 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 206 lpg</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 206 : 206 lpg]]></description>
  <pubDate>Mon, 04 May 2026 07:51:33 +0000</pubDate>
  <lastBuildDate>Tue, 04 Jun 2013 12:30:32 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=27601</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[206 lpg : Zarar vermeden gidin bir LPG uzman&#305;na...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=425982&amp;title=206-lpg#425982</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11281">ahmed206</a><br /><strong>Konu:</strong> 27601<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Haziran&nbsp;2013 Saat 12:30<br /><br />Zarar vermeden gidin bir LPG uzmanına gösterin derim..]]>
   </description>
   <pubDate>Tue, 04 Jun 2013 12:30:32 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=425982&amp;title=206-lpg#425982</guid>
  </item>
  <item>
   <title><![CDATA[206 lpg : asl&#305;nda devrili kullanm&#305;yorumm...devirli...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=425888&amp;title=206-lpg#425888</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10719">pierson</a><br /><strong>Konu:</strong> 27601<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Haziran&nbsp;2013 Saat 00:07<br /><br />aslında devrili kullanmıyorumm...devirli kullanmayı bile bilmem doğrusu..]]>
   </description>
   <pubDate>Tue, 04 Jun 2013 00:07:28 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=425888&amp;title=206-lpg#425888</guid>
  </item>
  <item>
   <title><![CDATA[206 lpg : Arac&#305; fazla devirli kullan&#305;yosan,lpg...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=425879&amp;title=206-lpg#425879</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10418">Mesut48</a><br /><strong>Konu:</strong> 27601<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Haziran&nbsp;2013 Saat 23:49<br /><br />Aracı fazla devirli kullanıyosan,lpg gücü yetmediğinde benzine geçer.Perfoormansı düşmemesi açısından.Sanırım dediğiniz bu gibi birşey.]]>
   </description>
   <pubDate>Mon, 03 Jun 2013 23:49:29 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=425879&amp;title=206-lpg#425879</guid>
  </item>
  <item>
   <title><![CDATA[206 lpg : selam arkad&#351;lar ...arac&#305; &#231;al&#305;&#351;t&#305;r&#305;yorum...s&#305;cak...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=425858&amp;title=206-lpg#425858</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10719">pierson</a><br /><strong>Konu:</strong> 27601<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Haziran&nbsp;2013 Saat 21:56<br /><br />selam arkadşlar ...aracı çalıştırıyorum...sıcak havalarda hemen lpg ye geçiyor..tık sesini duyuyorum..ama şu var..tık sesini bazen seyir giderken de duyuyorum ve göstregeye bakıyorum yeşil ışık yanıp sönüyor..sonra tekrar yeşil sürekli yanıyor..ses arkadan geliyor...lpg ye geçiş sesi..yani araç lpg den çıkıp lpg ye geçiyor.. sorun ne olabilir...]]>
   </description>
   <pubDate>Mon, 03 Jun 2013 21:56:28 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=425858&amp;title=206-lpg#425858</guid>
  </item>
  <item>
   <title><![CDATA[206 lpg : BRC ile Atiker&amp;#039;i k&#305;yaslayabilecek...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=415817&amp;title=206-lpg#415817</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11281">ahmed206</a><br /><strong>Konu:</strong> 27601<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Nisan&nbsp;2013 Saat 20:20<br /><br />BRC ile Atiker'i kıyaslayabilecek birisi var mı?]]>
   </description>
   <pubDate>Sun, 21 Apr 2013 20:20:05 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=415817&amp;title=206-lpg#415817</guid>
  </item>
  <item>
