 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Rolantı</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Arac&#305;n&#305;z Hakk&#305;ndaki T&#252;m Sorular : Rolantı]]></description>
  <pubDate>Sun, 03 May 2026 21:54:52 +0000</pubDate>
  <lastBuildDate>Thu, 11 Jul 2013 08:25:12 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=29817</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Rolantı : Oksijen sens&#246;r&#252; ar&#305;zas&#305; olabilir....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29817&amp;PID=437354&amp;title=rolanti#437354</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10539">_ali_</a><br /><strong>Konu:</strong> 29817<br /><strong>Gönderim Zamanı:</strong> 11&nbsp;Temmuz&nbsp;2013 Saat 08:25<br /><br />Oksijen sensörü arızası olabilir.<br>]]>
   </description>
   <pubDate>Thu, 11 Jul 2013 08:25:12 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29817&amp;PID=437354&amp;title=rolanti#437354</guid>
  </item>
  <item>
   <title><![CDATA[Rolantı : Selam Gecmis olsun.aracini cihaza...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29817&amp;PID=437337&amp;title=rolanti#437337</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11142">byx</a><br /><strong>Konu:</strong> 29817<br /><strong>Gönderim Zamanı:</strong> 11&nbsp;Temmuz&nbsp;2013 Saat 01:18<br /><br /> Selam Gecmis olsun.aracini cihaza baglattinmi.? Muhtemelen gaz kelebek potansiyometre arizasi olabilir.rolanti motorunu test etmek icin sokup fisi takili sekilde kontak acarak ; marsa basma.;kontak actiginda mil disa cikmali kapattigin zaman iceri girmeli. Bir kac kez denersen belli olur.bilg.baglayarak daha net sonuc alabilirsin.]]>
   </description>
   <pubDate>Thu, 11 Jul 2013 01:18:17 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29817&amp;PID=437337&amp;title=rolanti#437337</guid>
  </item>
  <item>
   <title><![CDATA[Rolantı :  Arkada&#351;lar arac&#305;mdastop etme...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29817&amp;PID=436400&amp;title=rolanti#436400</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=5538">sezar206</a><br /><strong>Konu:</strong> 29817<br /><strong>Gönderim Zamanı:</strong> 07&nbsp;Temmuz&nbsp;2013 Saat 15:14<br /><br />Arkadaşlar aracımdastop etme sorunu ortaya çıktı. Sabahları ya da motor soğuduğunda ayağını gazdan çekince stop ediyor. Marşa basınca hemen almıyor hafif gaza basınca çalışıyor. Lpg ye geçince hemen stop ediyor, benzinde ise çalışıyor ama rolantı düşerek çalışıyor sürekli. Motor ısındığında ise stop etmiyor rolantı yine dalgalı çalışıyor ama sorun biraz daha azalıyor.<div>Dün boğaz kelebeğini ve rolantı motorunu temizlettim motor sıcak olduğu için sorun düzelmiş gibiydi ancak bu sabah yine aynısını yaptı başka neden olabilir sizce? Rolantı motorunu felan değiştirsem mi yoksa depodaki gazı bitene kadar beklesem mi?</div><div>Akşam hiç sorunsuz park ettiğim aracım sabah marşa bastığımda böyle yaptı :((</div>]]>
   </description>
   <pubDate>Sun, 07 Jul 2013 15:14:58 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29817&amp;PID=436400&amp;title=rolanti#436400</guid>
  </item>
 </channel>
</rss>
