 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : hararet problemi</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 307 : hararet problemi]]></description>
  <pubDate>Sat, 02 May 2026 06:15:03 +0000</pubDate>
  <lastBuildDate>Tue, 19 Jun 2012 18:58:15 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=20210</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[hararet problemi :   &#231;ok te&#351;ekk&#252;r ederim &#252;stad...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=366945&amp;title=hararet-problemi#366945</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8645">toga406</a><br /><strong>Konu:</strong> 20210<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Haziran&nbsp;2012 Saat 18:58<br /><br />çok teşekkür ederim üstad şimdi anlaşıldı]]>
   </description>
   <pubDate>Tue, 19 Jun 2012 18:58:15 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=366945&amp;title=hararet-problemi#366945</guid>
  </item>
  <item>
   <title><![CDATA[hararet problemi :    toga406 Yazd&#305;:  peki azizim...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=366933&amp;title=hararet-problemi#366933</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=5813">monur</a><br /><strong>Konu:</strong> 20210<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Haziran&nbsp;2012 Saat 16:47<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: toga406" alt="Orjinalini yazan: toga406" style="vertical-align: text-bottom;" /> <strong>toga406 Yazdı:</strong><br /><br /><strong>peki azizim bu durum aracın sogutma tertibatında sorun olduğu anlamına gelir mi. çözümü basit midir birde su sıcaklığının 90 da sabit durması hiç yukarı aşağı kıpırdamaması da bir sorun olabilir mi</strong><div><strong>ger gelen su oldukça temizdi. yağ izi emaresi yoktu. conta sorunu olsa suya yağ veya yağa su karışır biliyorum</strong></div><div><strong>ne dersin </strong></div></td></tr></table><div><br></div><div>Dikkat ederseniz conta yakmış demiyorum azizim.Bir sebepten dolayı deforme olmuş ve bu bir iğne deliği kadar bir şeydir.Bu durumda motor yağına su zaten karışamaz,ama önlemini almazsanız bu delik büyür ve en son hararet yapar kalır.</div><div><br></div><div>Bir bosh-car servisine gidin,conta kontrolü yaptırmak istediğinizi söyleyin. Onlarda mavi bir sıvı var ve bunu şırınga gibi bir şeye çekiyorlar,motor sıcak ve çalışır haldeyken genleşme kabının ağzına getirip (suyla temas etmiyor) bu mavi sıvının içine su buharını çekiyorlar.Mavi sıvı sarı renge dönerse conta gidik,aynı mavi kalırsa conta sağlam demektir. Ben Bosh-Car service dedim ama sadece onlarda gördüm bu olayı,tanıdığınız ustalarınız da yapıyorsa onlara da yaptırabilirsiniz.</div>]]>
   </description>
   <pubDate>Tue, 19 Jun 2012 16:47:22 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=366933&amp;title=hararet-problemi#366933</guid>
  </item>
  <item>
   <title><![CDATA[hararet problemi :   peki azizim bu durum arac&#305;n...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=366926&amp;title=hararet-problemi#366926</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8645">toga406</a><br /><strong>Konu:</strong> 20210<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Haziran&nbsp;2012 Saat 15:50<br /><br /><strong>peki azizim bu durum aracın sogutma tertibatında sorun olduğu anlamına gelir mi. çözümü basit midir birde su sıcaklığının 90 da sabit durması hiç yukarı aşağı kıpırdamaması da bir sorun olabilir mi</strong><div><strong>ger gelen su oldukça temizdi. yağ izi emaresi yoktu. conta sorunu olsa suya yağ veya yağa su karışır biliyorum</strong></div><div><strong>ne dersin </strong></div>]]>
   </description>
   <pubDate>Tue, 19 Jun 2012 15:50:12 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=366926&amp;title=hararet-problemi#366926</guid>
