 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 206 ÖN KONSOL EKRAN PROBLEMİ</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Al&#305;n&#305;k Par&#231;alar : 206 ÖN KONSOL EKRAN PROBLEMİ]]></description>
  <pubDate>Sun, 03 May 2026 16:20:05 +0000</pubDate>
  <lastBuildDate>Mon, 25 Mar 2013 13:41:32 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=27771</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[206 ÖN KONSOL EKRAN PROBLEMİ : T&#252;rkiye&amp;#039;ye g&#246;nderim yapm&#305;yor...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27771&amp;PID=409448&amp;title=206-on-konsol-ekran-problemi#409448</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9585">Serkan</a><br /><strong>Konu:</strong> 27771<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Mart&nbsp;2013 Saat 13:41<br /><br />Türkiye'ye gönderim yapmıyor satıcı daha doğrusu ingiltere dışına satış yapmıyor. Çıkar ama ara ara bakmak lazım.]]>
   </description>
   <pubDate>Mon, 25 Mar 2013 13:41:32 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27771&amp;PID=409448&amp;title=206-on-konsol-ekran-problemi#409448</guid>
  </item>
  <item>
   <title><![CDATA[206 ÖN KONSOL EKRAN PROBLEMİ : bunlar&#305; alam&#305;yoruz yani ebaydan......]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27771&amp;PID=409446&amp;title=206-on-konsol-ekran-problemi#409446</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11411">ADANALI_01</a><br /><strong>Konu:</strong> 27771<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Mart&nbsp;2013 Saat 13:35<br /><br />bunları alamıyoruz yani ebaydan...]]>
   </description>
   <pubDate>Mon, 25 Mar 2013 13:35:33 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27771&amp;PID=409446&amp;title=206-on-konsol-ekran-problemi#409446</guid>
  </item>
  <item>
   <title><![CDATA[206 ÖN KONSOL EKRAN PROBLEMİ : Olmaz hocam motor ayn&#305; olmas&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27771&amp;PID=409445&amp;title=206-on-konsol-ekran-problemi#409445</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9585">Serkan</a><br /><strong>Konu:</strong> 27771<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Mart&nbsp;2013 Saat 13:31<br /><br />Olmaz hocam motor aynı olması bişey değiştirmez, hava filtresi değil ki bu motor aynı diye uysun birbirine, &nbsp;ebayda 2-3 tane var satılık ama Türkiye'ye gönderim yapmıyolar, bu ingilizler nedense hiçbir şey göndermiyorlar Türkiye'ye]]>
   </description>
   <pubDate>Mon, 25 Mar 2013 13:31:05 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27771&amp;PID=409445&amp;title=206-on-konsol-ekran-problemi#409445</guid>
  </item>
  <item>
   <title><![CDATA[206 ÖN KONSOL EKRAN PROBLEMİ : aynen te kendisi bu hocam &#231;ok...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27771&amp;PID=409444&amp;title=206-on-konsol-ekran-problemi#409444</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11411">ADANALI_01</a><br /><strong>Konu:</strong> 27771<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Mart&nbsp;2013 Saat 13:26<br /><br />aynen te kendisi bu hocam çok teşekkür ediyorum çıkmacı 307 motor var senin arabada dedi o yüzden olur dedi 3 satırlı ısrarla...]]>
   </description>
   <pubDate>Mon, 25 Mar 2013 13:26:04 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27771&amp;PID=409444&amp;title=206-on-konsol-ekran-problemi#409444</guid>
  </item>
  <item>
   <title><![CDATA[206 ÖN KONSOL EKRAN PROBLEMİ : Sizin ekran bu linktekindenmi...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27771&amp;PID=409443&amp;title=206-on-konsol-ekran-problemi#409443</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9585">Serkan</a><br /><strong>Konu:</strong> 27771<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Mart&nbsp;2013 Saat 13:18<br /><br />Sizin ekran bu linktekindenmi hocam<div><br></div><div><a href="http://www.ebay.co.uk/itm/peugeot-206-gti-xsi-4-bulb-clock-dash-display-ppt-30-/321080661435?_trksid=p2047675.m1850&amp;_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D6490895230032930994%26pid%3D100011%26prg%3D1005%26rk%3D2%26sd%3D251164692003%26" target="_blank" rel="nofollow">LİNK...</a></div><span style="font-size:10px"><br /><br />Düzenleyen Serco05 - 25&nbsp;Mart&nbsp;2013 Saat 13:19</span>]]>
   </description>
   <pubDate>Mon, 25 Mar 2013 13:18:58 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27771&amp;PID=409443&amp;title=206-on-konsol-ekran-problemi#409443</guid>
  </item>
  <item>
   <title><![CDATA[206 ÖN KONSOL EKRAN PROBLEMİ : pardon hocam bilmiyordum ger&#231;ekten...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27771&amp;PID=409441&amp;title=206-on-konsol-ekran-problemi#409441</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11411">ADANALI_01</a><br /><strong>Konu:</strong> 27771<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Mart&nbsp;2013 Saat 13:06<br /><br />pardon hocam bilmiyordum gerçekten öğrenmiş olduk büyük harfin bagırmak olduğunu...]]>
