 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : ? lpg ?</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 307 : ? lpg ?]]></description>
  <pubDate>Sun, 03 May 2026 22:36:49 +0000</pubDate>
  <lastBuildDate>Sat, 04 Jan 2014 00:13:42 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=26827</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[? lpg ? : Pogaz yada shell :) ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=471084&amp;title=lpg#471084</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10418">Mesut48</a><br /><strong>Konu:</strong> 26827<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Ocak&nbsp;2014 Saat 00:13<br /><br />Pogaz yada shell :)]]>
   </description>
   <pubDate>Sat, 04 Jan 2014 00:13:42 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=471084&amp;title=lpg#471084</guid>
  </item>
  <item>
   <title><![CDATA[? lpg ? : milangaz yada aygaz bi s&#305;k&#305;nt&#305;s&#305;n&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=471052&amp;title=lpg#471052</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11593">kuscu38</a><br /><strong>Konu:</strong> 26827<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Ocak&nbsp;2014 Saat 20:51<br /><br />milangaz yada aygaz bi sıkıntısını görmedim ikiside aynı benim için]]>
   </description>
   <pubDate>Fri, 03 Jan 2014 20:51:43 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=471052&amp;title=lpg#471052</guid>
  </item>
  <item>
   <title><![CDATA[? lpg ? : eger araca bi zarar&#305; yoksa milangaza...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=471025&amp;title=lpg#471025</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13175">rizeli_53</a><br /><strong>Konu:</strong> 26827<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Ocak&nbsp;2014 Saat 17:14<br /><br />eger araca bi zararı yoksa milangaza devam]]>
   </description>
   <pubDate>Fri, 03 Jan 2014 17:14:49 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=471025&amp;title=lpg#471025</guid>
  </item>
  <item>
   <title><![CDATA[? lpg ? : bu konuya net olarak cevap veremezsiniz....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=471018&amp;title=lpg#471018</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=13085">akantek</a><br /><strong>Konu:</strong> 26827<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Ocak&nbsp;2014 Saat 16:51<br /><br />bu konuya net olarak cevap veremezsiniz. bende bulunduğum yerde 3 farklı shell istasyonu var ve 2 ila 3 er kez denedim hepsinin kalitesi farklı. bu benzin istasyonunun yakıta farklı bişey karıştırıp karıştırmadığı, pompanın durumu vs. gibi etmenlerde değişiklik gösterir. shell de 1. istasyonda aldığım her gazda 250 km 2. istasyonda 230-240 km 3. istasyonda 200 km yol yaptım. her istasyonu bir kaç kez denedim.&nbsp;<div><br></div><div>sonra ipragaz aldım bu 270 km ye çıktı. milangazda 300 km yol yaptım totalden aldım 260 km yaptım ama aracın performansı biraz arttı. &nbsp;</div><div><br></div><div>bence yakınlarınızda ki istasyonları deneyerek bunu bulun daha güvenilir olur<br><div><br></div><div><br></div></div>]]>
   </description>
   <pubDate>Fri, 03 Jan 2014 16:51:33 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=471018&amp;title=lpg#471018</guid>
  </item>
  <item>
   <title><![CDATA[? lpg ? : hepsi iyidir ama dikkat etmen...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=465145&amp;title=lpg#465145</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10829">furkanyakar</a><br /><strong>Konu:</strong> 26827<br /><strong>Gönderim Zamanı:</strong> 02&nbsp;Aralık&nbsp;2013 Saat 15:04<br /><br />hepsi iyidir ama dikkat etmen gereken şu, farklı farklı gazları aracın deposunda karıştırma, en kötüsünü de alsan hep aynı gazı al. o zaman daha stabil çalışır aracın]]>
   </description>
