ağustos&nbsp;2013 Saat 13:19<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: pt206" alt="Orjinalini yazan: pt206" style="vertical-align: text-bottom;" /> <strong>pt206 Yazdı:</strong><br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Turgay_66" alt="Orjinalini yazan: Turgay_66" style="vertical-align: text-bottom;" /> <strong>Turgay_66 Yazdı:</strong><br /><br />sırf bu yüzden sanayi veya servise gitmek istemiyorum,sağı yapıyor solu bozuyorlar..</td></tr></table><br><br>aynen kardeşim.2 ay olmadı,serviste 100 liraya klima gazı bastırmak işime gelmedi,dışarıda 50 liraya bastırdım,klima soğutmamaya başladı.işin garip tarafı arkadaşımın 307sini de götürmüştüm aynı yere o da benden 1 ay önce aynı problemi yaşadı.fırsat bulduğumda tekrar götürücem düzeltsinbler diye.velhasıl kelam yarı fiyatına yaptırdık derken belki bir daha aynı ücreti ödeyip servis masrafına çıkıcam.uğraşmakta cabası.yetkilide belki fazla veriyoruz dışarıya göre ama hem kafamız rahat hem de bir işi bir kere yaptırıyoruz.</td></tr></table>doğru ama işte en başta böyle olacağını düşünemiyoruz neresi ucuzsa oraya koşuyoruz sonra bir sürü eziyet işte..]]>
   </description>
   <pubDate>Sun, 18 Aug 2013 13:19:08 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446374&amp;title=mutlu-olan-varta#446374</guid>
  </item>
  <item>
   <title><![CDATA[mutlu olan varta ! :   Turgay_66 Yazd&#305;:s&#305;rf bu y&#252;zden...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446370&amp;title=mutlu-olan-varta#446370</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8751">pt206</a><br /><strong>Konu:</strong> 30620<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Ağustos&nbsp;2013 Saat 12:49<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Turgay_66" alt="Orjinalini yazan: Turgay_66" style="vertical-align: text-bottom;" /> <strong>Turgay_66 Yazdı:</strong><br /><br />sırf bu yüzden sanayi veya servise gitmek istemiyorum,sağı yapıyor solu bozuyorlar..</td></tr></table><br><br>aynen kardeşim.2 ay olmadı,serviste 100 liraya klima gazı bastırmak işime gelmedi,dışarıda 50 liraya bastırdım,klima soğutmamaya başladı.işin garip tarafı arkadaşımın 307sini de götürmüştüm aynı yere o da benden 1 ay önce aynı problemi yaşadı.fırsat bulduğumda tekrar götürücem düzeltsinbler diye.velhasıl kelam yarı fiyatına yaptırdık derken belki bir daha aynı ücreti ödeyip servis masrafına çıkıcam.uğraşmakta cabası.yetkilide belki fazla veriyoruz dışarıya göre ama hem kafamız rahat hem de bir işi bir kere yaptırıyoruz.]]>
   </description>
   <pubDate>Sun, 18 Aug 2013 12:49:30 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446370&amp;title=mutlu-olan-varta#446370</guid>
  </item>
  <item>
   <title><![CDATA[mutlu olan varta ! : s&#305;rf bu y&#252;zden sanayi veya servise...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446363&amp;title=mutlu-olan-varta#446363</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11867">Turgay_66</a><br /><strong>Konu:</strong> 30620<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Ağustos&nbsp;2013 Saat 11:39<br /><br />sırf bu yüzden sanayi veya servise gitmek istemiyorum,sağı yapıyor solu bozuyorlar..]]>
   </description>
   <pubDate>Sun, 18 Aug 2013 11:39:43 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446363&amp;title=mutlu-olan-varta#446363</guid>
  </item>
  <item>
   <title><![CDATA[mutlu olan varta ! : &#220;&#231; kuru&#351; i&#231;in insan&#305;n can&#305;n&#305; tehlikeye...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446352&amp;title=mutlu-olan-varta#446352</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10321">Burak</a><br /><strong>Konu:</strong> 30620<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Ağustos&nbsp;2013 Saat 02:19<br /><br />Üç kuruş için insanın canını tehlikeye atan insan katilleri bu insanlar Allah bildigi gibi yapsın onları ucuz yırtmışsınız dediginiz gibi iyiki dağ başında bi yerde kalmamışsınız. Çok geçmiş olsun.<br>]]>
   </description>
   <pubDate>Sun, 18 Aug 2013 02:19:22 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446352&amp;title=mutlu-olan-varta#446352</guid>
  </item>
  <item>
   <title><![CDATA[mutlu olan varta ! :   Can Oksuz Yazd&#305;:ne adamlar...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446351&amp;title=mutlu-olan-varta#446351</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11908">errör</a><br /><strong>Konu:</strong> 30620<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Ağustos&nbsp;2013 Saat 02:15<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Can Oksuz" alt="Orjinalini yazan: Can Oksuz" style="vertical-align: text-bottom;" /> <strong>Can Oksuz Yazdı:</strong><br /><br />ne adamlar var arkadaş. peşini bırakmayın hocam. hakkınızı yedirmeyin.</td></tr></table><div><br></div><div><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: E.B" alt="Orjinalini yazan: E.B" style="vertical-align: text-bottom;" /> <strong>E.B Yazdı:</strong><br /><br />abi millet 3-5 tl daha fazla carpicam diye yaptiklarina bak cok gecmis olsun error :)</td></tr></table></div><div><br></div><div>teşekkürler arkadaşlar iddia edicek pek birşey yok sonuçta beyefendinin "bana böle geldi aabi" diyceeni bildiğim için ya bizzat kalkıp izmire gidildiğinde direk konuya diklemesine dalmak yada bir kamyon özlü iltifatı kendisine havale etmek kalıyor geriye..</div><div><br></div><div>ayrıca dağ başı bir sapa mecrada kalmadığıma dua ediyorum ben yatıp kalkıp yoksa yemişim parasını..</div>]]>
   </description>
   <pubDate>Sun, 18 Aug 2013 02:15:27 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446351&amp;title=mutlu-olan-varta#446351</guid>
  </item>
  <item>
   <title><![CDATA[mutlu olan varta ! :  abi millet &#351;a&#351;&#305;rm&#305;&#351; yaa &#351;erefsizler.......]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446348&amp;title=mutlu-olan-varta#446348</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11593">kuscu38</a><br /><strong>Konu:</strong> 30620<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Ağustos&nbsp;2013 Saat 02:02<br /><br />abi millet şaşırmış yaa şerefsizler.... onunla geçmiş olsun ya bijonlardan çalsalardı <img src="https://forum.peugeotturkey.com/smileys/smiley36.gif" height="17" width="17" border="0" alt="LOL" title="LOL" />]]>
   </description>
   <pubDate>Sun, 18 Aug 2013 02:02:01 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=30620&amp;PID=446348&amp;title=mutlu-olan-varta#446348</guid>
  </item>
 </channel>
</rss>
