 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 206 baskı balata hakkında bilgi</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 206 : 206 baskı balata hakkında bilgi]]></description>
  <pubDate>Mon, 04 May 2026 14:12:48 +0000</pubDate>
  <lastBuildDate>Sat, 21 Jul 2012 01:30:50 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=23987</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[206 baskı balata hakkında bilgi : &#304;&#351;&#231;ilik &#252;creti ne kadard&#305;r bask&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=23987&amp;PID=370429&amp;title=206-baski-balata-hakkinda-bilgi#370429</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9585">Serkan</a><br /><strong>Konu:</strong> 23987<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Temmuz&nbsp;2012 Saat 01:30<br /><br />İşçilik ücreti ne kadardır baskı balata değişimini tahminen...]]>
   </description>
   <pubDate>Sat, 21 Jul 2012 01:30:50 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=23987&amp;PID=370429&amp;title=206-baski-balata-hakkinda-bilgi#370429</guid>
  </item>
  <item>
   <title><![CDATA[206 baskı balata hakkında bilgi : bask&#305;balatay&#305; de&#287;i&#351;tirecek varsa...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=23987&amp;PID=370416&amp;title=206-baski-balata-hakkinda-bilgi#370416</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6495">ByHack</a><br /><strong>Konu:</strong> 23987<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Temmuz&nbsp;2012 Saat 00:01<br /><br /><P>baskıbalatayı değiştirecek varsa şahin peugeotta indirim var kaçırmayın:)</P>]]>
   </description>
   <pubDate>Sat, 21 Jul 2012 00:01:12 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=23987&amp;PID=370416&amp;title=206-baski-balata-hakkinda-bilgi#370416</guid>
  </item>
  <item>
   <title><![CDATA[206 baskı balata hakkında bilgi :    Serco05 Yazd&#305;:Arkada&#351;lar...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=23987&amp;PID=370291&amp;title=206-baski-balata-hakkinda-bilgi#370291</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7967">Alicilik</a><br /><strong>Konu:</strong> 23987<br /><strong>Gönderim Zamanı:</strong> 20&nbsp;Temmuz&nbsp;2012 Saat 00:28<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Serco05" alt="Orjinalini yazan: Serco05" style="vertical-align: text-bottom;" /> <strong>Serco05 Yazdı:</strong><br /><br />Arkadaşlar birkaç gündür araç vites geçişlerinde fark edilir derecede rahatlama var aynı şekilde performansında da artış var ama debriyaj daha yukardan kavrıyor, debriyajda kaçırma yok stop ettirme testini yaptım stop etti, dik rampada&nbsp;1. vitesle kalkıp sonra 3.vitese takıp tam gaz yaptım araç boğuldu ve yokuş inişte 1. viteste bıraktım araç kendini salmadı. 800-900 km önce şanzıman yağını değiştirdim motor yağınıda önceden 10/40 koyardım bu sefer castrol edge 5/40 koydum. Uzun zamandır başka araç kullanmamıştım cumartesi şirket aracıyla 1-2 saat dolaştım ondan indikten sonramı debriyaj çok yüksek geldi anlamadım. Şimdi beni burda tek rahatsız eden debriyajın çok yukarda kavraması onun haricinde vites geçişlerinde ve performansta iyi yönde gelişme var, bu arada debriyaj pedalıda sert değil. Bu konuda yorumlarınızı bekliyorum.<br></td></tr></table><br><br>Bir pejo klasiği :d<br><br>Aynı durum 2011 aracımda da var. 2006 chipli 1.4 ile 4. viteste bugün kafa kafaya gittik. Abi sen benden habersiz chip mi yaptırdın dedi. Nasıl vites değiştiriyorsun diye soruyor. 1/4 oranında basınca vites geçiyo sonuna kadar basmaya gerek yok<br>]]>
   </description>
   <pubDate>Fri, 20 Jul 2012 00:28:22 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=23987&amp;PID=370291&amp;title=206-baski-balata-hakkinda-bilgi#370291</guid>
  </item>
  <item>
   <title><![CDATA[206 baskı balata hakkında bilgi : Arkada&#351;lar birka&#231; g&#252;nd&#252;r ara&#231;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=23987&amp;PID=370285&amp;title=206-baski-balata-hakkinda-bilgi#370285</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9585">Serkan</a><br /><strong>Konu:</strong> 23987<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Temmuz&nbsp;2012 Saat 23:58<br /><br />Arkadaşlar birkaç gündür araç vites geçişlerinde fark edilir derecede rahatlama var aynı şekilde performansında da artış var ama debriyaj daha yukardan kavrıyor, debriyajda kaçırma yok stop ettirme testini yaptım stop etti, dik rampada&nbsp;1. vitesle kalkıp sonra 3.vitese takıp tam gaz yaptım araç boğuldu ve yokuş inişte 1. viteste bıraktım araç kendini salmadı. 800-900 km önce şanzıman yağını değiştirdim motor yağınıda önceden 10/40 koyardım bu sefer castrol edge 5/40 koydum. Uzun zamandır başka araç kullanmamıştım cumartesi şirket aracıyla 1-2 saat dolaştım ondan indikten sonramı debriyaj çok yüksek geldi anlamadım. Şimdi beni burda tek rahatsız eden debriyajın çok yukarda kavraması onun haricinde vites geçişlerinde ve performansta iyi yönde gelişme var, bu arada debriyaj pedalıda sert değil. Bu konuda yorumlarınızı bekliyorum.<br>]]>
   </description>
   <pubDate>Thu, 19 Jul 2012 23:58:33 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=23987&amp;PID=370285&amp;title=206-baski-balata-hakkinda-bilgi#370285</guid>
  </item>
 </channel>
</rss>