   <pubDate>Mon, 02 Dec 2013 15:04:33 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=465145&amp;title=lpg#465145</guid>
  </item>
  <item>
   <title><![CDATA[? lpg ? : Opet ve shell ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=465136&amp;title=lpg#465136</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6920">Bavik</a><br /><strong>Konu:</strong> 26827<br /><strong>Gönderim Zamanı:</strong> 02&nbsp;Aralık&nbsp;2013 Saat 14:39<br /><br />Opet ve shell]]>
   </description>
   <pubDate>Mon, 02 Dec 2013 14:39:46 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=465136&amp;title=lpg#465136</guid>
  </item>
  <item>
   <title><![CDATA[? lpg ? : BP veya Opetten al&#305;yorum... ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=465114&amp;title=lpg#465114</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=12268">gogly35</a><br /><strong>Konu:</strong> 26827<br /><strong>Gönderim Zamanı:</strong> 02&nbsp;Aralık&nbsp;2013 Saat 12:02<br /><br />BP veya Opetten alıyorum...]]>
   </description>
   <pubDate>Mon, 02 Dec 2013 12:02:48 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=465114&amp;title=lpg#465114</guid>
  </item>
  <item>
   <title><![CDATA[? lpg ? : opet almada nerden al&#305;rsan al...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=465098&amp;title=lpg#465098</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8493">C@GL@R</a><br /><strong>Konu:</strong> 26827<br /><strong>Gönderim Zamanı:</strong> 02&nbsp;Aralık&nbsp;2013 Saat 11:11<br /><br />opet almada nerden alırsan al :D<br>]]>
   </description>
   <pubDate>Mon, 02 Dec 2013 11:11:54 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=465098&amp;title=lpg#465098</guid>
  </item>
  <item>
   <title><![CDATA[? lpg ? : BP &amp;#039;den gaz al&#305;yorum ba&#351;ka...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=465096&amp;title=lpg#465096</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=12580">ozncnercn</a><br /><strong>Konu:</strong> 26827<br /><strong>Gönderim Zamanı:</strong> 02&nbsp;Aralık&nbsp;2013 Saat 11:06<br /><br />BP 'den gaz alıyorum başka yerden aldığım zaman aracımın motor ışığı yanıyor emisyon hatası veriyor çokta memnunum açıkçası]]>
   </description>
   <pubDate>Mon, 02 Dec 2013 11:06:58 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=465096&amp;title=lpg#465096</guid>
  </item>
  <item>
   <title><![CDATA[? lpg ? :   hsnsnl Yazd&#305;: total total..hasan...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=465095&amp;title=lpg#465095</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9810">impact</a><br /><strong>Konu:</strong> 26827<br /><strong>Gönderim Zamanı:</strong> 02&nbsp;Aralık&nbsp;2013 Saat 11:06<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: hsnsnl" alt="Orjinalini yazan: hsnsnl" style="vertical-align: text-bottom;" /> <strong>hsnsnl Yazdı:</strong><br /><br />total</td></tr></table><div><b>total..</b></div><div><b>hasan gecen hafta totalden murat abiyle tanıştık saxo su var senin arkadaşınmış sanırım arabayı görünce geldi muhabbetledik biraz.. bi ara görüşelim..</b></div>]]>
   </description>
   <pubDate>Mon, 02 Dec 2013 11:06:45 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=465095&amp;title=lpg#465095</guid>
  </item>
  <item>
   <title><![CDATA[? lpg ? : Gazlar da performans ve menzil...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=465091&amp;title=lpg#465091</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=12515">kursat3006</a><br /><strong>Konu:</strong> 26827<br /><strong>Gönderim Zamanı:</strong> 02&nbsp;Aralık&nbsp;2013 Saat 11:02<br /><br />Gazlar da performans ve menzil gazlarin kalinligina baglidir. Piyasadaki en ince gaz opetindir ( yani performans acisindan en iyisi menzil bakımından en dusugu ). Sonra shell in gazı gelir. Bu n son PO . PO gazı en kalinidir performans acisindan opet ve shell kadar iyi olmasa da menzil acisindan en iyisidir yani bi depoda en fazla PO gaz ile gidersiniz . Milangazi zorda kalmadikca tercih etmeyin derim .]]>
