 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Viteste oluşan Vibrasyon</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Arac&#305;n&#305;z Hakk&#305;ndaki T&#252;m Sorular : Viteste oluşan Vibrasyon]]></description>
  <pubDate>Sun, 03 May 2026 23:52:33 +0000</pubDate>
  <lastBuildDate>Sun, 18 Nov 2012 11:53:36 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=25460</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Viteste oluşan Vibrasyon :    inceyasar Yazd&#305;:Nerede yaptirdin...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=25460&amp;PID=385378&amp;title=viteste-olusan-vibrasyon#385378</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6612">yiğit4516</a><br /><strong>Konu:</strong> 25460<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Kasım&nbsp;2012 Saat 11:53<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: inceyasar" alt="Orjinalini yazan: inceyasar" style="vertical-align: text-bottom;" /> <strong>inceyasar Yazdı:</strong><br /><br />Nerede yaptirdin kardes</td></tr></table><div><br></div><div>Bursa'da küçük sanayide Tornacı İlhan'a</div>]]>
   </description>
   <pubDate>Sun, 18 Nov 2012 11:53:36 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=25460&amp;PID=385378&amp;title=viteste-olusan-vibrasyon#385378</guid>
  </item>
  <item>
   <title><![CDATA[Viteste oluşan Vibrasyon : Nerede yaptirdin kardes ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=25460&amp;PID=385353&amp;title=viteste-olusan-vibrasyon#385353</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=5121">inceyasar</a><br /><strong>Konu:</strong> 25460<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Kasım&nbsp;2012 Saat 23:45<br /><br />Nerede yaptirdin kardes]]>
   </description>
   <pubDate>Sat, 17 Nov 2012 23:45:59 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=25460&amp;PID=385353&amp;title=viteste-olusan-vibrasyon#385353</guid>
  </item>
  <item>
   <title><![CDATA[Viteste oluşan Vibrasyon :   10 numara yapm&#305;s&#305;n yan sanay&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=25460&amp;PID=385305&amp;title=viteste-olusan-vibrasyon#385305</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8322">hsnsnl</a><br /><strong>Konu:</strong> 25460<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Kasım&nbsp;2012 Saat 18:54<br /><br />10 numara yapmısın yan sanayı parca almıyarak, bolede sorun cıkcagını zannetmıyorum]]>
   </description>
   <pubDate>Sat, 17 Nov 2012 18:54:57 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=25460&amp;PID=385305&amp;title=viteste-olusan-vibrasyon#385305</guid>
  </item>
  <item>
   <title><![CDATA[Viteste oluşan Vibrasyon : Bug&#252;n aks tamiri yapan birisine...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=25460&amp;PID=385301&amp;title=viteste-olusan-vibrasyon#385301</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6612">yiğit4516</a><br /><strong>Konu:</strong> 25460<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Kasım&nbsp;2012 Saat 18:24<br /><br />Bugün aks tamiri yapan birisine gittim. Arabayı kaldırdı ve sağı ve solu kontrol etti, sağ taraf biraz fazla oynama yapıyor. Sol tarafta birşey yok dedi. Söktük ve içini açtı yağ kalmamış, ve istavrozun gezdiği yer aşınmış.. Orayı kaynakla doldurdu ve aynı seviyeye gelmesi için taşladı. Sonra toplayıp geri taktı. Aracı test ettim, ve sorun halledildi.. Vites çok titreme yapıyordu o da gitti. Dediğine göre yan sanayi parçadan daha iyi olurmuş böyle. Toplam olarak 115 tl te yaptırdım. Yan sanayi parçasının fiyatı 200 tl demişlerdi. Bu şekilde çok güzel oldu. Umarım ileride sorun yapmaz.]]>
   </description>
   <pubDate>Sat, 17 Nov 2012 18:24:21 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=25460&amp;PID=385301&amp;title=viteste-olusan-vibrasyon#385301</guid>
  </item>
  <item>
   <title><![CDATA[Viteste oluşan Vibrasyon : ankarada aks tamiri yapan bildi&#287;iniz...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=25460&amp;PID=384398&amp;title=viteste-olusan-vibrasyon#384398</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=5121">inceyasar</a><br /><strong>Konu:</strong> 25460<br /><strong>Gönderim Zamanı:</strong> 12&nbsp;Kasım&nbsp;2012 Saat 10:21<br /><br />ankarada aks tamiri yapan bildiğiniz yerler var mıdır?]]>
   </description>
   <pubDate>Mon, 12 Nov 2012 10:21:05 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=25460&amp;PID=384398&amp;title=viteste-olusan-vibrasyon#384398</guid>
  </item>
  <item>
   <title><![CDATA[Viteste oluşan Vibrasyon : ara&#231;ta spor egsoz sistemi varsa...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=25460&amp;PID=383160&amp;title=viteste-olusan-vibrasyon#383160</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6395">MagicPerformance</a><br /><strong>Konu:</strong> 25460<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Kasım&nbsp;2012 Saat 10:06<br /><br />araçta spor egsoz sistemi varsa devirlenirken ondanda titreme yapar.]]>
