 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 308 1.6 hdi</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 308 T7 (2008-2013) : 308 1.6 hdi]]></description>
  <pubDate>Sun, 03 May 2026 09:19:28 +0000</pubDate>
  <lastBuildDate>Tue, 29 May 2012 11:55:37 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=23279</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[308 1.6 hdi :   yumusak kullanmakla alakas&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=23279&amp;PID=363683&amp;title=308-1-6-hdi#363683</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8645">toga406</a><br /><strong>Konu:</strong> 23279<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Mayıs&nbsp;2012 Saat 11:55<br /><br /><strong>yumusak kullanmakla alakası olamaz. kesinlikle baska bitr sorun var.</strong><div><strong>istediğin kadar sert kullan öyle tak tuk ses gelmez hiçbir araçtan hele yeniyse</strong></div>]]>
   </description>
   <pubDate>Tue, 29 May 2012 11:55:37 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=23279&amp;PID=363683&amp;title=308-1-6-hdi#363683</guid>
  </item>
  <item>
   <title><![CDATA[308 1.6 hdi :   Biraz daha yumusak kullanmak...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=23279&amp;PID=363658&amp;title=308-1-6-hdi#363658</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=6892">Cmoss06</a><br /><strong>Konu:</strong> 23279<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Mayıs&nbsp;2012 Saat 10:06<br /><br />Biraz daha yumusak kullanmak lazım.]]>
   </description>
   <pubDate>Tue, 29 May 2012 10:06:35 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=23279&amp;PID=363658&amp;title=308-1-6-hdi#363658</guid>
  </item>
  <item>
   <title><![CDATA[308 1.6 hdi : kesinlikle servise gitmel&#305;s&#305;n&#305;z...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=23279&amp;PID=363642&amp;title=308-1-6-hdi#363642</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9372">eerkan</a><br /><strong>Konu:</strong> 23279<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Mayıs&nbsp;2012 Saat 07:58<br /><br />kesinlikle servise gitmelısınız hemen kulaklarda problem olabilir arkadasında dedıgı gıbı sık sık yapıyorsa problem sizden değil arabadan kaynaklanıyordur. ama ara ara yapıyorsa bu sizdende kaynaklanabilir .debriyajı hassas kullanmanızı tavsiye ederim yinede.]]>
   </description>
   <pubDate>Tue, 29 May 2012 07:58:54 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=23279&amp;PID=363642&amp;title=308-1-6-hdi#363642</guid>
  </item>
  <item>
   <title><![CDATA[308 1.6 hdi : Debriyaji biraz daha yumusak kulanmaya...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=23279&amp;PID=363638&amp;title=308-1-6-hdi#363638</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2147">koliva</a><br /><strong>Konu:</strong> 23279<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Mayıs&nbsp;2012 Saat 07:48<br /><br />Debriyaji biraz daha yumusak kulanmaya calisin. Kalkislarda gelen bu sesin motor kulaklarindan gelme ihtimali var. Isterseniz bir ustaya kontrol ettirin. <br>]]>
   </description>
   <pubDate>Tue, 29 May 2012 07:48:48 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=23279&amp;PID=363638&amp;title=308-1-6-hdi#363638</guid>
  </item>
  <item>
   <title><![CDATA[308 1.6 hdi : g&#252;ncel ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=23279&amp;PID=363605&amp;title=308-1-6-hdi#363605</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8616">nupel307</a><br /><strong>Konu:</strong> 23279<br /><strong>Gönderim Zamanı:</strong> 28&nbsp;Mayıs&nbsp;2012 Saat 23:06<br /><br />güncel]]>
   </description>
   <pubDate>Mon, 28 May 2012 23:06:47 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=23279&amp;PID=363605&amp;title=308-1-6-hdi#363605</guid>
  </item>
  <item>
   <title><![CDATA[308 1.6 hdi : Merhaba arkadaslar..1 haftad&#305;r...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=23279&amp;PID=363592&amp;title=308-1-6-hdi#363592</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8616">nupel307</a><br /><strong>Konu:</strong> 23279<br /><strong>Gönderim Zamanı:</strong> 28&nbsp;Mayıs&nbsp;2012 Saat 20:17<br /><br />Merhaba arkadaslar..1 haftadır yeni 2008 308 aldım..arac 54000 de ..bugün fark ettim aracı birinci vitesten ikinci vitese atarken ^' tak^gibi bir ses geliyor ..acaba ayagımı debriyajdan çabuk çektiğim için mi..yoksa baska bir nedendenmidir..fikri olan varsa yardımcı olursa sevinirim..tskler]]>
   </description>
   <pubDate>Mon, 28 May 2012 20:17:31 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=23279&amp;PID=363592&amp;title=308-1-6-hdi#363592</guid>
  </item>
 </channel>
</rss>