  </item>
  <item>
   <title><![CDATA[hararet problemi :    toga406 Yazd&#305;:   ugurkurt...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=366922&amp;title=hararet-problemi#366922</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=5813">monur</a><br /><strong>Konu:</strong> 20210<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Haziran&nbsp;2012 Saat 15:44<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: toga406" alt="Orjinalini yazan: toga406" style="vertical-align: text-bottom;" /> <strong>toga406 Yazdı:</strong><br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: ugurkurt" alt="Orjinalini yazan: ugurkurt" style="vertical-align: text-bottom;" /> <strong>ugurkurt Yazdı:</strong><br /><br />arkadaşlar bugün gündüz gözüyle aracı şöyle bi inceledim. depoda min seviye civarında su vardı. max çizgisine kadar su doldurdum. aracı çalıştırdım bide ne göreyim su nerdeyse depo ile radyatör arasındaki hortum giriş hizasına kadar çıkmış. sonra kontrol edeken silindir contasının sol alt köşesinde(arabaya göre sol) çok hafif su kabarcıkları gördüm. tabi motor ısınınca kesti tabi. bişey daha farkettim harareti 100 bulduramıyorum çünkü fan buna müsade etmiyor. 95 civarı kontağı kapatıp su deposunu gözlemleyince 2 dk içinde depodaki su seviyesinin gözle görülür bi şekilde artıp kapaktan su attığını gördüm. işin ilginç yanı hemen kontağa basarsanız su bi anda kayboluyo. stop edince gene aynı şey oluyor ama bi kere taşınca bidaha taşmıyo su eklemezseniz.</td></tr></table><div><strong>ustaların çözemediği servisin bulamadığı otomatik 406 aracımdaki yağ ısınma ve şanzıman korumaya geçme sorununu eve gidince aracın araba sogutma tertibatında mı sorun var diye radyatör suyunun genleşme tankı yani su ilave edilen kapağını açtım ve şaşırdım kaldım. aracı gazladım radyatör fanı açtı. durdu. bende kapağı hafif hafif açtım suyun sıcak olduğunu bilerek</strong></div><div><strong>ama su tamamen kabarcıklar çıkartarak fokurdaya fokurdaya boşaltı. neredeyse abartısız tamamı aktı gitti. fokurdayarak. araç göstergelerini arada kontrol ettim. yağ sıcaklık göstergesi 130 ları geçti radyatör su göstergesi 90 da sabit max 90. ama 90 derecede su kaynamaz biliyorum</strong></div><div><strong>sorun acaba termostadda veya göstergede olabilir mi </strong></div><div><strong>fikri olan var mı?</strong></div><div><strong>radyatör suyunun fokurdayarak kapaktan araçtan boşalması normal mi. stop ettim yine aynı aktı aktı boşaldı</strong></div><div><strong>biraz bekledim. sonra su ilave ettim. çalıştırdım ve hepsini yuttu çekti eksiğini tamamladım havasını felan alamadım tabi</strong></div></td></tr></table><div><br></div><div>Motor çalışırken genleşme tankından su fokurdayarak şişme yapıyor ve taşıyorsa silindirler üst kapağın su kanallarına kompresör veriyor demektir.Bu da = silindir kapak contasında bir sorun gözüküyor. Silindirlerin su kanalına kompresör vermesi sadece contanın tahribatıyla ilişkilidir.</div><div><br></div>]]>
   </description>
   <pubDate>Tue, 19 Jun 2012 15:44:59 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=366922&amp;title=hararet-problemi#366922</guid>
  </item>
  <item>
   <title><![CDATA[hararet problemi :    ugurkurt Yazd&#305;:arkada&#351;lar...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=366919&amp;title=hararet-problemi#366919</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8645">toga406</a><br /><strong>Konu:</strong> 20210<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Haziran&nbsp;2012 Saat 15:27<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: ugurkurt" alt="Orjinalini yazan: ugurkurt" style="vertical-align: text-bottom;" /> <strong>ugurkurt Yazdı:</strong><br /><br />arkadaşlar bugün gündüz gözüyle aracı şöyle bi inceledim. depoda min seviye civarında su vardı. max çizgisine kadar su doldurdum. aracı çalıştırdım bide ne göreyim su nerdeyse depo ile radyatör arasındaki hortum giriş hizasına kadar çıkmış. sonra kontrol edeken silindir contasının sol alt köşesinde(arabaya göre sol) çok hafif su kabarcıkları gördüm. tabi motor ısınınca kesti tabi. bişey daha farkettim harareti 100 bulduramıyorum çünkü fan buna müsade etmiyor. 