   </description>
   <pubDate>Mon, 25 Mar 2013 13:06:03 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27771&amp;PID=409441&amp;title=206-on-konsol-ekran-problemi#409441</guid>
  </item>
  <item>
   <title><![CDATA[206 ÖN KONSOL EKRAN PROBLEMİ : Elindeki ekran 3 amp&#252;lse &#231;al&#305;&#351;maz...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27771&amp;PID=409436&amp;title=206-on-konsol-ekran-problemi#409436</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9585">Serkan</a><br /><strong>Konu:</strong> 27771<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Mart&nbsp;2013 Saat 12:48<br /><br />Elindeki ekran 3 ampülse &nbsp;çalışmaz hocam, para istemiyorsa yinede bir denesin, birde büyük harf kullanmamaya özen gösterirsek sevinirim, büyük harf kullanmak bağırmak anlamına geldiği için kullanmak yasaktır.]]>
   </description>
   <pubDate>Mon, 25 Mar 2013 12:48:01 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27771&amp;PID=409436&amp;title=206-on-konsol-ekran-problemi#409436</guid>
  </item>
  <item>
   <title><![CDATA[206 ÖN KONSOL EKRAN PROBLEMİ : B&#304;R &#199;IKMACIYLA G&#214;R&#220;&#350;T&#220;M O &#199;ALI&#350;ACA&#286;INI...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27771&amp;PID=409434&amp;title=206-on-konsol-ekran-problemi#409434</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11411">ADANALI_01</a><br /><strong>Konu:</strong> 27771<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Mart&nbsp;2013 Saat 12:41<br /><br />BİR ÇIKMACIYLA GÖRÜŞTÜM O ÇALIŞACAĞINI SÖYLEDİ ÜÇ SATIRLI EKRANIN ACA O UYAR MI ADAM MOTORUN 307 MOTORU DEDİ OLUR OLMAZSA PARA VERME DEDİ...<div><br></div>]]>
   </description>
   <pubDate>Mon, 25 Mar 2013 12:41:46 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27771&amp;PID=409434&amp;title=206-on-konsol-ekran-problemi#409434</guid>
  </item>
  <item>
   <title><![CDATA[206 ÖN KONSOL EKRAN PROBLEMİ : O zaman i&#351;iniz zor hocam 4 amp&#252;l...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27771&amp;PID=409432&amp;title=206-on-konsol-ekran-problemi#409432</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9585">Serkan</a><br /><strong>Konu:</strong> 27771<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Mart&nbsp;2013 Saat 12:34<br /><br />O zaman işiniz zor hocam 4 ampül bulmak zor, piyasada bulacağınız 3 satır ekranların&nbsp;hemen hemen&nbsp;hepsi&nbsp;3 ampüllüdür ve 2003 model ve üzeri makyajlı kasalara uyar sizin aracınıza uymaz, ebayda şansınızı deneyin, bende bulabilirsem link gönderirim.]]>
   </description>
   <pubDate>Mon, 25 Mar 2013 12:34:15 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27771&amp;PID=409432&amp;title=206-on-konsol-ekran-problemi#409432</guid>
  </item>
  <item>
   <title><![CDATA[206 ÖN KONSOL EKRAN PROBLEMİ : 4 AMP&#220;L VAR 2001 MODEL 1,6 ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27771&amp;PID=409429&amp;title=206-on-konsol-ekran-problemi#409429</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11411">ADANALI_01</a><br /><strong>Konu:</strong> 27771<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Mart&nbsp;2013 Saat 12:29<br /><br />4 AMPÜL VAR 2001 MODEL 1,6]]>
   </description>
   <pubDate>Mon, 25 Mar 2013 12:29:33 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27771&amp;PID=409429&amp;title=206-on-konsol-ekran-problemi#409429</guid>
  </item>
  <item>
   <title><![CDATA[206 ÖN KONSOL EKRAN PROBLEMİ : Arac&#305;n&#305;z ka&#231; model hocam birde...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27771&amp;PID=409427&amp;title=206-on-konsol-ekran-problemi#409427</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9585">Serkan</a><br /><strong>Konu:</strong> 27771<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Mart&nbsp;2013 Saat 12:27<br /><br />Aracınız kaç model hocam birde 3 satır ekranınızda kaç ampül var, ekranın üzerindeki kasketi sökerseniz arkada duylar görünür.]]>
   </description>
   <pubDate>Mon, 25 Mar 2013 12:27:11 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27771&amp;PID=409427&amp;title=206-on-konsol-ekran-problemi#409427</guid>
  </item>
  <item>
   <title><![CDATA[206 ÖN KONSOL EKRAN PROBLEMİ : ARKADA&#350;LAR 206 1,6 ROLANGARROS...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27771&amp;PID=409420&amp;title=206-on-konsol-ekran-problemi#409420</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11411">ADANALI_01</a><br /><strong>Konu:</strong> 27771<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Mart&nbsp;2013 Saat 11:55<br /><br />ARKADAŞLAR 206 1,6 ROLANGARROS ALDIM BUNUN ÖN KONSOL EKRANI ÇALIŞMIYOR, İNTERNETTE ARAŞTIRDIM İKİ SATIRLI BENDEKİ ÜÇ SATIRLI OLUR DİYORLAR OLUR MU? BİR FİKRİNİZİ ALAYIM! BİRDE NE KADARDIR ÇIKMA ELİNDE OLAN VARMI...]]>
   </description>
   <pubDate>Mon, 25 Mar 2013 11:55:41 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27771&amp;PID=409420&amp;title=206-on-konsol-ekran-problemi#409420</guid>
  </item>
 </channel>
</rss>
