 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Bir problemde benden :)</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 307 : Bir problemde benden :)]]></description>
  <pubDate>Sun, 03 May 2026 05:58:18 +0000</pubDate>
  <lastBuildDate>Wed, 19 Jun 2013 13:22:59 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=29393</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Bir problemde benden :) : anlad&#305;m, te&#351;ekk&#252;r ederim, ak&#351;am...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29393&amp;PID=431231&amp;title=bir-problemde-benden#431231</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8684">reality59</a><br /><strong>Konu:</strong> 29393<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Haziran&nbsp;2013 Saat 13:22<br /><br />anladım, teşekkür ederim, akşam üzeri müsait bir zamanımda bakarım :)]]>
   </description>
   <pubDate>Wed, 19 Jun 2013 13:22:59 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29393&amp;PID=431231&amp;title=bir-problemde-benden#431231</guid>
  </item>
  <item>
   <title><![CDATA[Bir problemde benden :) : torpido ba&#287;lant&#305;lar&#305;n&#305; s&#246;k&#252;p kontrol...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29393&amp;PID=431226&amp;title=bir-problemde-benden#431226</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9228">ismailkaya</a><br /><strong>Konu:</strong> 29393<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Haziran&nbsp;2013 Saat 13:14<br /><br />torpido bağlantılarını söküp kontrol et derim ama ben hiç söküp bakmadım bağlantı soketlerine oradaki ]]>
   </description>
   <pubDate>Wed, 19 Jun 2013 13:14:48 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29393&amp;PID=431226&amp;title=bir-problemde-benden#431226</guid>
  </item>
  <item>
   <title><![CDATA[Bir problemde benden :) : ba&#287;lant&#305; soketlerinde sorun olu&#351;uyor ayn&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29393&amp;PID=431224&amp;title=bir-problemde-benden#431224</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9228">ismailkaya</a><br /><strong>Konu:</strong> 29393<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Haziran&nbsp;2013 Saat 13:12<br /><br />bağlantı soketlerinde sorun oluşuyor<DIV>&nbsp;aynı bendede sorun vardı analog kademeyi söktüm kontrol ettim gayet iyidi temizleyip taktım gene çalışmadı sonra servise götürdüm normalde komple değişecek dediler bende çaresi varmı dedim 100 tl. hallederiz dediler tamam dedim hallet tiler sordum sıkıntı nerede diye kabloları 307 de torbidonun arkasında bağlantı soketi varde di orası yanmış soketi değiştirdik dediler ama şimdi 2. kademe ara gidip geliyor. </DIV>]]>
   </description>
   <pubDate>Wed, 19 Jun 2013 13:12:43 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29393&amp;PID=431224&amp;title=bir-problemde-benden#431224</guid>
  </item>
  <item>
   <title><![CDATA[Bir problemde benden :) :   ondercan Yazd&#305;:klarif&#246;r tesisat&#305;nda...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29393&amp;PID=431219&amp;title=bir-problemde-benden#431219</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8684">reality59</a><br /><strong>Konu:</strong> 29393<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Haziran&nbsp;2013 Saat 12:57<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: ondercan" alt="Orjinalini yazan: ondercan" style="vertical-align: text-bottom;" /> <strong>ondercan Yazdı:</strong><br /><br />klariför tesisatında ve rezistansında problem olabilir.genellikle 307 lerde olur bu problem.rezistansı söküp soketine bakarsan belli olur.sökmek biraz zor olabilir ama büyük ihtimalle senin problemin orası.torpido gözünü söküp,kabin hava ayırıcı dügmesine basarsan rezistansı görebilirsin.saat yönüne çevirip kendine dogru çektiginde soketiyle beraber gelecektir.bi bak derim.<div>kolay gelsin.</div></td></tr></table><div><br></div><div>dediğiniz yere baktım ancak orada her hangi bir sıkıntı göremedim dirençlerde falan vs. her hangi bir sıkıntı yok gibi duruyor ancak fan kademe motoru sağlam elektriği iletiyor ama aracın içinden klima devresine gelen ana hatta problem var onu nasıl çözebilirim ?</div>]]>