   <title><![CDATA[206 lpg : hocam atikerden &#351;a&#351;ma...f&#305;st&#305;k...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=415808&amp;title=206-lpg#415808</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10719">pierson</a><br /><strong>Konu:</strong> 27601<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Nisan&nbsp;2013 Saat 19:40<br /><br />hocam atikerden şaşma...fıstık gibi marka...çekişten falan düşmede ytok...ben de otomatik&nbsp; var..atikeer sıralı sistem lpg var...çok az yakıyor..sorun da çıkarmıyor...az önceki arakadaşın dediği gibi bakımı geldiğinde sinir bozucu bir sesi var o kadar...<br>]]>
   </description>
   <pubDate>Sun, 21 Apr 2013 19:40:29 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=415808&amp;title=206-lpg#415808</guid>
  </item>
  <item>
   <title><![CDATA[206 lpg : Atiker kullan&#305;yorum, a&#351;&#305;r&#305; derecede...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=415802&amp;title=206-lpg#415802</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7856">ufuk91</a><br /><strong>Konu:</strong> 27601<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Nisan&nbsp;2013 Saat 17:54<br /><br />Atiker kullanıyorum, aşırı derecede memnunum diyemem ama çok sorunu da olmadı, stop etme falan asla yok zaten, 5. vites ile ilgili bahsettiğiniz sorun da yok. LPG elbet biraz çekişten düşürüyor ama çok farkedilecek düzeyde değil.<br><br>Benim sinirimi bozan tek şey, bakımı vs geldiğinde kontak kapattığında dit dit diiiit diye 3 defa ötüyor deli oluyorm her arabayı durdurup stop ettiğimde bağırıyor heralde kullanıcıyı deli etsin de gelsin hemen bakıma girsin diye yapmışlar.<br><br>Peki ben ne yaptım, açtım hoparlörün olduğu yeri(minicik bişey) ucuna sakız tıkadım&nbsp;<img src="https://forum.peugeotturkey.com/smileys/smiley36.gif" border="0" alt="LOL" title="LOL" /><img src="https://forum.peugeotturkey.com/smileys/smiley36.gif" border="0" alt="LOL" title="LOL" /><img src="https://forum.peugeotturkey.com/smileys/smiley36.gif" border="0" alt="LOL" title="LOL" />]]>
   </description>
   <pubDate>Sun, 21 Apr 2013 17:54:01 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=415802&amp;title=206-lpg#415802</guid>
  </item>
  <item>
   <title><![CDATA[206 lpg : Arac&#305;m&#305; 20bin km dir Atiker ile...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=415770&amp;title=206-lpg#415770</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11619">BGR_LLC</a><br /><strong>Konu:</strong> 27601<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Nisan&nbsp;2013 Saat 13:41<br /><br />Aracımı 20bin km dir Atiker ile kullanıyorum. Herhangi bir problem yaşamadım.<br>Bütçeniz Atiker sistem ve ruhsat işlemleri için yeterli olacaktır.<br>]]>
   </description>
   <pubDate>Sun, 21 Apr 2013 13:41:11 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=415770&amp;title=206-lpg#415770</guid>
  </item>
  <item>
   <title><![CDATA[206 lpg : b&#252;t&#231;e 1000-1200 tl civar&#305; hocam...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=407951&amp;title=206-lpg#407951</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10798">Engin ASLAN</a><br /><strong>Konu:</strong> 27601<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Mart&nbsp;2013 Saat 18:58<br /><br />bütçe 1000-1200 tl civarı hocam&nbsp;]]>
   </description>
   <pubDate>Sun, 17 Mar 2013 18:58:52 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=407951&amp;title=206-lpg#407951</guid>
  </item>
  <item>
   <title><![CDATA[206 lpg : b&#252;t&#231;enizi belirtirseniz ona g&#246;re...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=407901&amp;title=206-lpg#407901</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8556">elsoberano</a><br /><strong>Konu:</strong> 27601<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Mart&nbsp;2013 Saat 12:50<br /><br />bütçenizi belirtirseniz ona göre tavsiye edilebilir prince,kıt mtm gibi kıtler var enjektör olarak kheın kullanır kaliteli kıtler ama fiyatları yüksektir birde prins sılver lıne &nbsp;yaptı 1900 tl civarı . lpg kıtı kadar montaj yapan yerde çok önemli .]]>
   </description>