95 civarı kontağı kapatıp su deposunu gözlemleyince 2 dk içinde depodaki su seviyesinin gözle görülür bi şekilde artıp kapaktan su attığını gördüm. işin ilginç yanı hemen kontağa basarsanız su bi anda kayboluyo. stop edince gene aynı şey oluyor ama bi kere taşınca bidaha taşmıyo su eklemezseniz.</td></tr></table><div><strong>ustaların çözemediği servisin bulamadığı otomatik 406 aracımdaki yağ ısınma ve şanzıman korumaya geçme sorununu eve gidince aracın araba sogutma tertibatında mı sorun var diye radyatör suyunun genleşme tankı yani su ilave edilen kapağını açtım ve şaşırdım kaldım. aracı gazladım radyatör fanı açtı. durdu. bende kapağı hafif hafif açtım suyun sıcak olduğunu bilerek</strong></div><div><strong>ama su tamamen kabarcıklar çıkartarak fokurdaya fokurdaya boşaltı. neredeyse abartısız tamamı aktı gitti. fokurdayarak. araç göstergelerini arada kontrol ettim. yağ sıcaklık göstergesi 130 ları geçti radyatör su göstergesi 90 da sabit max 90. ama 90 derecede su kaynamaz biliyorum</strong></div><div><strong>sorun acaba termostadda veya göstergede olabilir mi </strong></div><div><strong>fikri olan var mı?</strong></div><div><strong>radyatör suyunun fokurdayarak kapaktan araçtan boşalması normal mi. stop ettim yine aynı aktı aktı boşaldı</strong></div><div><strong>biraz bekledim. sonra su ilave ettim. çalıştırdım ve hepsini yuttu çekti eksiğini tamamladım havasını felan alamadım tabi</strong></div>]]>
   </description>
   <pubDate>Tue, 19 Jun 2012 15:27:52 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=366919&amp;title=hararet-problemi#366919</guid>
  </item>
  <item>
   <title><![CDATA[hararet problemi : benim fikrim zannedersem silindir...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=332271&amp;title=hararet-problemi#332271</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8001">ugurkurt</a><br /><strong>Konu:</strong> 20210<br /><strong>Gönderim Zamanı:</strong> 26&nbsp;Kasım&nbsp;2011 Saat 11:42<br /><br />benim fikrim zannedersem silindir contasını değiştirmem gerekecek. silindir contasının sol köşesinde su kabarcıkları yaptığı için.silindir contası yapılırkende diğer değişmesi gereken ne varsa işte. biraz tuzlu olacak o yüzden birkaç ay para biriktirmekte fayda var. işin acayipi silinddir contasıyla alakalı diğer belirtilerin hiçbirini gözlemleyemiyorum. heralde yeni yeni koyvermeye başlıyor. daha önce bu işlemleri yaptıranlar takribi ne kadar masraf yaptılar acaba_? ilginize teşekkürler<br>]]>
   </description>
   <pubDate>Sat, 26 Nov 2011 11:42:54 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=332271&amp;title=hararet-problemi#332271</guid>
  </item>
  <item>
   <title><![CDATA[hararet problemi : arkada&#351;lar bug&#252;n g&#252;nd&#252;z g&#246;z&#252;yle...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=332269&amp;title=hararet-problemi#332269</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8001">ugurkurt</a><br /><strong>Konu:</strong> 20210<br /><strong>Gönderim Zamanı:</strong> 26&nbsp;Kasım&nbsp;2011 Saat 11:38<br /><br />arkadaşlar bugün gündüz gözüyle aracı şöyle bi inceledim. depoda min seviye civarında su vardı. max çizgisine kadar su doldurdum. aracı çalıştırdım bide ne göreyim su nerdeyse depo ile radyatör arasındaki hortum giriş hizasına kadar çıkmış. sonra kontrol edeken silindir contasının sol alt köşesinde(arabaya göre sol) çok hafif su kabarcıkları gördüm. tabi motor ısınınca kesti tabi. bişey daha farkettim harareti 100 bulduramıyorum çünkü fan buna müsade etmiyor. 95 civarı kontağı kapatıp su deposunu gözlemleyince 2 dk içinde depodaki su seviyesinin gözle görülür bi şekilde artıp kapaktan su attığını gördüm. işin ilginç yanı hemen kontağa basarsanız su bi anda kayboluyo. stop edince gene aynı şey oluyor ama bi kere taşınca bidaha taşmıyo su eklemezseniz.]]>
