 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 307 HDI Beyaz Duman</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 307 : 307 HDI Beyaz Duman]]></description>
  <pubDate>Mon, 04 May 2026 16:27:19 +0000</pubDate>
  <lastBuildDate>Fri, 27 Jul 2012 14:18:42 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=24111</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[307 HDI Beyaz Duman : O zaman &#246;nce bir turbo de&#287;i&#351;tirmeyi...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=24111&amp;PID=371432&amp;title=307-hdi-beyaz-duman#371432</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6130">piyade12</a><br /><strong>Konu:</strong> 24111<br /><strong>Gönderim Zamanı:</strong> 27&nbsp;Temmuz&nbsp;2012 Saat 14:18<br /><br />&nbsp;O zaman önce bir turbo değiştirmeyi deneyelim bakalım.<br>Problem çözülmezse bakarız...<br><br>]]>
   </description>
   <pubDate>Fri, 27 Jul 2012 14:18:42 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=24111&amp;PID=371432&amp;title=307-hdi-beyaz-duman#371432</guid>
  </item>
  <item>
   <title><![CDATA[307 HDI Beyaz Duman : 300 tl civar&#305; fiyat&#305; vard&#305;r sekman...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=24111&amp;PID=371428&amp;title=307-hdi-beyaz-duman#371428</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=5075">spearo</a><br /><strong>Konu:</strong> 24111<br /><strong>Gönderim Zamanı:</strong> 27&nbsp;Temmuz&nbsp;2012 Saat 14:07<br /><br />300 tl civarı fiyatı vardır sekman takımının motor sök tak maaliyetide olur, 500 tlden aşağı kimse motor sok taka girmez&nbsp;]]>
   </description>
   <pubDate>Fri, 27 Jul 2012 14:07:36 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=24111&amp;PID=371428&amp;title=307-hdi-beyaz-duman#371428</guid>
  </item>
  <item>
   <title><![CDATA[307 HDI Beyaz Duman : &#214;ncelikle cevap i&#231;in te&#351;ekk&#252;rler.Sekmanlarla...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=24111&amp;PID=371397&amp;title=307-hdi-beyaz-duman#371397</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6130">piyade12</a><br /><strong>Konu:</strong> 24111<br /><strong>Gönderim Zamanı:</strong> 27&nbsp;Temmuz&nbsp;2012 Saat 11:00<br /><br />Öncelikle cevap için teşekkürler.<br>Sekmanlarla ilgili bir sorunsa maliyeti ne olur ?<br>Ben aracı satmak ya da yaptırıp kullanmak arasında karar vermeye çalışıyorum şu aralar.<br><br>]]>
   </description>
   <pubDate>Fri, 27 Jul 2012 11:00:57 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=24111&amp;PID=371397&amp;title=307-hdi-beyaz-duman#371397</guid>
  </item>
  <item>
   <title><![CDATA[307 HDI Beyaz Duman : turbo milinden yag cok kac&#305;r&#305;yorda...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=24111&amp;PID=371396&amp;title=307-hdi-beyaz-duman#371396</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=5075">spearo</a><br /><strong>Konu:</strong> 24111<br /><strong>Gönderim Zamanı:</strong> 27&nbsp;Temmuz&nbsp;2012 Saat 10:51<br /><br />turbo milinden yag cok kacırıyorda dumana sebep olur.<br>turbodan silindire yag kaçması hdi dizelde en tehlikeli durumdur, yanma oda harareti artar enjektör memesi yüksek devirlerde devamlı giderseniz erir ve kırıp patlar,&nbsp; silindire yüksek basınclı yakıt dolar motor hızlı bir sekilde yüksek devire cıkarak kendini parçalar.<br>ihmal etmeyip hemen onarım yaptırın.<br>turbodan sonrada düzelmezse yag sekmanlarınız bitmiş dmektir ;)<br>]]>
   </description>
   <pubDate>Fri, 27 Jul 2012 10:51:13 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=24111&amp;PID=371396&amp;title=307-hdi-beyaz-duman#371396</guid>
  </item>
  <item>
   <title><![CDATA[307 HDI Beyaz Duman : Merhaba Arkada&#351;lar, 2004 Model,...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=24111&amp;PID=371392&amp;title=307-hdi-beyaz-duman#371392</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6130">piyade12</a><br /><strong>Konu:</strong> 24111<br /><strong>Gönderim Zamanı:</strong> 27&nbsp;Temmuz&nbsp;2012 Saat 10:37<br /><br />Merhaba Arkadaşlar, <br>2004 Model, 1,4 HDI 307 Sahibiyim.<br>Aracımda çekişte sorun vardı, yağ akıtıyordu ve egzostan beyaz duman atıyordu yoğun bir şekilde.<br>Çekiş problemi katalitik konvertörün tıkanması sebebiyle olmuş, temizlendi.<br>Öntarafta bulunan ısı kalkanları değişti.<br>Turbo yağlama hortumu patlamış, yağı buradan akıtıyormuş, değişti.<br>Motor yağı ve filtreler değişti.<br>460 TL masraf yaptık fakat egzostan beyaz duman atma olayı sinirimi bozuyor.<br>Ustanın dediği ise turboda çok az bir ıslık sesi varmış ve değiştirirsek beyaz duman kesilebilirmiş.<br>Yine kesilmezse motor inecekmiş.<br>Turbo masrafı nerden baksan 750 TL ya çıkar şimdi bana, bir de beyaz duman devam ederse boşuna masraf yapmış olacağım.<br>Sizce yaptırmak mı yoksa aracı bu haliyle satmak mı daha mantıklı ?<br>Fikirleriniz nelerdir.<br><br>]]>
   </description>
   <pubDate>Fri, 27 Jul 2012 10:37:48 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=24111&amp;PID=371392&amp;title=307-hdi-beyaz-duman#371392</guid>
  </item>
 </channel>
</rss>