   </description>
   <pubDate>Wed, 19 Jun 2013 12:57:30 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29393&amp;PID=431219&amp;title=bir-problemde-benden#431219</guid>
  </item>
  <item>
   <title><![CDATA[Bir problemde benden :) :    Yazd&#305;:Foto&#287;raftaki 206&amp;#039;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29393&amp;PID=431217&amp;title=bir-problemde-benden#431217</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8684">reality59</a><br /><strong>Konu:</strong> 29393<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Haziran&nbsp;2013 Saat 12:52<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: " alt="Orjinalini yazan: " style="vertical-align: text-bottom;" /> <strong> Yazdı:</strong><br /><br />Fotoğraftaki 206' ya ait fakat sizdekinin de içi pek farklı değildir. Fotoğrafta işaretlediğim bölgeyi güzelce temizleyin. Bir de öyle deneyin. Kolay gelsin.<br><br><a href="http://bit.ly/c25MCx" target="_blank" rel="nofollow"><img src="http://l1306.hizliresim.com/1b/l/pb8bn.jpg" border="0" /></a><br></td></tr></table><div><br></div><div>burasını kontrol ettim sağlam iletimi sağlıyor, ancak bunun arkasında bir tane ana hat var, sorun ana hatta kısa devre yaparak denedim ve sonuç olarak yine aynı 1. ve 2. kademe çalışmıyor 3. ve 4. kademe çalışıyor sorun o devrede değil o devreye gelen tesisatta ama nasıl çözebilirim</div>]]>
   </description>
   <pubDate>Wed, 19 Jun 2013 12:52:56 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29393&amp;PID=431217&amp;title=bir-problemde-benden#431217</guid>
  </item>
  <item>
   <title><![CDATA[Bir problemde benden :) : klarif&#246;r tesisat&#305;nda ve rezistans&#305;nda...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29393&amp;PID=430999&amp;title=bir-problemde-benden#430999</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10975">ondercan</a><br /><strong>Konu:</strong> 29393<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Haziran&nbsp;2013 Saat 00:09<br /><br />klariför tesisatında ve rezistansında problem olabilir.genellikle 307 lerde olur bu problem.rezistansı söküp soketine bakarsan belli olur.sökmek biraz zor olabilir ama büyük ihtimalle senin problemin orası.torpido gözünü söküp,kabin hava ayırıcı dügmesine basarsan rezistansı görebilirsin.saat yönüne çevirip kendine dogru çektiginde soketiyle beraber gelecektir.bi bak derim.<div>kolay gelsin.</div>]]>
   </description>
   <pubDate>Wed, 19 Jun 2013 00:09:25 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29393&amp;PID=430999&amp;title=bir-problemde-benden#430999</guid>
  </item>
  <item>
   <title><![CDATA[Bir problemde benden :) : Foto&#287;raftaki 206&amp;#039; ya ait...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29393&amp;PID=430990&amp;title=bir-problemde-benden#430990</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 29393<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Haziran&nbsp;2013 Saat 23:51<br /><br />Fotoğraftaki 206' ya ait fakat sizdekinin de içi pek farklı değildir. Fotoğrafta işaretlediğim bölgeyi güzelce temizleyin. Bir de öyle deneyin. Kolay gelsin.<br><br><a href="http://bit.ly/c25MCx" target="_blank" rel="nofollow"><img src="http://l1306.hizliresim.com/1b/l/pb8bn.jpg" border="0" /></a><br>]]>
   </description>
   <pubDate>Tue, 18 Jun 2013 23:51:35 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29393&amp;PID=430990&amp;title=bir-problemde-benden#430990</guid>
  </item>
  <item>
   <title><![CDATA[Bir problemde benden :) : g&#252;ncel :) ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29393&amp;PID=430988&amp;title=bir-problemde-benden#430988</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8684">reality59</a><br /><strong>Konu:</strong> 29393<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Haziran&nbsp;2013 Saat 23:49<br /><br />güncel :)]]>
