 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 206+ Sesler</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 206+ : 206+ Sesler]]></description>
  <pubDate>Mon, 04 May 2026 19:39:20 +0000</pubDate>
  <lastBuildDate>Fri, 06 Jul 2012 21:49:34 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=20542</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[206+ Sesler : bence direksiyon pompas&#305;n&#305; yag&#305;n&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=20542&amp;PID=368803&amp;title=206-sesler#368803</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7085">istanbullu_3886</a><br /><strong>Konu:</strong> 20542<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Temmuz&nbsp;2012 Saat 21:49<br /><br />bence direksiyon pompasını yagını kontrol ettir yagı az veya uygunsuz bir yag konulmuş olabilir]]>
   </description>
   <pubDate>Fri, 06 Jul 2012 21:49:34 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=20542&amp;PID=368803&amp;title=206-sesler#368803</guid>
  </item>
  <item>
   <title><![CDATA[206+ Sesler : 2010 206+ 1.4 Dizel 70.000 de...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=20542&amp;PID=368782&amp;title=206-sesler#368782</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9644">paujayjay</a><br /><strong>Konu:</strong> 20542<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Temmuz&nbsp;2012 Saat 19:29<br /><br />2010 206+ 1.4 Dizel 70.000 de aracım var . Problem cok büyük cok acil gaz pedalına ihtiyacım var. araç 3000 deviri geçmiyor. bilen varsa dönsün mail atsın bişe yapsın..]]>
   </description>
   <pubDate>Fri, 06 Jul 2012 19:29:59 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=20542&amp;PID=368782&amp;title=206-sesler#368782</guid>
  </item>
  <item>
   <title><![CDATA[206+ Sesler : &#231;ok te&#351;ekk&#252;r ederim cevaplar i&#231;in,...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=20542&amp;PID=336216&amp;title=206-sesler#336216</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8159">ahmetyil75</a><br /><strong>Konu:</strong> 20542<br /><strong>Gönderim Zamanı:</strong> 13&nbsp;Aralık&nbsp;2011 Saat 02:31<br /><br />çok teşekkür ederim cevaplar için, öncelikle&nbsp;<span style="text-align: left; : rgb251, 251, 253; ">karter koruma yok bende :( götürüp göstericez bir şekilde. Yani sabah soğuktandır diyorum üstüne düşmüyüm diyorum ama sadece belli bir devir aralığında yapması çok can sıkıcı 2200 ile 2400 &nbsp;arası defelarca kontrol ettim. Sorunu bulursam burada paylaşacağım</span>]]>
   </description>
   <pubDate>Tue, 13 Dec 2011 02:31:55 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=20542&amp;PID=336216&amp;title=206-sesler#336216</guid>
  </item>
  <item>
   <title><![CDATA[206+ Sesler : arkadas ses gelmes&#305; cok normal...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=20542&amp;PID=336195&amp;title=206-sesler#336195</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7808">buston_01</a><br /><strong>Konu:</strong> 20542<br /><strong>Gönderim Zamanı:</strong> 12&nbsp;Aralık&nbsp;2011 Saat 22:20<br /><br />arkadas ses gelmesı cok normal cunku sabah araba sogdugu ıcın yag pompası boşalıyor tekrar yag pompasına yag dolana kadar ufak ses yapar merak etme huzrla bın]]>
   </description>
   <pubDate>Mon, 12 Dec 2011 22:20:35 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=20542&amp;PID=336195&amp;title=206-sesler#336195</guid>
  </item>
  <item>
   <title><![CDATA[206+ Sesler : valla bendede aya&#287;&#305;m&#305; gazdan &#231;ekince...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=20542&amp;PID=336175&amp;title=206-sesler#336175</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8094">hakan38</a><br /><strong>Konu:</strong> 20542<br /><strong>Gönderim Zamanı:</strong> 12&nbsp;Aralık&nbsp;2011 Saat 20:42<br /><br />valla bendede ayağımı gazdan çekince ses geliyor ama çok üstüne düşmedim,]]>
   </description>
   <pubDate>Mon, 12 Dec 2011 20:42:45 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=20542&amp;PID=336175&amp;title=206-sesler#336175</guid>
  </item>
  <item>