   </description>
   <pubDate>Mon, 05 Nov 2012 10:06:26 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=25460&amp;PID=383160&amp;title=viteste-olusan-vibrasyon#383160</guid>
  </item>
  <item>
   <title><![CDATA[Viteste oluşan Vibrasyon :   hocam arac&#305; &#305;y&#305; b&#305;yere goturup...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=25460&amp;PID=383153&amp;title=viteste-olusan-vibrasyon#383153</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8322">hsnsnl</a><br /><strong>Konu:</strong> 25460<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Kasım&nbsp;2012 Saat 10:01<br /><br />hocam aracı ıyı bıyere goturup aracın altına gırıp aksları sallıcaklar zaten orda bellı olur buyuk ıhtımal aks lalesıdır, cok hafıf bosluk olusuyo cozumu ya temız cıkma parca yada yansanayı parca ama tavsıye edılmez bılırsın..bide sole cozumu var,&nbsp;sole bısıde duymustum aks lalelerını sokup asındıgı yerlere iclerine&nbsp;cok saglam kaynak yapıp orjınal seklıne degerlerine&nbsp;getırıyolar.. aks tamır edenlar varmıs ve onlarda sımulatorde test edıyolarmıs olup olmadıgını..<div>&nbsp;</div><div>aksın ya yagsızlıktan sorun cıkardı yada yagsız kalıp sert vıraja gırdısen ondan olmustur</div><div>&nbsp;</div><div>bu parcanın sıfırını sor ama baya pahalıdır</div>]]>
   </description>
   <pubDate>Mon, 05 Nov 2012 10:01:43 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=25460&amp;PID=383153&amp;title=viteste-olusan-vibrasyon#383153</guid>
  </item>
  <item>
   <title><![CDATA[Viteste oluşan Vibrasyon :    hsnsnl Yazd&#305;:  aks lales&#305;nden...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=25460&amp;PID=383130&amp;title=viteste-olusan-vibrasyon#383130</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6612">yiğit4516</a><br /><strong>Konu:</strong> 25460<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Kasım&nbsp;2012 Saat 23:54<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: hsnsnl" alt="Orjinalini yazan: hsnsnl" style="vertical-align: text-bottom;" /> <strong>hsnsnl Yazdı:</strong><br /><br />aks lalesınden olabılır.. cıkma parcası 150-200 degısıyo</td></tr></table><div><br></div><div>Çıkması 150-200 tl mi&nbsp;<img src="https://forum.peugeotturkey.com/smileys/smiley3.gif" border="0" alt="Shocked" title="Shocked" />&nbsp;Sıfırı ne kadar kimbilir...</div>]]>
   </description>
   <pubDate>Sun, 04 Nov 2012 23:54:47 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=25460&amp;PID=383130&amp;title=viteste-olusan-vibrasyon#383130</guid>
  </item>
  <item>
   <title><![CDATA[Viteste oluşan Vibrasyon : genelde akslardan yapar. ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=25460&amp;PID=383098&amp;title=viteste-olusan-vibrasyon#383098</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8502">Barut</a><br /><strong>Konu:</strong> 25460<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Kasım&nbsp;2012 Saat 21:18<br /><br />genelde akslardan yapar.]]>
   </description>
   <pubDate>Sun, 04 Nov 2012 21:18:08 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=25460&amp;PID=383098&amp;title=viteste-olusan-vibrasyon#383098</guid>
  </item>
  <item>
   <title><![CDATA[Viteste oluşan Vibrasyon :   aks lales&#305;nden olab&#305;l&#305;r.....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=25460&amp;PID=383087&amp;title=viteste-olusan-vibrasyon#383087</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8322">hsnsnl</a><br /><strong>Konu:</strong> 25460<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Kasım&nbsp;2012 Saat 20:01<br /><br />aks lalesınden olabılır.. cıkma parcası 150-200 degısıyo]]>
   </description>
   <pubDate>Sun, 04 Nov 2012 20:01:49 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=25460&amp;PID=383087&amp;title=viteste-olusan-vibrasyon#383087</guid>
  </item>
  <item>
   <title><![CDATA[Viteste oluşan Vibrasyon : 80-90 km h&#305;zda giderken motor...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=25460&amp;PID=383080&amp;title=viteste-olusan-vibrasyon#383080</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6612">yiğit4516</a><br /><strong>Konu:</strong> 25460<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Kasım&nbsp;2012 Saat 19:45<br /><br />80-90 km hızda giderken motor tarafında titreşim oluşuyor ve ön taraf bariz şekilde sağ sol yaparak titriyor. Viteste aynı şekilde titreme yapıyor. Özellikle 4 viteste çok fazla yapıyor. Araç ağır olunca aynı şekildeçok belirgin oluyor bu.. Balans ayarı daha yeni yapıldı. Hatta balansçıya sormuştum, nedendir diye, balanstandır dedi. yaptıktan sonra sanki düzeldi gibi ama bir süre sonra baktım hiç değişme olmadı.. Başka birisine sordum akstandır dedi. Akslardan ise bize masrafı ne olur acaba?]]>
   </description>
   <pubDate>Sun, 04 Nov 2012 19:45:21 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=25460&amp;PID=383080&amp;title=viteste-olusan-vibrasyon#383080</guid>
  </item>
 </channel>
</rss>