   </description>
   <pubDate>Mon, 02 Dec 2013 11:02:25 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=465091&amp;title=lpg#465091</guid>
  </item>
  <item>
   <title><![CDATA[? lpg ? : Hep Aygaz al&#305;yorum, mecbur kal&#305;nca...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=465085&amp;title=lpg#465085</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10539">_ali_</a><br /><strong>Konu:</strong> 26827<br /><strong>Gönderim Zamanı:</strong> 02&nbsp;Aralık&nbsp;2013 Saat 10:42<br /><br />Hep Aygaz alıyorum, mecbur kalınca Shell'den aldım 10km sonra stop ettim ertesi gün sabah araç zor çalıştı hem benzinde hem lpg'de çekiş çok düştü motor 3 silindir gibi çalışmaya başladı, 20-30 km kadar yolda kaldı kalacak korkusuyla pedalı kökleye kökleye kullandım, sonra ustaya telefon ettim, benzine al biraz kullan geçer düzelmezse gel dedi.<br><br>O gün biraz daha benzinde kullandım, ertesi gün saat gibi çalıştı ve bir daha yapmadı. <br><br>(Aspendos Bulvarı Latanya City Otel yanındaki Shell istasyonu)<br>]]>
   </description>
   <pubDate>Mon, 02 Dec 2013 10:42:46 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=465085&amp;title=lpg#465085</guid>
  </item>
  <item>
   <title><![CDATA[? lpg ? : Ben hep opet ten al&#305;yorum, siz...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=410868&amp;title=lpg#410868</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11466">Bünyamin.Kar</a><br /><strong>Konu:</strong> 26827<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Mart&nbsp;2013 Saat 22:32<br /><br />Ben hep opet ten alıyorum, siz siz olun ucuz gaz almayın, biraderim yola gitmişti dönüşte ucuz diye bi istasyondan gaz almış döndüğünde araç lpg ye geçtiğinde hafiften titreme yapıyordu benzine aldığımda titreme geçiyordu buji kabloları felan komple kontrol ettik bişey bulamadık tüptendir dedik 1 kaç gün böyle devam etti tüpü bitirdik her zamanki yerden tüp aldık sorun yine devam ediyor sonra &nbsp;sanayinin yolunu tuttuk ustamız baktı etti en son üst kapağı açtı sübaplar aldığımız ucuz olan kötü gazdan dolayı yanmış bana maliyeti bi kaç ufak tefek keçe değişimi de vardı toplamda 700 tl ye maal oldu, 30-40 kuruş un hesabını yapmayın]]>
   </description>
   <pubDate>Fri, 29 Mar 2013 22:32:53 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=410868&amp;title=lpg#410868</guid>
  </item>
  <item>
   <title><![CDATA[? lpg ? : Milangaz dan al&#305;yorum... &#214;nceki...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=398771&amp;title=lpg#398771</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10793">Semih ÇAVDAR</a><br /><strong>Konu:</strong> 26827<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Ocak&nbsp;2013 Saat 14:57<br /><br />Milangaz dan alıyorum... Önceki aracımda da oradan alıyordum... Komşum Milangaz da çalışıyordu tavsiye etti gittim aldım... Hep oradan alırım... Hem ucuz hem de hiç sıkıntısını görmedim...]]>
   </description>
   <pubDate>Thu, 24 Jan 2013 14:57:59 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=398771&amp;title=lpg#398771</guid>
  </item>
  <item>
   <title><![CDATA[? lpg ? : lt fiyat&#305; 2.24 mi :D aboww biz...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=398770&amp;title=lpg#398770</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10072">EnSoNiQ</a><br /><strong>Konu:</strong> 26827<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Ocak&nbsp;2013 Saat 14:54<br /><br />lt fiyatı 2.24 mi :D aboww biz burda 2.81 den alıyoz. Milangaz ve shell kullanıyorum ikisindede sıkıntı çekmedim]]>
   </description>
   <pubDate>Thu, 24 Jan 2013 14:54:56 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26827&amp;PID=398770&amp;title=lpg#398770</guid>
  </item>
 </channel>
</rss>
