 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 307 abs ile ilgili</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 307 : 307 abs ile ilgili]]></description>
  <pubDate>Sun, 03 May 2026 22:21:06 +0000</pubDate>
  <lastBuildDate>Tue, 21 May 2013 20:06:32 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=28759</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[307 abs ile ilgili : forumumuzun sponsorunda var orjinal...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=28759&amp;PID=422277&amp;title=307-abs-ile-ilgili#422277</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7941">Buğra</a><br /><strong>Konu:</strong> 28759<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Mayıs&nbsp;2013 Saat 20:06<br /><br />forumumuzun sponsorunda var orjinal fren tertibatı parçaları. bi ziyaret edin isterseniz.]]>
   </description>
   <pubDate>Tue, 21 May 2013 20:06:32 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=28759&amp;PID=422277&amp;title=307-abs-ile-ilgili#422277</guid>
  </item>
  <item>
   <title><![CDATA[307 abs ile ilgili :   kas&#305;rga16 Yazd&#305;:&#246;n arka balata...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=28759&amp;PID=422232&amp;title=307-abs-ile-ilgili#422232</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11814">kasırga16</a><br /><strong>Konu:</strong> 28759<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Mayıs&nbsp;2013 Saat 17:07<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: kasırga16" alt="Orjinalini yazan: kasırga16" style="vertical-align: text-bottom;" /> <strong>kasırga16 Yazdı:</strong><br /><br />ön arka balata ve frenleri</td></tr></table>&nbsp; <DIV>&nbsp;balata ve disk leri diyecektim :)</DIV>]]>
   </description>
   <pubDate>Tue, 21 May 2013 17:07:25 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=28759&amp;PID=422232&amp;title=307-abs-ile-ilgili#422232</guid>
  </item>
  <item>
   <title><![CDATA[307 abs ile ilgili : Hocam &#231;ok te&#351;ekk&#252;r ediyorum verdi&#287;in...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=28759&amp;PID=422231&amp;title=307-abs-ile-ilgili#422231</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11814">kasırga16</a><br /><strong>Konu:</strong> 28759<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Mayıs&nbsp;2013 Saat 17:05<br /><br />Hocam çok teşekkür ediyorum verdiğin değerli bilgilerin için , aracın fren bakımını yaptırmayı düşünüyorum ön arka balata ve frenleri kontrol ettirip değiştirmek istiyorum, bu arada önereceğiniz bir fren ve disk markası var mı acaba? orjinale eşdeğer<DIV>&nbsp;saygılar</DIV>]]>
   </description>
   <pubDate>Tue, 21 May 2013 17:05:55 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=28759&amp;PID=422231&amp;title=307-abs-ile-ilgili#422231</guid>
  </item>
  <item>
   <title><![CDATA[307 abs ile ilgili :   bugrature Yazd&#305;:&#246;nlere oranla...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=28759&amp;PID=422034&amp;title=307-abs-ile-ilgili#422034</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9069">eeccaa</a><br /><strong>Konu:</strong> 28759<br /><strong>Gönderim Zamanı:</strong> 20&nbsp;Mayıs&nbsp;2013 Saat 23:48<br /><br /><div><span style="line-height: 1.4;"><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: bugrature" alt="Orjinalini yazan: bugrature" style="vertical-align: text-bottom;" /> <strong>bugrature Yazdı:</strong><br /><br />önlere oranla arkalar daha az frenleme yapar (ayak freninde) &nbsp;</td></tr></table></span></div><div>Aynen. Motoru önde ve önden çekişli olan (yani ortalıktaki otomobillerin büyük çoğunluğunun) ön-arka ağırlık dağılımları yaklaşık %70-%60 ön, %30-%40 arka şeklindedir. Hareketsizken bile araç ağırlığının çoğunu ön tekerlekler taşır. Etkili biçimde yavaşlamakta olan bir araçta ağırlık merkezi daha da öne kayacağından ön-arka yük dağılım farkı daha da artar. Zaten arka disk ve balata boyutları öndekilere göre çok daha küçük tasarlanır, buna karşın kullanım ömürleri öndekilere göre 3-4 kat uzundur. En kötü, en eski teknoloji araçlar bile fren yapıldığında arkaya giden basıncı düşürerek çoğunluğu öne gönderen düzeneklere sahiptirler. Sizde bu sağlıklı işlemiyor görünüyor. Fren bakımı sonrası bu çözülecektir, aman bakımı ertelemeyin.