   <title><![CDATA[206+ Sesler : 2011 model ara&#231;ta nas&#305;l oluyor...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=20542&amp;PID=336162&amp;title=206-sesler#336162</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3388">toprak</a><br /><strong>Konu:</strong> 20542<br /><strong>Gönderim Zamanı:</strong> 12&nbsp;Aralık&nbsp;2011 Saat 18:08<br /><br />2011 model araçta nasıl oluyor arkadaş böyle sesler ya :@]]>
   </description>
   <pubDate>Mon, 12 Dec 2011 18:08:11 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=20542&amp;PID=336162&amp;title=206-sesler#336162</guid>
  </item>
  <item>
   <title><![CDATA[206+ Sesler : Onlar normal bencede.As&#305;l sorun...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=20542&amp;PID=336149&amp;title=206-sesler#336149</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7967">Alicilik</a><br /><strong>Konu:</strong> 20542<br /><strong>Gönderim Zamanı:</strong> 12&nbsp;Aralık&nbsp;2011 Saat 15:34<br /><br />Onlar normal bencede.<br><br>Asıl sorun geri vitese geçiş ve bende de bu aralar rezistansı açınca çıt çıt diye sürekli bir ses çıkıyor.<br>]]>
   </description>
   <pubDate>Mon, 12 Dec 2011 15:34:00 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=20542&amp;PID=336149&amp;title=206-sesler#336149</guid>
  </item>
  <item>
   <title><![CDATA[206+ Sesler : 1. Problem Bende de Mevcut. Direksiyonu...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=20542&amp;PID=336146&amp;title=206-sesler#336146</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2301">denizcAn</a><br /><strong>Konu:</strong> 20542<br /><strong>Gönderim Zamanı:</strong> 12&nbsp;Aralık&nbsp;2011 Saat 14:57<br /><br /><b>1. Problem Bende de Mevcut. Direksiyonu Döndürüken Ses Geliyor. Servise Götürdüm Normal Dediler.</b>]]>
   </description>
   <pubDate>Mon, 12 Dec 2011 14:57:15 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=20542&amp;PID=336146&amp;title=206-sesler#336146</guid>
  </item>
  <item>
   <title><![CDATA[206+ Sesler :  Ayn&#305; ara&#231; bende de var 2010...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=20542&amp;PID=336127&amp;title=206-sesler#336127</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2142">rifatseker</a><br /><strong>Konu:</strong> 20542<br /><strong>Gönderim Zamanı:</strong> 12&nbsp;Aralık&nbsp;2011 Saat 08:50<br /><br />Aynı araç bende de var 2010 modeli Dizel.. ,&nbsp;<div><br></div><div>Birinci problem ile karşılaşmadım hiç fakat ikinci problemin için bir önerim olabilir , aracındaki karter koruma metal ise onun bağlantılarını bir kontrol ettir derim. O bağlantılarda gevşeklik olunca aracın içinde sanki motordan yada ön göğüsten hırıltı geliyormuşcasına ses yapıyor. Ben bu şekilde çözmüştüm. :)))</div><span style="font-size:10px"><br /><br />Düzenleyen rifatseker - 12&nbsp;Aralık&nbsp;2011 Saat 08:50</span>]]>
   </description>
   <pubDate>Mon, 12 Dec 2011 08:50:16 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=20542&amp;PID=336127&amp;title=206-sesler#336127</guid>
  </item>
  <item>
   <title><![CDATA[206+ Sesler : Selamlar herkese,2011 model 206+...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=20542&amp;PID=336124&amp;title=206-sesler#336124</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8159">ahmetyil75</a><br /><strong>Konu:</strong> 20542<br /><strong>Gönderim Zamanı:</strong> 12&nbsp;Aralık&nbsp;2011 Saat 02:44<br /><br />Selamlar herkese,<div><br></div><div>2011 model 206+ 1.4 benzinli araç aldım, iki tane de ciddi problemim var, birincisi sabahları aracı çalıştırdığımda direksiyonu çevirirken çok ince bir ses gelmesi, bir müddet sonra gidiyor fakat çok rahatsız edici, bu problemi yaşamış ve çözmüş arkadaşlar varmıdır? bir diğeri ise, sabahları yine çalıştırdıktan sonra giderken 2200 ile 2400 devirler arasında bayağı bir ses gelmesi hırıltı, sürtünme bir garip ses gibi, 15 dakika kadar sonra geçiyor</div><div><br></div><div><br></div>]]>
   </description>
   <pubDate>Mon, 12 Dec 2011 02:44:17 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=20542&amp;PID=336124&amp;title=206-sesler#336124</guid>
  </item>
 </channel>
</rss>
