 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : ABS</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Arac&#305;n&#305;z Hakk&#305;ndaki T&#252;m Sorular : ABS]]></description>
  <pubDate>Mon, 04 May 2026 02:03:57 +0000</pubDate>
  <lastBuildDate>Tue, 23 Oct 2012 19:32:42 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=25229</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[ABS : titreme olduysa abs devrede demek...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=25229&amp;PID=381654&amp;title=abs#381654</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8044">jiyanxese</a><br /><strong>Konu:</strong> 25229<br /><strong>Gönderim Zamanı:</strong> 23&nbsp;Ekim&nbsp;2012 Saat 19:32<br /><br />titreme olduysa abs devrede demek :)]]>
   </description>
   <pubDate>Tue, 23 Oct 2012 19:32:42 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=25229&amp;PID=381654&amp;title=abs#381654</guid>
  </item>
  <item>
   <title><![CDATA[ABS : siz lastikler konusunu ele al&#305;n...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=25229&amp;PID=381577&amp;title=abs#381577</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=4703">aslanparcası</a><br /><strong>Konu:</strong> 25229<br /><strong>Gönderim Zamanı:</strong> 23&nbsp;Ekim&nbsp;2012 Saat 09:50<br /><br />siz lastikler konusunu ele alın derimn sanırım abs de devreye erken giriyor lastik sertleştiğinden veya diş kalmadığından]]>
   </description>
   <pubDate>Tue, 23 Oct 2012 09:50:14 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=25229&amp;PID=381577&amp;title=abs#381577</guid>
  </item>
  <item>
   <title><![CDATA[ABS : eyvallah sa&#287;olun ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=25229&amp;PID=381224&amp;title=abs#381224</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6948">rhcpeppers</a><br /><strong>Konu:</strong> 25229<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Ekim&nbsp;2012 Saat 20:27<br /><br />eyvallah sağolun]]>
   </description>
   <pubDate>Thu, 18 Oct 2012 20:27:25 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=25229&amp;PID=381224&amp;title=abs#381224</guid>
  </item>
  <item>
   <title><![CDATA[ABS : ABS&amp;#039;nin durma mesafesine...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=25229&amp;PID=381222&amp;title=abs#381222</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9585">Serkan</a><br /><strong>Konu:</strong> 25229<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Ekim&nbsp;2012 Saat 20:22<br /><br />ABS'nin durma mesafesine etkisi yok denecek kadar azdır, asıl görevi fren anında tekerleklerin kitlenmesi önleyip araca manevra müdahesi vermektir, yani hem fren yapıp hemde sağa sola kaçabilirsiniz, ama abs yoksa araç kaymaya başladıktan sonra istediğiniz kadar manevra yapın araç düz gider...]]>
   </description>
   <pubDate>Thu, 18 Oct 2012 20:22:24 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=25229&amp;PID=381222&amp;title=abs#381222</guid>
  </item>
  <item>
   <title><![CDATA[ABS : do&#287;rudur bilgiler i&#231;in te&#351;ekk&#252;rler...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=25229&amp;PID=381218&amp;title=abs#381218</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6948">rhcpeppers</a><br /><strong>Konu:</strong> 25229<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Ekim&nbsp;2012 Saat 19:40<br /><br />doğrudur bilgiler için teşekkürler arkadaşlar]]>
   </description>
   <pubDate>Thu, 18 Oct 2012 19:40:53 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=25229&amp;PID=381218&amp;title=abs#381218</guid>
  </item>
  <item>
   <title><![CDATA[ABS : abs yi anl&#305;&#351; biliyosun malesef....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=25229&amp;PID=381135&amp;title=abs#381135</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7803">simirnoffredbull</a><br /><strong>Konu:</strong> 25229<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Ekim&nbsp;2012 Saat 15:19<br /><br />abs yi anlış biliyosun malesef. abs ani durumlarda direksiyonu kilitlemeden frenler yaparak kazayı önleme amaçlıdır yani ani fren yapınca durması için yapılan bir fren sistemi değil.genelde agırlığı olan arabalarda ani frenlemede çok kısa sürelerde frenlemelerde ki amaca ulaşılıyor.]]>
   </description>
