 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : far motoru</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 206 : far motoru]]></description>
  <pubDate>Sat, 02 May 2026 13:26:08 +0000</pubDate>
  <lastBuildDate>Sat, 05 Jan 2013 23:17:55 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=26409</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[far motoru :   feline Yazd&#305;:2 tane orjinal...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=394729&amp;title=far-motoru#394729</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9972">peugeotttt</a><br /><strong>Konu:</strong> 26409<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Ocak&nbsp;2013 Saat 23:17<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: feline" alt="Orjinalini yazan: feline" style="vertical-align: text-bottom;" /> <strong>feline Yazdı:</strong><br /><br />2 tane orjinal var satabilirim<div><br></div></td></tr></table><div>&nbsp;</div><div>&nbsp;</div><div>muayeneden sonra almayı dusunuyorum ustam.</div>]]>
   </description>
   <pubDate>Sat, 05 Jan 2013 23:17:55 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=394729&amp;title=far-motoru#394729</guid>
  </item>
  <item>
   <title><![CDATA[far motoru : 2 tane orjinal var satabilirim...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=394481&amp;title=far-motoru#394481</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7614">feline</a><br /><strong>Konu:</strong> 26409<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Ocak&nbsp;2013 Saat 01:04<br /><br />2 tane orjinal var satabilirim<div><br></div>]]>
   </description>
   <pubDate>Sat, 05 Jan 2013 01:04:47 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=394481&amp;title=far-motoru#394481</guid>
  </item>
  <item>
   <title><![CDATA[far motoru :    ozaannn Yazd&#305;:Far motoru...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=394462&amp;title=far-motoru#394462</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9972">peugeotttt</a><br /><strong>Konu:</strong> 26409<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Ocak&nbsp;2013 Saat 23:44<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: ozaannn" alt="Orjinalini yazan: ozaannn" style="vertical-align: text-bottom;" /> <strong>ozaannn Yazdı:</strong><br /><br />Far motoru lazimda irtibata gecebilirsiniz elimde iki adet orjinal vardir</td></tr></table><div>&nbsp;</div><div>&nbsp;</div><div>hocam irtibarta gecebiirim ama aracı muayeneye sokucam ondan sonra.</div>]]>
   </description>
   <pubDate>Fri, 04 Jan 2013 23:44:10 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=394462&amp;title=far-motoru#394462</guid>
  </item>
  <item>
   <title><![CDATA[far motoru : Far motoru lazimda irtibata gecebilirsiniz...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=394051&amp;title=far-motoru#394051</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2136">ozaannn</a><br /><strong>Konu:</strong> 26409<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Ocak&nbsp;2013 Saat 23:33<br /><br />Far motoru lazimda irtibata gecebilirsiniz elimde iki adet orjinal vardir]]>
   </description>
   <pubDate>Thu, 03 Jan 2013 23:33:31 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=394051&amp;title=far-motoru#394051</guid>
  </item>
  <item>
   <title><![CDATA[far motoru : Olabilir hocam, orjinal far motoru...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=394046&amp;title=far-motoru#394046</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9585">Serkan</a><br /><strong>Konu:</strong> 26409<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Ocak&nbsp;2013 Saat 23:30<br /><br />Olabilir hocam, orjinal far motoru yan sanayi farla aynı fiyat nerdeyse]]>
   </description>
   <pubDate>Thu, 03 Jan 2013 23:30:00 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=394046&amp;title=far-motoru#394046</guid>
  </item>
  <item>
   <title><![CDATA[far motoru :   bilmiyorum arac&#305; ald&#305;g&#305;mda...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=394037&amp;title=far-motoru#394037</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9972">peugeotttt</a><br /><strong>Konu:</strong> 26409<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Ocak&nbsp;2013 Saat 23:18<br /><br />bilmiyorum aracı aldıgımda farlar üzerindeydi benden önceki sahbi değiştirmiş olabilir.]]>
   </description>
   <pubDate>Thu, 03 Jan 2013 23:18:09 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=394037&amp;title=far-motoru#394037</guid>
  </item>
  <item>
   <title><![CDATA[far motoru : O zaman far motoru yoktur, farlar&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=394033&amp;title=far-motoru#394033</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9585">Serkan</a><br /><strong>Konu:</strong> 26409<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Ocak&nbsp;2013 Saat 23:14<br /><br />O zaman far motoru yoktur, farları değiştirdiyseniz ayrı satılır far motorları, far üzerinde gelmez.]]>
   </description>
   <pubDate>Thu, 03 Jan 2013 23:14:00 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=394033&amp;title=far-motoru#394033</guid>
  </item>
  <item>
   <title><![CDATA[far motoru :   far ayar d&#252;gmesi var ama ayar...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=394019&amp;title=far-motoru#394019</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9972">peugeotttt</a><br /><strong>Konu:</strong> 26409<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Ocak&nbsp;2013 Saat 23:06<br /><br />far ayar dügmesi var ama ayar yapılmıyor.]]>
   </description>
   <pubDate>Thu, 03 Jan 2013 23:06:54 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=394019&amp;title=far-motoru#394019</guid>