   </description>
   <pubDate>Sat, 26 Nov 2011 11:38:25 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=332269&amp;title=hararet-problemi#332269</guid>
  </item>
  <item>
   <title><![CDATA[hararet problemi :   koliva Yazd&#305;:Eger aracin sogutma...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=332262&amp;title=hararet-problemi#332262</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2739">okankrgz</a><br /><strong>Konu:</strong> 20210<br /><strong>Gönderim Zamanı:</strong> 26&nbsp;Kasım&nbsp;2011 Saat 10:52<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: koliva" alt="Orjinalini yazan: koliva" style="vertical-align: text-bottom;" /> <strong>koliva Yazdı:</strong><br /><br />Eger aracin sogutma sisteminde hava olmus olsaydi aracin harareti birden bire kirmizi bolgeye vururdu sonra inerdi. Ya da kaloriferler sicak uflemezdi. <BR><BR>Sn. ugurkurt;<BR>Sizin durumunda aracta kaclik termostat var bir kontrol etmek zarar getirmez. Diger kontrol ettirmeniz gereken yer ise harareti olcen musur. Diger durumlarda su devridaim oluyorsa, fan aciyorsa sorun yoktur. <BR></td></tr></table> <DIV></DIV><DIV></DIV>+++++]]>
   </description>
   <pubDate>Sat, 26 Nov 2011 10:52:23 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=332262&amp;title=hararet-problemi#332262</guid>
  </item>
  <item>
   <title><![CDATA[hararet problemi : Eger aracin sogutma sisteminde...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=332244&amp;title=hararet-problemi#332244</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2147">koliva</a><br /><strong>Konu:</strong> 20210<br /><strong>Gönderim Zamanı:</strong> 26&nbsp;Kasım&nbsp;2011 Saat 08:32<br /><br />Eger aracin sogutma sisteminde hava olmus olsaydi aracin harareti birden bire kirmizi bolgeye vururdu sonra inerdi. Ya da kaloriferler sicak uflemezdi. <br><br>Sn. ugurkurt;<br>Sizin durumunda aracta kaclik termostat var bir kontrol etmek zarar getirmez. Diger kontrol ettirmeniz gereken yer ise harareti olcen musur. Diger durumlarda su devridaim oluyorsa, fan aciyorsa sorun yoktur. <br>]]>
   </description>
   <pubDate>Sat, 26 Nov 2011 08:32:22 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=332244&amp;title=hararet-problemi#332244</guid>
  </item>
  <item>
   <title><![CDATA[hararet problemi : 100 &#252; bulmama nedeni bu arada...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=332125&amp;title=hararet-problemi#332125</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7783">Üçyüzaltı</a><br /><strong>Konu:</strong> 20210<br /><strong>Gönderim Zamanı:</strong> 26&nbsp;Kasım&nbsp;2011 Saat 00:05<br /><br />100 ü bulmama nedeni bu arada&nbsp; aracın fan açmasındanda olabilr , bakmakta fayda var kafanız rahat olur.]]>
   </description>
   <pubDate>Sat, 26 Nov 2011 00:05:28 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=332125&amp;title=hararet-problemi#332125</guid>
  </item>
  <item>
   <title><![CDATA[hararet problemi : Bende yedek su deposu yok , drek...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=332123&amp;title=hararet-problemi#332123</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7783">Üçyüzaltı</a><br /><strong>Konu:</strong> 20210<br /><strong>Gönderim Zamanı:</strong> 26&nbsp;Kasım&nbsp;2011 Saat 00:03<br /><br />Bende yedek su deposu yok , drek radyotöre koyuyorsun suyu gecen kontrol için arac sıcakken unutup açmaya kalktım , son anda aklıma geldi ama geç kalmışım possss&nbsp;<img src="https://forum.peugeotturkey.com/smileys/smiley5.gif" border="0" alt="C&#111;nfused" title="C&#111;nfused" /> ama tuttum kapağı sıktım çoz az su çıktı tabi elimide yaktı bundan kaynaklanan hava alma ihtiyacı duyarmı araç . Hava nasıl alınır arkadaşlar ?]]>