   <pubDate>Sun, 17 Mar 2013 12:50:22 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=407901&amp;title=206-lpg#407901</guid>
  </item>
  <item>
   <title><![CDATA[206 lpg : eyvallah hocam sa&#287;olas&#305;n ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=407837&amp;title=206-lpg#407837</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10798">Engin ASLAN</a><br /><strong>Konu:</strong> 27601<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Mart&nbsp;2013 Saat 00:50<br /><br />eyvallah hocam sağolasın]]>
   </description>
   <pubDate>Sun, 17 Mar 2013 00:50:39 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=407837&amp;title=206-lpg#407837</guid>
  </item>
  <item>
   <title><![CDATA[206 lpg : duymad&#305;m hi&#231; ama ben atikerden...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=407836&amp;title=206-lpg#407836</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10142">_PunisheR_</a><br /><strong>Konu:</strong> 27601<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Mart&nbsp;2013 Saat 00:44<br /><br />duymadım hiç ama ben atikerden memnunum hiç bi sorun olmadı]]>
   </description>
   <pubDate>Sun, 17 Mar 2013 00:44:39 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=407836&amp;title=206-lpg#407836</guid>
  </item>
  <item>
   <title><![CDATA[206 lpg :   _PunisheR_ Yazd&#305;:  enas Yazd&#305;:dur...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=407830&amp;title=206-lpg#407830</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10798">Engin ASLAN</a><br /><strong>Konu:</strong> 27601<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Mart&nbsp;2013 Saat 00:21<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: _PunisheR_" alt="Orjinalini yazan: _PunisheR_" style="vertical-align: text-bottom;" /> <strong>_PunisheR_ Yazdı:</strong><br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: enas" alt="Orjinalini yazan: enas" style="vertical-align: text-bottom;" /> <strong>enas Yazdı:</strong><br /><br />dur kalklarda rölanti hızla düşüp stop ediyormu araçlarınız ya da 5 viteste giderken gaz pedalı ayağınıza vuruyormu&nbsp;</td></tr></table>dediğiniz olayların hiç biri aracımda olmuyor.</td></tr></table><div>benim arabamda aldesa vardı dayanamadım söktürdüm en sonunda</div>]]>
   </description>
   <pubDate>Sun, 17 Mar 2013 00:21:32 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=407830&amp;title=206-lpg#407830</guid>
  </item>
  <item>
   <title><![CDATA[206 lpg :   enas Yazd&#305;:dur kalklarda r&#246;lanti...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=407815&amp;title=206-lpg#407815</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10142">_PunisheR_</a><br /><strong>Konu:</strong> 27601<br /><strong>Gönderim Zamanı:</strong> 16&nbsp;Mart&nbsp;2013 Saat 23:54<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: enas" alt="Orjinalini yazan: enas" style="vertical-align: text-bottom;" /> <strong>enas Yazdı:</strong><br /><br />dur kalklarda rölanti hızla düşüp stop ediyormu araçlarınız ya da 5 viteste giderken gaz pedalı ayağınıza vuruyormu&nbsp;</td></tr></table>dediğiniz olayların hiç biri aracımda olmuyor.]]>
   </description>
   <pubDate>Sat, 16 Mar 2013 23:54:55 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=407815&amp;title=206-lpg#407815</guid>
  </item>
  <item>
   <title><![CDATA[206 lpg : &#351;u konunun uzman&#305; arkada&#351;lar baksada...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=407807&amp;title=206-lpg#407807</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10798">Engin ASLAN</a><br /><strong>Konu:</strong> 27601<br /><strong>Gönderim Zamanı:</strong> 16&nbsp;Mart&nbsp;2013 Saat 23:10<br /><br />şu konunun uzmanı arkadaşlar baksada bize öneride bulunsa]]>
   </description>
   <pubDate>Sat, 16 Mar 2013 23:10:41 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=27601&amp;PID=407807&amp;title=206-lpg#407807</guid>
  </item>
 </channel>
</rss>
