 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : bi biip sesi :)</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 307 : bi biip sesi :)]]></description>
  <pubDate>Sun, 03 May 2026 14:31:28 +0000</pubDate>
  <lastBuildDate>Tue, 04 Jun 2013 01:13:34 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=29050</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[bi biip sesi :) : oses bende genelde gaz bitince...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29050&amp;PID=425910&amp;title=bi-biip-sesi#425910</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9972">peugeotttt</a><br /><strong>Konu:</strong> 29050<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Haziran&nbsp;2013 Saat 01:13<br /><br /> oses bende genelde gaz bitince yapıyo :)) lpg şamandırasıda bozuk olabilir.aracta gazda olsa bozuksa eger gaz bitti diye uyarı verir.kasislerde şamandıra hareket edebilir.her turlu ıhtımal var yani.lpg bu aarkadasım hafife alma kontrol ettir biran aönce.]]>
   </description>
   <pubDate>Tue, 04 Jun 2013 01:13:34 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29050&amp;PID=425910&amp;title=bi-biip-sesi#425910</guid>
  </item>
  <item>
   <title><![CDATA[bi biip sesi :) :   Serkan Yazd&#305;:5 ayda olsa filtre...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29050&amp;PID=425767&amp;title=bi-biip-sesi#425767</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10418">Mesut48</a><br /><strong>Konu:</strong> 29050<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Haziran&nbsp;2013 Saat 13:59<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Serkan" alt="Orjinalini yazan: Serkan" style="vertical-align: text-bottom;" /> <strong>Serkan Yazdı:</strong><br /><br />5 ayda olsa filtre falan değişmesi gerekiyorsa uyarı verir siz lpg'den gelme ihtimalinide değerlendirin, ses geldiği zaman ekrana dikkat edin FUEL LEVEL LOW yazıyormu? Yazıyorsa kesin yakıt seviyesindendir. (çok kısa süreli yazar)</td></tr></table><br><br>Budur <img src="https://forum.peugeotturkey.com/smileys/smiley20.gif" border="0" alt="Thumbs Up" title="Thumbs Up" /> LPG bakım zamanınız gelmiş bakıma gidin.<br>]]>
   </description>
   <pubDate>Mon, 03 Jun 2013 13:59:13 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29050&amp;PID=425767&amp;title=bi-biip-sesi#425767</guid>
  </item>
  <item>
   <title><![CDATA[bi biip sesi :) : Lpg tesisat&#305; yap&#305;l&#305;rken ve ya...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29050&amp;PID=425678&amp;title=bi-biip-sesi#425678</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7967">Alicilik</a><br /><strong>Konu:</strong> 29050<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Haziran&nbsp;2013 Saat 08:59<br /><br />Lpg tesisatı yapılırken ve ya montjı sırasında şase açığı oluşmuş olabilir araçta. Benzer bir açık bana da oldu araç sürekli ötüp duruyordu. Şase vidasını sıkılayınca düzeldi. ]]>
   </description>
   <pubDate>Mon, 03 Jun 2013 08:59:57 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29050&amp;PID=425678&amp;title=bi-biip-sesi#425678</guid>
  </item>
  <item>
   <title><![CDATA[bi biip sesi :) : yok yazm&#305;yor bakt&#305;m ama benzinde...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29050&amp;PID=425666&amp;title=bi-biip-sesi#425666</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11774">nevce</a><br /><strong>Konu:</strong> 29050<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Haziran&nbsp;2013 Saat 00:58<br /><br />yok yazmıyor baktım ama benzinde çeyrekte hep tamam yarın baktıra cam onada...]]>
   </description>
   <pubDate>Mon, 03 Jun 2013 00:58:02 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29050&amp;PID=425666&amp;title=bi-biip-sesi#425666</guid>
  </item>
  <item>
   <title><![CDATA[bi biip sesi :) : 5 ayda olsa filtre falan de&#287;i&#351;mesi...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29050&amp;PID=425661&amp;title=bi-biip-sesi#425661</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9585">Serkan</a><br /><strong>Konu:</strong> 29050<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Haziran&nbsp;2013 Saat 00:46<br /><br />5 ayda olsa filtre falan değişmesi gerekiyorsa uyarı verir siz lpg'den gelme ihtimalinide değerlendirin, ses geldiği zaman ekrana dikkat edin FUEL LEVEL LOW yazıyormu? Yazıyorsa kesin yakıt seviyesindendir. (çok kısa süreli yazar)]]>
   </description>
   <pubDate>Mon, 03 Jun 2013 00:46:18 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29050&amp;PID=425661&amp;title=bi-biip-sesi#425661</guid>
  </item>
  <item>
