 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 307</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Ara&#231; Al&#305;m &amp; Sat&#305;m&#305; : 307]]></description>
  <pubDate>Sun, 03 May 2026 16:00:05 +0000</pubDate>
  <lastBuildDate>Tue, 26 Mar 2013 09:41:59 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=27770</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[307 : aynalar&#305;n kapanmas&#305; olay&#305; ayna...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27770&amp;PID=409669&amp;title=307#409669</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8556">elsoberano</a><br /><strong>Konu:</strong> 27770<br /><strong>Gönderim Zamanı:</strong> 26&nbsp;Mart&nbsp;2013 Saat 09:41<br /><br />aynaların kapanması olayı ayna motoru ile de alakalı değil mi ? sadece yazılım güncellemesi yapsak yetersiz kalır ?<br>&#091;/QUOTE&#093;<div><br></div><div>bildiğim kadarıyla ayna motoruyla alakalı .</div>]]>
   </description>
   <pubDate>Tue, 26 Mar 2013 09:41:59 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27770&amp;PID=409669&amp;title=307#409669</guid>
  </item>
  <item>
   <title><![CDATA[307 :   elsoberano Yazd&#305;:ayn&#305; ara&#231;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27770&amp;PID=409591&amp;title=307#409591</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8684">reality59</a><br /><strong>Konu:</strong> 27770<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Mart&nbsp;2013 Saat 22:44<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: elsoberano" alt="Orjinalini yazan: elsoberano" style="vertical-align: text-bottom;" /> <strong>elsoberano Yazdı:</strong><br /><br />aynı araç bende var arızası hatası tamamen nasıl kullanıldığına bağlı. sinyal kolunu kontrol et zamanla &nbsp;sola kendi kendine sinyal veriyor tüm 307lerde kronik diye biliyorum .yan aynaları kontrol et araç çalışıp stop ettiğinde kapanıp açılması lazım . ağrıza ışıklarına bak yanan bir ışık var mı .genel anlamda ben tavsiye ederim 1 yılı geçti ben alalı şimdilik bir şikayetim yok .</td></tr></table><br><br>aynaların kapanması olayı ayna motoru ile de alakalı değil mi ? sadece yazılım güncellemesi yapsak yetersiz kalır ?<br>]]>
   </description>
   <pubDate>Mon, 25 Mar 2013 22:44:55 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27770&amp;PID=409591&amp;title=307#409591</guid>
  </item>
  <item>
   <title><![CDATA[307 : vergiden yana s&#305;k&#305;nt&#305;n yoksa al...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27770&amp;PID=409537&amp;title=307#409537</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9810">impact</a><br /><strong>Konu:</strong> 27770<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Mart&nbsp;2013 Saat 20:20<br /><br /><b>vergiden yana sıkıntın yoksa al derim.. sinyal kolu süngerle çözülüyor diğer mevzulara bak ama</b>]]>
   </description>
   <pubDate>Mon, 25 Mar 2013 20:20:27 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27770&amp;PID=409537&amp;title=307#409537</guid>
  </item>
  <item>
   <title><![CDATA[307 : ayn&#305; ara&#231; bende var ar&#305;zas&#305; hatas&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27770&amp;PID=409450&amp;title=307#409450</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8556">elsoberano</a><br /><strong>Konu:</strong> 27770<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Mart&nbsp;2013 Saat 13:53<br /><br />aynı araç bende var arızası hatası tamamen nasıl kullanıldığına bağlı. sinyal kolunu kontrol et zamanla &nbsp;sola kendi kendine sinyal veriyor tüm 307lerde kronik diye biliyorum .yan aynaları kontrol et araç çalışıp stop ettiğinde kapanıp açılması lazım . ağrıza ışıklarına bak yanan bir ışık var mı .genel anlamda ben tavsiye ederim 1 yılı geçti ben alalı şimdilik bir şikayetim yok .]]>
   </description>
   <pubDate>Mon, 25 Mar 2013 13:53:42 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27770&amp;PID=409450&amp;title=307#409450</guid>
  </item>
  <item>
   <title><![CDATA[307 : s.a arkada&#351;lar 307 2.0xs&#305; almay&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27770&amp;PID=409414&amp;title=307#409414</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11435">307 20xsı</a><br /><strong>Konu:</strong> 27770<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Mart&nbsp;2013 Saat 11:40<br /><br />s.a arkadaşlar 307 2.0xsı almayı düşünüyorum herhangı bi hata sorun arıza falan verir mi daha önce kullanan arkadaşlar varsa bilgilendirirse sevinirim&nbsp;]]>
   </description>
   <pubDate>Mon, 25 Mar 2013 11:40:38 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27770&amp;PID=409414&amp;title=307#409414</guid>
  </item>
 </channel>
</rss>