   </description>
   <pubDate>Sat, 26 Nov 2011 00:03:10 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=332123&amp;title=hararet-problemi#332123</guid>
  </item>
  <item>
   <title><![CDATA[hararet problemi : Yard&#305;mc&#305; olabildiysem ne mutlu  ...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=332119&amp;title=hararet-problemi#332119</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7783">Üçyüzaltı</a><br /><strong>Konu:</strong> 20210<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Kasım&nbsp;2011 Saat 23:59<br /><br />Yardımcı olabildiysem ne mutlu&nbsp;]]>
   </description>
   <pubDate>Fri, 25 Nov 2011 23:59:22 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=332119&amp;title=hararet-problemi#332119</guid>
  </item>
  <item>
   <title><![CDATA[hararet problemi :    fatihpekgoz Yazd&#305;:Hava nas&#305;l...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=332112&amp;title=hararet-problemi#332112</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7401">djchaos</a><br /><strong>Konu:</strong> 20210<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Kasım&nbsp;2011 Saat 23:44<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: fatihpekgoz" alt="Orjinalini yazan: fatihpekgoz" style="vertical-align: text-bottom;" /> <strong>fatihpekgoz Yazdı:</strong><br /><br />Hava nasıl alınıyor acaba ben arada su ekleyip kapatıyorum kapağı ve hiç hava alma işlemi felan da yapmadım. benim araç da 90 ile 100 arası gidip geliyo hararet.eksi onda bile 100 e geliyo.</td></tr></table><div>&nbsp;</div><div>eğer radyatör suyunu komple boşaltıp tekrar dolurursanız radyatörde hava kalır conta yakmaya kadar götürür eğer sadece yedek su deposuna su bitmeden az bir azalma var diye su eklerseniz hava yapma sorunu olmaz sanırım siz sadece yedek su deposuna su&nbsp;ekliyorsunuz.</div>]]>
   </description>
   <pubDate>Fri, 25 Nov 2011 23:44:32 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=332112&amp;title=hararet-problemi#332112</guid>
  </item>
  <item>
   <title><![CDATA[hararet problemi : Hava nas&#305;l al&#305;n&#305;yor acaba ben...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=332111&amp;title=hararet-problemi#332111</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=5538">sezar206</a><br /><strong>Konu:</strong> 20210<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Kasım&nbsp;2011 Saat 23:38<br /><br />Hava nasıl alınıyor acaba ben arada su ekleyip kapatıyorum kapağı ve hiç hava alma işlemi felan da yapmadım. benim araç da 90 ile 100 arası gidip geliyo hararet.eksi onda bile 100 e geliyo.]]>
   </description>
   <pubDate>Fri, 25 Nov 2011 23:38:42 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=332111&amp;title=hararet-problemi#332111</guid>
  </item>
  <item>
   <title><![CDATA[hararet problemi :   antifirizinde organik antifiriz...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=332107&amp;title=hararet-problemi#332107</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7401">djchaos</a><br /><strong>Konu:</strong> 20210<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Kasım&nbsp;2011 Saat 23:34<br /><br />antifirizinde organik antifiriz deniliyor kırmızı renkte olmalı ayarlamasını iyi yapmalısın eğer kendin yapıcaksan kesinlikle hava kalmamalı içinde çok dikkat etmen gerek]]>
   </description>
   <pubDate>Fri, 25 Nov 2011 23:34:52 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=20210&amp;PID=332107&amp;title=hararet-problemi#332107</guid>
  </item>
 </channel>
</rss>