   <title><![CDATA[bi biip sesi :) : yak&#305;t sesi olabilir :) bak hi&#231;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29050&amp;PID=425654&amp;title=bi-biip-sesi#425654</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11774">nevce</a><br /><strong>Konu:</strong> 29050<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Haziran&nbsp;2013 Saat 00:37<br /><br />yakıt sesi olabilir :) bak hiç aklıma gelmedi &nbsp;şaşırdım kralsın yaa :) yok lpg takılalı 5 ay oldu)]]>
   </description>
   <pubDate>Mon, 03 Jun 2013 00:37:44 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29050&amp;PID=425654&amp;title=bi-biip-sesi#425654</guid>
  </item>
  <item>
   <title><![CDATA[bi biip sesi :) : Yak&#305;t durumu derken yak&#305;t seviyesini...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29050&amp;PID=425649&amp;title=bi-biip-sesi#425649</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9585">Serkan</a><br /><strong>Konu:</strong> 29050<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Haziran&nbsp;2013 Saat 00:26<br /><br />Yakıt durumu derken yakıt seviyesini kastetmiştim yakıt ışığı yanınca ikaz sesi verir :) Birde araçda lpg'de var lpg bakım zamanı da gelmiş olabilir, ses geldiği zaman sesi dinleyin lpg düğmesinin olduğu yerdenmi geliyor? Sesin amortisörle falan alakası olmaz, amortisör kırılsa yine öyle bir ses çıkmaz araçtan]]>
   </description>
   <pubDate>Mon, 03 Jun 2013 00:26:37 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29050&amp;PID=425649&amp;title=bi-biip-sesi#425649</guid>
  </item>
  <item>
   <title><![CDATA[bi biip sesi :) : hay&#305;r dijital bir ses ve arka...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29050&amp;PID=425647&amp;title=bi-biip-sesi#425647</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11774">nevce</a><br /><strong>Konu:</strong> 29050<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Haziran&nbsp;2013 Saat 00:22<br /><br />hayır dijital bir ses ve arka amortisörler vurunca yapıyor yakıt durumu iyi :) lpg karışık 28 kuruş:)]]>
   </description>
   <pubDate>Mon, 03 Jun 2013 00:22:13 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29050&amp;PID=425647&amp;title=bi-biip-sesi#425647</guid>
  </item>
  <item>
   <title><![CDATA[bi biip sesi :) : Yak&#305;t durumu nas&#305;l? dijital bi...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29050&amp;PID=425646&amp;title=bi-biip-sesi#425646</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9585">Serkan</a><br /><strong>Konu:</strong> 29050<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Haziran&nbsp;2013 Saat 00:20<br /><br />Yakıt durumu nasıl? dijital bi ses dimi, mekanik ses değil?]]>
   </description>
   <pubDate>Mon, 03 Jun 2013 00:20:51 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29050&amp;PID=425646&amp;title=bi-biip-sesi#425646</guid>
  </item>
  <item>
   <title><![CDATA[bi biip sesi :) : hay&#305;r hi&#231; bir uyar&#305; yok hatta...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29050&amp;PID=425644&amp;title=bi-biip-sesi#425644</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11774">nevce</a><br /><strong>Konu:</strong> 29050<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Haziran&nbsp;2013 Saat 00:19<br /><br />hayır hiç bir uyarı yok hatta bu sesi ispat etmek için paso kasise girdim :)<div><br></div>]]>
   </description>
   <pubDate>Mon, 03 Jun 2013 00:19:32 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29050&amp;PID=425644&amp;title=bi-biip-sesi#425644</guid>
  </item>
  <item>
   <title><![CDATA[bi biip sesi :) : Abs olsa uyar&#305; &#305;&#351;&#305;&#287;&#305;da yanar,...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29050&amp;PID=425643&amp;title=bi-biip-sesi#425643</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9585">Serkan</a><br /><strong>Konu:</strong> 29050<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Haziran&nbsp;2013 Saat 00:18<br /><br />Abs olsa uyarı ışığıda yanar, herhangi bir ışık yanmıyormu yada ekranda bi uyarı falan?]]>
   </description>
   <pubDate>Mon, 03 Jun 2013 00:18:27 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29050&amp;PID=425643&amp;title=bi-biip-sesi#425643</guid>
  </item>
  <item>
   <title><![CDATA[bi biip sesi :) : arkada&#351;lar kasislerde araban&#305;n...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=29050&amp;PID=425640&amp;title=bi-biip-sesi#425640</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11774">nevce</a><br /><strong>Konu:</strong> 29050<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Haziran&nbsp;2013 Saat 00:08<br /><br />arkadaşlar kasislerde arabanın bi yerinden bi bip sesi geliyor tırstım pak sensörü dedim olmaz dediler abs den diyenler var ama frene basmadan da oluyor anladım yardımmm]]>
   </description>
   <pubDate>Mon, 03 Jun 2013 00:08:56 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=29050&amp;PID=425640&amp;title=bi-biip-sesi#425640</guid>
  </item>
 </channel>
</rss>