   <pubDate>Wed, 17 Oct 2012 15:19:32 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=25229&amp;PID=381135&amp;title=abs#381135</guid>
  </item>
  <item>
   <title><![CDATA[ABS :    rhcpeppers Yazd&#305;:evet titretiyor...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=25229&amp;PID=381133&amp;title=abs#381133</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6052">fTh206</a><br /><strong>Konu:</strong> 25229<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Ekim&nbsp;2012 Saat 15:02<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: rhcpeppers" alt="Orjinalini yazan: rhcpeppers" style="vertical-align: text-bottom;" /> <strong>rhcpeppers Yazdı:</strong><br /><br />evet titretiyor ama pat diye durması gerekmezmi ? ;) geçen ışıklar tam kırmızıya dönecek öndeki transporter baktım geçecek arkasına takılayım geçeyim dedim. 1 2. vites derken araç bir anda durdu bastım ama nafile geçirdik neyseki 1 2 izden başka birşey olmadı.&nbsp;</td></tr></table><b>Yok abi pat diye durmaz bizim araçlarda öle birden durmuyo kaymasını önlemek için olsa gerek yani benimde ani frenlerde baya geç duruyo</b>]]>
   </description>
   <pubDate>Wed, 17 Oct 2012 15:02:16 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=25229&amp;PID=381133&amp;title=abs#381133</guid>
  </item>
  <item>
   <title><![CDATA[ABS : evet titretiyor ama pat diye durmas&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=25229&amp;PID=381128&amp;title=abs#381128</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6948">rhcpeppers</a><br /><strong>Konu:</strong> 25229<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Ekim&nbsp;2012 Saat 14:29<br /><br />evet titretiyor ama pat diye durması gerekmezmi ? ;) geçen ışıklar tam kırmızıya dönecek öndeki transporter baktım geçecek arkasına takılayım geçeyim dedim. 1 2. vites derken araç bir anda durdu bastım ama nafile geçirdik neyseki 1 2 izden başka birşey olmadı.&nbsp;]]>
   </description>
   <pubDate>Wed, 17 Oct 2012 14:29:23 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=25229&amp;PID=381128&amp;title=abs#381128</guid>
  </item>
  <item>
   <title><![CDATA[ABS : geri geri at&#305;yor titretiyor ise...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=25229&amp;PID=381127&amp;title=abs#381127</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6907">xpyhre</a><br /><strong>Konu:</strong> 25229<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Ekim&nbsp;2012 Saat 14:26<br /><br />geri geri atıyor titretiyor ise abs calişiyor.]]>
   </description>
   <pubDate>Wed, 17 Oct 2012 14:26:25 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=25229&amp;PID=381127&amp;title=abs#381127</guid>
  </item>
  <item>
   <title><![CDATA[ABS : ABS de s&#305;k&#305;nt&#305; yok ama &#246;yle ani...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=25229&amp;PID=381125&amp;title=abs#381125</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9810">impact</a><br /><strong>Konu:</strong> 25229<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Ekim&nbsp;2012 Saat 14:24<br /><br /><b>ABS de sıkıntı yok ama öyle ani frenlerde açıkcası ben pek faydası olmuyor gibi ya da psikolojik..&nbsp;</b>]]>
   </description>
   <pubDate>Wed, 17 Oct 2012 14:24:12 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=25229&amp;PID=381125&amp;title=abs#381125</guid>
  </item>
  <item>
   <title><![CDATA[ABS : Arkada&#351;lar merhaba. Bu ara fren...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=25229&amp;PID=381123&amp;title=abs#381123</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6948">rhcpeppers</a><br /><strong>Konu:</strong> 25229<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Ekim&nbsp;2012 Saat 14:17<br /><br />Arkadaşlar merhaba. Bu ara fren beni korkutuyor. frene bastıgımda abs devreye giriyormu girmiyormu şüphelerim var. Geçenlerde ışıklardan geçerken öndeki araç pat diye durdu frene bastım ama nafile.. Titreme yapıyor ayagımı geri geri atıyo titretiyo. Debriyaj seti değişmişti 1 2 ay evvel. Onunla alakası olabilirmi ? Yoksa abs devreye giriyorda benmi farkına varamıyorum ?]]>
   </description>
   <pubDate>Wed, 17 Oct 2012 14:17:16 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=25229&amp;PID=381123&amp;title=abs#381123</guid>
  </item>
 </channel>
</rss>