  </item>
  <item>
   <title><![CDATA[far motoru : Far ayar d&#252;&#287;mesi varm&#305;, varsa...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=393973&amp;title=far-motoru#393973</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9585">Serkan</a><br /><strong>Konu:</strong> 26409<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Ocak&nbsp;2013 Saat 21:59<br /><br />Far ayar düğmesi varmı, varsa çalışıyormu?]]>
   </description>
   <pubDate>Thu, 03 Jan 2013 21:59:09 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=393973&amp;title=far-motoru#393973</guid>
  </item>
  <item>
   <title><![CDATA[far motoru :    Serco05 Yazd&#305;:Far motoru...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=393971&amp;title=far-motoru#393971</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9972">peugeotttt</a><br /><strong>Konu:</strong> 26409<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Ocak&nbsp;2013 Saat 21:57<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Serco05" alt="Orjinalini yazan: Serco05" style="vertical-align: text-bottom;" /> <strong>Serco05 Yazdı:</strong><br /><br />Far motoru ne oldu hocam bulabildinizmi?</td></tr></table><div>&nbsp;</div><div>&nbsp;</div><div>yok ustam ya bende oyle bişey.</div>]]>
   </description>
   <pubDate>Thu, 03 Jan 2013 21:57:55 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=393971&amp;title=far-motoru#393971</guid>
  </item>
  <item>
   <title><![CDATA[far motoru : Far motoru ne oldu hocam bulabildinizmi?  ...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=393965&amp;title=far-motoru#393965</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9585">Serkan</a><br /><strong>Konu:</strong> 26409<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Ocak&nbsp;2013 Saat 21:54<br /><br />Far motoru ne oldu hocam bulabildinizmi?]]>
   </description>
   <pubDate>Thu, 03 Jan 2013 21:54:19 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=393965&amp;title=far-motoru#393965</guid>
  </item>
  <item>
   <title><![CDATA[far motoru :   anas&#305;n&#305; satay&#305;m sa&#287; sis far&#305;m...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=393964&amp;title=far-motoru#393964</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9972">peugeotttt</a><br /><strong>Konu:</strong> 26409<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Ocak&nbsp;2013 Saat 21:52<br /><br />anasını satayım sağ sis farım kesikti gecen hafta onu yaptrıdım bu aksamda sol taraftaki sis kesti.bir turlu ikisini birden kullanamıycam :))]]>
   </description>
   <pubDate>Thu, 03 Jan 2013 21:52:54 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=393964&amp;title=far-motoru#393964</guid>
  </item>
  <item>
   <title><![CDATA[far motoru :    Serco05 Yazd&#305;:Resimdeki karenin...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=393962&amp;title=far-motoru#393962</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9972">peugeotttt</a><br /><strong>Konu:</strong> 26409<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Ocak&nbsp;2013 Saat 21:51<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Serco05" alt="Orjinalini yazan: Serco05" style="vertical-align: text-bottom;" /> <strong>Serco05 Yazdı:</strong><br /><br />Resimdeki karenin sırt kısmında<br><br><a href="http://bit.ly/c25MCx" target="_blank" rel="nofollow"><img src="http://a1301.hizliresim.com/15/2/hlf3x.jpg" border="0" /></a><br></td></tr></table><div>&nbsp;</div><div>&nbsp;</div><div>hocam senin işaret koydugun yerde benim mavi park ampulleri yanıyor.</div>]]>
   </description>
   <pubDate>Thu, 03 Jan 2013 21:51:38 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=393962&amp;title=far-motoru#393962</guid>
  </item>
  <item>
   <title><![CDATA[far motoru :    ufuk91 Yazd&#305;:hocam arac&#305;n&#305;zda...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=393959&amp;title=far-motoru#393959</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9972">peugeotttt</a><br /><strong>Konu:</strong> 26409<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Ocak&nbsp;2013 Saat 21:50<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: ufuk91" alt="Orjinalini yazan: ufuk91" style="vertical-align: text-bottom;" /> <strong>ufuk91 Yazdı:</strong><br /><br />hocam aracınızda far ayarı yapılabiliyorsa ki yapılabiliyor olması lazım, far motoru nasıl olmaz :))</td></tr></table><div>&nbsp;</div><div>&nbsp;</div><div>ustam aracta far ayarı var ama yapılmıyor.o yuzden soruyorum bende nerde die :)) bakıcam arızalımı değilmi yoksa hiç mi yok diye.ama ben hiç öyle bişey görmedim farlarda sanırım yok.</div>]]>
   </description>
   <pubDate>Thu, 03 Jan 2013 21:50:27 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=393959&amp;title=far-motoru#393959</guid>
  </item>
  <item>
   <title><![CDATA[far motoru :    Serco05 Yazd&#305;:Orjinali 80-100...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=393934&amp;title=far-motoru#393934</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=10652">fxmen</a><br /><strong>Konu:</strong> 26409<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Ocak&nbsp;2013 Saat 21:23<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Serco05" alt="Orjinalini yazan: Serco05" style="vertical-align: text-bottom;" /> <strong>Serco05 Yazdı:</strong><br /><br />Orjinali 80-100 TL arasında, yan sanayisi 50-60 TL arasında</td></tr></table><br>tesekkur ederım <br>]]>
   </description>
   <pubDate>Thu, 03 Jan 2013 21:23:52 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=26409&amp;PID=393934&amp;title=far-motoru#393934</guid>
  </item>
 </channel>
</rss>