</div><div><span style="line-height: 1.4;"><br></span></div><div><span style="line-height: 1.4;">ABS'li bir araçta, kayan bir tekerleğin söz konusu olması da düşündürücü. Kontağı açtığınızda marşa basmadan birkaç saniye ABS lambanız yanmalı sonra sönmelidir. Böyle oluyorsa sistem normal çalışıyor olmalı, zaten sistemin sesini duyduğunuzu da söylediniz. Çünkü ABS'nin belirli tekerleklerde çalışıp bazılarında çalışmaması olanaksız. En ufak arızada kendini tamamen devre dışı bırakacak şekilde programlanırlar.</span></div><div><span style="line-height: 1.4;"><br></span></div><div><span style="line-height: 1.4;">Siz tam indirseniz de el freniniz bir miktar çekili mi kalıyor ki? Bu yaşadığınız tüm dengesizliği açıklayabilir.</span><span style="line-height: 1.4;">&nbsp;Neyse siz çözünce bizi de bilgilendirin, geçmiş olsun :)</span></div>]]>
   </description>
   <pubDate>Mon, 20 May 2013 23:48:52 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=28759&amp;PID=422034&amp;title=307-abs-ile-ilgili#422034</guid>
  </item>
  <item>
   <title><![CDATA[307 abs ile ilgili : Te&#351;ekk&#252;r ederim hocam sa&#287;olas&#305;n...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=28759&amp;PID=421812&amp;title=307-abs-ile-ilgili#421812</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11814">kasırga16</a><br /><strong>Konu:</strong> 28759<br /><strong>Gönderim Zamanı:</strong> 20&nbsp;Mayıs&nbsp;2013 Saat 09:40<br /><br />Teşekkür ederim hocam sağolasın paylaşımın için.<DIV>Bakımı da gelmişti aracın komple check-up a koymak lazım </DIV>]]>
   </description>
   <pubDate>Mon, 20 May 2013 09:40:35 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=28759&amp;PID=421812&amp;title=307-abs-ile-ilgili#421812</guid>
  </item>
  <item>
   <title><![CDATA[307 abs ile ilgili : heh &#351;imdi anla&#351;&#305;ld&#305;. &#351;imdi &#351;&#246;le...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=28759&amp;PID=421810&amp;title=307-abs-ile-ilgili#421810</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7941">Buğra</a><br /><strong>Konu:</strong> 28759<br /><strong>Gönderim Zamanı:</strong> 20&nbsp;Mayıs&nbsp;2013 Saat 09:27<br /><br />heh şimdi anlaşıldı. şimdi şöle söyliyim aracının frenine bastığında ön lastikler %75 fren yapıyossa arka lastiklerde %25 oranında fren yapar. yani önlere oranla arkalar daha az frenleme yapar (ayak freninde) eğer bu oranda bi farklilik olursa yani arkalar daha fazla fren yaparsa şuan başına gelen şey gelir ve daha kötüsü aracın fren yaptığında savrulur (heleki virajda fren, bu durumda taklaya getirir) o yüzden hiç bekleme bi ustaya göster arka frenleri artık kampanamı diskmi bilemiyorum...&nbsp;<span style="font-size:10px"><br /><br />Düzenleyen bugrature - 20&nbsp;Mayıs&nbsp;2013 Saat 09:29</span>]]>
   </description>
   <pubDate>Mon, 20 May 2013 09:27:51 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=28759&amp;PID=421810&amp;title=307-abs-ile-ilgili#421810</guid>
  </item>
  <item>
   <title><![CDATA[307 abs ile ilgili : hocam lastikler k&#305;zakl&#305;yor diyeyim,...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=28759&amp;PID=421809&amp;title=307-abs-ile-ilgili#421809</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11814">kasırga16</a><br /><strong>Konu:</strong> 28759<br /><strong>Gönderim Zamanı:</strong> 20&nbsp;Mayıs&nbsp;2013 Saat 09:16<br /><br />hocam lastikler kızaklıyor diyeyim, kitleniyor arka lastikler iz yapıyor ]]>
   </description>
   <pubDate>Mon, 20 May 2013 09:16:12 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=28759&amp;PID=421809&amp;title=307-abs-ile-ilgili#421809</guid>
  </item>
  <item>
   <title><![CDATA[307 abs ile ilgili : &#231;izdiriMEK	ne demek hocam biraz...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=28759&amp;PID=421808&amp;title=307-abs-ile-ilgili#421808</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7941">Buğra</a><br /><strong>Konu:</strong> 28759<br /><strong>Gönderim Zamanı:</strong> 20&nbsp;Mayıs&nbsp;2013 Saat 09:14<br /><br /><span style=": rgb251, 251, 253;">çizdiriMEK<span ="apple-tab-span"="" style="white-space:pre">	</span>&nbsp;ne demek hocam biraz açarmısın. bi tür sesmi yoksa iz mi ben pek anlamadım.&nbsp;</span><span style="font-size:10px"><br /><br />Düzenleyen bugrature - 20&nbsp;Mayıs&nbsp;2013 Saat 09:29</span>]]>