   </description>
   <pubDate>Tue, 18 Jun 2013 23:49:07 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29393&amp;PID=430988&amp;title=bir-problemde-benden#430988</guid>
  </item>
  <item>
   <title><![CDATA[Bir problemde benden :) :   fexzi Yazd&#305;:kalorifer termi&#287;i...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29393&amp;PID=430849&amp;title=bir-problemde-benden#430849</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8684">reality59</a><br /><strong>Konu:</strong> 29393<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Haziran&nbsp;2013 Saat 16:49<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: fexzi" alt="Orjinalini yazan: fexzi" style="vertical-align: text-bottom;" /> <strong>fexzi Yazdı:</strong><br /><br />kalorifer termiği oksitlenmiş ya da panelde ki düğmede temassızlık var.</td></tr></table><div><br></div><div><span style="font-size: 12px; line-height: 1.4;">bende ki klima bu<br><img src="http://image5.sahibinden.com/photos/76/49/44/big_116764944bti.jpg" height="600" width="800" border="0" />&nbsp;</span><br><div><br></div></div><div>bu üniteye 3 parça kablo geliyor yukarıda iki tane kablo var ve altta bir tane büyük hat var o ana hat oluyor sanırım bu ana hatta kısa devre yöntemi ile 1.2.3.4 kademeli çalıştırabiliyorum ama 1 ve 2. kademe çalışmıyor 3. ve 4. kademe çalışıyor, 1.ve 2. kademenin sigortası farklı mı ?</div>]]>
   </description>
   <pubDate>Tue, 18 Jun 2013 16:49:43 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29393&amp;PID=430849&amp;title=bir-problemde-benden#430849</guid>
  </item>
  <item>
   <title><![CDATA[Bir problemde benden :) : problem i&#231;in bi&#351;ey diyemiycem...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29393&amp;PID=430847&amp;title=bir-problemde-benden#430847</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7941">Buğra</a><br /><strong>Konu:</strong> 29393<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Haziran&nbsp;2013 Saat 16:40<br /><br />problem için bişey diyemiycem ama bi şu konuya bak istersen<img src="https://forum.peugeotturkey.com/smileys/smiley2.gif" border="0" alt="Wink" title="Wink" /><div><br></div><div><a href="http://forum.peugeotturkey.com/forum_posts.asp?TID=29368" rel="nofollow">http://forum.peugeotturkey.com/forum_posts.asp?TID=29368</a></div>]]>
   </description>
   <pubDate>Tue, 18 Jun 2013 16:40:57 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29393&amp;PID=430847&amp;title=bir-problemde-benden#430847</guid>
  </item>
  <item>
   <title><![CDATA[Bir problemde benden :) : kalorifer termi&#287;i oksitlenmi&#351;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29393&amp;PID=430845&amp;title=bir-problemde-benden#430845</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6824">fexzi</a><br /><strong>Konu:</strong> 29393<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Haziran&nbsp;2013 Saat 16:36<br /><br />kalorifer termiği oksitlenmiş ya da panelde ki düğmede temassızlık var.]]>
   </description>
   <pubDate>Tue, 18 Jun 2013 16:36:50 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29393&amp;PID=430845&amp;title=bir-problemde-benden#430845</guid>
  </item>
  <item>
   <title><![CDATA[Bir problemde benden :) : Arkada&#351;lar, 2004 model 307 hdi...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29393&amp;PID=430839&amp;title=bir-problemde-benden#430839</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8684">reality59</a><br /><strong>Konu:</strong> 29393<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Haziran&nbsp;2013 Saat 15:50<br /><br />Arkadaşlar, 2004 model 307 hdi xr analog klimalı aracım, problemim ise kademe olarak 1 ve 2. seviye çalışmıyor 3-4 çalışıyor sebebi ne olabilir ? :)]]>
   </description>
   <pubDate>Tue, 18 Jun 2013 15:50:39 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29393&amp;PID=430839&amp;title=bir-problemde-benden#430839</guid>
  </item>
 </channel>
</rss>
