 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : arıza kodu ???</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 307 : arıza kodu ???]]></description>
  <pubDate>Mon, 04 May 2026 05:19:24 +0000</pubDate>
  <lastBuildDate>Sun, 07 Oct 2012 08:05:13 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=25097</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[arıza kodu ??? : Oksijen sensoru voltajindan kaynakli...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=25097&amp;PID=380019&amp;title=ariza-kodu#380019</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2147">koliva</a><br /><strong>Konu:</strong> 25097<br /><strong>Gönderim Zamanı:</strong> 07&nbsp;Ekim&nbsp;2012 Saat 08:05<br /><br />Oksijen sensoru voltajindan kaynakli bir sorun oldugu yaziyor asagidaki linkte. Hatayi silin, biraz aracinizi kullanin ve sonra hatanin geri gelip gelmedigine bakin.<br><a href="http://www.permoveo.ltd.uk/tabid/122/OBD-Error-Code/P2250/Diagnostics/Peugeot/Default.aspx" target="_blank" rel="nofollow">http://www.permoveo.ltd.uk/tabid/122/OBD-Error-Code/P2250/Diagnostics/Peugeot/Default.aspx</a>]]>
   </description>
   <pubDate>Sun, 07 Oct 2012 08:05:13 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=25097&amp;PID=380019&amp;title=ariza-kodu#380019</guid>
  </item>
  <item>
   <title><![CDATA[arıza kodu ??? : &#246;n iki airbag patlak... direnci...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=25097&amp;PID=379996&amp;title=ariza-kodu#379996</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9418">mesutay20</a><br /><strong>Konu:</strong> 25097<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Ekim&nbsp;2012 Saat 23:53<br /><br />ön iki airbag patlak... direnci düşünmüyorum. çünkü hem hayat hemde satarken insanlığımızdan çıkmayalım.. :) bu arıza kodunu merak ettim. çünkü arıza lambası yanmazken bile gene pc ye bağladığımızda verdi kod :p2250 bilinmyen arıza kodu]]>
   </description>
   <pubDate>Sat, 06 Oct 2012 23:53:47 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=25097&amp;PID=379996&amp;title=ariza-kodu#379996</guid>
  </item>
  <item>
   <title><![CDATA[arıza kodu ??? : airbagi patlaksa s&#305;stem&#305; kand&#305;rarak...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=25097&amp;PID=379960&amp;title=ariza-kodu#379960</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3690">berk2309</a><br /><strong>Konu:</strong> 25097<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Ekim&nbsp;2012 Saat 15:35<br /><br />airbagi patlaksa sıstemı kandırarak kurtulursun ancak direnc atıcaksın oda cok saglam olmaz &nbsp;kaza anında dıger aırbaglar acılmayabılır yada gıdıp aırbag alıcaksın hangılerı patlak]]>
   </description>
   <pubDate>Sat, 06 Oct 2012 15:35:05 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=25097&amp;PID=379960&amp;title=ariza-kodu#379960</guid>
  </item>
  <item>
   <title><![CDATA[arıza kodu ??? : merhabalar, 307 2002 xt premium...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=25097&amp;PID=379936&amp;title=ariza-kodu#379936</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9418">mesutay20</a><br /><strong>Konu:</strong> 25097<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Ekim&nbsp;2012 Saat 23:26<br /><br />merhabalar, 307 2002 xt premium aracımın airbag i patlaktı. airbag fault uyarısı verip duruyor. bu ışıktan uyarıdan kurtulmak için ne yapmalıyım ve aracı bu gün teste soktuğumda 2250 bilinmeyen hata uyarısı verdi. bu kodun ne olduğunu bilen var mı???]]>
   </description>
   <pubDate>Fri, 05 Oct 2012 23:26:17 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=25097&amp;PID=379936&amp;title=ariza-kodu#379936</guid>
  </item>
 </channel>
</rss>