   </description>
   <pubDate>Mon, 20 May 2013 09:14:49 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=28759&amp;PID=421808&amp;title=307-abs-ile-ilgili#421808</guid>
  </item>
  <item>
   <title><![CDATA[307 abs ile ilgili : arkada&#351;lar, merak etti&#287;im esas&#305;nda...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=28759&amp;PID=421796&amp;title=307-abs-ile-ilgili#421796</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11814">kasırga16</a><br /><strong>Konu:</strong> 28759<br /><strong>Gönderim Zamanı:</strong> 20&nbsp;Mayıs&nbsp;2013 Saat 08:31<br /><br />arkadaşlar, merak ettiğim esasında abs sisteminde bir sorun olup olmadığı , arka lastikler tozlu çakıllı zeminde çizdiriyor özellikle bayır aşağı inerken. Bu durum üzerinde durmak istiyorum. Acaba bu lastiklerde mi balata disklerde mi yoksa abs sisteminde mi bir problem vardır?<DIV>herkese selamlar..</DIV>]]>
   </description>
   <pubDate>Mon, 20 May 2013 08:31:49 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=28759&amp;PID=421796&amp;title=307-abs-ile-ilgili#421796</guid>
  </item>
  <item>
   <title><![CDATA[307 abs ile ilgili : &#199;izdiriyor dedi&#287;iniz lastiklerin...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=28759&amp;PID=421788&amp;title=307-abs-ile-ilgili#421788</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9069">eeccaa</a><br /><strong>Konu:</strong> 28759<br /><strong>Gönderim Zamanı:</strong> 20&nbsp;Mayıs&nbsp;2013 Saat 02:00<br /><br />Çizdiriyor dediğiniz lastiklerin yerde iz bırakmasıysa, ABS normal çalışsa da lastik izi kalabiliyor bazen asfaltta. Çünkü kesik kesik ve cm'ler bazında kısa kısa lastikler kayıyor aslında. Biz o izlerin birleşimini görüyoruz. Ama ön taraf iz bırakıyordur. Çünkü özellikle sert frende arka lastiklerin yere yaptığı basınç çok azdır ve önün bırakmayıp arkanın iz bırakması imkansız gibi bana göre.&nbsp;<div><br></div><div>ABS arızası da almadığınızdan hiç sanmıyorum ama eğer arka tekerleklerin kilitlendiğinden çok eminseniz ya da öne göre daha güçlü frenleme yaptığından şüpheleniyorsanız, frende hafif bir direksiyon haraketiyle savrulursunuz, bu da çok tehlikeli. Bu sebeple üstüne gitmek istedim.&nbsp;</div>]]>
   </description>
   <pubDate>Mon, 20 May 2013 02:00:12 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=28759&amp;PID=421788&amp;title=307-abs-ile-ilgili#421788</guid>
  </item>
  <item>
   <title><![CDATA[307 abs ile ilgili : Hocam o &#231;atur &#231;utur sesler ABS...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=28759&amp;PID=421690&amp;title=307-abs-ile-ilgili#421690</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9585">Serkan</a><br /><strong>Konu:</strong> 28759<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Mayıs&nbsp;2013 Saat 22:35<br /><br />Hocam o çatur çutur sesler ABS devreye girdiği için çıkıyor, ABS devreye girince göstergede ışık yanmaz, ABS ışığı ABS sisteminde bi arıza olduğu zaman yanar. Yani sorun yok]]>
   </description>
   <pubDate>Sun, 19 May 2013 22:35:36 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=28759&amp;PID=421690&amp;title=307-abs-ile-ilgili#421690</guid>
  </item>
  <item>
   <title><![CDATA[307 abs ile ilgili : arkada&#351;lar merhaba, 307 sw otomatik...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=28759&amp;PID=421678&amp;title=307-abs-ile-ilgili#421678</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11814">kasırga16</a><br /><strong>Konu:</strong> 28759<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Mayıs&nbsp;2013 Saat 21:55<br /><br />arkadaşlar merhaba, 307 sw otomatik vites aracımda arka lastikler frene basınca bazen çizdiriyor , ve frene sağlam yüklenince catır cutur sesler geliyor durmayacak diye geriliyorum ancak araç duruyor acaba bir problem mi vardır ?<DIV>göstergede abs uyarı lambası yanmıyor</DIV><DIV>yardımcı olursanız sevinirim</DIV><DIV>saygılar..</DIV>]]>
   </description>
   <pubDate>Sun, 19 May 2013 21:55:02 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=28759&amp;PID=421678&amp;title=307-abs-ile-ilgili#421678</guid>
  </item>
 </channel>
</rss>
